wenn ich am folgenden device (YAMAHA_MC) das attr disable von 1 auf 0 setze, bekomme ich ein dblog problem.
ist das ein YAMAHA_MC oder DbLog problem ?
ACTIVE_ZONE main
API_VERSION 1
DEF 192.168.0.116
DEVICEID 0
FUUID 5ec1016e-f33f-c0e9-209f-81c8c46a8a07d47c
HOST 192.168.0.116
LastTtsFile
NAME ysp2700
NOTIFYDEV global
NR 519
OFF_INTERVAL 120
ON_INTERVAL 60
PORT 80
PowerOnInProgress 0
STATE on
TYPE YAMAHA_MC
URLCMD /YamahaExtendedControl
UdpClientPort 41100
VERSION v2.1.1
ZONE main
attemptsToReturnMenu 0
dist_group_id 00000000000000000000000000000000
dist_group_name (Linked) Wohnzimmer
dist_group_role none
settingChannelInProgress 0
2020-12-11 12:28:23 DLNARenderer unknown
2021-10-22 12:05:05 FirmwareAvailable 0
2020-12-11 12:28:23 MediaServer unknown
2021-10-22 12:54:02 album_name
2021-10-22 12:54:02 albumart_id 1155
1 albumart_url http://192.168.0.116
2021-10-22 12:54:02 auto_power_standby 0
2020-05-17 20:15:12 currentFavNetRadioChannel 2
2020-05-17 20:15:34 currentMenuName NET RADIO
2020-05-17 20:15:34 currentMenuPlayingIndex -1
2020-05-17 20:15:34 currentMenumaxItems 2
2021-10-22 12:54:02 hdmi_out_1 false
2021-10-22 12:54:02 hdmi_out_2 false
2021-10-22 12:54:02 headphone false
2021-01-23 14:07:51 input tv
2021-10-22 12:54:02 ir_sensor false
2021-10-22 12:54:02 last_error Invalid Parameter (Out of range, invalid characters etc.)
2021-10-22 12:54:02 linkedClients
2021-10-22 12:54:02 max_volume 100
2020-05-17 11:18:39 mute 0
2021-10-22 12:54:02 party_mode false
2021-10-22 12:54:02 play_time 0
2021-10-22 12:54:02 playback_input server
2021-10-22 12:54:02 playback_status stop
2021-10-22 12:05:05 power on
2021-10-22 12:53:58 presence present
2021-10-22 12:54:02 repeat_status off
2021-10-22 12:54:02 response_code 0
2021-10-22 12:54:02 shuffle_status off
2020-05-17 11:18:39 sound_program off
2021-10-22 12:54:02 speaker_a false
2021-10-22 12:54:02 speaker_b false
2021-10-22 12:54:02 state on
2021-10-22 12:54:02 station_name
2021-10-22 12:54:02 total_time 0
2021-10-22 12:54:02 track
2021-10-22 12:05:05 volume 52
helper:
AVAILABLE 1
DISABLED 0
RUNNING_REQUEST 0
TIMEOUT_COUNT 0
inputs_comma
inputs_piped
menuitems_comma
menuitems_piped
soundprograms_comma
CMD_QUEUE:
SELECTED_ZONE:
ZONES:
client_list:
disable 1
room Wohnzimmer
2021.10.22 12:06:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 150 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:07:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 201 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:08:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 259 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:09:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 353 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:10:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 425 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:10:32 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 501 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:10:32 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 504 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:11:06 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 552 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:11:07 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 577 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:11:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 627 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:11:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 629 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:12:09 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 664 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:12:09 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 666 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:12:43 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 702 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:12:43 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 705 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:13:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 740 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:13:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 753 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:13:50 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 820 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:13:50 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 823 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:14:24 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 851 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:14:24 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 853 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:15:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 922 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:15:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 924 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:15:30 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1004 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:15:31 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1006 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:16:01 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1065 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:16:02 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1067 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:16:35 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1113 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:16:35 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1115 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:17:06 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1149 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:17:07 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1151 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:17:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1205 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:17:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1210 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:18:11 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1226 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:18:11 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1232 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:18:42 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1299 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:18:43 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1302 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:19:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1334 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:19:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1336 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:19:49 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1374 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:19:50 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1376 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:20:28 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1414 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:20:28 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1430 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:21:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1481 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:21:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1496 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:21:30 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1550 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:21:31 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1561 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:22:04 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1612 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:22:05 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1614 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:22:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1673 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:22:38 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1676 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:23:09 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1692 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:23:10 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1706 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:23:40 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1754 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:23:41 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1760 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:24:19 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1820 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:24:19 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1829 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:24:52 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1872 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:24:53 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1874 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:25:27 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1937 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:25:27 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1956 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:26:01 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1999 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:26:02 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2009 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:26:33 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2064 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:26:34 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2067 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:27:07 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2127 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:27:08 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2135 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:27:41 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2173 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:27:41 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2182 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:28:21 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2231 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:28:22 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2233 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:29:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2299 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:29:01 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2308 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:29:34 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2343 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:29:34 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2345 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:30:10 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2429 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:30:10 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2431 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:30:46 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2488 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:30:47 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2502 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:31:17 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2565 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:31:18 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2577 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:31:52 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2625 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:31:53 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2632 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:32:24 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2661 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:32:25 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2669 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:32:58 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2717 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:32:59 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2719 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:33:29 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2761 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:33:30 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2767 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:34:02 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2850 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:34:03 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2866 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:34:35 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2883 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:34:36 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2892 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:35:09 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2974 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:35:10 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2989 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:35:43 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3045 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:35:44 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3047 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:36:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3128 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:36:17 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3148 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:36:48 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3193 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:36:49 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3195 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:37:20 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3255 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:37:21 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3269 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:37:51 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3317 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:37:53 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3319 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:38:25 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3373 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:38:26 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3403 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:38:56 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3447 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:38:57 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3453 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:39:28 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3469 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:39:29 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3472 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:40:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3525 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:40:01 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3534 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:40:32 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3591 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:40:33 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3593 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:41:04 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3661 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:41:05 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3676 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:41:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3731 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:41:38 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3740 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:42:12 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3797 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:42:14 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3811 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:42:47 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3842 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:42:48 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3846 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:43:18 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3923 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:43:20 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3932 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:43:51 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3978 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:43:52 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3983 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:44:29 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4074 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:44:31 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4083 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:45:02 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4125 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:45:03 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4153 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:45:38 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4194 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:45:39 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4196 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:46:10 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4267 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:46:11 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4276 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:46:42 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4312 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:46:43 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4327 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:47:14 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4386 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:47:15 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4394 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:47:46 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4436 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:47:48 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4468 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:48:19 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4522 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:48:21 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4531 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:48:53 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4598 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:48:54 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4607 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:49:30 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4643 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:49:32 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4645 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:50:02 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4687 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:50:04 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4727 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:50:40 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4747 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:50:42 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4756 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:51:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4850 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:51:18 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4852 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:51:49 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4890 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:51:51 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4898 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:52:22 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4963 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:52:23 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4965 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:52:59 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4999 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:53:01 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 5008 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:53:32 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 5083 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:53:34 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 5097 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
COLUMNS field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
CONFIGURATION ./db.conf
DEF ./db.conf .*:.*
FUUID 5c7ff2ee-f33f-c0e9-5666-b23d05e8cbd44787
FVERSION 93_DbLog.pm:v4.12.3-s24440/2021-05-15
MODE asynchronous
MODEL MYSQL
NAME logdb
NR 21
NTFY_ORDER 50-logdb
PID 15816
REGEXP .*:.*
STATE connected
TYPE DbLog
UTF8 0
dbconn mysql:database=fhem;host=localhost;port=3306
dbuser fhemuser
HELPER:
COLSET 1
DEVICECOL 64
EVENTCOL 512
OLDSTATE connected
PACKAGE main
READINGCOL 64
TC current
TH history
TYPECOL 64
UNITCOL 32
VALUECOL 128
VERSION 4.12.3
Helper:
DBLOG:
CacheOverflowLastNum:
logdb:
TIME 1634915239.20104
VALUE 0
CacheOverflowLastState:
logdb:
TIME 1634900114.95193
VALUE normal
state:
logdb:
TIME 1634900041.60095
VALUE connected
2021-10-22 17:07:19 CacheOverflowLastNum 0
2021-10-22 12:55:14 CacheOverflowLastState normal
2021-10-22 17:08:04 CacheUsage 91
2021-10-22 17:07:19 NextSync 2021-10-22 17:08:19 or if CacheUsage 500 reached
2017-07-29 15:08:31 countCurrent 0
2017-07-29 15:08:30 countHistory 21
2021-01-01 12:16:47 lastRowsDeleted 24835071
2021-10-22 17:07:19 state connected
DbLogSelectionMode Exclude/Include
asyncMode 1
room Server
syncInterval 60
grüße
da will ein Event nicht in die db. Du siehst ihn vermutlich wenn du dir zum geeigneten zeitpunkt den Ingalt des cache vom dblog anschaust. listCache
Die Frage die ich mir Stelle, ist ob das so "gewollt" ist, das ein Event die ganze logging Routine lahm legt.
