HTTPMOD - JSON - HOW TO
Begonnen von petitpunch, 26 Juli 2023, 12:33:13
petitpunch
Hello,
i'm trying to set a light ON when my electrical panels producing more than I consume.
Normally I can do this with a define notify, but in this case, i'm not able to read the value of P1METER ProdOrConso
here is the definition:
define P1METER HTTPMOD http://192.168.1.138/api/v1/data 180\
setuuid P1METER 6245acf3-f33f-266d-5423-cc86a3ed6683e38a
attr P1METER userattr get01JSON get01Regex getData requestHeader stateFormat
attr P1METER enableCookies 1
attr P1METER icon measure_photovoltaic_inst
attr P1METER enforceGoodReadingNames 1
attr P1METER reading01Name ProdOrConso
attr P1METER reading01JSON active_power_w
attr P1METER reading02JSON total_power_export_t1_kwh
attr P1METER reading03JSON total_power_export_t2_kwh
attr P1METER reading04JSON total_power_import_t1_kwh
attr P1METER reading05JSON total_power_import_t2_kwh
attr P1METER reading06JSON active_power_l1_w
attr P1METER reading07JSON active_power_l2_w
attr P1METER reading08JSON active_power_l3_w
attr P1METER requestHeader1 Content-Type: application/json
attr P1METER requestHeader2 Accept: */*
attr P1METER room ENERGIE
attr P1METER stateFormat ProdOrConso W J:total_power_import_t1_kwh Kwh N:total_power_import_t2_kwh kwh  I :total_power_export_t1_kwh kwh
Someone could help me ?
Thank you
Prof. Dr. Peter Henning
Saw this only now, and maybe it is much too late. What exactly do you mean by "not being able to read"? Is the reading ProdOrConso filled with content ?
Regards
pah
