Hallo Zusammen,
ich habe FHEM auf einem Pi3 installiert und nutze Mosquitto.
Wenn ich sudo apt-get update ausführe bekomme ich den Fehler unten.
Die URL 'http://repo.mosquitto.org/debian/dists/wheezy/main/binary-armhf/Packages' bringt einen 404
Ich denke es sollte eher diese URL sein:
http://repo.mosquitto.org/debian/dists/jessie/main/binary-armhf/Packages
Wie kann ich das fixen?
Danke Euch!
pi@raspberrypi:~ $ sudo apt-get update
OK http://archive.raspberrypi.org jessie InRelease
OK http://mirrordirector.raspbian.org jessie InRelease
OK http://linux.teamviewer.com stable InRelease
OK http://linux.teamviewer.com preview InRelease
Ign http://repo.mosquitto.org wheezy InRelease
Ign http://repo.mosquitto.org wheezy Release.gpg
Holen: 1 http://linux.teamviewer.com stable/main armhf Packages [2.170 B]
Fehl http://repo.mosquitto.org wheezy/main armhf Packages
404 Not Found [IP: 2001:ba8:1f1:f271::2 80]
Ign http://repo.mosquitto.org wheezy/main Translation-de_DE
OK http://archive.raspberrypi.org jessie/main armhf Packages
Ign http://repo.mosquitto.org wheezy/main Translation-en
OK http://archive.raspberrypi.org jessie/ui armhf Packages
Holen: 2 http://linux.teamviewer.com preview/main armhf Packages [1.930 B]
OK http://mirrordirector.raspbian.org jessie/main armhf Packages
OK http://mirrordirector.raspbian.org jessie/contrib armhf Packages
OK http://mirrordirector.raspbian.org jessie/non-free armhf Packages
OK http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-de_DE
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Ign http://linux.teamviewer.com stable/main Translation-de_DE
Ign http://linux.teamviewer.com stable/main Translation-en
Ign http://linux.teamviewer.com preview/main Translation-de_DE
Ign http://linux.teamviewer.com preview/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE
Ign http://mirrordirector.raspbian.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
Es wurden 4.100 B in 8 s geholt (509 B/s).
W: Fehlschlag beim Holen von http://repo.mosquitto.org/debian/dists/wheezy/main/binary-armhf/Packages 404 Not Found [IP: 2001:ba8:1f1:f271::2 80]
E: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
Mal unterstellt, das taucht seit einem Distri-update auf: testweise deaktivieren (mosquitto ist irgendwann im offiziellen repo aufgenommen worden, wenn ich das richtig im Kopf habe); gibt es Probleme: wieder aktivieren und manuell ändern...
Hab es gefixt.
In etc/apt/sources.list.d in Datei mosquitto-wheezy.list von wheezy auf jessie geändert.
danke
