Wert füpr setreading myTemp wird nicht übernommen?
Begonnen von Invers, 02 Februar 2024, 15:48:38
Invers
Nochmal das DOIF von gestern.
mit set DI_TemperaturLog cmd_1 setze ich myTemp auf 100.
Bei e_DI_TemperaturLog_myTemp sieht man die 100 auch, aber bei myTemp nicht.
Hier nochmal die Def:
define DI_TemperaturLog DOIF ([23:59]) \
    ({open (my $DATEI, ">>/opt/fhem/TempLogAussen.txt") or die $!;;\
      print $DATEI ReadingsVal("DI_TemperaturLog","myTime","0")." ". ReadingsVal("DI_TemperaturLog","myTemp","0")."\n";;\
      close ($DATEI);;}\
    (set DU_TempLow [$SELF:myTemp])\
    (setreading $SELF myTemp 100)\
DOELSEIF ([TMP_Aussen:temperature] < [$SELF:myTemp])\
    ({fhem("setreading $SELF myTemp ". ReadingsVal("TMP_Aussen","temperature","0"))})\
    ({fhem("setreading $SELF myTime ". ReadingsTimestamp("TMP_Aussen","temperature","0"))})\
DOELSE
attr DI_TemperaturLog do always
attr DI_TemperaturLog room 1_TEST,System
#   DEF        ([23:59])
#    ({open (my $DATEI, ">>/opt/fhem/TempLogAussen.txt") or die $!;
#      print $DATEI ReadingsVal("DI_TemperaturLog","myTime","0")." ". ReadingsVal("DI_TemperaturLog","myTemp","0")."\n";
#      close ($DATEI);}
#    (set DU_TempLow [$SELF:myTemp])
#    (setreading $SELF myTemp 100)
#DOELSEIF ([TMP_Aussen:temperature] < [$SELF:myTemp])
#    ({fhem("setreading $SELF myTemp ". ReadingsVal("TMP_Aussen","temperature","0"))})
#    ({fhem("setreading $SELF myTime ". ReadingsTimestamp("TMP_Aussen","temperature","0"))})
#DOELSE
#   FUUID      65bba71d-f33f-8098-1b76-d668663d5090733b
#   MODEL      FHEM
#   NAME       DI_TemperaturLog
#   NOTIFYDEV  TMP_Aussen,global,DI_TemperaturLog
#   NR         606
#   NTFY_ORDER 50-DI_TemperaturLog
#   STATE      cmd_3
#   TYPE       DOIF
#   VERSION    27740 2023-07-10 09:31:11
#   eventCount 451
#   OLDREADINGS:
#   READINGS:
#     2024-02-02 15:46:30   Device          TMP_Aussen
#     2024-02-02 15:46:30   cmd             3
#     2024-02-02 15:46:30   cmd_event       TMP_Aussen
#     2024-02-02 15:46:30   cmd_nr          3
#     2024-02-02 15:42:49   e_DI_TemperaturLog_myTemp 100
#     2024-02-02 15:46:30   e_TMP_Aussen_temperature 6.7
#     2024-02-02 15:41:43   mode            enabled
#     2024-02-02 15:42:49   myTemp          6.7
#     2024-02-02 15:42:49   myTime          2024-02-02 15:41:02
#     2024-02-02 15:46:30   state           cmd_3
#     2024-02-02 15:41:43   timer_01_c01    02.02.2024 23:59:00
#   Regex:
#     accu:
#     bar:
#     barAvg:
#     collect:
#     cond:
#       DI_TemperaturLog:
#         0:
#         1:
#           myTemp     ^DI_TemperaturLog$:^myTemp:
#       TMP_Aussen:
#         0:
#         1:
#           temperature ^TMP_Aussen$:^temperature:
#   attr:
#     cmdState:
#     wait:
#     waitdel:
#   condition:
#     0          ::DOIF_time_once($hash,0,$wday)
#     1          ::ReadingValDoIf($hash,'TMP_Aussen','temperature') < ::ReadingValDoIf($hash,'DI_TemperaturLog','myTemp')
#   days:
#   do:
#     0:
#       0          {open (my $DATEI, ">>/opt/fhem/TempLogAussen.txt") or die $!;       print $DATEI ReadingsVal("DI_TemperaturLog","myTime","0")." ". ReadingsVal("DI_TemperaturLog","myTemp","0")."\n";       close ($DATEI);}
#       1          set DU_TempLow [DI_TemperaturLog:myTemp]
#       2          setreading DI_TemperaturLog myTemp 100
#     1:
#       0          {fhem("setreading DI_TemperaturLog myTemp ". ReadingsVal("TMP_Aussen","temperature","0"))}
#       1          {fhem("setreading DI_TemperaturLog myTime ". ReadingsTimestamp("TMP_Aussen","temperature","0"))}
#     2:
#       0
#   helper:
#     event      battery: ok,humidity: 71,T: 6.7 H: 71,temperature: 6.7
#     globalinit 1
#     last_timer 1
#     sleeptimer -1
#     timerdev   TMP_Aussen
#     timerevent battery: ok,humidity: 71,T: 6.7 H: 71,temperature: 6.7
#     triggerDev TMP_Aussen
#     timerevents:
#       battery: ok
#       humidity: 71
#       T: 6.7 H: 71
#       temperature: 6.7
#     timereventsState:
#       battery: ok
#       humidity: 71
#       state: T: 6.7 H: 71
#       temperature: 6.7
#     triggerEvents:
#       battery: ok
#       humidity: 71
#       T: 6.7 H: 71
#       temperature: 6.7
#     triggerEventsState:
#       battery: ok
#       humidity: 71
#       temperature: 6.7
#   internals:
#   intervalfunc:
#   localtime:
#     0          1706914740
#   readings:
#     all         TMP_Aussen:temperature DI_TemperaturLog:myTemp
#   realtime:
#     0          23:59:00
#   time:
#     0          23:59:00
#   timeCond:
#     0          0
#   timer:
#     0          0
#   timers:
#     0           0
#   trigger:
#   triggertime:
#     1706914740:
#       localtime  1706914740
#       hash:
#   uiState:
#   uiTable:
setstate DI_TemperaturLog cmd_3
setstate DI_TemperaturLog 2024-02-02 15:46:30 Device TMP_Aussen
setstate DI_TemperaturLog 2024-02-02 15:46:30 cmd 3
setstate DI_TemperaturLog 2024-02-02 15:46:30 cmd_event TMP_Aussen
setstate DI_TemperaturLog 2024-02-02 15:46:30 cmd_nr 3
setstate DI_TemperaturLog 2024-02-02 15:42:49 e_DI_TemperaturLog_myTemp 100
setstate DI_TemperaturLog 2024-02-02 15:46:30 e_TMP_Aussen_temperature 6.7
setstate DI_TemperaturLog 2024-02-02 15:41:43 mode enabled
setstate DI_TemperaturLog 2024-02-02 15:42:49 myTemp 6.7
setstate DI_TemperaturLog 2024-02-02 15:42:49 myTime 2024-02-02 15:41:02
setstate DI_TemperaturLog 2024-02-02 15:46:30 state cmd_3
setstate DI_TemperaturLog 2024-02-02 15:41:43 timer_01_c01 02.02.2024 23:59:00
