PID20 how to use the right value
Begonnen von kroonen, 18 August 2015, 20:56:29
kroonen
I want to use my esp8266 for my pid20.
I only use one reading that looks like this
state    T: 20.5 H: 60     2015-08-18 20:46:46
Now I used it before with oregon, and there was a value of temperature with only the temperature
define thermostaat_slaapkamer PID20 Slaapkamertemp:temperature thermostaat_slaap:valve
Can i define it right to get only the temp? something like this?
define thermostaat_slaapkamer PID20 Slaapkamertemp:state.T: thermostaat_slaap:valve
regards Richard
frank
hi kroonen,
you can make a new reading temperature with the attribute userReadings
attr Slaapkamertemp userReadings temperature {my (undef,$temp,undef,undef)=split(' ',ReadingsVal($name,"state",0));return $temp}
and take this to your old definition of pid20.
FHEM: 6.0(SVN) => Pi3(buster)
kroonen
Thanx for the reply. I only cut and paste this
configfile: Unknown command return, try help
is there a additional perl package for required?
regards Richard
frank
Zitatconfigfile: Unknown command return, try help
i have tried the code with my fhem on my router fritzbox with a minimal perl lib.
i think you directly copy the code in your fhem.cfg. that is the wrong way. you should try the attribute-edit-section in the details window.
kroonen
Well after putting it in the web config it went ok.
Thnx for the solution
regards Richard
