[gelöst] Fritzbox Problem
Begonnen von matze1999, 19 Januar 2024, 18:57:05
matze1999
heute hatte ich plötzlich folgende Fehlermeldungen im Log
2024.01.19 07:28:12 1: PERL WARNING: Use of uninitialized value $avmModel in pattern match (m//) at ./FHEM/72_FRITZBOX.pm line 8717.
2024.01.19 07:28:12 1: stacktrace:
2024.01.19 07:28:12 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8717)
2024.01.19 07:28:12 1:     main::FRITZBOX_open_Web_Connection  called by ./FHEM/72_FRITZBOX.pm (8753)
2024.01.19 07:28:12 1:     main::FRITZBOX_call_Lua_Query       called by ./FHEM/72_FRITZBOX.pm (2825)
2024.01.19 07:28:12 1:     main::FRITZBOX_Readout_Run_Web      called by FHEM/Blocking.pm (194)
2024.01.19 07:28:12 1:     main::BlockingStart                 called by FHEM/Blocking.pm (107)
2024.01.19 07:28:12 1:     main::BlockingCall                  called by ./FHEM/72_FRITZBOX.pm (2655)
2024.01.19 07:28:12 1:     main::FRITZBOX_Readout_Start        called by fhem.pl (3508)
2024.01.19 07:28:12 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.01.19 07:28:13 2: [FritzRepeater1 | 0000 | 128.07.15 | open_Web_Connection.8734] - SIGNIFICANT:Web connection could not be established. Please check your credentials (password, user).
2024.01.19 07:28:13 2: [FritzRepeater1 | 0000 | 128.07.15 | Readout_Response.4747] - SIGNIFICANT:Web connection could not be established
2024.01.19 07:28:13 2: [FritzRepeater4 | 0000 | 169.07.57 | open_Web_Connection.8734] - SIGNIFICANT:Web connection could not be established. Please check your credentials (password, user).
2024.01.19 07:28:13 2: [FritzRepeater4 | 0000 | 169.07.57 | Readout_Response.4747] - SIGNIFICANT:Web connection could not be established
2024.01.19 07:28:14 2: [FritzRepeater | 0000 | 263.07.57 | open_Web_Connection.8734] - SIGNIFICANT:Web connection could not be established. Please check your credentials (password, user).
2024.01.19 07:28:14 2: [FritzRepeater | 0000 | 263.07.57 | Readout_Response.4747] - SIGNIFICANT:Web connection could not be established
2024.01.19 07:33:12 2: [FritzRepeater | 0000 | 263.07.57 | Readout_Start.2598] - SIGNIFICANT:stopped while to many authentication errors
2024.01.19 07:33:12 2: [FritzRepeater4 | 0000 | 169.07.57 | Readout_Start.2598] - SIGNIFICANT:stopped while to many authentication errors
2024.01.19 07:33:12 2: [FritzRepeater1 | 0000 | 128.07.15 | Readout_Start.2598] - SIGNIFICANT:stopped while to many authentication errors
Bei den drei Repeatern war der admin abgeschaltet und ein username angelegt, seit Jahren.
Nachdem ich wieder auf die Anmeldung nur mit Kennwort zurück bin, ist der Fehler weg. Nur der FRITZ!WLAN Repeater 450E zeigt jetzt im Status jetzt
undefined situation.
Alles nach dem letzten update:
72_FRITZBOX.pm             28384 2024-01-15 06:50:49Z jowiemann
Was ist hier los?
matze1999
JoWiemann
Hallo matze,
ich hatte ja hier geschrieben: https://forum.fhem.de/index.php?topic=136517.0, dass ich einiges im Modul umgestellt habe um es wartbarer zu machen. Nachdem sich keiner gemeldet hatte, bin ich davon ausgegangen, dass soweit alles ok ist. Nun ja, so ist das.
Deine Beschreibung hilft auf jeden Fall weiter. Dein Problem mit dem Repeater FRITZ!WLAN Repeater 450E ist auch schon hier adressiert:https://forum.fhem.de/index.php?topic=136718.0. Ich bräuchte hier ein List des Device mit der letzten funktionierenden Version des FRITZOX Moduls.
Grüße und Danke
Jörg
PS: Bitte verschieb den Post in das richtige Board. Also FritzBox. Danke Dir.
Jörg Wiemann
JoWiemann
Hallo Matze,
anbei eine neue Version. Bitte prüfe einmal, ob das Problem mit User/Passwort bei den Repeatern damit behoben ist.
