Max with dummy sensor from MQTT
Begonnen von RobinC, 22 Januar 2025, 21:00:30
RobinC
I have several Max rad valves working with FHEM. In two rooms the valves are remote, not in the room. I made this work by using a setpoint of 30°C when I wanted them on.
To improve this I have got some Bluetooth sensors which I have connected to FHEM via MQTT. Is it possible to use the readings from these with the valves?
Beta-User
RobinC
Thankyou,
It's easy to forget about language as my browser translates everything for me.
I've now got something like this (from Wzut via a forum post I found).
My biggest challenge was trying to understand the MQQT2_DEVICE.
I'm now waiting for my CUL queue to clear so I can see if it's all behaving.