Nein und macht es ja auch nicht. Oder ?
Setz dir das attr commitMode ac:on_ta:off.
Ja doch. Ich hab's nur bemerkt weil alle Plots stehen geblieben sind.
Dann sei froh sonst wärst du nicht darauf gekommen das mit dem yamaha was nicht stimmt.
output von inform timer logdb
2021-10-24 11:08:54 DbLog logdb CacheUsage: 88
2021-10-24 11:08:54 DbLog logdb DBD::mysql::st execute failed: Incorrect datetime value: '1' for column 'TIMESTAMP' at row 10 at ./FHEM/93_DbLog.pm line 2644.
2021-10-24 11:08:54 DbLog logdb CacheUsage: 89
2021-10-24 11:09:54 DbLog logdb CacheOverflowLastNum: 0
2021-10-24 11:09:54 DbLog logdb CacheUsage: 182
2021-10-24 11:10:54 DbLog logdb CacheOverflowLastNum: 0
2021-10-24 11:10:54 DbLog logdb CacheUsage: 373
2021-10-24 11:11:52 DbLog logdb CacheOverflowLastNum: 0
2021-10-24 11:11:52 DbLog logdb CacheUsage: 501
2021-10-24 11:11:52 DbLog logdb CacheOverflowLastNum: 1
2021-10-24 11:11:52 DbLog logdb CacheOverflowLastState: exceeded
2021-10-24 11:11:52 DbLog logdb NextSync: 2021-10-24 11:12:52 or if CacheUsage 500 reached
2021-10-24 11:11:52 DbLog logdb DBD::mysql::st execute failed: Incorrect datetime value: '1' for column 'TIMESTAMP' at row 10 at ./FHEM/93_DbLog.pm line 2644.
2021-10-24 11:11:52 DbLog logdb DBD::mysql::st execute failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 at ./FHEM/93_DbLog.pm line 2644.
2021-10-24 11:11:52 DbLog logdb CacheUsage: 2
2021-10-24 11:11:52 DbLog logdb CacheUsage: 504
output set logdb listCache
[code]240747 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|energy: 42643.5|energy|42643.5|
240748 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|power: 58.88|power|58.88|
240749 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalc: Hour: 17.6 Day: 42.7 Month: 479.5 Year: 25281.2|statEnergyCalc|Hour: 17.6 Day: 42.7 Month: 479.5 Year: 25281.2|
240750 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcHour: 17.6|statEnergyCalcHour|17.6|
240751 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcDay: 42.7|statEnergyCalcDay|42.7|
240752 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcMonth: 479.5|statEnergyCalcMonth|479.5|
240753 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcYear: 25281.2|statEnergyCalcYear|25281.2|
240754 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergy: Hour: 17.6 Day: 42.7 Month: 479.5 Year: 25281.2|statEnergy|Hour: 17.6 Day: 42.7 Month: 479.5 Year: 25281.2|
240755 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statPowerDayAvg: 3.84|statPowerDayAvg|3.84|
240756 => 2021-10-24 11:13:01|logdb|DBLOG|state: DBD::mysql::st execute failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 at ./FHEM/93_DbLog.pm line 2644.
|state|DBD::mysql::st execute failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server vers|
240757 => 2021-10-24 11:12:29|logdb|DBLOG|state: DBD::mysql::st execute failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 at ./FHEM/93_DbLog.pm line 2644.
240758 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statEnergyCalcYear: 80270.5|statEnergyCalcYear|80270.5|
240759 => 2021-10-24 11:11:52|logdb|DBLOG|state: DBD::mysql::st execute failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 at ./FHEM/93_DbLog.pm line 2644.
240760 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|volume: 15|volume|15|
240761 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|max_volume: 100|max_volume|100|
240762 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|last_error: Invalid Parameter (Out of range, invalid characters etc.)|last_error|Invalid Parameter (Out of range, invalid characters etc.)|
240763 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|response_code: 4|response_code|4|
240764 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|playback_input: server|playback_input|server|
240765 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|playback_status: stop|playback_status|stop|
240766 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|station_name: |station_name||
240767 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|album_name: |album_name||
240768 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|track: |track||
240769 => 1|ysp2700|YAMAHA_MC|albumart_url: http://192.168.0.116|albumart_url|http://192.168.0.116|
240770 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|albumart_id: 7718|albumart_id|7718|
240771 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|repeat_status: off|repeat_status|off|
240772 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|shuffle_status: off|shuffle_status|off|
240773 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|play_time: 0|play_time|0|
240774 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|total_time: 0|total_time|0|
240775 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|linkedClients: |linkedClients||
240776 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|auto_power_standby: 0|auto_power_standby|0|
240777 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|speaker_a: false|speaker_a|false|
240778 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|speaker_b: false|speaker_b|false|
240779 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|headphone: false|headphone|false|
240780 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|hdmi_out_1: false|hdmi_out_1|false|
240781 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|hdmi_out_2: false|hdmi_out_2|false|
240782 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|ir_sensor: false|ir_sensor|false|
240783 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|party_mode: false|party_mode|false|
240784 => 2021-10-24 11:08:02|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240785 => 2021-10-24 11:08:06|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
240786 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|current: 380|current|380|
240787 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|energy: 42638.7|energy|42638.7|
240788 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|power: 59.88|power|59.88|
240789 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalc: Hour: 12.8 Day: 37.9 Month: 474.7 Year: 25276.4|statEnergyCalc|Hour: 12.8 Day: 37.9 Month: 474.7 Year: 25276.4|
240790 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcHour: 12.8|statEnergyCalcHour|12.8|