Beim FRITZ!WLAN Repeater 450E bin ich noch am suchen.
Grüße Jörg
Jörg Wiemann
matze1999
für den 450E:
2024.01.19 19:48:19 1: PERL WARNING: Use of uninitialized value $avmModel in pattern match (m//) at ./FHEM/72_FRITZBOX.pm line 8718.
2024.01.19 19:48:19 1: stacktrace:
2024.01.19 19:48:19 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8718)
2024.01.19 19:48:19 1:     main::FRITZBOX_open_Web_Connection  called by ./FHEM/72_FRITZBOX.pm (8753)
2024.01.19 19:48:19 1:     main::FRITZBOX_call_Lua_Query       called by ./FHEM/72_FRITZBOX.pm (2825)
2024.01.19 19:48:19 1:     main::FRITZBOX_Readout_Run_Web      called by FHEM/Blocking.pm (194)
2024.01.19 19:48:19 1:     main::BlockingStart                 called by FHEM/Blocking.pm (107)
2024.01.19 19:48:19 1:     main::BlockingCall                  called by ./FHEM/72_FRITZBOX.pm (2655)
2024.01.19 19:48:19 1:     main::FRITZBOX_Readout_Start        called by ./FHEM/72_FRITZBOX.pm (2066)
2024.01.19 19:48:19 1:     main::FRITZBOX_Set                  called by fhem.pl (3980)
2024.01.19 19:48:19 1:     main::CallFn                        called by fhem.pl (1970)
2024.01.19 19:48:19 1:     main::DoSet                         called by fhem.pl (2002)
2024.01.19 19:48:19 1:     main::CommandSet                    called by fhem.pl (1282)
2024.01.19 19:48:19 1:     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2861)
2024.01.19 19:48:19 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (1025)
2024.01.19 19:48:19 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (609)
2024.01.19 19:48:19 1:     main::FW_Read                       called by fhem.pl (3985)
2024.01.19 19:48:19 1:     main::CallFn                        called by fhem.pl (786)
2024.01.19 19:48:19 2: [FritzRepeaterDD | 0000 | 174.07.57 | open_Web_Connection.8719] - SIGNIFICANT:No boxUser set. Please define it (once) with 'attr FritzRepeaterDD boxUser YourBoxUser'
2024.01.19 19:48:19 2: [FritzRepeaterDD | 0000 | 174.07.57 | Readout_Response.4747] - SIGNIFICANT:No attr boxUser set
BoxUser ist gesetzt:
defmod FritzRepeaterDD FRITZBOX 192.168.1.5
attr FritzRepeaterDD boxUser username
attr FritzRepeaterDD verbose 2
matze1999
matze1999
mit der Version bei allen Repeatern (auch die immer schon keinen usernamen hatten) das gleiche.
2400, 3000, 600
matze1999
JoWiemann
Zitat von: matze1999 am 19 Januar 2024, 19:55:05mit der Version bei allen Repeatern (auch die immer schon keinen usernamen hatten) das gleiche.
2400, 3000, 600
matze1999
Sorry, hatte noch etwas übersehen.
Grüße Jörg
Jörg Wiemann
matze1999
Repeater 3000, 2400, 600 funktionieren wieder, auch mit usernamen (nicht admin) und passwort, nur der 450E macht noch Probleme:
2024.01.19 20:48:49 1: PERL WARNING: Use of uninitialized value $user in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 8724.
2024.01.19 20:48:49 1: stacktrace:
2024.01.19 20:48:49 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8724)
2024.01.19 20:48:49 1:     main::FRITZBOX_open_Web_Connection  called by ./FHEM/72_FRITZBOX.pm (8753)
2024.01.19 20:48:49 1:     main::FRITZBOX_call_Lua_Query       called by ./FHEM/72_FRITZBOX.pm (2825)
2024.01.19 20:48:49 1:     main::FRITZBOX_Readout_Run_Web      called by FHEM/Blocking.pm (194)
2024.01.19 20:48:49 1:     main::BlockingStart                 called by FHEM/Blocking.pm (107)
2024.01.19 20:48:49 1:     main::BlockingCall                  called by ./FHEM/72_FRITZBOX.pm (2655)
2024.01.19 20:48:49 1:     main::FRITZBOX_Readout_Start        called by fhem.pl (3508)
2024.01.19 20:48:49 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.01.19 20:48:49 2: [FritzRepeater3 | 450 | 128.07.15 | Readout_Response.4762] - SIGNIFICANT:undefined situation
2024.01.19 20:48:50 2: [FritzRepeater | 450 | 128.07.15 | Readout_Response.4762] - SIGNIFICANT:undefined situation
matze1999
matze1999
Korrektur:
2400
boxUser ungleich admin, geht, aber
ich hab jetzt wieder auf admin umgestellt, und attr boxUser ist geblieben (nicht admin) trotzdem wird der repeater ohne Fehlermeldung ausgelesen.
