Unbekannte Teilnehmer dauerhaft anliegend
Begonnen von dahansi, 17 Januar 2024, 09:35:20
dahansi
Hallo.
Ich wusste jetzt nicht genau, wie ich es betiteln soll.
Mir ist aufgefallen, dass im Event monitor ständig Teilnehmer auftauchen, die Meldungen machen:
2024-01-17 09:32:30 EnOcean EnO_00000001 buttons: pressed
2024-01-17 09:32:30 EnOcean EnO_00000001 channelB: BI
2024-01-17 09:32:30 EnOcean EnO_00000001 BI
2024-01-17 09:32:30 EnOcean EnO_00000002 buttons: pressed
2024-01-17 09:32:30 EnOcean EnO_00000002 channelB: BI
2024-01-17 09:32:30 EnOcean EnO_00000002 BI
2024-01-17 09:32:30 EnOcean EnO_00000003 buttons: pressed
2024-01-17 09:32:30 EnOcean EnO_00000003 channelB: BI
2024-01-17 09:32:30 EnOcean EnO_00000003 BI
2024-01-17 09:32:30 EnOcean EnO_00000004 off
2024-01-17 09:32:30 EnOcean EnO_00000005 buttons: pressed
2024-01-17 09:32:30 EnOcean EnO_00000005 channelB: BI
2024-01-17 09:32:30 EnOcean EnO_00000005 BI
2024-01-17 09:32:30 EnOcean EnO_00000006 off
2024-01-17 09:32:31 EnOcean EnO_00000007 buttons: pressed
2024-01-17 09:32:31 EnOcean EnO_00000007 channelB: BI
2024-01-17 09:32:31 EnOcean EnO_00000007 BI
2024-01-17 09:32:31 EnOcean EnO_00000008 buttons: pressed
2024-01-17 09:32:31 EnOcean EnO_00000008 channelB: BI
2024-01-17 09:32:31 EnOcean EnO_00000008 BI
2024-01-17 09:32:31 EnOcean EnO_00000009 buttons: pressed
2024-01-17 09:32:31 EnOcean EnO_00000009 channelB: BI
2024-01-17 09:32:31 EnOcean EnO_00000009 BI
2024-01-17 09:32:31 EnOcean EnO_0000000A off
2024-01-17 09:32:31 EnOcean EnO_0000000B off
2024-01-17 09:32:31 EnOcean EnO_0000000C buttons: pressed
2024-01-17 09:32:31 EnOcean EnO_0000000C channelB: BI
2024-01-17 09:32:31 EnOcean EnO_0000000C BI
2024-01-17 09:32:31 EnOcean EnO_0000000D buttons: pressed
2024-01-17 09:32:31 EnOcean EnO_0000000D channelB: BI
2024-01-17 09:32:31 EnOcean EnO_0000000D BI
2024-01-17 09:32:31 EnOcean EnO_0000000E on
2024-01-17 09:32:31 EnOcean EnO_0000000F buttons: pressed
2024-01-17 09:32:31 EnOcean EnO_0000000F channelB: BI
2024-01-17 09:32:31 EnOcean EnO_0000000F BI
2024-01-17 09:32:31 EnOcean EnO_00000010 buttons: pressed
2024-01-17 09:32:31 EnOcean EnO_00000010 channelB: BI
2024-01-17 09:32:31 EnOcean EnO_00000010 BI
2024-01-17 09:32:31 EnOcean EnO_00000011 buttons: pressed
2024-01-17 09:32:31 EnOcean EnO_00000011 channelB: BI
2024-01-17 09:32:31 EnOcean EnO_00000011 BI
2024-01-17 09:32:31 EnOcean EnO_00000012 off
2024-01-17 09:32:31 EnOcean EnO_00000013 buttons: pressed
2024-01-17 09:32:31 EnOcean EnO_00000013 channelB: BI
2024-01-17 09:32:31 EnOcean EnO_00000013 BI
2024-01-17 09:32:31 EnOcean EnO_00000014 off
2024-01-17 09:32:31 EnOcean EnO_00000015 off
2024-01-17 09:32:31 EnOcean EnO_00000016 buttons: pressed
2024-01-17 09:32:31 EnOcean EnO_00000016 channelB: BI
2024-01-17 09:32:31 EnOcean EnO_00000016 BI
2024-01-17 09:32:32 EnOcean EnO_00000017 buttons: pressed
2024-01-17 09:32:32 EnOcean EnO_00000017 channelB: BI
2024-01-17 09:32:32 EnOcean EnO_00000017 BI
2024-01-17 09:32:32 EnOcean EnO_00000018 buttons: pressed
2024-01-17 09:32:32 EnOcean EnO_00000018 channelB: BI
2024-01-17 09:32:32 EnOcean EnO_00000018 BI
2024-01-17 09:32:32 Global global SAVE
Diese Meldungen laufen rund um die Uhr durch.