240791 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcDay: 37.9|statEnergyCalcDay|37.9|
240792 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcMonth: 474.7|statEnergyCalcMonth|474.7|
240793 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcYear: 25276.4|statEnergyCalcYear|25276.4|
240794 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statPowerDayAvg: 3.44|statPowerDayAvg|3.44|
240795 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergy: Hour: 12.8 Day: 37.9 Month: 474.7 Year: 25276.4|statEnergy|Hour: 12.8 Day: 37.9 Month: 474.7 Year: 25276.4|
240796 => 2021-10-24 11:08:10|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 234|ENERGY_Voltage|234|
240797 => 2021-10-24 11:08:10|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Power: 0|ENERGY_Power|0|
240798 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.0_255_value: 11519947.2|1-0_1.8.0_255_value|11519947.2|
240799 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.1_255_value: 11519947.2|1-0_1.8.1_255_value|11519947.2|
240800 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.2_255_value: 0.0|1-0_1.8.2_255_value|0.0|
240801 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.0_255_value: 10152.1|1-0_2.8.0_255_value|10152.1|
240802 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.1_255_value: 10152.1|1-0_2.8.1_255_value|10152.1|
240803 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.2_255_value: 0.0|1-0_2.8.2_255_value|0.0|
240804 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_16.7.0_255_value: 54|1-0_16.7.0_255_value|54|
240805 => 2021-10-24 11:08:15|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240806 => 2021-10-24 11:08:16|LaCrosse_02|LACROSSE|humidity: 58|humidity|58|%
240807 => 2021-10-24 11:08:19|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
240808 => 2021-10-24 11:08:23|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240809 => 2021-10-24 11:08:26|LaCrosse_12|LACROSSE|temperature: 7|temperature|7|°C
240810 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 86.4|ENERGY_ApparentPower|86.4|
240811 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 69.9|ENERGY_ReactivePower|69.9|
240812 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:08:31|Time|2021-10-24T11:08:31|
240813 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.371|ENERGY_Current|0.371|
240814 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Total: 961.749|ENERGY_Total|961.749|
240815 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 50.9|ENERGY_Power|50.9|
240816 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 233.0|ENERGY_Voltage|233.0|
240817 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_PowerHourAvg: 50.9|statENERGY_PowerHourAvg|50.9|
240818 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_PowerDayAvg: 51.0|statENERGY_PowerDayAvg|51.0|
240819 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalHour: 0.010|statENERGY_TotalHour|0.010|
240820 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalDay: 0.572|statENERGY_TotalDay|0.572|
240821 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalMonth: 28.015|statENERGY_TotalMonth|28.015|
240822 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalYear: 362.994|statENERGY_TotalYear|362.994|
240823 => 2021-10-24 11:08:32|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
240824 => 2021-10-24 11:08:36|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240825 => 2021-10-24 11:08:41|CUL_HM_HM_TC_IT_WM_W_EU_3226D3|CUL_HM|battery: ok|battery|ok|
240826 => 2021-10-24 11:08:41|CUL_HM_HM_TC_IT_WM_W_EU_3226D3|CUL_HM|batteryLevel: 2.9|batteryLevel|2.9|
240827 => 2021-10-24 11:08:41|CUL_HM_HM_TC_IT_WM_W_EU_3226D3|CUL_HM|desired-temp: 21.0|desired-temp|21.0|
240828 => 2021-10-24 11:08:41|CUL_HM_HM_TC_IT_WM_W_EU_3226D3|CUL_HM|measured-temp: 22.7|measured-temp|22.7|
240829 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_value: Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|stat1-0_2.8.0_255_value|Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|
240830 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueHour: 0.0|stat1-0_2.8.0_255_valueHour|0.0|
240831 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueDay: 0.3|stat1-0_2.8.0_255_valueDay|0.3|
240832 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueMonth: 213.0|stat1-0_2.8.0_255_valueMonth|213.0|
240833 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueYear: 2789.8|stat1-0_2.8.0_255_valueYear|2789.8|
240834 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_value: Hour: 17.0 Day: 2158.1 Month: 128174.0 Year: 307040.5 (since: 2021-08-16 )|stat1-0_1.8.0_255_value|Hour: 17.0 Day: 2158.1 Month: 128174.0 Year: 307040.5 (since: 2021-08-16 )|
240835 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueHour: 17.0|stat1-0_1.8.0_255_valueHour|17.0|
240836 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueDay: 2158.1|stat1-0_1.8.0_255_valueDay|2158.1|
240837 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueMonth: 128174.0|stat1-0_1.8.0_255_valueMonth|128174.0|
240838 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueYear: 307040.5|stat1-0_1.8.0_255_valueYear|307040.5|
240839 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_36.7.0_255_value: -97|1-0_36.7.0_255_value|-97|
240840 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_56.7.0_255_value: 6|1-0_56.7.0_255_value|6|
240841 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_76.7.0_255_value: 147|1-0_76.7.0_255_value|147|
240842 => 2021-10-24 11:08:45|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
240843 => 2021-10-24 11:08:46|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 235|ENERGY_Voltage|235|
240844 => 2021-10-24 11:08:49|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240845 => 2021-10-24 11:08:50|eaton|NUT|ups.load: 14|ups.load|14|
240846 => 2021-10-24 11:08:51|CUL_HM_HM_TC_IT_WM_W_EU_3226D3_Weather|CUL_HM|temperature: 22.7|temperature|22.7|°C
240847 => 2021-10-24 11:08:54|logdb|DBLOG|CacheOverflowLastNum: 0|CacheOverflowLastNum|0|
240848 => 2021-10-24 11:08:54|logdb|DBLOG|state: DBD::mysql::st execute failed: Incorrect datetime value: '1' for column 'TIMESTAMP' at row 10 at ./FHEM/93_DbLog.pm line 2644.
|state|DBD::mysql::st execute failed: Incorrect datetime value: '1' for column 'TIMESTAMP' at row 10 at ./FHEM/93_DbLog.pm line 2644.