matze
matze1999
Jetzt noch Fritzboxen; 7490, 7590, 7580 und 6850 LTE, teils mit admin, teils mit anderem Usernamen
keine Probleme, bei keiner der Versionen 72_FRITZBOX.pm
matze1999
JoWiemann
Zitat von: matze1999 am 19 Januar 2024, 20:56:40ich hab jetzt wieder auf admin umgestellt, und attr boxUser ist geblieben (nicht admin) trotzdem wird der repeater ohne Fehlermeldung ausgelesen.
Hallo Matze,
ich habe das bei den Repeatern noch nicht ausprobiert. Bei Admin wird doch kein User benötigt!? Wenn das Passwort stimmt, dann wird bei der Anmeldung der Benutzer wohl einfach ignoriert.
Ich habe in der angehängte Version das Log bei "undefined situation" erweitert.
Ich hoffe da kommen dann mehr Infos beim 450E.
Grüße Jörg
Jörg Wiemann
matze1999
jetzt das im log:
2024.01.20 09:34:26 2: [FritzRepeater | 450 | 128.07.15 | Readout_Response.4762] - SIGNIFICANT:undefined situation
$VAR1 = {};
matze1999
JoWiemann
Zitat von: matze1999 am 20 Januar 2024, 09:35:54Hallo,
jetzt das im log:
$VAR1 = {};
matze1999
Hallo matze,
da kommt vom 450E gar nichts bei einer Anfrage zurück. Ich muss mal überlegen, wie ich damit umgehe.
Grüße Jörg
Jörg Wiemann
JoWiemann
Hallo Matze,
ich habe doch noch etwas gefunden. Bitte einmal probieren. Danke Dir
Grüße Jörg
Jörg Wiemann
Nobbynews
#13
Hallo Jörg,
funktioniert!
Danke.
Norbert
matze1999
alles bestens, Danke!
matze1999
JoWiemann
Hallo Norbert, hallo Matze,
vielen Dank für die Geduld und Unterstützung. Leider muss ich gestehen, durch eine falsche Codezeile das Problem selber verursacht zu haben. Ist halt nur bisher nicht aufgefallen.
Grüße Jörg
Jörg Wiemann
Nobbynews
#16
Zitat von: JoWiemann am 21 Januar 2024, 14:10:34vielen Dank für die Geduld und Unterstützung. Leider muss ich gestehen, durch eine falsche Codezeile das Problem selber verursacht zu haben.
Kein Problem. Wer arbeitet, macht Fehler.
Noch eine ergänzende Frage:
In den letzten 3 Tagen habe ich nur mit dem Fritzbox-Modul rumgespielt.
Dabei hat es mir ggf. irgendwie die config zerbröselt und zawr dahingehend, dass ein Backup nicht mehr fehlerfrei möglich war. Das Backup-Verzeichnis wurde immer mit gesichert, was natürlich zu sehr, sehr großen Dateien geführt hat.
Kann das irgendwie mit dem Debug-Log und verbose=5 in Zusammenhang stehen?
Ich frage nur deshalb, da ich nix anderes verändert habe, zumindestens bewusst.
Norbert
JoWiemann
Zitat von: Nobbynews am 21 Januar 2024, 16:44:02Noch eine ergänzende Frage:
Norbert
Hallo Norbert,
wenn Du im FRITZBOX Modul das Attribut verbose löschst, dann wird das spezielle Log File auch gelöscht. Wenn Du nur den verbose Level < 5 setzt, dann bleibt es erhalten, wird aber nicht mehr gefüllt.
Grüße Jörg
Jörg Wiemann
Nobbynews
#18
Zitat von: JoWiemann am 21 Januar 2024, 17:19:20wenn Du im FRITZBOX Modul das Attribut verbose löschst, dann wird das spezielle Log File auch gelöscht. Wenn Du nur den verbose Level < 5 setzt, dann bleibt es erhalten, wird aber nicht mehr gefüllt.
