HMUARTLGW Fehlermeldung frame with wrong length received:
Begonnen von laxmann, 02 Oktober 2022, 11:32:20
laxmann
Guten Tag zusammen,
in der letzten Woche habe ich ein FHEM-Backup von Jessy auf Rasp OS Bullseye durchgeführt. Ging alles gut. Leider gibt es Fehlermeldungen vom HMUARTLGW (HM-MOD-UART) im 5-Minutentakt.
2022.10.02 10:03:38.307 1: HMUARTLGW HMRaspi1 frame with wrong length received: 10, should: 4: FD00000500BF040202C06F
2022.10.02 10:03:42.310 1: HMUARTLGW HMRaspi1 frame with wrong length received: 10, should: 4: FD00000500BF040202C06F
2022.10.02 10:06:57.369 1: HMUARTLGW HMRaspi1 frame with wrong length received: 8, should: 4: FD00000500CD040202
2022.10.02 10:06:57.371 1: HMUARTLGW HMRaspi1 frame with wrong length received: 10, should: 4: FD00000500CD040202287B
2022.10.02 10:07:00.167 1: HMUARTLGW HMRaspi1 frame with wrong length received: 10, should: 4: FD00000500CD040202287B
2022.10.02 10:13:46.488 1: HMUARTLGW HMRaspi1 frame with wrong length received: 8, should: 4: FD00000500E9040202
2022.10.02 10:13:46.490 1: HMUARTLGW HMRaspi1 frame with wrong length received: 10, should: 4: FD00000500E90402027874
2022.10.02 10:13:50.512 1: HMUARTLGW HMRaspi1 frame with wrong length received: 10, should: 4: FD00000500E90402027874
2022.10.02 10:15:49.843 1: HMUARTLGW HMRaspi1 frame with wrong length received: 8, should: 4: FD0000150101050000
2022.10.02 10:15:49.845 1: HMUARTLGW HMRaspi1 frame with wrong length received: 26, should: 4: FD0000150101050000511D8610455B5D0000000A40BE0C00004BA6
2022.10.02 10:15:50.554 1: HMUARTLGW HMRaspi1 frame with wrong length received: 26, should: 4: FD0000150101050000511D8610455B5D0000000A40BE0C00004BA6
2022.10.02 10:18:49.628 1: HMUARTLGW HMRaspi1 frame with wrong length received: 8, should: 4: FD0000120112050000
2022.10.02 10:18:49.631 1: HMUARTLGW HMRaspi1 frame with wrong length received: 23, should: 4: FD00001201120500003440865A5152BC00000040BB47AEEF
2022.10.02 10:18:50.605 1: HMUARTLGW HMRaspi1 frame with wrong length received: 23, should: 4: FD00001201120500003440865A5152BC00000040BB47AEEF
2022.10.02 10:19:16.633 1: HMUARTLGW HMRaspi1 frame with wrong length received: 8, should: 4: FD00001A0114050000
2022.10.02 10:19:16.635 1: HMUARTLGW HMRaspi1 frame with wrong length received: 31, should: 4: FD00001A01140500003D31845E370BA5000000800019000000000008F503C7E6
2022.10.02 10:19:20.614 1: HMUARTLGW HMRaspi1 frame with wrong length received: 31, should: 4: FD00001A01140500003D31845E370BA5000000800019000000000008F503C7E6
2022.10.02 10:21:35.651 1: HMUARTLGW HMRaspi1 frame with wrong length received: 8, should: 4: FD0000050009040202
2022.10.02 10:21:35.653 1: HMUARTLGW HMRaspi1 frame with wrong length received: 10, should: 4: FD0000050009040202F85A
2022.10.02 10:21:39.656 1: HMUARTLGW HMRaspi1 frame with wrong length received: 10, should: 4: FD0000050009040202F85A
2022.10.02 10:23:26.394 1: HMUARTLGW HMRaspi1 frame with wrong length received: 8, should: 4: FD00001A012D050000
2022.10.02 10:23:26.396 1: HMUARTLGW HMRaspi1 frame with wrong length received: 31, should: 4: FD00001A012D0500004D49845E36D30C000000800000000000000008E3021CFC
2022.10.02 10:23:39.691 1: HMUARTLGW HMRaspi1 frame with wrong length received: 31, should: 4: FD00001A012D0500004D49845E36D30C000000800000000000000008E3021CFC
2022.10.02 10:26:30.897 1: HMUARTLGW HMRaspi1 frame with wrong length received: 8, should: 4: FD000015013E050000
2022.10.02 10:26:30.899 1: HMUARTLGW HMRaspi1 frame with wrong length received: 26, should: 4: FD000015013E050000244A8610455B3C0000000A40BB0C0000A397
2022.10.02 10:26:39.744 1: HMUARTLGW HMRaspi1 frame with wrong length received: 26, should: 4: FD000015013E050000244A8610455B3C0000000A40BB0C0000A397
2022.10.02 10:37:10.066 1: HMUARTLGW HMRaspi1 frame with wrong length received: 8, should: 4: FD0000050048040202
2022.10.02 10:37:10.069 1: HMUARTLGW HMRaspi1 frame with wrong length received: 10, should: 4: FD0000050048040202EC44
2022.10.02 10:37:14.071 1: HMUARTLGW HMRaspi1 frame with wrong length received: 10, should: 4: FD0000050048040202EC44
2022.10.02 10:37:16.509 1: HMUARTLGW HMRaspi1 frame with wrong length received: 8, should: 4: FD000010017D050000
2022.10.02 10:37:16.511 1: HMUARTLGW HMRaspi1 frame with wrong length received: 21, should: 4: FD000010017D05000051EA800229A291379FF20037A6
2022.10.02 10:37:16.755 1: HMUARTLGW HMRaspi1 frame with wrong length received: 21, should: 4: FD000010017D05000051EA800229A291379FF20037A6
2022.10.02 10:46:26.079 1: HMUARTLGW HMRaspi1 frame with wrong length received: 8, should: 4: FD00001301B3050000
2022.10.02 10:46:26.081 1: HMUARTLGW HMRaspi1 frame with wrong length received: 24, should: 4: FD00001301B30500005249A6104C20CA29A291060100000F77
2022.10.02 10:46:26.200 1: HMUARTLGW HMRaspi1 frame with wrong length received: 24, should: 4: FD00001301B30500005249A6104C20CA29A291060100000F77
Die Hardware ist nach dem Backup bis auf die SSH-Festplatte geblieben. Ich verwende den Rasp 3B.
Ich habe schon bestehende Firmware nochmals aufgespielt und den HMUARTLGW ausgetauscht. Die Meldungen bleiben. Ebenfalls den HMUARTLGW gelöscht und neu Installiert. Diese Fehlermeldungen haben aber bis jetzt in meiner FHEM-Installation noch keine Fehlfunktionen.
Die Bilder zeigen das Defice vom HMUARTLGW HMRaspi1 und das Device vccu1, da ich zwei HM-MOD-UART betreibe. Der zweite HM-MOD-UART zeigt keine Fehler.
Wer kann mir weiterhelfen? Im voraus meinen Dank
Gruß Uwe
