Alexa Fhem Connector ...sieht alles gut aus, findet keine Geräte
Begonnen von Aladin222, 10 August 2023, 14:44:36
Aladin222
da ich ja zur Zeit alles neu stricke , bin ich im Zuge des Umzuges auch dabei , mal den Alexa Fhem Connector zu testen .
Installation war (hoffe ich ) erfolgreich  ;D
Nun habe ich mal zum testen ,zwei Geräten, einen Alexa-Namen vergeben und Alexa restart durchgeführt
im logfile :
connections: [
      server: '127.0.0.1',
      webname: 'fhem',
      filter: 'alexaName=..*',
      uid: 1000,
      port: 8083
[8/10/2023, 2:21:48 PM] sshautoconf: SSH key seems to exist
[8/10/2023, 2:21:48 PM] sshautoconf: Our SSH key is known at the reverse proxy, good!
[8/10/2023, 2:21:48 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7B%22alexa%22%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7B%22alexa%22%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
*** FHEM: connected
[8/10/2023, 2:21:48 PM] [FHEM] got: 3 results
[8/10/2023, 2:21:48 PM] [FHEM] Esszimmerlampe is switch
[8/10/2023, 2:21:48 PM] [FHEM] Esszimmerlampe has
[8/10/2023, 2:21:48 PM] [FHEM]   FirmwareRevision [D-firmware]
[8/10/2023, 2:21:48 PM] [FHEM]   On [state;on,off]
[8/10/2023, 2:21:48 PM] [FHEM] Esszimmerlampe will not send proactive events
[8/10/2023, 2:21:48 PM] [FHEM] Esszimmerlampe uses ID: OEQ0653406
  2023-08-10 14:21:48 caching: Esszimmerlampe-D-firmware: 2.8
  2023-08-10 14:21:48 caching: Esszimmerlampe-state: on
[8/10/2023, 2:21:48 PM] [FHEM] ignoring LEDEZ (structure) without genericDeviceType
[8/10/2023, 2:21:48 PM] [FHEM] no device created for LEDEZ (structure)
[8/10/2023, 2:21:48 PM] [FHEM] Wohnzimmerlampe is switch
[8/10/2023, 2:21:48 PM] [FHEM] Wohnzimmerlampe has
[8/10/2023, 2:21:48 PM] [FHEM] Wohnzimmerlampe will not send proactive events
[8/10/2023, 2:21:48 PM] [FHEM] Wohnzimmerlampe uses ID: MEQ0990232
  2023-08-10 14:21:48 caching: Wohnzimmerlampe-D-firmware: 2.8
  2023-08-10 14:21:48 caching: Wohnzimmerlampe-state: off
[8/10/2023, 2:21:48 PM] BearerToken '...EF923' read from alexa
[8/10/2023, 2:21:48 PM] 39_alexa.pm is new version: true
[8/10/2023, 2:21:48 PM] sshautoconf: completed successfully
[8/10/2023, 2:21:48 PM] *** SSH: proxy configuration set up done
[8/10/2023, 2:21:48 PM] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[8/10/2023, 2:21:48 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7B%22alexa%22%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7B%22alexa%22%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
[8/10/2023, 2:21:48 PM] Starting SSH with -R 1234:127.0.0.1:38789 -oServerAliveInterval=90 -i /home/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[8/10/2023, 2:21:48 PM] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[8/10/2023, 2:21:48 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7B%22alexa%22%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7B%22alexa%22%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
[8/10/2023, 2:21:48 PM] *** SSH: proxy connection established
[8/10/2023, 2:21:48 PM] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[8/10/2023, 2:37:24 PM] Got SIGTERM, shutting down alexa-fhem...
[8/10/2023, 2:37:24 PM] Reading alexaFHEM.ProxyConnection set to stopping;; alexa-fhem terminating
[8/10/2023, 2:37:24 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7B%22alexa%22%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopping%3B%3B%20alexa-fhem%20terminating%3B%7B%24defs%7B%22alexa%22%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
[8/10/2023, 2:37:24 PM] Stopping SSH ...
[8/10/2023, 2:37:24 PM] Reading alexaFHEM.ProxyConnection set to stopped
[8/10/2023, 2:37:24 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7B%22alexa%22%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopped%3B%7B%24defs%7B%22alexa%22%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
[8/10/2023, 2:37:24 PM] *** SSH: exited with 255
Aber ich kann die zwei Geräte über Alexa nicht schalten !
Auch finde ich sie nicht in der Alexa App
Weiss einer rat ?
Aladin222
konnte es nur lösen , indem ich das Fhem Connector deaktiviert habe , neu aktivieren ( code eingeben ) - jetzt scheint es soweit zulaufen .
Ned
#2
Hallo Aladin
das Suchen (bzw. FINDEN) habe ich auch noch nicht ganz verstanden.
wenn ich etwas geändert habe, dann gehe ich auf diese Seite und lasse die Geräte neu suchen:
https://alexa.amazon.de/spa/index.html#appliances
und dann findet die Alexa App auf meinem iPad  die neuen Geräte unter "Geräte" und dann ganz oben Rechts das PLUS-Symbol drücken
diese Lösung funktioniert nicht mehr!
Für das Finden von smarten FHEM Geräten einfach "Alexa, suche smarte Geräte", wie unten beschrieben, aufrufen
doc.
Zitat von: Ned am 10 September 2023, 22:21:12wenn ich etwas geändert habe, dann gehe ich auf diese Seite und lasse die Geräte neu suchen:
die Weboberfläche gibt es ja nicht mehr und in der App gibt es keine Möglichkeit nach neuen Geräten zu suchen - wie geht das denn jetzt?
Danke und Gruß
MadMax-FHEM
Zitat von: doc. am 08 Januar 2024, 14:52:37wie geht das denn jetzt?
Per Sprache (wie schon immer): Alexa suche neue Geräte / Alexa suche smarte Geräte.
Alternativ (aber wenig von mir genutzt): set AlexaDevice add FhemDeviceName (oder alexaName?)
Laut Hilfe wird es so alexa-fhem (ohne "Neustart"/Reload) "mitgeteilt" und alexa-fhem versucht es auch Amazon "beizubringen"...
Steht alles bei der Hilfe zum Alexa-Modul...
Gruß, Joachim
FHEM PI3 Buster (Test)
doc.
Erstmal vielen Dank! Ich hatte mich natürlich mit dem Wiki Eintrag beschäftigt - ich bin davon ausgegangen dass die beschriebenen Befehle nur mit dem aktiven Pushen von Zuständen zu tun hätten, mein Fehler.
