Keine Readings über Nacht?
Begonnen von petjek, 03 März 2016, 13:04:20
petjek
Ich betreibe in Wohn- und Badezimmer Heizkörperthermostate. Die Steuerung funktioniert über einen zum CUN umgeflashten CUBE. Soweit ist alles prima.
Allerdings habe ich beim Thermostat im Bad (Heizkörperthermostat+) einen seltsamen Effekt bei den Readings und damit verbunden bei den Plots.
Anbei ein Auszug aus dem Logfile.
2016-03-01_15:25:50 MAX_0f5cfa mode: auto
2016-03-01_15:25:50 MAX_0f5cfa battery: ok
2016-03-01_15:25:50 MAX_0f5cfa desiredTemperature: 17.0
2016-03-01_15:25:50 MAX_0f5cfa valveposition: 0
2016-03-01_15:25:50 MAX_0f5cfa 17.0 °C
2016-03-01_15:25:50 MAX_0f5cfa RSSI: -52
2016-03-01_21:25:51 MAX_0f5cfa mode: auto
2016-03-01_21:25:51 MAX_0f5cfa battery: ok
2016-03-01_21:25:51 MAX_0f5cfa desiredTemperature: 17.0
2016-03-01_21:25:51 MAX_0f5cfa valveposition: 0
2016-03-01_21:25:51 MAX_0f5cfa 17.0 °C
2016-03-01_21:25:51 MAX_0f5cfa RSSI: -51.5
2016-03-02_03:25:51 MAX_0f5cfa mode: auto
2016-03-02_03:25:51 MAX_0f5cfa battery: ok
2016-03-02_03:25:51 MAX_0f5cfa desiredTemperature: 17.0
2016-03-02_03:25:51 MAX_0f5cfa valveposition: 0
2016-03-02_03:25:51 MAX_0f5cfa 17.0 °C
2016-03-02_03:25:51 MAX_0f5cfa RSSI: -53.5
2016-03-02_06:00:12 MAX_0f5cfa mode: auto
2016-03-02_06:00:12 MAX_0f5cfa battery: ok
2016-03-02_06:00:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_06:00:12 MAX_0f5cfa temperature: 18.7
2016-03-02_06:00:12 MAX_0f5cfa valveposition: 83
2016-03-02_06:00:12 MAX_0f5cfa 21.0 °C
2016-03-02_06:00:12 MAX_0f5cfa RSSI: -53.5
2016-03-02_06:36:11 MAX_0f5cfa mode: auto
2016-03-02_06:36:11 MAX_0f5cfa battery: ok
2016-03-02_06:36:11 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_06:36:11 MAX_0f5cfa temperature: 21.7
2016-03-02_06:36:11 MAX_0f5cfa valveposition: 36
2016-03-02_06:36:11 MAX_0f5cfa 21.0 °C
2016-03-02_06:36:11 MAX_0f5cfa RSSI: -54
2016-03-02_06:45:12 MAX_0f5cfa mode: auto
2016-03-02_06:45:12 MAX_0f5cfa battery: ok
2016-03-02_06:45:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_06:45:12 MAX_0f5cfa temperature: 22.6
2016-03-02_06:45:12 MAX_0f5cfa valveposition: 29
2016-03-02_06:45:12 MAX_0f5cfa 21.0 °C
2016-03-02_06:45:12 MAX_0f5cfa RSSI: -57.5
2016-03-02_06:48:12 MAX_0f5cfa mode: auto
2016-03-02_06:48:12 MAX_0f5cfa battery: ok
2016-03-02_06:48:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_06:48:12 MAX_0f5cfa temperature: 22.6
2016-03-02_06:48:12 MAX_0f5cfa valveposition: 26
2016-03-02_06:48:12 MAX_0f5cfa 21.0 °C
2016-03-02_06:48:12 MAX_0f5cfa RSSI: -54.5
2016-03-02_06:51:12 MAX_0f5cfa mode: auto
