Korrekte Syntax FHEM-Befehl in Perl im ...notify... in myUtils auslagern
Begonnen von TomLee, 10 Juli 2020, 12:34:40
TomLee
Danke.
Ich komm denk ich auch noch alleine drauf was schief läuft, aber erst später, jetzt geht nicht mehr.
Braucht auch keiner was zu sagen, halt aber auch keinen davon ab:
sub wochentag{
my $v = shift // "my ($day, $month, $year) = (localtime)[3,4,5]; sprintf('%02d.%02d.%s',$month+1,$day,$year+1900)";
my ($d,$m,$y) = split(/\./,$v)};
$m-=1;
my @weekdays = qw(So Mo Di Mi Do Fr Sa);
return $weekdays[((localtime(timelocal('0','0','0',$d,$m,$y)))[6])];
Global symbol "$day" requires explicit package name (did you forget to declare "my $day"?) at ./FHEM/99_Calendar_Utils.pm line 14. Global symbol "$month" requires explicit package name (did you forget to declare "my $month"?) at ./FHEM/99_Calendar_Utils.pm line 14. Global symbol "$year" requires explicit package name (did you forget to declare "my $year"?) at ./FHEM/99_Calendar_Utils.pm line 14. Global symbol "$month" requires explicit package name (did you forget to declare "my $month"?) at ./FHEM/99_Calendar_Utils.pm line 14. Global symbol "$day" requires explicit package name (did you forget to declare "my $day"?) at ./FHEM/99_Calendar_Utils.pm line 14. Global symbol "$year" requires explicit package name (did you forget to declare "my $year"?) at ./FHEM/99_Calendar_Utils.pm line 14. Global symbol "$m" requires explicit package name (did you forget to declare "my $m"?) at ./FHEM/99_Calendar_Utils.pm line 16. Global symbol "$d" requires explicit package name (did you forget to declare "my $d"?) at ./FHEM/99_Calendar_Utils.pm line 18. Global symbol "$m" requires explicit package name (did you forget to declare "my $m"?) at ./FHEM/99_Calendar_Utils.pm line 18. Global symbol "$y" requires explicit package name (did you forget to declare "my $y"?) at ./FHEM/99_Calendar_Utils.pm line 18. Unmatched right curly bracket at ./FHEM/99_Calendar_Utils.pm line 19, at end of line ./FHEM/99_Calendar_Utils.pm has too many errors.
In der Kommandozeile macht das my ($day, $month, $year) = (localtime)[3,4,5]; sprintf('%02d.%02d.%s',$month+1,$day,$year+1900) was ich will.
Hinter // solltest Du einfach keinen perl code zur Ausführung schreiben, das macht die Nachvollziehbarkeit extrem unübersichtlich.
Und schon gar nicht perl Code in Anführungszeichen - was soll das sein?
Mach es möglichst simpel und mach es richtig,
dann wird es auch funktionieren.
JoWiemann
Und hier:
my ($d,$m,$y) = split(/\./,$v)}; ist definitiv die } zu viel.
Jörg Wiemann
Kommt davon, wenn man sich überall Code-Stücke zusammenklaut, um sie später dann irgendwo als seinen eigenen Code zu präsentieren...
JoWiemann
warum vertauscht Du hier sprintf('%02d.%02d.%s',$month+1,$day,$year+1900) Monat und Tag?
und so funktioniert es:
sub wochentag{
   my $v = shift // sprintf('%02d.%02d.%s',(localtime)[3],(localtime)[4]+1,(localtime)[5]+1900);
   my ($d,$m,$y) = split(/\./,$v);
   $m -= 1;
Grüße Jörg
Jörg Wiemann
TomLee
ZitatKommt davon, wenn man sich überall Code-Stücke zusammenklaut, um sie später dann irgendwo als seinen eigenen Code zu präsentieren...
Heute schon das zweite mal, wo du zeigst das dein Wahrnehmungsvermögen was mich betrifft, völlig daneben liegt.
Kennst du Diodon ? Hab mich eingedacht, war voll drin in dem Thema, hier und da meine eigenen Beispiele kopiert und das falsche Beispiel am Ende aus der Zwischenablage eingefügt/ausgewählt und nicht mehr bemerkt als ich hier das dann postete. Das mit der schliessenden Klammer hab ich danach auf festgestellt, das da ein Kopierfehler stattfand.
Ja so klappts jetzt wie ich mir das vorgestellt hatte.
Ich muss mich immer wieder eindenken wenn es um Zeiten geht, mich würds jetzt interessieren wie Isegrim bzw. Ihr euch das aktuelle Datum "ziehen" würden ?
JoWiemann
Bitte an betateilchen adressieren-
Jörg Wiemann
TomLee
JoWiemann
Zitat von: TomLee am 20 Januar 2023, 20:53:07
Spatz, du warst gemeint.
Verstehe ich nicht. Habe ich nicht gepostet:
Und Spatz schon lange nicht. Lese ich als nicht positiv.
Jörg Wiemann
Zitat von: JoWiemann am 20 Januar 2023, 21:21:01
Verstehe ich nicht.
Wahrscheinlich bist Du jetzt der Nächste, dem der Oberkasper "falsches Wahrnehmungsvermögen" vorwerden wird.
Popcorn?  8)
JoWiemann
Jörg Wiemann
TomLee
Du warst definitiv nicht gemeint.
Oberkasper, find ich, ist genau das treffende Wort für das was ich die letzten Jahre hier im Forum oft gemacht habe. Sag ich mir auch oft bevor ich hier schreibe -> Wenn du nicht den Kasper machst und doof frägst wird sich in absehbarer Zeit mit hoher Wahrscheinlichkeit auch kein anderer finden/trauen.
Mich hat das mit dem aktuellen Datum weiter beschäftigt und das mit dem vermeiden von Perlcode nach den // der Nachvollziehbarkeit wegen.
Es bleibt ja nix anderes dann übrig wie den Perlcode in einer Variable vor der shift-Zeile zu deklarieren, um dann nur den Variablennamen nach den // anzugeben.
Vermutlich war das aber nicht so gemeint und ich bin noch auf eine andere Variante gekommen:
sub wochentag {
   my $v = shift;
   $v //= localtime->dmy('.');
   return $weekdays[((localtime(timelocal('0','0','0',$d,$m-1,$y)))[6])];
edit: wie in #149 bereits vorgeschlagen  8)
edit2:
und jetzt noch die return-Zeile angepasst auf die Time::Piece Variante:
(die genauen Hintergründe warum mein System das use ... nicht braucht sind mir noch nicht ganz klar)
sub wochentag {
   my $v = shift;
   return localtime(timelocal('0','0','0',$d,$m-1,$y))->day(@weekdays);
edit3: nach weiteren Gedanken noch eine Variante:
sub wochentag {
   my $v = shift;
   $v //= return localtime->day(@weekdays);
   return localtime(time_str2num(join '-', reverse split '\D', $v))->day(@weekdays);
edit4:
vorausgesetzt das ich nicht irgendwas gravierendes übersehe, hier noch eine Variante für die hartnäckigen:
sub wochentag {
   my $v = shift;
   return localtime(time_str2num(join q(-), reverse split m/[\D]/xms, $v))->day(@weekdays);
edit5:
sub wochentag {
   my $v = shift;
   #Time::Piece->use_locale(); # if set german locale, delete line above and (@weekdays) next lines
   return Time::Piece->strptime($v, '%d.%m.%Y')->day(@weekdays);