240849 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|max_volume: 100|max_volume|100|
240850 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|last_error: Invalid Parameter (Out of range, invalid characters etc.)|last_error|Invalid Parameter (Out of range, invalid characters etc.)|
240851 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|response_code: 4|response_code|4|
240852 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|playback_input: server|playback_input|server|
240853 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|playback_status: stop|playback_status|stop|
240854 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|station_name: |station_name||
240855 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|album_name: |album_name||
240856 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|track: |track||
240857 => 1|ysp2700|YAMAHA_MC|albumart_url: http://192.168.0.116|albumart_url|http://192.168.0.116|
240858 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|albumart_id: 7718|albumart_id|7718|
240859 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|repeat_status: off|repeat_status|off|
240860 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|shuffle_status: off|shuffle_status|off|
240861 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|play_time: 0|play_time|0|
240862 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|total_time: 0|total_time|0|
240863 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|linkedClients: |linkedClients||
240864 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|auto_power_standby: 0|auto_power_standby|0|
240865 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|speaker_a: false|speaker_a|false|
240866 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|speaker_b: false|speaker_b|false|
240867 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|headphone: false|headphone|false|
240868 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|hdmi_out_1: false|hdmi_out_1|false|
240869 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|hdmi_out_2: false|hdmi_out_2|false|
240870 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|ir_sensor: false|ir_sensor|false|
240871 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|party_mode: false|party_mode|false|
240872 => 2021-10-24 11:09:04|LaCrosse_02|LACROSSE|humidity: 57|humidity|57|%
240873 => 2021-10-24 11:09:13|OWX_28_FF6721361603|OWTHERM|temperature: 19.75|temperature|19.75|°C
240874 => 2021-10-24 11:09:13|LaCrosse_02|LACROSSE|temperature: 15.5|temperature|15.5|°C
240875 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.0_255_value: 11519948.2|1-0_1.8.0_255_value|11519948.2|
240876 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.1_255_value: 11519948.2|1-0_1.8.1_255_value|11519948.2|
240877 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.2_255_value: 0.0|1-0_1.8.2_255_value|0.0|
240878 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.0_255_value: 10152.1|1-0_2.8.0_255_value|10152.1|
240879 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.1_255_value: 10152.1|1-0_2.8.1_255_value|10152.1|
240880 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.2_255_value: 0.0|1-0_2.8.2_255_value|0.0|
240881 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_16.7.0_255_value: 54|1-0_16.7.0_255_value|54|
240882 => 2021-10-24 11:09:25|CUL_HM_HB_UW_Sen_THPL_I_E453C2|CUL_HM|batVoltage: 2.50|batVoltage|2.50|
240883 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|boot: off|boot|off|
240884 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|eState: E: 223777.7 P: 51|eState|E: 223777.7 P: 51|
240885 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|energy: 223777.7|energy|223777.7|
240886 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|energyCalc: 6934663.3|energyCalc|6934663.3|
240887 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|power: 51|power|51|
240888 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|kWh: 11529.7|kWh|11529.7|
240889 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergyCalc: Hour: 18.5 Day: 2162.6 Month: 128408.7 Year: 1626391.4|statEnergyCalc|Hour: 18.5 Day: 2162.6 Month: 128408.7 Year: 1626391.4|
240890 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergyCalcHour: 18.5|statEnergyCalcHour|18.5|
240891 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergyCalcDay: 2162.6|statEnergyCalcDay|2162.6|
240892 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergyCalcMonth: 128408.7|statEnergyCalcMonth|128408.7|
240893 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergyCalcYear: 1626391.4|statEnergyCalcYear|1626391.4|
240894 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergy: Hour: 18.5 Day: 2162.6 Month: 128408.7 Year: -51330.0|statEnergy|Hour: 18.5 Day: 2162.6 Month: 128408.7 Year: -51330.0|
240895 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statPowerDayMin: 10|statPowerDayMin|10|
240896 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statPowerDayAvg: 197|statPowerDayAvg|197|
240897 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statPowerDayMax: 2118|statPowerDayMax|2118|
240898 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|kWh: 11529.7|kWh|11529.7|
240899 => 2021-10-24 11:09:28|HM_698044_IEC_02|CUL_HM|state: 223777.7|state|223777.7|
240900 => 2021-10-24 11:09:30|CUL_HM_HM_TC_IT_WM_W_EU_34B40A_Weather|CUL_HM|humidity: 61|humidity|61|%
240901 => 2021-10-24 11:09:30|CUL_HM_HM_TC_IT_WM_W_EU_34B40A_Weather|CUL_HM|temperature: 18.5|temperature|18.5|°C
240902 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 68.5|ENERGY_ReactivePower|68.5|
240903 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 85.1|ENERGY_ApparentPower|85.1|
240904 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 229.9|ENERGY_Voltage|229.9|
240905 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 50.4|ENERGY_Power|50.4|
240906 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Today: 0.571|ENERGY_Today|0.571|
240907 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.370|ENERGY_Current|0.370|
240908 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:09:31|Time|2021-10-24T11:09:31|
240909 => 2021-10-24 11:09:43|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|ENERGY_Voltage: 229|ENERGY_Voltage|229|
240910 => 2021-10-24 11:09:43|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|ENERGY_Power: 0|ENERGY_Power|0|
240911 => 2021-10-24 11:09:45|LaCrosse_02|LACROSSE|temperature: 15.4|temperature|15.4|°C
240912 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_value: Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|stat1-0_2.8.0_255_value|Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|
240913 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueHour: 0.0|stat1-0_2.8.0_255_valueHour|0.0|
240914 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueDay: 0.3|stat1-0_2.8.0_255_valueDay|0.3|
240915 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueMonth: 213.0|stat1-0_2.8.0_255_valueMonth|213.0|
240916 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueYear: 2789.8|stat1-0_2.8.0_255_valueYear|2789.8|
240917 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_value: Hour: 17.9 Day: 2159.0 Month: 128174.9 Year: 307041.4 (since: 2021-08-16 )|stat1-0_1.8.0_255_value|Hour: 17.9 Day: 2159.0 Month: 128174.9 Year: 307041.4 (since: 2021-08-16 )|
240918 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueHour: 17.9|stat1-0_1.8.0_255_valueHour|17.9|
240919 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueDay: 2159.0|stat1-0_1.8.0_255_valueDay|2159.0|
240920 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueMonth: 128174.9|stat1-0_1.8.0_255_valueMonth|128174.9|
240921 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueYear: 307041.4|stat1-0_1.8.0_255_valueYear|307041.4|
240922 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_36.7.0_255_value: -96|1-0_36.7.0_255_value|-96|
240923 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_56.7.0_255_value: 6|1-0_56.7.0_255_value|6|
240924 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_76.7.0_255_value: 155|1-0_76.7.0_255_value|155|
240925 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|eState: E: 186760.5 P: 0.14 I: 1 U: 235.2 f: 49.99|eState|E: 186760.5 P: 0.14 I: 1 U: 235.2 f: 49.99|
240926 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|energy: 186760.5|energy|186760.5|
240927 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|energyCalc: 575809.2|energyCalc|575809.2|
240928 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|frequency: 49.99|frequency|49.99|
240929 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|power: 0.14|power|0.14|
240930 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|voltage: 235.2|voltage|235.2|
240931 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statEnergyCalcHour: 4.6|statEnergyCalcHour|4.6|
240932 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statEnergyCalcDay: 238.3|statEnergyCalcDay|238.3|
240933 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statEnergyCalcMonth: 6827.4|statEnergyCalcMonth|6827.4|
240934 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statEnergyCalcYear: 80268.1|statEnergyCalcYear|80268.1|
240935 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statPowerDayAvg: 20.56|statPowerDayAvg|20.56|
240936 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statPowerDayMax: 704.06|statPowerDayMax|704.06|
240937 => 2021-10-24 11:09:50|eaton|NUT|ups.load: 15|ups.load|15|