Ok, dann gibt es hier also keine Verbindung zum backup. Hätte mich auch gewundert.
matze1999
Hallo, doch noch Probleme, alle Repeater (auch 3000, 600,, 2400, 450E) sind heute früh weg:
2024.01.21 01:56:11 2: [FritzRepeater | 600 | 263.07.57 | open_Web_Connection.8734] - SIGNIFICANT:Web connection could not be established. Please check your credentials (password, user).
2024.01.21 01:56:11 2: [FritzRepeater | 600 | 263.07.57 | Readout_Response.4747] - SIGNIFICANT:Web connection could not be established
2024.01.21 01:56:11 1: PERL WARNING: Odd number of elements in hash assignment at ./FHEM/72_FRITZBOX.pm line 4825.
2024.01.21 01:56:11 1: eval: {FRITZBOX_Readout_Done('FritzRepeater|RXJyb3J8V2ViIGNvbm5lY3Rpb24gY291bGQgbm90IGJlIGVzdGFibGlzaGVkfGZoZW0tPnNpZFRpbWV8MHxmaGVtLT5zaWRFcnJDb3VudHwyfGZoZW0tPnJhZGlvQ291bnR8MHxmaGVtLT53bGFuRGV2aWNlLT5FOF9GRF9GOF83RV8wQl82Qy0+c3BlZWR8MHxmaGVtLT53bGFuRGV2aWNlLT5FOF9GRF9GOF83RV8wQl82Qy0+c3BlZWRfcnh8MHxmaGVtLT53bGFuRGV2aWNlLT5FOF9GRF9GOF83RV8wQl82Qy0+cnNzaXwwfGZoZW0tPndsYW5EZXKpY2UtPjFDX0VEXzZGX0U2XzAzXzFDLT5zcGVlZHwxNDR8ZmhlbS0+d2xhbkRldmljZS0+MUNfRURfNkZfRTZfMDNfMUMtPnNwZWVkX3J4fDE0NHxmaGVtLT53bGFuRGV2aWNlLT4xQ19FRF82Rl9FNl8wM18xQy0+cnNzaXwtNDh8ZmhlbS0+d2xhbkRldmljZS0+RThfREJfODRfQzZfNTFfQ0ItPnNwZWVkfDB8ZmhlbS0+d2xhbkRldmljZS0+RThfREJfODRfQzZfNTFfQ0ItPnNwZWVkX3J4fDB8ZmhlbS0+d2xhbkRldmljZS0+RThfREJfODRfQzZfNTFfQ0ItPnJzc2l8MHxmaGVtLT53bGFuRGV2aWNlLT40OF8wMl8yQV81Ql9EMF9FNi0+c3BlZWR8MHxmaGVtLT53bGFuRGV2aWNlLT40OF8wMl8yQV81Ql9EMF9FNi0+c3BlZWRfcnh8MHxmaGVtLT53bGFuRGV2aWNlLT40OF8wMl8yQV81Ql9EMF9FNi0+cnNzaXwwfGZoZW0tPndsYW5EZXZpY2UtPjM4X0EyXzhDX0QzX0UxX0RFLT5zcGVlZHwwfGZoZW0tPndsYW5EZXZpY2UtPjM4X0EyXzhDX0QzX0UxX0RFLT5zcGVlZF9yeHwwfGZoZW0tPndsYW5EZXZpY2UtPjM4X0EyXzhDX0QzX0UxX0RFLT5yc3NpfDB8ZmhlbS0+d2xhbkRldmljZS0+MjJfNjNfMTJfQzRfNzlfOUEtPnNwZWVkfDB8ZmhlbS0+d2xhbkRldmljZS0+MjJfNjNfMTJfQzRfNzlfOUEtPnNwZWVkX3J4fDB8ZmhlbS0+d2xhbkRldmljZS0+MjJfNjNfMTJfQzRfNzlfOUEtPnJzc2l8MHxmaGVtLT53bGFuRGV2aWNlLT4yNF9BMV82MF8xN18zRF8wRC0+c3BlZWR8MHxmaGVtLT53bGFuRGV2aWNlLT4yNF9