[73_GardenaSmartBridge, 74_GardenaSmartDevice] - Module für Gardena Smart System
Begonnen von CoolTux, 05 August 2017, 23:17:06
Mucki
Zitat von: BOFH am 28 März 2024, 09:07:57Löscht dann bitte mal eure Quelle.
Aktuelle zusammengeführte Version liegt nun im testing
https://git.cooltux.net/FHEM/mod-GardenaSmart/raw/branch/testing/controls_GardenaSmartDevice.txt
Hallo BOFH,
vielen Dank für das Update. Für mich super: keine Log-Einträge und der Mäher lässt sich wieder manuell starten.
BOFH
Zitat von: Seidenschnabel am 05 April 2024, 00:14:17Hallo BOFH, ich hoffe diese Daten können helfen:
   CFGFN
   DEF        4242196d-b408-400d-86ae-28fd91a5095 mower
   DEVICEID   4242196d-b408-400d-86ae-28fd91a5095
   FUUID      660ecf7b-f33f-9919-4379-a27d1df0a8cd9d2
   FVERSION   74_GardenaSmartDevice.pm:v2.6.1-s28216/2023-11-28
   IODev      myGardenaBridge
   LASTInputDev myGardenaBridge
   MSGCNT     364
   NAME       SILENO
   NR         300
   STATE      parked_park_selected
   TYPE       GardenaSmartDevice
   VERSION    v2.6.1
   eventCount 381
   myGardenaBridge_MSGCNT 364
   myGardenaBridge_TIME 2024-04-05 00:09:25
     2024-04-04 18:04:11   IODev           myGardenaBridge
     2024-04-04 20:32:29   battery-auto_rechargeable_battery_status full
     2024-04-04 20:32:29   battery-charging 0
     2024-04-04 20:32:29   battery-level   100
     2024-04-04 18:05:11   device_info-category mower
     2024-04-04 18:05:11   device_info-connection_status online
     2024-04-04 23:27:14   device_info-last_time_online 2024-04-04 23:26:28
     2024-04-04 18:05:11   device_info-manufacturer Gardena
     2024-04-04 18:05:11   device_info-model_number 29694
     2024-04-04 18:05:11   device_info-product 9-DEVICE
     2024-04-04 18:05:11   device_info-serial_number 00007596
     2024-04-04 18:05:11   device_info-sgtin N/A
     2024-04-04 18:05:11   device_info-version 1.0.0-4.0.0-1.5.3-2.4.0
     2024-04-04 18:05:11   firmware-firmware_command n/a
     2024-04-04 18:05:11   firmware-firmware_status up_to_date
     2024-04-04 18:05:11   firmware-inclusion_status included
     2024-04-04 18:05:32   lastRequestState request_error
     2024-04-04 18:05:11   mower-error     no_message
     2024-04-04 18:05:11   mower-initialized_initialized 1
     2024-04-04 18:05:11   mower-last_error_code cutting_system_blocked
     2024-04-04 18:05:11   mower-manual_operation 0
     2024-04-04 20:25:28   mower-source_for_next_start no_source
     2024-04-04 18:05:11   mower-start_delay_ms 0
     2024-04-04 20:25:28   mower-status    parked_park_selected
     2024-04-04 18:05:11   mower-timestamp_last_error_code 2024-03-21 18:38:37
     2024-04-04 20:25:28   mower-timestamp_next_start temporarily unavailable
     2024-04-04 18:05:11   mower_stats-charging_cycles 591
     2024-04-04 19:37:13   mower_stats-collisions 1901
     2024-04-04 19:37:13   mower_stats-cutting_time 581
     2024-04-04 19:37:13   mower_stats-running_time 620
     2024-04-04 20:25:28   mower_timer-mower_timer 0
     2024-04-04 20:25:28   mower_timer-mower_timer_timestamp 1712262280
     2024-04-04 18:05:11   mower_type-base_software_up_to_date 1
     2024-04-04 18:05:11   mower_type-capabilities_max_daily_operating_time 24
     2024-04-04 18:05:11   mower_type-capabilities_maximal_lawn_size 750
     2024-04-04 18:05:11   mower_type-capabilities_mowing_rate_capacity 74
     2024-04-04 18:05:11   mower_type-device_type 18
     2024-04-04 18:05:11   mower_type-device_variant 4
     2024-04-04 18:05:11   mower_type-mainboard_version 41.6
     2024-04-04 18:05:11   mower_type-mmi_version 41.4
     2024-04-04 18:05:11   mower_type-serial_number 200709416
     2024-04-04 20:26:28   radio-quality   80
     2024-04-04 18:05:11   radio-state     good