2016-03-02_06:51:12 MAX_0f5cfa battery: ok
2016-03-02_06:51:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_06:51:12 MAX_0f5cfa temperature: 23.0
2016-03-02_06:51:12 MAX_0f5cfa valveposition: 23
2016-03-02_06:51:12 MAX_0f5cfa 21.0 °C
2016-03-02_06:51:12 MAX_0f5cfa RSSI: -53.5
2016-03-02_06:57:12 MAX_0f5cfa mode: auto
2016-03-02_06:57:12 MAX_0f5cfa battery: ok
2016-03-02_06:57:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_06:57:12 MAX_0f5cfa temperature: 23.3
2016-03-02_06:57:12 MAX_0f5cfa valveposition: 19
2016-03-02_06:57:12 MAX_0f5cfa 21.0 °C
2016-03-02_06:57:12 MAX_0f5cfa RSSI: -53.5
2016-03-02_07:15:12 MAX_0f5cfa mode: auto
2016-03-02_07:15:12 MAX_0f5cfa battery: ok
2016-03-02_07:15:12 MAX_0f5cfa desiredTemperature: 12.0
2016-03-02_07:15:12 MAX_0f5cfa temperature: 22.5
2016-03-02_07:15:12 MAX_0f5cfa valveposition: 0
2016-03-02_07:15:12 MAX_0f5cfa 12.0 °C
2016-03-02_07:15:12 MAX_0f5cfa RSSI: -53.5
2016-03-02_07:21:12 MAX_0f5cfa mode: auto
2016-03-02_07:21:12 MAX_0f5cfa battery: ok
2016-03-02_07:21:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_07:21:12 MAX_0f5cfa temperature: 21.5
2016-03-02_07:21:12 MAX_0f5cfa valveposition: 26
2016-03-02_07:21:12 MAX_0f5cfa 21.0 °C
2016-03-02_07:21:12 MAX_0f5cfa RSSI: -52.5
2016-03-02_07:27:12 MAX_0f5cfa mode: auto
2016-03-02_07:27:12 MAX_0f5cfa battery: ok
2016-03-02_07:27:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_07:27:12 MAX_0f5cfa temperature: 21.3
2016-03-02_07:27:12 MAX_0f5cfa valveposition: 32
2016-03-02_07:27:12 MAX_0f5cfa 21.0 °C
2016-03-02_07:27:12 MAX_0f5cfa RSSI: -51.5
2016-03-02_07:57:12 MAX_0f5cfa mode: auto
2016-03-02_07:57:12 MAX_0f5cfa battery: ok
2016-03-02_07:57:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_07:57:12 MAX_0f5cfa temperature: 21.1
2016-03-02_07:57:12 MAX_0f5cfa valveposition: 38
2016-03-02_07:57:12 MAX_0f5cfa 21.0 °C
2016-03-02_07:57:12 MAX_0f5cfa RSSI: -49.5
2016-03-02_08:21:12 MAX_0f5cfa mode: auto
2016-03-02_08:21:12 MAX_0f5cfa battery: ok
2016-03-02_08:21:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_08:21:12 MAX_0f5cfa temperature: 22.2
2016-03-02_08:21:12 MAX_0f5cfa valveposition: 32
2016-03-02_08:21:12 MAX_0f5cfa 21.0 °C
2016-03-02_08:21:12 MAX_0f5cfa RSSI: -50
2016-03-02_08:30:12 MAX_0f5cfa mode: auto
2016-03-02_08:30:12 MAX_0f5cfa battery: ok
2016-03-02_08:30:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_08:30:12 MAX_0f5cfa temperature: 22.6
2016-03-02_08:30:12 MAX_0f5cfa valveposition: 26
2016-03-02_08:30:12 MAX_0f5cfa 21.0 °C
