FHEM - Hausautomations-Systeme => ZWave => Thema gestartet von: tabbi am 04 Februar 2021, 14:35:53
Titel: Integration Schlage Link Mini Keypad RFID in Alarmanlage
Beitrag von: tabbi am 04 Februar 2021, 14:35:53
ich habe nach längerer Wartezeit o.g. Gerät zu kaufen bekommen und möchte es in meine Alarmfunktion integrieren.
   DEF        cef08a77 33
   FUUID      6013ef00-f33f-c7ad-dd80-a4668b141c5a4ee4
   IODev      ZWDongle_1
   LASTInputDev ZWDongle_1
   MSGCNT     78
   NAME       ZWave_ENTRY_CONTROL_33
   NR         249
   STATE      unscharf
   TYPE       ZWave
   ZWDongle_1_MSGCNT 78
   ZWDongle_1_RAWMSG 00040021028407
   ZWDongle_1_TIME 2021-02-04 14:15:30
   ZWaveSubDevice no
   cmdsPending 0
   homeId     cef08a77
   isWakeUp   1
   lastMsgSent 1612444532.16762
   nodeIdHex  21
   Helper:
     DBLOG:
       battery:
         dblog:
           TIME       1612408909.35534
           VALUE      100 %
       batteryPercent:
         dblog:
           VALUE      100
       batteryState:
         dblog:
           VALUE      ok
       state:
         dblog:
           TIME       1612428173.18409
           VALUE      unscharf
       wakeup:
         dblog:
           TIME       1612428173.22468
           VALUE      notification
     2021-02-04 10:55:31   alarm           AccessControl: Keypad Unlock Operation, arg 101
     2021-02-04 04:21:49   battery         100 %
     2021-02-04 04:21:49   batteryPercent  100
     2021-02-04 04:21:49   batteryState    ok
     2021-01-29 12:23:40   configFeedbackBeepsPerSecond 2
     2021-01-29 12:23:40   configFeedbackTime 15
     2021-01-29 12:23:40   configFeedbackTimeout 0
     2021-01-29 12:23:40   configSetToDefault 170
     2021-01-29 12:23:40   configTheMode   Mode1NormalOperatingMode
     2021-01-29 12:23:40   model           Schlage Link Mini Keypad RFID
     2021-01-29 12:23:40   modelConfig     schlagelink/minikeypad.xml
     2021-01-29 12:23:40   modelId         0097-6131-4501
     2021-01-29 12:20:04   neighborList    ZWDongle_1 ZWave_SWITCH_BINARY_8 ZWave_SENSOR_NOTIFICATION_13 ZWave_SENSOR_NOTIFICATION_14 ZWave_SWITCH_BINARY_31 ZWave_SWITCH_BINARY_32
     2021-02-04 09:52:52   reportedState   off
     2021-02-04 09:52:52   state           off
     2021-02-04 14:15:32   timeToAck       0.029
     2021-02-04 14:15:32   transmit        OK
     2021-01-29 13:36:02   userCode        id 0 status 0 code 8f4b4978010010050000
     2021-01-29 13:32:48   userCodeUsersNumber 255
     2021-01-29 12:23:40   version         Lib 3 Prot 3.67 App 0.28
     2021-02-04 14:15:30   wakeup          notification
     2021-01-29 13:04:14   wakeupReport    interval 600 target 1
   IODev      ZWDongle_1
   alias      Keyreader
   classes    ASSOCIATION BATTERY WAKE_UP VERSION MANUFACTURER_SPECIFIC ALARM CONFIGURATION SWITCH_BINARY USER_CODE
   event-on-change-reading state,userCode,batteryPercent,battery
   eventMap   .*Lock.*:scharf .*Unlock.*:unscharf
   group      Anwesenheit
   icon       rfid_emblem
   room       100_flur,ZWave
   stateFormat alarm
   vclasses   ALARM:2 ASSOCIATION:1 BATTERY:1 CONFIGURATION:1 MANUFACTURER_SPECIFIC:2 SWITCH_BINARY:1 USER_CODE:1 VERSION:1 WAKE_UP:1
Den aktuellen Status habe ich schon herausgefiltert. Aber meine erste Idee war wohl falsch. Der Status nützt mir nur etwas in meinem Anwesenheitsmanagement, wenn er mit einer Person verbunden ist. Über die Anwesenheit der Personen kann ich den Zustand erkennen, wenn keiner mehr im Haus ist, um dann die Alarmanlage scharf zu schalten.
Ich habe schon gesehen, dass im Reading Alarm der Chip unter "arg 10?" verschlüsselt ist. Wie kann ich die Chip-ID aber mit einem konkreten Nutzer verbinden und über ein ?Reading...? erkennen und die Veränderung dann gekoppelt mit dem Zustand der Person als an/abwesend zuordnen?
Momentan stelle ich die Anwesenheit über das Smartphone da, dass ist in meinen Augen aber nicht sehr zuverlässig und nicht so zeitnah, dass die Alarmanlage auch rechtzeitig entschärft wird.
Das muss ich im Moment noch manuell machen, aber das ist kein Zustand.
Gruß tabbi
