Sensors advice
Begonnen von egesia, 23 August 2015, 01:51:15
egesia
Hello,
I would like to expand my fhem system running in a sport club.
I'm using RFX, FHT and FS20 protocols and got a good wifi coverage.
I need to monitor:
- air pressure inside an airdome (pressostatic tennis court)
- heat water tank temp and level
- a pulse gas meter
Do you have any suggestion on sensors and protocols?
Thanks!
fruit
Second attempt, the internet broke!
A difficult question, there are so many possibilities!
I monitor temperatures and pressure with 1-wire but also have several panStamp temperature and humidty sensors.
For gas and electricity I use panStamps.
There used to be RFX meter sensors (for gas/electricity) but I'm not sure they are still available.
I don't have FHT or FS20 so cannot help with them.
Feel free to follow up in German if you prefer
egesia
Thank you for your answer!
Could you explain your setup (devices, gateway, code, arduino?) for panStamp monitoring gas and electricity ?
fruit
Rather than duplicating everything here see http://www.ply.me.uk/bits_and_pieces/panStamp.html
When I started with panStamps I put up that page which should be step-by-step as it detailed my experiences - but note that the NRGs I used are no longer current, I think they are at NRG 1.1 now, should still work of course.
egesia
Thank you very much. Grat tutorial!