2016-03-02_08:30:12 MAX_0f5cfa RSSI: -50
2016-03-02_08:33:12 MAX_0f5cfa mode: auto
2016-03-02_08:33:12 MAX_0f5cfa battery: ok
2016-03-02_08:33:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_08:33:12 MAX_0f5cfa temperature: 22.6
2016-03-02_08:33:12 MAX_0f5cfa valveposition: 23
2016-03-02_08:33:12 MAX_0f5cfa 21.0 °C
2016-03-02_08:33:12 MAX_0f5cfa RSSI: -50
2016-03-02_08:54:12 MAX_0f5cfa mode: auto
2016-03-02_08:54:12 MAX_0f5cfa battery: ok
2016-03-02_08:54:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_08:54:12 MAX_0f5cfa temperature: 23.1
2016-03-02_08:54:12 MAX_0f5cfa valveposition: 19
2016-03-02_08:54:12 MAX_0f5cfa 21.0 °C
2016-03-02_08:54:12 MAX_0f5cfa RSSI: -50
2016-03-02_09:18:12 MAX_0f5cfa mode: auto
2016-03-02_09:18:12 MAX_0f5cfa battery: ok
2016-03-02_09:18:12 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_09:18:12 MAX_0f5cfa temperature: 23.4
2016-03-02_09:18:12 MAX_0f5cfa valveposition: 15
2016-03-02_09:18:12 MAX_0f5cfa 21.0 °C
2016-03-02_09:18:12 MAX_0f5cfa RSSI: -50
2016-03-02_09:25:51 MAX_0f5cfa mode: auto
2016-03-02_09:25:51 MAX_0f5cfa battery: ok
2016-03-02_09:25:51 MAX_0f5cfa desiredTemperature: 21.0
2016-03-02_09:25:51 MAX_0f5cfa valveposition: 15
2016-03-02_09:25:51 MAX_0f5cfa 21.0 °C
2016-03-02_09:25:51 MAX_0f5cfa RSSI: -49
2016-03-02_10:00:11 MAX_0f5cfa mode: auto
2016-03-02_10:00:11 MAX_0f5cfa battery: ok
2016-03-02_10:00:11 MAX_0f5cfa desiredTemperature: 17.0
2016-03-02_10:00:11 MAX_0f5cfa temperature: 23.1
2016-03-02_10:00:11 MAX_0f5cfa valveposition: 0
2016-03-02_10:00:11 MAX_0f5cfa 17.0 °C
2016-03-02_10:00:11 MAX_0f5cfa RSSI: -52.5
2016-03-02_12:00:11 MAX_0f5cfa mode: auto
2016-03-02_12:00:11 MAX_0f5cfa battery: ok
2016-03-02_12:00:11 MAX_0f5cfa desiredTemperature: 17.0
2016-03-02_12:00:11 MAX_0f5cfa temperature: 20.7
2016-03-02_12:00:11 MAX_0f5cfa valveposition: 0
2016-03-02_12:00:11 MAX_0f5cfa 17.0 °C
2016-03-02_12:00:11 MAX_0f5cfa RSSI: -50.5
2016-03-02_15:12:11 MAX_0f5cfa mode: auto
2016-03-02_15:12:11 MAX_0f5cfa battery: ok
2016-03-02_15:12:11 MAX_0f5cfa desiredTemperature: 12.0
2016-03-02_15:12:11 MAX_0f5cfa temperature: 19.5
2016-03-02_15:12:11 MAX_0f5cfa valveposition: 0
2016-03-02_15:12:11 MAX_0f5cfa 12.0 °C
2016-03-02_15:12:11 MAX_0f5cfa RSSI: -52
2016-03-02_15:38:14 MAX_0f5cfa mode: auto
2016-03-02_15:38:14 MAX_0f5cfa battery: ok
2016-03-02_15:38:14 MAX_0f5cfa desiredTemperature: 12.0
2016-03-02_15:38:14 MAX_0f5cfa valveposition: 0
2016-03-02_15:38:14 MAX_0f5cfa 12.0 °C
2016-03-02_15:38:14 MAX_0f5cfa RSSI: -52.5
2016-03-02_16:30:11 MAX_0f5cfa mode: auto
