Revision 28889: 49_SSCAM: NOTE! set enable/disable renamed to enableCam/disableCam, ...
Begonnen von System, 19 Mai 2024, 23:21:09
System
49_SSCAM: NOTE! set enable/disable renamed to enableCam/disableCam, switch commandref to ID tags
Source: Revision 28889: 49_SSCAM: NOTE! set enable/disable renamed to enableCam/disableCam, ...