     2024-04-04 18:05:11   scheduling-schedules_event_1_end_at 13:00
     2024-04-04 18:05:11   scheduling-schedules_event_1_id 8cc263f8-c3e8-44d5-a47a-52501a62f66
     2024-04-04 18:05:11   scheduling-schedules_event_1_start_at 10:00
     2024-04-04 18:05:11   scheduling-schedules_event_1_valve_id 0
     2024-04-04 18:05:11   scheduling-schedules_event_1_weekly monday,friday,sunday
     2024-04-04 18:05:11   scheduling-schedules_events_count 1
     2024-04-04 18:13:49   scheduling-schedules_paused_until 2038-01-17T23:00:00Z
     2024-04-04 18:05:11   startpoint-1-enabled 0
     2024-04-04 18:05:11   startpoint-2-enabled 1
     2024-04-04 18:05:11   startpoint-3-enabled 0
     2024-04-05 00:09:25   state           parked_park_selected
   helper:
     STARTINGPOINTID 5f991538-77da-4089-9cad-c29e1344eb04
     STARTINGPOINTS { "name": "starting_points", "value": [{"follow":"guide_1","probability_in_percent":0,"enabled":false,"distance_in_meters":30,"corridor_cut_enabled":false},{"distance_in_meters":30,"follow":"guide_1","probability_in_percent":100,"enabled":true,"corridor_cut_enabled":false},{"follow":"guide_1","probability_in_percent":0,"enabled":false,"distance_in_meters":4,"corridor_cut_enabled":false}]}
     _id
     button_config_time_id
     eco_mode_id a6560b69-5556-4c62-b023-fa8a1fd3419
     leakage_detection_id
     operating_mode_id
     schedules_paused_until_1_id
     schedules_paused_until_2_id
     schedules_paused_until_3_id
     schedules_paused_until_4_id
     schedules_paused_until_5_id
     schedules_paused_until_6_id
     schedules_paused_until_id f007e5b7-c35f-4df3-a6bb-82c852a4b8b
     turn_on_pressure_id
     winter_mode_id
   model      mower
   room       GardenaSmart
Du hast die testing Quelle nicht drin.
Schau mal mit
update listOb du noch eine andere Quelle von cooltux drin hast. Die muss erst raus
RasPi 4
ZWave.me ZME_UZB (Fibaro Auge Gen.2)/ HM-USB2 (Thermostat | Hutschienen Relais | 1-/2fach Schalter) / Enigma2 / PhilipsTV / Philips HUE (GO|Bulb|Stripe (plus)) / Somfy IO Rollos / BOSCH HSG636XS6 / SONOS (P1, P3, P5 2.Gen, SUB, Bar)
Seidenschnabel
Hallo BOFH, habe ich gemacht.
http://fhem.de/fhemupdate/controls_fhem.txt
https://raw.githubusercontent.com/oskarn97/fhem-xiaomi-mqtt/master/controls_xiaomi-zb2mqtt.txt
https://raw.githubusercontent.com/klein0r/fhem-style-haus-automatisierung/version-2/controls_ha_theme.txt
https://raw.githubusercontent.com/uniqueck/fhem-abfall/master/controls_fhemabfall.txt
https://raw.githubusercontent.com/ThorstenPferdekaemper/FHEM-FUIP/master/controls_fuip.txt
https://git.cooltux.net/FHEM/mod-GardenaSmart/raw/branch/patch_newstart_command/controls_GardenaSmartDevice.txt
Kann man da etwas erkennen?
BOFH
update delete https://git.cooltux.net/FHEM/mod-GardenaSmart/raw/branch/patch_newstart_command/controls_GardenaSmartDevice.txt
Und dann
update add https://git.cooltux.net/FHEM/mod-GardenaSmart/raw/branch/testing/controls_GardenaSmartDevice.txt
Und dann
update
Und shutdown reboot
RasPi 4
Seidenschnabel
Hallo BOFH,
heute bist du der Held des Tages  8)
Vielen Dank für die Unterstützung, es läuft wieder alles.
marboj
Hallo BOFH,
wann wird der Inhalt des Patches in das Hauptpaket aufgenommen?
Marco
meine FHEM-Konfiguration: Raspberry Pi4, BT-Dongle, CUL868, CeeBee II
BOFH
Aktuell ist jetzt noch der Patch Code von hhhdg eingeflossen. Würde das jetzt 1-2 Wochen in Testing lassen. Und dann Richtung Main anschieben
RasPi 4
ih-sqeezer
Hallo BOFH,
aus derzeitiger Sicht sollte das update nun stabil funktionieren. Kann es aus deiner Sicht nun in das Main verschoben werden?
Danke und beste Grüße
BOFH
morgen ab 8 im fhem update enthalten.
@Tester: gerne quelle entfernen oder wer mag gerne drin lassen
RasPi 4