2016-03-02_16:30:11 MAX_0f5cfa battery: ok
2016-03-02_16:30:11 MAX_0f5cfa desiredTemperature: 17.0
2016-03-02_16:30:11 MAX_0f5cfa temperature: 18.2
2016-03-02_16:30:11 MAX_0f5cfa valveposition: 11
2016-03-02_16:30:11 MAX_0f5cfa 17.0 °C
2016-03-02_16:30:11 MAX_0f5cfa RSSI: -52
2016-03-02_16:48:11 MAX_0f5cfa mode: auto
2016-03-02_16:48:11 MAX_0f5cfa battery: ok
2016-03-02_16:48:11 MAX_0f5cfa desiredTemperature: 17.0
2016-03-02_16:48:11 MAX_0f5cfa temperature: 19.7
2016-03-02_16:48:11 MAX_0f5cfa valveposition: 3
2016-03-02_16:48:11 MAX_0f5cfa 17.0 °C
2016-03-02_16:48:11 MAX_0f5cfa RSSI: -52
2016-03-02_16:54:12 MAX_0f5cfa mode: auto
2016-03-02_16:54:12 MAX_0f5cfa battery: ok
2016-03-02_16:54:12 MAX_0f5cfa desiredTemperature: 17.0
2016-03-02_16:54:12 MAX_0f5cfa temperature: 20.3
2016-03-02_16:54:12 MAX_0f5cfa valveposition: 0
2016-03-02_16:54:12 MAX_0f5cfa 17.0 °C
2016-03-02_16:54:12 MAX_0f5cfa RSSI: -52
2016-03-02_21:11:01 MAX_0f5cfa mode: auto
2016-03-02_21:11:01 MAX_0f5cfa battery: ok
2016-03-02_21:11:01 MAX_0f5cfa desiredTemperature: 17.0
2016-03-02_21:11:01 MAX_0f5cfa valveposition: 0
2016-03-02_21:11:01 MAX_0f5cfa 17.0 °C
2016-03-02_21:11:01 MAX_0f5cfa RSSI: -53
2016-03-03_03:11:01 MAX_0f5cfa mode: auto
2016-03-03_03:11:01 MAX_0f5cfa battery: ok
2016-03-03_03:11:01 MAX_0f5cfa desiredTemperature: 17.0
2016-03-03_03:11:01 MAX_0f5cfa valveposition: 0
2016-03-03_03:11:01 MAX_0f5cfa 17.0 °C
2016-03-03_03:11:01 MAX_0f5cfa RSSI: -53.5
2016-03-03_06:00:10 MAX_0f5cfa mode: auto
2016-03-03_06:00:10 MAX_0f5cfa battery: ok
2016-03-03_06:00:10 MAX_0f5cfa desiredTemperature: 21.0
Wie man sieht kommen hier ab ca. 21 Uhr keine Readings mehr an. Erst am nächsten Tag geht es gegen 3 Uhr weiter. Der Zeitraum variiert von Tag zu Tag um eine halbe Stunde +/-.
Auch erkennt man, das in den Morgenstunden deutlich häufiger Daten weggeschrieben werden. Danach nur noch zwischendurch und das auch nach keinem für mich erkennbaren Muster.
In den Plots sieht das dann so aus:
(http://content.screencast.com/users/petjek/folders/Snagit/media/02c2781c-1a88-4f49-93dc-53ebecc9bb95/2016-03-03_12-50-12.png)
Beim Wandthermostat im Wohnzimmer ist alles OK, da kommen die Werte rund um die Uhr zuverlässig an. Vor allem kommen von dort auch deutlich mehr Daten.
Woran kann das liegen?
petjek
Die Möglichkeiten der deutschen Grammatik können einen, wenn man sich darauf, was man ruhig, wenn man möchte, sollte, einlässt, überraschen.
petjek
OK, vielleicht sollte ich mich mit dem MAX! Temperatur-Scanner mal auseinandersetzen. ;) Sorry!
LG,
petjek