240938 => 2021-10-24 11:09:53|LaCrosse_02|LACROSSE|temperature: 15.5|temperature|15.5|°C
240939 => 2021-10-24 11:09:53|LaCrosse_02|LACROSSE|humidity: 56|humidity|56|%
240940 => 2021-10-24 11:09:53|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
240941 => 2021-10-24 11:09:54|logdb|DBLOG|CacheOverflowLastNum: 0|CacheOverflowLastNum|0|
240942 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|max_volume: 100|max_volume|100|
240943 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|last_error: Invalid Parameter (Out of range, invalid characters etc.)|last_error|Invalid Parameter (Out of range, invalid characters etc.)|
240944 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|response_code: 4|response_code|4|
240945 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|playback_input: server|playback_input|server|
240946 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|playback_status: stop|playback_status|stop|
240947 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|station_name: |station_name||
240948 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|album_name: |album_name||
240949 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|track: |track||
240950 => 1|ysp2700|YAMAHA_MC|albumart_url: http://192.168.0.116|albumart_url|http://192.168.0.116|
240951 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|albumart_id: 7718|albumart_id|7718|
240952 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|repeat_status: off|repeat_status|off|
240953 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|shuffle_status: off|shuffle_status|off|
240954 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|play_time: 0|play_time|0|
240955 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|total_time: 0|total_time|0|
240956 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|linkedClients: |linkedClients||
240957 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|auto_power_standby: 0|auto_power_standby|0|
240958 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|speaker_a: false|speaker_a|false|
240959 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|speaker_b: false|speaker_b|false|
240960 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|headphone: false|headphone|false|
240961 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|hdmi_out_1: false|hdmi_out_1|false|
240962 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|hdmi_out_2: false|hdmi_out_2|false|
240963 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|ir_sensor: false|ir_sensor|false|
240964 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|party_mode: false|party_mode|false|
240965 => 2021-10-24 11:09:56|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 234|ENERGY_Voltage|234|
240966 => 2021-10-24 11:10:01|LaCrosse_02|LACROSSE|temperature: 15.4|temperature|15.4|°C
240967 => 2021-10-24 11:10:01|45er|DUMMY|uptime: 3895667.39|uptime|3895667.39|
240968 => 2021-10-24 11:10:01|twooone|DUMMY|cpu: 51.000|cpu|51.000|
240969 => 2021-10-24 11:10:01|camlight|DUMMY|hofpython: 127|hofpython|127|
240970 => 2021-10-24 11:10:01|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240971 => 2021-10-24 11:10:01|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240972 => 2021-10-24 11:10:01|camlight|DUMMY|hofpythonr: 129.23484126984127|hofpythonr|129.23484126984127|
240973 => 2021-10-24 11:10:01|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240974 => 2021-10-24 11:10:01|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240975 => 2021-10-24 11:10:02|camlight|DUMMY|hofpythong: 128.05662698412698|hofpythong|128.05662698412698|
240976 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240977 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240978 => 2021-10-24 11:10:02|camlight|DUMMY|feldpython: 154|feldpython|154|
240979 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240980 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240981 => 2021-10-24 11:10:02|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240982 => 2021-10-24 11:10:02|camlight|DUMMY|feldpythonr: 105.85717647058823|feldpythonr|105.85717647058823|
240983 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240984 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240985 => 2021-10-24 11:10:02|camlight|DUMMY|hofpythonb: 107.89746031746031|hofpythonb|107.89746031746031|
240986 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240987 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240988 => 2021-10-24 11:10:02|camlight|DUMMY|feldpythong: 162.11891067538127|feldpythong|162.11891067538127|
240989 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240990 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240991 => 2021-10-24 11:10:02|twooone|DUMMY|fan1: 242.000|fan1|242.000|
240992 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 75.5|ENERGY_ReactivePower|75.5|
240993 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.60|ENERGY_Factor|0.60|
240994 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 94.5|ENERGY_ApparentPower|94.5|
240995 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 232.2|ENERGY_Voltage|232.2|
240996 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 56.8|ENERGY_Power|56.8|
240997 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Today: 0.572|ENERGY_Today|0.572|
240998 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Total: 961.750|ENERGY_Total|961.750|
240999 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:10:03|Time|2021-10-24T11:10:03|
241000 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.407|ENERGY_Current|0.407|
241001 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalHour: 0.011|statENERGY_TotalHour|0.011|
241002 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalDay: 0.573|statENERGY_TotalDay|0.573|
241003 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalMonth: 28.016|statENERGY_TotalMonth|28.016|
241004 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalYear: 362.995|statENERGY_TotalYear|362.995|
241005 => 2021-10-24 11:10:02|camlight|DUMMY|feldpythonb: 211.2236688453159|feldpythonb|211.2236688453159|
241006 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
241007 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
241008 => 2021-10-24 11:10:03|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.54|ENERGY_Factor|0.54|
241009 => 2021-10-24 11:10:03|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 79.8|ENERGY_ReactivePower|79.8|
241010 => 2021-10-24 11:10:03|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 50.7|ENERGY_Power|50.7|
241011 => 2021-10-24 11:10:03|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:10:04|Time|2021-10-24T11:10:04|
241012 => 2021-10-24 11:10:03|twooone|DUMMY|sys: 32.000|sys|32.000|
241013 => 2021-10-24 11:10:06|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
241014 => 2021-10-24 11:10:11|fh|PWM|roomsOn: 1|roomsOn|1|
241015 => 2021-10-24 11:10:11|fh|PWM|roomsOff: 2|roomsOff|2|
241016 => 2021-10-24 11:10:11|fh|PWM|avgPulseRoomsOn: 0.15|avgPulseRoomsOn|0.15|
241017 => 2021-10-24 11:10:11|fh|PWM|avgPulseRoomsOff: 0.00|avgPulseRoomsOff|0.00|
241018 => 2021-10-24 11:10:11|fh|PWM|pulseMax: 0.15|pulseMax|0.15|
241019 => 2021-10-24 11:10:11|fh|PWM|pulseSum: 0.15|pulseSum|0.15|
241020 => 2021-10-24 11:10:11|fh|PWM|pulseAvg: 0.05|pulseAvg|0.05|
241021 => 2021-10-24 11:10:11|fh|PWM|pulseAvg2: 0.07|pulseAvg2|0.07|
241022 => 2021-10-24 11:10:11|fh|PWM|pulseAvg3: 0.05|pulseAvg3|0.05|
241023 => 2021-10-24 11:10:11|LaCrosse_01|LACROSSE|temperature: 20.3|temperature|20.3|°C
241024 => 2021-10-24 11:10:11|ESPEasy_8fbh_Arbeitszimmer|ESPEASY|AZ: on|AZ|on|
241025 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.408|ENERGY_Current|0.408|
241026 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:10:14|Time|2021-10-24T11:10:14|
241027 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 234.2|ENERGY_Voltage|234.2|
241028 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 56.6|ENERGY_Power|56.6|
241029 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 95.6|ENERGY_ApparentPower|95.6|
241030 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 77.0|ENERGY_ReactivePower|77.0|
241031 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.59|ENERGY_Factor|0.59|
241032 => 2021-10-24 11:10:13|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|ENERGY_Power: 7|ENERGY_Power|7|
241033 => 2021-10-24 11:10:13|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|ENERGY_Voltage: 234|ENERGY_Voltage|234|
241034 => 2021-10-24 11:10:14|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 50.3|ENERGY_Power|50.3|
241035 => 2021-10-24 11:10:14|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:10:15|Time|2021-10-24T11:10:15|
241036 => 2021-10-24 11:10:14|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 81.2|ENERGY_ReactivePower|81.2|
241037 => 2021-10-24 11:10:14|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.53|ENERGY_Factor|0.53|
241038 => 2021-10-24 11:10:15|LaCrosse_01|LACROSSE|temperature: 20.2|temperature|20.2|°C
241039 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.0_255_value: 11519949.2|1-0_1.8.0_255_value|11519949.2|
241040 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.1_255_value: 11519949.2|1-0_1.8.1_255_value|11519949.2|
241041 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.2_255_value: 0.0|1-0_1.8.2_255_value|0.0|
241042 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.0_255_value: 10152.1|1-0_2.8.0_255_value|10152.1|