Was kann das sein.
Wenn autocreate aktive ist, dann werden die Teilnehmer natürlich angelegt. Hier ein liste eines solchen Teilnehmers.
   DEF        00000001
   FGW14_MSGCNT 60
   FGW14_TIME 2024-01-17 09:33:51
   FUUID      65a78b91-f33f-0cc0-b312-4c1647f36adfa98e
   IODev      FGW14
   LASTInputDev FGW14
   MSGCNT     60
   NAME       EnO_00000001
   NR         220
   NTFY_ORDER 50-EnO_00000001
   STATE      BI
   TYPE       EnOcean
   eventCount 60
     2024-01-17 09:30:28   IODev           FGW14
     2024-01-17 09:33:51   buttons         pressed
     2024-01-17 09:33:51   channelB        BI
     2024-01-17 09:33:51   state           BI
     2024-01-17 09:10:57   teach           RPS teach-in accepted EEP F6-02-01 Manufacturer: no ID
   helper:
   IODev      FGW14
   alias      EnO_00000001
   creator    autocreate
   eep        F6-02-01
   manufID    7FF
   room       EnOcean,unbekannt
   subType    switch
   teachMethod RPS
Button pressed steht da. Wüsste aber wie gesagt nicht, was das sein soll.
Könnte es eventuell von Wibutler kommen? Den habe ich vor kurzem entfernt, da Wibutler der größte M*** im Smarthomebereich ist.
Flachzange
Ich kenne mich mit der 14er Serie von Eltako nicht aus, aber was ja hier offensichtlich passiert: Irgendein Gerät erzeugt fortlaufend Nachrichten und zählt dabei seine EnOceanID hoch. In dem Ausschnitt oben fängt es bei EnO_00000001 an und endet bei EnO_00000018. Gleichzeitig beschreibst Du in Deinem anderen Thread einen Issue mit dem FGW14. Ich kenne jetzt Deine Landschaft nicht, aber die Wahrscheinlichkeit, dass das direkt vom FGW14 generiert wird ist ziemlich hoch. Der scheint in irgendeinem merkwürdigen Zustand zu laufen.
dahansi
Hier steht ja buttons:Pressed. Es ist aber keiner gedrückt.
Die ID ist auch sehr ungewöhnlich, da die Enocean Taster eine ID wie EnO_FEDEDBC7 besitzen
dahansi
#3
Aufbau ist folgender:
FAM14
FSR 14
FUD 14
FSB 14
FGW 14 - Hier hängt FHEM drauf
zusätzlich noch vom Installatieur: Wibutler.
Ich habe jetzt mal die komplette Anlage neu gestartet (Hauptsicherung raus) Habe auch den Wibutler nochmal angeschaltet.
Das Problem das die Teilnehmer melden ist immer noch vorhanden. Im Sekundentakt treten die im Event monitor auf.
Als ich die Konfiguration von Fhem erstellt habe und die Teilnehmer angelegt habe, waren diese Teilnehmer hier noch nicht vorhanden. Das kam dann erst irgendwann später dazu. Nur woher?
dahansi
Okay, also folgendes: Ich hatte um was zu testen FAM14 an BA von 2 auf 4 umgestellt. Zurück stellen auf 2 hat jetzt bewirkt, dass keine neuen Events auftreten. Soweit so gut.
Allerdings wäre es interessant, was diese Teilnehmer sind.
Wie man das wohl herausfinden könnte?
Cybers
Laß uns doch erstmal schauen, daß du das System sauber ans Laufen bekommst. Siehe meinen letzten Beitrag in deinem anderen Thread.
Gruß, Sascha
FHEM 6.2 auf Raspberry PI 4 / Smartvisu
Eltako Serie 14: FAM14, FGW14-USB, FSB14, FSR14-4x, FSR14-2x, FDG14, FTS14-EM in Kombination mit Jung F50 24V Tastern
1-Wire Temperatursensoren
aus alter Zeit:
Gott sei Dank nur noch 3 Homematic Jalousie- & Schaltaktoren! Wer sich mit Funk auskennt, legt Kabel
