hmusb: Unknown code
Begonnen von mfeske, 01 November 2025, 22:40:19
mfeske
Nein :-(
   DEF        240271
   FUUID      69089ac5-f33f-be1a-6c39-de9cd0482c1fda01
   IODev      hmusb
   NAME       VCCU
   NR         167
   NTFY_ORDER 48-VCCU
   STATE      hmusb:ok
   TYPE       CUL_HM
   chanNo     01
   disableNotifyFn 1
     2025-11-03 15:59:25   IODev           hmusb
     2025-11-03 13:06:30   IOopen          1
     2025-11-03 13:06:30   state           hmusb:ok
     2025-11-03 15:58:41   unknown_2EA46B  received
     2025-11-03 15:59:05   unknown_308B18  received
     2025-11-03 15:57:39   unknown_308E84  received
     2025-11-03 15:57:23   unknown_309145  received
     2025-11-03 15:57:42   unknown_30936B  received
     2025-11-03 15:56:58   unknown_309DC6  received
     2025-11-03 15:58:05   unknown_309FAA  received
     2025-11-03 15:58:20   unknown_315A14  received
     2025-11-03 15:22:50   unknown_3298B1  received
     2025-11-03 15:28:10   unknown_4DFD51  received
     2025-11-03 15:58:10   unknown_5AD64A  received
     2025-11-03 15:51:57   unknown_5B5FB2  received
     2025-11-03 15:32:15   unknown_5BDFCC  received
     2025-11-03 15:54:40   unknown_62E9FD  received
     2025-11-03 15:58:16   unknown_63A10E  received
     2025-11-03 15:01:08   unknown_769275  received
     2025-11-03 15:58:45   unknown_78CF38  received
     2025-11-03 15:42:29   unknown_7FDE23  received
     2025-11-03 15:58:45   unknown_B9ED87  received
     2025-11-03 15:51:29   unknown_BBAD2D  received
     2025-11-03 15:51:57   unknown_FF8EF1  received
   helper:
     HM_CMDNR   230
     mId        0000
     peerFriend
     peerOpt    -:-
     regLst     0
     rxType     1
     ack:
     cmds:
       TmplKey    :no:1762181966.0554
       TmplTs     1762181966.0554
       cmdKey     1:1:1::VCCU:0000:01:
       cmdLst:
         assignHmKey noArg
         clear      (readings|all)
         deviceRename -newName-
         fwUpdate   -filename- [-bootTime-]
         getDevInfo noArg
         peerChan   -btnNumber- -actChn- [({single}|dual|reverse)] [({set}|unset)] [(actor|remote|{both})]
         postEvent  -condition-
         press      [(long|{short})] [(-peer-|{all})] [(noBurst|{Burst})] [(-repCount-|{0})] [(-repDelay-|{0.25})]
         pressL     [(-peer-|{all})]
         pressS     [(-peer-|{all})]
         raw        -data- [...]
         reset      noArg
         unpair     noArg
         update     noArg
         virtual    [(1..50;1|{1})]
       lst:
         condition  slider,0,1,255
         peer
         peerOpt
         tplDel
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         listDevice [({all}|alive|unknown|dead|notAlive)]
         param      -param-
         status     noArg
     expert:
       def        1
       det        0
       raw        0
       tpl        0
     io:
       vccu
       prefIO:
     mRssi:
       mNo
     peerIDsH:
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       vrt        1
     tmpl:
   model
   room       Funkzentrale
   subType    virtual
attr VCCU IOList HMLAN --> VCCU: unknown attribute IOList. Type 'attr VCCU ?' for a detailed list.
soll ich delete VCCU machen und neu beginnen ?
