Hi all
I just got my Soil Sensor and see in the RFXmanager that my FRXtrx supports the sensor. but now I also want to add them to fhem. What is the best way to add these.
Below you see 2 of the 3 sensors that I have.
0A520C040001012C620359
Packettype = TEMP_HUM
subtype = TH12 - Imagintronix
channel 1
Sequence nbr = 4
ID = 1
Temperature = 30 °C
Humidity = 98
Status = Wet
Signal level = 5
Battery = OK
0A520C060002015E050259
channel 2
Sequence nbr = 6
ID = 2
Temperature = 35 °C
Humidity = 5
Status = Dry
Signal level = 5
Battery = OK
got it working now, adding one line to 46_TRX_WEATHER.pm will give support for these new sensors :-) ( humidity, temperature, battery status )
add
0x0c => "OPUS_TX300",
to
my %devname =
list, in the
sub TRX_WEATHER_common_temphydro
function
amigob
could you tell me where you purchased this sensor? I am also interested.
Thanks!
Just ordered some here: http://www.plantcaretools.com/
Regards, karl
Sent from my iPad using Tapatalk
Hi
Sensor received, just activated the first one, working perfect. But it seems that there are just 3 sensors possible because of the address jumpers 1-3?
regards,
Karl
Hey,
it´s very good!!! One sensor for only 8€!! I think i´m buying some sensors...
Yes, only three sensors are usable with the RFXtrx433 as there is no additional ID in the RF packet to distinguish them.
Regards
Willi