241043 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.1_255_value: 10152.1|1-0_2.8.1_255_value|10152.1|
241044 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.2_255_value: 0.0|1-0_2.8.2_255_value|0.0|
241045 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_16.7.0_255_value: 70|1-0_16.7.0_255_value|70|
241046 => 2021-10-24 11:10:19|LaCrosse_01|LACROSSE|temperature: 20.3|temperature|20.3|°C
241047 => 2021-10-24 11:10:21|esp8266_2|DUMMY|level: 417.00|level|417.00|
241048 => 2021-10-24 11:10:22|LaCrosse_12|LACROSSE|temperature: 7.1|temperature|7.1|°C
241049 => 2021-10-24 11:10:28|esp8266_2|DUMMY|temperature: 19.00|temperature|19.00|
241050 => 2021-10-24 11:10:28|esp8266_2|DUMMY|trend: 0|trend|0|
241051 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241052 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|eState: E: 186760.8 P: 135.34 I: 1266 U: 233.9 f: 50.01|eState|E: 186760.8 P: 135.34 I: 1266 U: 233.9 f: 50.01|
241053 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|energy: 186760.8|energy|186760.8|
241054 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|energyCalc: 575809.5|energyCalc|575809.5|
241055 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|frequency: 50.01|frequency|50.01|
241056 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|power: 135.34|power|135.34|
241057 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|voltage: 233.9|voltage|233.9|
241058 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statPowerDayAvg: 20.54|statPowerDayAvg|20.54|
241059 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statPowerDayMax: 704.06|statPowerDayMax|704.06|
241060 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statEnergyCalcHour: 4.9|statEnergyCalcHour|4.9|
241061 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statEnergyCalcDay: 238.6|statEnergyCalcDay|238.6|
241062 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statEnergyCalcMonth: 6827.7|statEnergyCalcMonth|6827.7|
241063 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statEnergyCalcYear: 80268.4|statEnergyCalcYear|80268.4|
241064 => 2021-10-24 11:10:28|HM_283B50_Sw|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241065 => 2021-10-24 11:10:29|esp8266_2|DUMMY|humidity: 43.50|humidity|43.50|
241066 => 2021-10-24 11:10:29|LaCrosse_02|LACROSSE|humidity: 57|humidity|57|%
241067 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 84.3|ENERGY_ApparentPower|84.3|
241068 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.60|ENERGY_Factor|0.60|
241069 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 67.6|ENERGY_ReactivePower|67.6|
241070 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:10:31|Time|2021-10-24T11:10:31|
241071 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.363|ENERGY_Current|0.363|
241072 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 232.2|ENERGY_Voltage|232.2|
241073 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241074 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|eState: E: 186762 P: 639.22 I: 2743 U: 232.9 f: 49.99|eState|E: 186762 P: 639.22 I: 2743 U: 232.9 f: 49.99|
241075 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|energy: 186762|energy|186762|
241076 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|energyCalc: 575810.7|energyCalc|575810.7|
241077 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|frequency: 49.99|frequency|49.99|
241078 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|power: 639.22|power|639.22|
241079 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|voltage: 232.9|voltage|232.9|
241080 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statEnergyCalcHour: 6.1|statEnergyCalcHour|6.1|
241081 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statEnergyCalcDay: 239.8|statEnergyCalcDay|239.8|
241082 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statEnergyCalcMonth: 6828.9|statEnergyCalcMonth|6828.9|
241083 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statEnergyCalcYear: 80269.6|statEnergyCalcYear|80269.6|
241084 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statPowerDayAvg: 20.56|statPowerDayAvg|20.56|
241085 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statPowerDayMax: 704.06|statPowerDayMax|704.06|
241086 => 2021-10-24 11:10:35|HM_283B50_Sw|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241087 => 2021-10-24 11:10:37|LaCrosse_02|LACROSSE|humidity: 56|humidity|56|%
241088 => 2021-10-24 11:10:41|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 233|ENERGY_Voltage|233|
241089 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|current: 375|current|375|
241090 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|energy: 42641.2|energy|42641.2|
241091 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|power: 57.52|power|57.52|
241092 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statPowerDayAvg: 3.65|statPowerDayAvg|3.65|
241093 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergy: Hour: 15.3 Day: 40.4 Month: 477.2 Year: 25278.9|statEnergy|Hour: 15.3 Day: 40.4 Month: 477.2 Year: 25278.9|
241094 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalc: Hour: 15.3 Day: 40.4 Month: 477.2 Year: 25278.9|statEnergyCalc|Hour: 15.3 Day: 40.4 Month: 477.2 Year: 25278.9|
241095 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcHour: 15.3|statEnergyCalcHour|15.3|
241096 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcDay: 40.4|statEnergyCalcDay|40.4|
241097 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcMonth: 477.2|statEnergyCalcMonth|477.2|
241098 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcYear: 25278.9|statEnergyCalcYear|25278.9|
241099 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241100 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|eState: E: 186762.9 P: 0.15 I: 1 U: 234.3 f: 49.99|eState|E: 186762.9 P: 0.15 I: 1 U: 234.3 f: 49.99|
241101 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|energy: 186762.9|energy|186762.9|
241102 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|energyCalc: 575811.6|energyCalc|575811.6|
241103 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|frequency: 49.99|frequency|49.99|
241104 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|power: 0.15|power|0.15|
241105 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|voltage: 234.3|voltage|234.3|
241106 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statPowerDayAvg: 20.69|statPowerDayAvg|20.69|
241107 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statPowerDayMax: 704.06|statPowerDayMax|704.06|
241108 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statEnergyCalcHour: 7.0|statEnergyCalcHour|7.0|
241109 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statEnergyCalcDay: 240.7|statEnergyCalcDay|240.7|
241110 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statEnergyCalcMonth: 6829.8|statEnergyCalcMonth|6829.8|
241111 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statEnergyCalcYear: 80270.5|statEnergyCalcYear|80270.5|
241112 => 2021-10-24 11:10:43|HM_283B50_Sw|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241113 => 2021-10-24 11:10:44|LaCrosse_29|LACROSSE|temperature: 18.2|temperature|18.2|°C
241114 => 2021-10-24 11:10:44|HM_57D135_Motion|CUL_HM|brightness: 147|brightness|147|
241115 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_value: Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|stat1-0_2.8.0_255_value|Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|
241116 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueHour: 0.0|stat1-0_2.8.0_255_valueHour|0.0|
241117 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueDay: 0.3|stat1-0_2.8.0_255_valueDay|0.3|
241118 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueMonth: 213.0|stat1-0_2.8.0_255_valueMonth|213.0|
241119 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueYear: 2789.8|stat1-0_2.8.0_255_valueYear|2789.8|
241120 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_value: Hour: 21.4 Day: 2162.5 Month: 128178.4 Year: 307044.9 (since: 2021-08-16 )|stat1-0_1.8.0_255_value|Hour: 21.4 Day: 2162.5 Month: 128178.4 Year: 307044.9 (since: 2021-08-16 )|
241121 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueHour: 21.4|stat1-0_1.8.0_255_valueHour|21.4|
241122 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueDay: 2162.5|stat1-0_1.8.0_255_valueDay|2162.5|
241123 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueMonth: 128178.4|stat1-0_1.8.0_255_valueMonth|128178.4|
241124 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueYear: 307044.9|stat1-0_1.8.0_255_valueYear|307044.9|
241125 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_36.7.0_255_value: -101|1-0_36.7.0_255_value|-101|
241126 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_56.7.0_255_value: 12|1-0_56.7.0_255_value|12|
241127 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_76.7.0_255_value: 165|1-0_76.7.0_255_value|165|
241128 => 2021-10-24 11:10:47|ESPEasy_ESP_Kueche_LED_W|ESPEASY|state: absent|state|absent|
241129 => 2021-10-24 11:10:50|eaton|NUT|battery.runtime: 1500|battery.runtime|1500|
241130 => 2021-10-24 11:10:50|eaton|NUT|ups.load: 14|ups.load|14|
241131 => 2021-10-24 11:10:54|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 234|ENERGY_Voltage|234|
241132 => 2021-10-24 11:10:54|logdb|DBLOG|CacheOverflowLastNum: 0|CacheOverflowLastNum|0|
241133 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|max_volume: 100|max_volume|100|