Hardware:
1 x Raspberry Pi Mod. B 512 MB
eq-3 2 x MAX! eTRV Heizungssteller, 1 x MAX! Fensterkontakt, 1 x MAX! Cube - LAN Gateway (ausser Betrieb)
Intertechno 1x ITZ-500, 3x ITT-1500, 9x ITR-1500, 3 x ITDL-1000, 2 x ITL-500
1 x CC1101-USB-Lite 433MHz (CUL433)  V3 1 x CC1101-USB-Lite 868MHz (CUL868)
Beta-User
Zitat von: mfeske am 03 November 2025, 16:49:17Nein :-(
   DEF        240271
   IODev      hmusb
   NAME       VCCU
   NR         167
   NTFY_ORDER 48-VCCU
   STATE      hmusb:ok
   TYPE       CUL_HM
   chanNo     01
   disableNotifyFn 1
   helper:
     HM_CMDNR   230
     mId        0000
     peerFriend
     peerOpt    -:-
     regLst     0
     rxType     1
     ack:
     cmds:
       cmdLst:
         assignHmKey noArg
         getDevInfo noArg
         raw        -data- [...]
         reset      noArg
         unpair     noArg
         update     noArg
       lst:
         peer
         peerOpt
         tplDel
       rtrvLst:
         param      -param-
         status     noArg
     expert:
       def        1
       det        0
       raw        0
       tpl        0
     io:
       vccu
       prefIO:
     mRssi:
       mNo
     peerIDsH:
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       vrt        1
     tmpl:
   model
   room       Funkzentrale
   subType    virtual
Nein. model setzen. Dann nochmal in der richtigen logischen Reihenfolge, jedes Mal prüfen, ob das ankommt.
RalfRog
#17
Das von MadMax aufgezeigte Problem, dass du (mit CCU und Thermostate) dein eigener Nachbar bist bleibt ja.
Vermutlich z.B. (unter Mehreren)
2025.11.01 22:17:57 3: hmusb: Unknown code A0F438610309FAA0000000A88D60D0000::-50:hmusb
Dein hmusb bekommt ja mit was die mit der CCU gepairten Geräte so senden. Mit der Folge die du siehst.
FHEM VM Debian13 (trixie) auf Proxmox VE9  (Futro S740) - nanoCUL, HM-MOD-RPI-PCB und MAX!Cube über LAN
HM- Fensterkontakte, UP-Schalter, Bewegungsmelder und ein Rauchmelder sowie Shelly 3EM, 1PM, PlugS und IT Schaltsteckdosen
mfeske
#18
@Beta-User, schritt für schritt hat jetzt wohl geholfen, das List sieht jetzt (denke ich) besser aus.
Was kann ich als nächstes machen um die Geräte zu identifizieren ?
Von den Hager Rauchmeldern sollte es ja nicht sein die konnte ich ja (leider) nie ansprechen.
   DEF        240271
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     11
   NAME       VCCU
   NR         167
   NTFY_ORDER 48-VCCU
   STATE      hmusb:ok
   TYPE       CUL_HM
   assignedIOs hmusb
   chanNo     01
   disableNotifyFn 1
   eventCount 4
   hmusb_MSGCNT 11
   hmusb_RAWMSG EFF8EF1,0000,09D8DAC9,FF,FF9D,108002FF8EF15BDFCC0053E99863
   hmusb_RSSI -99
   hmusb_TIME 2025-11-03 19:16:25
     2025-11-03 19:15:06   IODev           hmusb
     2025-11-03 19:15:07   IOopen          1
     2025-11-03 19:15:07   state           hmusb:ok
     2025-11-03 19:15:07   unknown_2EA46B  received
     2025-11-03 19:15:38   unknown_308B18  received
     2025-11-03 19:15:38   unknown_308E84  received
     2025-11-03 19:14:47   unknown_309145  received
     2025-11-03 19:14:53   unknown_30936B  received
     2025-11-03 19:14:56   unknown_309DC6  received
     2025-11-03 19:15:07   unknown_309FAA  received
     2025-11-03 19:15:38   unknown_315A14  received
     2025-11-03 19:15:38   unknown_5AD64A  received
     2025-11-03 19:16:24   unknown_5BDFCC  received
     2025-11-03 19:16:03   unknown_63A10E  received
