einige meiner 1wire Sensoren ignorieren das Interval Attibut.
z.B.: LIST
ASYNC 0
DEF DS2438 9ACC0A010000
INTERVAL 300
IODev 1wire
NAME Aussen_rH
NOTIFYDEV global
NR 187
NTFY_ORDER 50-Aussen_rH
OW_FAMILY 26
OW_ID 9ACC0A010000
PRESENT 1
ROM_ID 26.9ACC0A010000.AC
STATE rH: 28.75 % (T: 29.6 °C s: 0.00 V)
TYPE OWMULTI
Helper:
Dblog:
Vdd:
Logdb:
TIME 1497881548.95711
VALUE 5.08
Absfeuchte:
Logdb:
VALUE 8.5
Data:
Logdb:
VALUE rH: 28.75 % (T: 29.6 °C s: 0.00 V)
Rh:
Logdb:
VALUE 28.75
State:
Logdb:
TIME 1497881520.79357
VALUE interval 300
Taupunkt:
Logdb:
VALUE 9.6
Temperature:
Logdb:
VALUE 29.6
Readings:
2017-06-19 16:12:28 VDD 5.08
2017-06-19 16:12:28 absFeuchte 8.5
2017-06-19 16:12:28 rH 28.75
2017-06-19 16:12:28 sense 0
2017-06-19 16:12:28 state rH: 28.75 % (T: 29.6 °C s: 0.00 V)
2017-06-19 16:12:28 taupunkt 9.6
2017-06-19 16:12:28 temperature 29.6
owg_val:
29.625
5.08
1.71
0.002197265625
Tempf:
factor 1
offset 0
DbLogExclude sense
IODev 1wire
VFunction (161.29 * V / VDD - 25.8065)/(1.0546 - 0.00216 * T)
VName rH
VUnit %
group Wetter
interval 300
model DS2438
room Temp / Feucht,zentrale Funktionen
erzeugt ca alle 4 Sekunden neue Werte.
DBLog:
2017-06-19 16:13:01|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:13:05|Aussen_rH|OWMULTI|temperature: 29.6|temperature|29.6|°C
2017-06-19 16:13:09|Aussen_rH|OWMULTI|temperature: 29.6|temperature|29.6|°C
2017-06-19 16:13:13|Aussen_rH|OWMULTI|temperature: 29.6|temperature|29.6|°C
2017-06-19 16:13:16|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:13:21|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:13:24|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:13:29|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:13:33|Aussen_rH|OWMULTI|temperature: 29.6|temperature|29.6|°C
2017-06-19 16:13:37|Aussen_rH|OWMULTI|temperature: 29.4|temperature|29.4|°C
2017-06-19 16:13:40|Aussen_rH|OWMULTI|temperature: 29.6|temperature|29.6|°C
2017-06-19 16:13:44|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:13:49|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:13:53|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:13:56|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:01|Aussen_rH|OWMULTI|temperature: 29.6|temperature|29.6|°C
2017-06-19 16:14:04|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:09|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:13|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:16|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:20|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:25|Aussen_rH|OWMULTI|temperature: 29.6|temperature|29.6|°C
2017-06-19 16:14:28|Aussen_rH|OWMULTI|temperature: 29.6|temperature|29.6|°C
2017-06-19 16:14:32|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:37|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:40|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:44|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:49|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:53|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:14:56|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:15:00|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
2017-06-19 16:15:04|Aussen_rH|OWMULTI|temperature: 29.5|temperature|29.5|°C
list vom Busmaster: (der von Denkovi)
ALARMED no
DEF /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_DAE002vX-if00-port0
DeviceName /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_DAE002vX-if00-port0@9600
FD 23
INTERFACE DS2480
NAME 1wire
NOTIFYDEV global
NR 112
NTFY_ORDER 50-1wire
PARTIAL
PRESENT 1
ROM_ID FF
STATE Active
TYPE OWX
followAlarms off
interval 300
ALARMDEVS:
DEVS:
28.54F21C070000.99
28.AC7929070000.38
28.622529070000.00
28.465029070000.D5
28.8E5060070000.98
28.6EAF5F070000.AA
28.DEA01C070000.AA
28.A59C29070000.A6
28.FF70F3841605.59
28.FFB2F5841605.F1
28.FF8560801604.84
26.AA8D73010000.5E
26.9ACC0A010000.AC
Readings:
2017-06-11 10:38:59 state defined
group System-Hardware
interval 300
room SYSTEM
wie kommt es dazu?
Wie kann ich es korrigieren?
Zitatwie kommt es dazu?
Keine Ahnung, aus dem Modul OWMULTI kommt das garantiert nicht.
ZitatWie kann ich es korrigieren?
Auch das kann ich nicht beantworten, denn es fehlt jede Art von Information darüber, wie sich "einige" Sensoren von "anderen" Sensoren unterscheiden.
pah
Ja dafür müsste ich mal alle 1wire devices überprüfen. Möglich dass es auch alle sind. Kuck ich mir wenn ich zuhause bin genauer an und poste hier wieder.
Gesendet von meinem S3_32 mit Tapatalk
Guten Morgen,
Habe jetzt alle 1wire devices überprüft.
Es ist ein OWMULTI uznd ein OWTHERM die den Interval ignorieren.
Beide bilden zusammen meinen Aussenfühler Temp/Feuchte.
Bin jetzt auch mal durch die Plots, begonnen hat das ganze am 18.06.2017 kurz vor 23:00
Kann das ein Kabelproblem sein?
Werd mir das auf jeden Fall noch genauer anschauen.
Irgend etwas auf das ich speziell achten sollte?
EDIT:
eine zweite FHEM Instanz hat zur gleichen Zeit angefangen zu häufig Werte zu liefern.
KG und EG zeigen das Problem, OG und DG machen alles korrekt.
Der Aussenfühler hängt am PI KG, ist aber physikalisch eher auf EG Höhe.
könnte das irgendwie Funktechnisch bedingt sein dass da irgend etwas reinstört?
In den Logfiles sehe ich keine Auffälligkeiten.
Habe zu der Zeit auch nichts am Setup geändert.
Habe ungefähr zu der Uhrzeit ein Tablet ans Ladegerät gesteckt und bin zu Bett.
Bin jetzt noch ratloser als zuvor. Muss heute Abend mal experimentieren. (Tablet vom Strom nehmen, CUL abschalten etc und beobachten.)
Morgen,
Ich kann es nicht erklären, aber als ich das Tablet vom Ladegerät genommen hab war der Spuk zuende.
Ich werd das beim nächsten Ladevorgang nochmal beobachten und/oder das Ladegerät wechseln.
Frank