241134 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|last_error: Invalid Parameter (Out of range, invalid characters etc.)|last_error|Invalid Parameter (Out of range, invalid characters etc.)|
241135 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|response_code: 4|response_code|4|
241136 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|playback_input: server|playback_input|server|
241137 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|playback_status: stop|playback_status|stop|
241138 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|station_name: |station_name||
241139 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|album_name: |album_name||
241140 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|track: |track||
241141 => 1|ysp2700|YAMAHA_MC|albumart_url: http://192.168.0.116|albumart_url|http://192.168.0.116|
241142 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|albumart_id: 7718|albumart_id|7718|
241143 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|repeat_status: off|repeat_status|off|
241144 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|shuffle_status: off|shuffle_status|off|
241145 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|play_time: 0|play_time|0|
241146 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|total_time: 0|total_time|0|
241147 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|linkedClients: |linkedClients||
241148 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|auto_power_standby: 0|auto_power_standby|0|
241149 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|speaker_a: false|speaker_a|false|
241150 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|speaker_b: false|speaker_b|false|
241151 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|headphone: false|headphone|false|
241152 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|hdmi_out_1: false|hdmi_out_1|false|
241153 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|hdmi_out_2: false|hdmi_out_2|false|
241154 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|ir_sensor: false|ir_sensor|false|
241155 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|party_mode: false|party_mode|false|
241156 => 2021-10-24 11:10:59|CUL_HM_HM_TC_IT_WM_W_EU_3226D3_Weather|CUL_HM|humidity: 55|humidity|55|%
241157 => 2021-10-24 11:10:59|LaCrosse_12|LACROSSE|temperature: 7|temperature|7|°C
241158 => 2021-10-24 11:11:01|LaCrosse_02|LACROSSE|humidity: 57|humidity|57|%
241159 => 2021-10-24 11:11:02|ESPEasy_ESP_UV_sysinfo|ESPEASY|uptime: 33130|uptime|33130|
241160 => 2021-10-24 11:11:03|LaCrosse_12|LACROSSE|temperature: 7.1|temperature|7.1|°C
241161 => 2021-10-24 11:11:04|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 235|ENERGY_Voltage|235|
241162 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Today: 0.573|ENERGY_Today|0.573|
241163 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Total: 961.751|ENERGY_Total|961.751|
241164 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:06|Time|2021-10-24T11:11:06|
241165 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.391|ENERGY_Current|0.391|
241166 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 58.1|ENERGY_Power|58.1|
241167 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 232.6|ENERGY_Voltage|232.6|
241168 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 90.9|ENERGY_ApparentPower|90.9|
241169 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 70.0|ENERGY_ReactivePower|70.0|
241170 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.64|ENERGY_Factor|0.64|
241171 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalHour: 0.012|statENERGY_TotalHour|0.012|
241172 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalDay: 0.574|statENERGY_TotalDay|0.574|
241173 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalMonth: 28.017|statENERGY_TotalMonth|28.017|
241174 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalYear: 362.996|statENERGY_TotalYear|362.996|
241175 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_PowerHourAvg: 50.8|statENERGY_PowerHourAvg|50.8|
241176 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 89.6|ENERGY_ApparentPower|89.6|
241177 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 73.6|ENERGY_ReactivePower|73.6|
241178 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.57|ENERGY_Factor|0.57|
241179 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:07|Time|2021-10-24T11:11:07|
241180 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 229.1|ENERGY_Voltage|229.1|
241181 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 51.1|ENERGY_Power|51.1|
241182 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.0_255_value: 11519952.6|1-0_1.8.0_255_value|11519952.6|
241183 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.1_255_value: 11519952.6|1-0_1.8.1_255_value|11519952.6|
241184 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.2_255_value: 0.0|1-0_1.8.2_255_value|0.0|
241185 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.0_255_value: 10152.1|1-0_2.8.0_255_value|10152.1|
241186 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.1_255_value: 10152.1|1-0_2.8.1_255_value|10152.1|
241187 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.2_255_value: 0.0|1-0_2.8.2_255_value|0.0|
241188 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_16.7.0_255_value: 41|1-0_16.7.0_255_value|41|
241189 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.365|ENERGY_Current|0.365|
241190 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:22|Time|2021-10-24T11:11:22|
241191 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 59.9|ENERGY_Power|59.9|
241192 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 229.5|ENERGY_Voltage|229.5|
241193 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 83.8|ENERGY_ApparentPower|83.8|
241194 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.72|ENERGY_Factor|0.72|
241195 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 58.6|ENERGY_ReactivePower|58.6|
241196 => 2021-10-24 11:11:22|LaCrosse_14|LACROSSE|temperature: -18.6|temperature|-18.6|°C
241197 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.53|ENERGY_Factor|0.53|
241198 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 82.6|ENERGY_ReactivePower|82.6|
241199 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 97.3|ENERGY_ApparentPower|97.3|
241200 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 51.5|ENERGY_Power|51.5|
241201 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.424|ENERGY_Current|0.424|
241202 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:23|Time|2021-10-24T11:11:23|
241203 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_PowerHourAvg: 50.9|statENERGY_PowerHourAvg|50.9|
241204 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_PowerHourAvg: 180|statENERGY_PowerHourAvg|180|
241205 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_Total: Hour: 0.030 Day: 0.213 Month: 12.094 Year: 183.651 (since: 2021-03-31_10:36:04 )|statENERGY_Total|Hour: 0.030 Day: 0.213 Month: 12.094 Year: 183.651 (since: 2021-03-31_10:36:04 )|
241206 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalDay: 0.213|statENERGY_TotalDay|0.213|
241207 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalMonth: 12.094|statENERGY_TotalMonth|12.094|
241208 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalYear: 183.651|statENERGY_TotalYear|183.651|
241209 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|ENERGY_Power: 186|ENERGY_Power|186|
241210 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|ENERGY_Today: 0.228|ENERGY_Today|0.228|
241211 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_Total: Hour: 0.046 Day: 0.229 Month: 12.110 Year: 183.667 (since: 2021-03-31_10:36:04 )|statENERGY_Total|Hour: 0.046 Day: 0.229 Month: 12.110 Year: 183.667 (since: 2021-03-31_10:36:04 )|
241212 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalDay: 0.229|statENERGY_TotalDay|0.229|
241213 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalMonth: 12.110|statENERGY_TotalMonth|12.110|
241214 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalYear: 183.667|statENERGY_TotalYear|183.667|
241215 => 2021-10-24 11:11:29|LaCrosse_17|LACROSSE|humidity: 53|humidity|53|%
241216 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|boot: off|boot|off|
241217 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|eState: E: 223781.6 P: 45|eState|E: 223781.6 P: 45|
241218 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|energy: 223781.6|energy|223781.6|
241219 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|energyCalc: 6934667.2|energyCalc|6934667.2|
241220 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|power: 45|power|45|
241221 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|kWh: 11529.7|kWh|11529.7|
241222 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergyCalc: Hour: 22.4 Day: 2166.5 Month: 128412.6 Year: 1626395.3|statEnergyCalc|Hour: 22.4 Day: 2166.5 Month: 128412.6 Year: 1626395.3|
241223 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergyCalcHour: 22.4|statEnergyCalcHour|22.4|
241224 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergyCalcDay: 2166.5|statEnergyCalcDay|2166.5|
241225 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergyCalcMonth: 128412.6|statEnergyCalcMonth|128412.6|
241226 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergyCalcYear: 1626395.3|statEnergyCalcYear|1626395.3|
241227 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statPowerDayMin: 10|statPowerDayMin|10|