     2025-11-03 19:13:47   unknown_7FDE23  received
     2025-11-03 19:14:04   unknown_BBAD2D  received
     2025-11-03 19:16:25   unknown_FF8EF1  received
   helper:
     HM_CMDNR   152
     peerFriend
     peerOpt    v:virtual
     regLst
     rxType     1
     cmds:
       TmplKey    :no:1762193707.23526
       TmplTs     1762193707.23526
       cmdKey     1:1:1::VCCU::01:
       cmdLst:
         assignIO   -IO- [({set}|unset)]
         clear      [(readings|rssi|msgEvents|attack|{msgErrors}|unknownDev)]
         defIgnUnknown noArg
         hmPairForSec [-sec-]
         hmPairSerial -serial-
         update     noArg
       lst:
         peer
         peerOpt
         tplDel
       rtrvLst:
         listDevice noArg
         param      -param-
     expert:
       def        1
       det        0
       raw        0
       tpl        0
     io:
       vccu       VCCU
       ioList:
         hmusb
       prefIO:
     mRssi:
       mNo
     peerIDsH:
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       vrt        1
     tmpl:
   IOList     hmusb
   IOgrp      VCCU
   model      CCU-FHEM
   room       Funkzentrale
   subType    virtual
   webCmd     virtual:update
Hardware:
Beta-User
Zitat von: mfeske am 03 November 2025, 19:19:57@Beta-User, schritt für schritt hat jetzt wohl geholfen, das List sieht jetzt (denke ich) besser aus.
Jup.
Zitat von: mfeske am 03 November 2025, 19:19:57Was kann ich als nächstes machen um die Geräte zu identifizieren ?
Zum einen: Du kannst die Geräte manuell anlegen (automatisiert anlegen lassen geht vermutlich nicht ohne paiing) und schauen, welche Readings kommen, der hmusb liest ja den Funkverkehr mit.
Oder du schaust dir an, was die CCU des Herstellers an Infos auswirft, irgendwo müßte ja die ID der Geräte verwurstelt sein...
Zu den Hager bin ich ratlos, wie kommst du drauf, dass die überhaupt BidCoS "sprechen"? (schon die originalen RM von eQ3 in der HM-Variante scheinen aber "speziell" zu sein, sagt mir mein vermutlich falsches Hörensagengedächtnis).
RalfRog
#20
Es gab mal ne Diskussion zum Thema Autocreate etc. bei Homematic (hab ich nicht mehr gefunden). Um die Devices "loszuwerden" die nicht mit der VCCU gepairt sind gibt es ein Set-Kommando in der VCCU.
set <Name der VCCU> defIgnUnknown
ComRef:
  defIgnUnknown
  Definiere die unbekannten Devices und setze das Attribut ignore. Dann loesche die Readings.
Richtig weg sind sie nicht sondern nur per Attribut Ignore unsichtbar.
Ich habe z.B. auch gerade ca. zwei Dutzend Readings ala:
unknown_14394C   received  2025-11-03 14:24:49
Wenn dein IO ein HM-Protokoll wie in Beitrag#0 emfpängt landet es in den Readings, da FHEM die ID nicht kennt - weil es nicht gepairt ist.
Du willst natürlich auch nicht pairen, da es dem Nachbarn gehört oder wie bei dir die Thermostate der CCU sind.
2025.11.01 22:17:20 3: hmusb: Unknown code A0F658610 30936B 000000 0A88C60D0000::-63:hmusb, help me!
                                                     Sender Emfpänger
Hier sendet die ID 30936B (Adresse, steht auf dem Gerät/Karton) an Broadcast und wird von der VCCU "aufgenommen".
Also enweder ignorieren oder das set-Kommado ausführen dann sollte es weg sein.
Gruß Ralf
RalfRog
Dort wo du zuerst gefragt hast, ist das ja unter #3 (wenn auch schon älter) von @Frank beschriebenen.
https://forum.fhem.de/index.php?msg=525480