241228 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statPowerDayAvg: 197|statPowerDayAvg|197|
241229 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statPowerDayMax: 2118|statPowerDayMax|2118|
241230 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergy: Hour: 22.4 Day: 2166.5 Month: 128412.6 Year: -51326.1|statEnergy|Hour: 22.4 Day: 2166.5 Month: 128412.6 Year: -51326.1|
241231 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|kWh: 11529.7|kWh|11529.7|
241232 => 2021-10-24 11:11:36|HM_698044_IEC_02|CUL_HM|state: 223781.6|state|223781.6|
241233 => 2021-10-24 11:11:38|LaCrosse_17|LACROSSE|temperature: 21.4|temperature|21.4|°C
241234 => 2021-10-24 11:11:44|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 234|ENERGY_Voltage|234|
241235 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_value: Hour: 22.3 Day: 2163.4 Month: 128179.3 Year: 307045.8 (since: 2021-08-16 )|stat1-0_1.8.0_255_value|Hour: 22.3 Day: 2163.4 Month: 128179.3 Year: 307045.8 (since: 2021-08-16 )|
241236 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueHour: 22.3|stat1-0_1.8.0_255_valueHour|22.3|
241237 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueDay: 2163.4|stat1-0_1.8.0_255_valueDay|2163.4|
241238 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueMonth: 128179.3|stat1-0_1.8.0_255_valueMonth|128179.3|
241239 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueYear: 307045.8|stat1-0_1.8.0_255_valueYear|307045.8|
241240 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_value: Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|stat1-0_2.8.0_255_value|Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|
241241 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueHour: 0.0|stat1-0_2.8.0_255_valueHour|0.0|
241242 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueDay: 0.3|stat1-0_2.8.0_255_valueDay|0.3|
241243 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueMonth: 213.0|stat1-0_2.8.0_255_valueMonth|213.0|
241244 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueYear: 2789.8|stat1-0_2.8.0_255_valueYear|2789.8|
241245 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_36.7.0_255_value: -100|1-0_36.7.0_255_value|-100|
241246 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_56.7.0_255_value: 11|1-0_56.7.0_255_value|11|
241247 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_76.7.0_255_value: 133|1-0_76.7.0_255_value|133|
241248 => 2021-10-24 11:11:50|eaton|NUT|battery.runtime: 1450|battery.runtime|1450|
241249 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|eState: E: 186762.9 P: 0.14 I: 1 U: 234.8 f: 50.01|eState|E: 186762.9 P: 0.14 I: 1 U: 234.8 f: 50.01|
241250 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|energy: 186762.9|energy|186762.9|
241251 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|energyCalc: 575811.6|energyCalc|575811.6|
241252 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|frequency: 50.01|frequency|50.01|
241253 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|power: 0.14|power|0.14|
241254 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|voltage: 234.8|voltage|234.8|
241255 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statPowerDayAvg: 20.65|statPowerDayAvg|20.65|
241256 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statPowerDayMax: 704.06|statPowerDayMax|704.06|
241257 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statEnergyCalcHour: 7.0|statEnergyCalcHour|7.0|
241258 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statEnergyCalcDay: 240.7|statEnergyCalcDay|240.7|
241259 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statEnergyCalcMonth: 6829.8|statEnergyCalcMonth|6829.8|
241260 => 2021-10-24 11:11:52|logdb|DBLOG|CacheOverflowLastNum: 0|CacheOverflowLastNum|0|
241261 => 2021-10-24 11:11:52|logdb|DBLOG|state: DBD::mysql::st execute failed: Incorrect datetime value: '1' for column 'TIMESTAMP' at row 10 at ./FHEM/93_DbLog.pm line 2644.
241262 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 62.3|ENERGY_ReactivePower|62.3|
241263 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.68|ENERGY_Factor|0.68|
241264 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 84.7|ENERGY_ApparentPower|84.7|
241265 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 234.6|ENERGY_Voltage|234.6|
241266 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 57.4|ENERGY_Power|57.4|
241267 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Total: 961.752|ENERGY_Total|961.752|
241268 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:53|Time|2021-10-24T11:11:53|
241269 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.361|ENERGY_Current|0.361|
241270 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalHour: 0.013|statENERGY_TotalHour|0.013|
241271 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalDay: 0.575|statENERGY_TotalDay|0.575|
241272 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalMonth: 28.018|statENERGY_TotalMonth|28.018|
241273 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalYear: 362.997|statENERGY_TotalYear|362.997|
241274 => 2021-10-24 11:11:52|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|Wifi_Signal: -58|Wifi_Signal|-58|
241275 => 2021-10-24 11:11:52|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|ENERGY_Power: 1|ENERGY_Power|1|
241276 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 234.2|ENERGY_Voltage|234.2|
241277 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 50.4|ENERGY_Power|50.4|
241278 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:54|Time|2021-10-24T11:11:54|
241279 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 67.9|ENERGY_ReactivePower|67.9|
241280 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.60|ENERGY_Factor|0.60|
241281 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 84.5|ENERGY_ApparentPower|84.5|
241282 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|max_volume: 100|max_volume|100|
241283 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|last_error: Invalid Parameter (Out of range, invalid characters etc.)|last_error|Invalid Parameter (Out of range, invalid characters etc.)|
241284 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|response_code: 4|response_code|4|
241285 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|playback_input: server|playback_input|server|
241286 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|playback_status: stop|playback_status|stop|
241287 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|station_name: |station_name||
241288 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|album_name: |album_name||
241289 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|track: |track||
241290 => 1|ysp2700|YAMAHA_MC|albumart_url: http://192.168.0.116|albumart_url|http://192.168.0.116|
241291 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|albumart_id: 7718|albumart_id|7718|
241292 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|repeat_status: off|repeat_status|off|
241293 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|shuffle_status: off|shuffle_status|off|
241294 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|play_time: 0|play_time|0|
241295 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|total_time: 0|total_time|0|
241296 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|linkedClients: |linkedClients||
241297 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|auto_power_standby: 0|auto_power_standby|0|
241298 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|speaker_a: false|speaker_a|false|
241299 => 2021-10-24 11:11:56|ysp2
Ja, du siehst dass der Event des Readings albumart_url keinen Timestamp hat:
Wenn du mit den anderen Einträgen im Cache vergleichst, siehst du ja wie der Timestamp aufgebaut ist.
Jetzt wo es mir aufgefallen ist, sieht man es auch schon in deinem List von YAMAHA:
2020-12-11 12:28:23 DLNARenderer unknown
2021-10-22 12:05:05 FirmwareAvailable 0
2020-12-11 12:28:23 MediaServer unknown
2021-10-22 12:54:02 album_name
2021-10-22 12:54:02 albumart_id 1155
1 albumart_url http://192.168.0.116
2021-10-22 12:54:02 auto_power_standby 0
2020-05-17 20:15:12 currentFavNetRadioChannel 2
2020-05-17 20:15:34 currentMenuName NET RADIO
2020-05-17 20:15:34 currentMenuPlayingIndex -1
2020-05-17 20:15:34 currentMenumaxItems 2
2021-10-22 12:54:02 hdmi_out_1 false
2021-10-22 12:54:02 hdmi_out_2 false
2021-10-22 12:54:02 headphone false
Kein Wunder dass DbLog bzw. die DB es nicht verarbeiten kann.
ich werde versuchen den mainainer darauf aufmerksam zu machen. trotzdem stellt sich mir die frage, ob man sowas (zukünftig) in logdb abfangen will, ich finde ein modul/device sollte nicht die ganze db lahmlegen können.
danke fürs schauen.
Dafür gibt es ja das Attribut commitMode. Es steuert ob das Wegschreiben in die DB als Transaktion ausgeführt wird oder nicht.
Es ist wichtig um temporäre Fehler der DB (z.B. Wartungsmodus, Absturz, etc. ) abzufangen und die Events im Cache zu behalten damit sie nicht verloren gehen. Mit entsprechenden Einstellungen des CommitMode kann der User das Verhalten in solchen Fällen korrigieren.
Insofern hat der User alle Möglichkeiten. Und ich bzw. DbLog kann auch nicht alle eventuell auftretenden Fehlervarianten vordenken und abfangen. Da muß der User schonmal selber mit ran ;).
Im synchronen Modus hat man dieses Problem übrigens nicht ... dafür aber andere. :)
Das hatte ich noch gar nicht gesetzt, danke für die erinnerung.