BMV82MF8xN18zRF8wRC0+c3BlZWRfcnh8MHxmaGVtLT53bGFuRGV2aWNlLT4yNF9BMV82MF8xN18zRF8wRC0+cnNzaXwwfGZoZW0tPndsYW5EZXZpY2UtPjdDXzg3X0NFXzlEXzlDXzM1LT5zcGVlZHwwfGZoZW0tPndsYW5EZXZpY2UtPjdDXzg3X0NFXzlEXzlDXzM1LT5zcGVlZF9yeHwwfGZoZW0tPndsYW5EZXZpY2UtPjdDXzg3X0NFXzlEXzlDXzM1LT5yc3NpfDB8ZmhlbS0+d2xhbkRldmljZS0+QzRfRERfNTdfMURfNzhfQ0ItPnNwZWVkfDB8ZmhlbS0+d2xhbkRldmljZS0+QzRfRERfNTdfMURfNzhfQ0ItPnNwZWVkX3J4fDB8ZmhlbS0+d2xhbkRldmljZS0+QzRfRERfNTdfMURfNzhfQ0ItPnJzc2l8MHxmaGVtLT53bGFuRGV2aWNlLT5DOF8yQl85Nl9DQV9BQV8zMS0+c3BlZWR8NzJ8ZmhlbS0+d2xhbkRldmljZS0+QzhfMkJfOTZfQ0FfQUFfMzEtPnNwZWVkX3J4fDE0fGZoZW0tPndsYW5EZXZpY2UtPkM4XzJCXzk2X0NBX0FBXzMxLT5yc3NpfC00NnxmaGVtLT53bGFuRGV2aWNlLT5FOF9EQl84NF84NF81MF9BQi0+c3BlZWR8Njl8ZmhlbS0+d2xhbkRldmljZS0+RThfREJfODRfODRfNTBfQUItPnNwZWVkX3J4fDEwfGZoZW0tPndsYW5EZXZpY2UtPkU4X0RCXzg0Xzg0XzUwX0FCLT5yc3NpfC01NHxmaGVtLT53bGFuRGV2aWNlLT5GNF9DRl9BMl8wMl9GQl8xQi0+c3BlZWR8NzF8ZmhlbS0+d2xhbkRldmljZS0+RjRfQ0ZfQTJfMDJfRkJfMUItPnNwZWVkX3J4fDN8ZmhlbS0+d2xhbkRldmljZS0+RjRfQ0ZfQTJfMDJfRkJfMUItPnJzc2l8LTM4fGZoZW0tPndsYW5EZXZpY2UtPkY0X0NGX0EyXzA5XzlBXzk3LT5zcGVlZHwwfGZoZW0tPndsYW5EZXZpY2UtPkY0X0NGX0EyXzA5XzlBXzk3LT5zcGVlZF9yeHwwfGZoZW0tPndsYW5EZXZpY2UtPkY0X0NGX0EyXzA5XzlBXzk3LT5yc3NpfDB8ZmhlbS0+d2xhbkRldmljZS0+ODRfRjNfRUJfM0VfNkRfQ0EtPnNwZWVkfDB8ZmhlbS0+d2xhbkRldmljZS0+ODRfRjNfRUJfM0VfNkRfQ0EtPnNwZWVkX3J4fDB8ZmhlbS0+d2xhbkRldmljZS0+ODRfRjNfRUJfM0VfNkRfQ0EtPnJzc2l8MHxmaGVtLT53bGFuRGV2aWNlLT5FQ185NF9DQl84N19FOF8zNC0+c3BlZWR8NzJ8ZmhlbS0+d2xhbkRldmljZS0+RUNfOTRfQ0JfODdfRThfMzQtPnNwZWVkX3J4fDh8ZmhlbS0+d2xhbkRldmljZS0+RUNfOTRfQ0JfODdfRThfMzQtPnJzc2l8LTU0fGZoZW0tPndsYW5EZXZpY2UtPkM4XzJCXzk2X0NBXzcyXzU4LT5zcGVlZHw3MnxmaGVtLT53bGFuRGV2aWNlLT5DOF8yQl85Nl9DQV83Ml81OC0+c3BlZWRfcnh8MTN8ZmhlbS0+d2xhbkRldmljZS0+QzhfMkJfOTZfQ0FfNzJfNTgtPnJzc2l8LTM5fGZoZW0tPndsYW5EZXZpY2UtPjhDX0FBX0I1XzVGX0JGXzg0LT5zcGVlZHwwfGZoZW0tPndsYW5EZXZpY2UtPjhDX0FBX0I1XzVGX0JGXzg0LT5zcGVlZF9yeHwwfGZoZW0tPndsYW5EZXZpY2UtPjhDX0FBX0I1XzVGX0JGXzg0LT5yc3NpfDB8ZmhlbS0+d2xhbkRldmljZS0+NDhfM0ZfREFfQUFfQzNfNTUtPnNwZWVkfDB8ZmhlbS0+d2xhbkRldmljZS0+NDhfM0ZfREFfQUFfQzNfNTUtPnNwZWVkX3J4fDB8ZmhlbS0+d2xhbkRldmljZS0+NDhfM0ZfREFfQUFfQzNfNTUtPnJzc2l8MHxmaGVtLT53bGFuRGV2aWNlLT4yNF83N18wM18yMl81M183NC0+c3BlZWR8MHxmaGVtLT53bGFuRGV2aWNlLT4yNF83N18wM18yMl81M183NC0+c3BlZWRfcnh8MHxmaGVtLT53bGFuRGV2aWNlLT4yNF83N18wM18yMl81M183NC0+cnNzaXwwfGZoZW0tPndsYW5EZXZpY2UtPkM0X0RFX0UyX0Q2X0IxXzg0LT5zcGVlZHwwfGZoZW0tPndsYW5EZXZpY2UtPkM0X0RFX0UyX0Q2X0IxXzg0LT5zcGVlZF9yeHwwfGZoZW0tPndsYW5EZXZpY2UtPkM0X0RFX0UyX0Q2X0IxXzg0LT5yc3NpfDB8ZmhlbS0+d2xhbkRldmljZS0+QzRfNUJfQkVfNTRfQTJfMTItPnNwZWVkfDB8ZmhlbS0+d2xhbkRldmljZS0+QzRfNUJfQkVfNTRfQTJfMTItPnNwZWVkX3J4fDB8ZmhlbS0+d2xhbkRldmljZS0+QzRfNUJfQkVfNTRfQTJfMTItPnJzc2l8MHxmaGVtLT53bGFuRGV2aWNlLT43MF8wM185Rl82Ml81Q18wOC0+c3BlZWR8MHxmaGVtLT53bGFuRGV2aWNlLT43MF8wM185Rl82Ml81Q18wOC0+c3BlZWRfcnh8MHxmaGVtLT53bGFuRGV2aWNlLT43MF8wM185Rl82Ml81Q18wOC0+cnNzaXwwfGZoZW0tPndsYW5EZXZpY2UtPjRDX0VCX0Q2X0M2XzVDXzIwLT5zcGVlZHwwfGZoZW0tPndsYW5EZXZpY2UtPjRDX0VCX0Q2X0M2XzVDXzIwLT5zcGVlZF9yeHwwfGZoZW0tPndsYW5EZXZpY2UtPjRDX0VCX0Q2X0M2XzVDXzIwLT5yc3NpfDB8ZmhlbS0+d2xhbkRldmljZS0+ODRfRjNfRUJfREFfNjNfNTItPnNwZWVkfDcxfGZoZW0tPndsYW5EZXZpY2UtPjg0X0YzX0VCX0RBXzYzXzUyLT5zcGVlZF9yeHw3fGZoZW0tPndsYW5EZXZpY2UtPjg0X0YzX0VCX0RBXzYzXzUyLT5yc3NpfC0yNnxmaGVtLT53bGFuRGV2aWNlLT4wOF9CRV9BQ18wN18yRV85Mi0+c3BlZWR8MHxmaGVtLT53bGFuRGV2aWNlLT4wOF9CRV9BQ18wN18yRV85Mi0+c3BlZWRfcnh8MHxmaGVtLT53bGFuRGV2aWNlLT4wOF9CRV9BQ18wN18yRV85Mi0+cnNzaXwwfGZoZW0tPndsYW5EZXZpY2UtPjRDX0VCX0Q2X0RDX0VCXzQzLT5zcGVlZHwwfGZoZW0tPndsYW5EZXZpY2UtPjRDX0VCX0Q2X0RDX0VCXzQzLT5zcGVlZF9yeHwwfGZoZW0tPndsYW5EZXZpY2UtPjRDX0VCX0Q2X0RDX0VCXzQzLT5yc3NpfDB8ZmhlbS0+d2xhbkRldmljZS0+NzBfMDNfOUZfOEZfQkRfQzAtPnNwZWVkfDcyfGZoZW0tPndsYW5EZXZpY2UtPjcwXzAzXzlGXzhGX0JEX0MwLT5zcGVlZF9yeHw2fGZoZW0tPndsYW5EZXZpY2UtPjcwXzAzXzlGXzhGX0JEX0MwLT5yc3NpfC00MnxmaGVtLT53bGFuRGV2aWNlLT5DNF9ERF81N18wQl9BRF9DMC0+c3BlZWR8MHxmaGVtLT53bGFuRGV2aWNlLT5DNF9ERF81N18wQl9BRF9DMC0+c3BlZWRfcnh8MHxmaGVtLT53bGFuRGV2aWNlLT5DNF9ERF81N18wQl9BRF9DMC0+cnNzaXwwfGZoZW0tPndsYW5EZXZpY2UtPkM4XzJCXzk2X0M5X0U2XzFGLT5zcGVlZHwwfGZoZW0tPndsYW5EZXZpY2UtPkM4XzJCXzk2X0M5X0U2XzFGLT5zcGVlZF9yeHwwfGZoZW0tPndsYW5EZXZpY2UtPkM4XzJCXzk2X0M5X0U2XzFGLT5yc3NpfDB8ZmhlbS0+d2xhbkRldmljZS0+N0NfODdfQ0VfOURfMDVfQzAtPnNwZWVkfDcyfGZoZW0tPndsYW5EZXZpY2UtPjdDXzg3X0NFXzlEXzA1X0MwLT5zcGVlZF9yeHw4fGZoZW0tPndsYW5EZXZpY2UtPjdDXzg3X0NFXzlEXzA1X0MwLT5yc3NpfC00MXxmaGVtLT5sYW5kZXZpY2UtPjE5Mi4xNjguMi4xfEJhc2lzc3RhdGlvbnxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTI0NXxCYXNpc3N0YXRpb258ZmhlbS0+bGFuZGV2aWNlLT4xQ19FRF82Rl9FNl8wM18xOXxsYW5kZXZpY2UyNDV8bWFjXzFDX0VEXzZGX0U2XzAzXzE5fEJhc2lzc3RhdGlvbiBbbGFuZGV2aWNlMjQ1XSAoMTQ0IE1iaXQvcyl8ZmhlbS0+bGFuZGV2aWNlLT4xOTIuMTY4LjIuMzd8RFZFUy0wMkZCMUItNjkzfGZoZW0tPmxhbmRldmljZS0+bGFuZGV2aWNlMjMxfERWRVMtMDJGQjFCLTY5M3xmaGVtLT5sYW5kZXZpY2UtPkY0X0NGX0EyXzAyX0ZCXzFCfGxhbmRldmljZTIzMXxtYWNfRjRfQ0ZfQTJfMDJfRkJfMUJ8RFZFUy0wMkZCMUItNjkzIFtsYW5kZXZpY2UyMzFdIChXTEFOOiA3MSAvIDMgTWJpdC9zLCBSU1NJOiAtMzgpfGZoZW0tPmxhbmRldmljZS0+MTkyLjE2OC4yLjQ0fERWRVMtOEZCREMwLTc2MXxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIxNnxEVkVTLThGQkRDMC03NjF8ZmhlbS0+bGFuZGV2aWNlLT43MF8wM185Rl84Rl9CRF9DMHxsYW5kZXZpY2UyMTZ8bWFjXzcwXzAzXzlGXzhGX0JEX0MwfERWRVMtOEZCREMwLTc2MSBbbGFuZGV2aWNlMjE2XSAoV0xBTjogNzIgLyA2IE1iaXQvcywgUlNTSTogLTQyKXxmaGVtLT5sYW5kZXZpY2UtPnxQQy0wOC1CRS1BQy0wNy0yRS05MnxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIxOHxQQy0wOC1CRS1BQy0wNy0yRS05MnxmaGVtLT5sYW5kZXZpY2UtPjE5Mi4xNjguMi4xMnxQQy0xOTItMTY4LTItMTJ8ZmhlbS0+bGFuZGV2aWNlLT5sYW5kZXZpY2UyNDd8UEMtMTkyLTE2OC0yLTEyfGZoZW0tPmxhbmRldmljZS0+MTkyLjE2OC4yLjE3fFBDLTE5Mi0xNjgtMi0xN3xmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTI0OHxQQy0xOTItMTY4LTItMTd8ZmhlbS0+bGFuZGV2aWNlLT4xOTIuMTY4LjIuOHxQQy0xOTItMTY4LTItOHxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTI0NnxQQy0xOTItMTY4LTItOHxmaGVtLT5sYW5kZXZpY2UtPnxQQy0yMi02My0xMi1DNC03OS05QXxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIzN3xQQy0yMi02My0xMi1DNC03OS05QXxmaGVtLT5sYW5kZXZpY2UtPnxQQy0yNC03Ny0wMy0yMi01My03NHxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIyNHxQQy0yNC03Ny0wMy0yMi01My03NHxmaGVtLT5sYW5kZXZpY2UtPnxQQy0yNC1BMS02MC0xNy0zRC0wRHxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIzNnxQQy0yNC1BMS02MC0xNy0zRC0wRHxmaGVtLT5sYW5kZXZpY2UtPnxQQy0zOC1BMi04Qy1EMy1FMS1ERXxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIzOHxQQy0zOC1BMi04Qy1EMy1FMS1ERXxmaGVtLT5sYW5kZXZpY2UtPnxQQy00OC0wMi0yQS01Qi1EMC1FNnxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIzOXxQQy00OC0wMi0yQS01Qi1EMC1FNnxmaGVtLT5sYW5kZXZpY2UtPnxQQy00OC0zRi1EQS1BQS1DMy01NXxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIyNXxQQy00OC0zRi1EQS1BQS1DMy01NXxmaGVtLT5sYW5kZXZpY2UtPnxQQy00Qy1FQi1ENi1DNi01Qy0yMHxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIyMHxQQy00Qy1FQi1ENi1DNi01Qy0yMHxmaGVtLT5sYW5kZXZpY2UtPnxQQy00Qy1FQi1ENi1EQy1FQi00M3xmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIxN3xQQy00Qy1FQi1ENi1EQy1FQi00M3xmaGVtLT5sYW5kZXZpY2UtPnxQQy03MC0wMy05Ri02Mi01Qy0wOHxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIyMXxQQy03MC0wMy05Ri02Mi01Qy0wOHxmaGVtLT5sYW5kZXZpY2UtPjE5Mi4xNjguMi40NnxQQy03Qy04Ny1DRS05RC0wNS1DMHxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIxM3xQQy03Qy04Ny1DRS05RC0wNS1DMHxmaGVtLT5sYW5kZXZpY2UtPjdDXzg3X0NFXzlEXzA1X0MwfGxhbmRldmljZTIxM3xtYWNfN0NfODdfQ0VfOURfMDVfQzB8UEMtN0MtODctQ0UtOUQtMDUtQzAgW2xhbmRldmljZTIxM10gKFdMQU46IDcyIC8gOCBNYml0L3MsIFJTU0k6IC00MSl8ZmhlbS0+bGFuZGV2aWNlLT58UEMtN0MtODctQ0UtOUQtOUMtMzV8ZmhlbS0+bGFuZGV2aWNlLT5sYW5kZXZpY2UyMzV8UEMtN0MtODctQ0UtOUQtOUMtMzV8ZmhlbS0+bGFuZGV2aWNlLT58UEMtODQtRjMtRUItM0UtNkQtQ0F8ZmhlbS0+bGFuZGV2aWNlLT5sYW5kZXZpY2UyMjl8UEMtODQtRjMtRUItM0UtNkQtQ0F8ZmhlbS0+bGFuZGV2aWNlLT4xOTIuMTY4LjIuNDJ8UEMtODQtRjMtRUItREEtNjMtNTJ8ZmhlbS0+bGFuZGV2aWNlLT5sYW5kZXZpY2UyMTl8UEMtODQtRjMtRUItREEtNjMtNTJ8ZmhlbS0+bGFuZGV2aWNlLT44NF9GM19FQl9EQV82M181MnxsYW5kZXZpY2UyMTl8bWFjXzg0X0YzX0VCX0RBXzYzXzUyfFBDLTg0LUYzLUVCLURBLTYzLTUyIFtsYW5kZXZpY2UyMTldIChXTEFOOiA3MSAvIDcgTWJpdC9zLCBSU1NJOiAtMjYpfGZoZW0tPmxhbmRldmljZS0+fFBDLThDLUFBLUI1LTVGLUJGLTg0fGZoZW0tPmxhbmRldmljZS0+bGFuZGV2aWNlMjI2fFBDLThDLUFBLUI1LTVGLUJGLTg0fGZoZW0tPmxhbmRldmljZS0+fFBDLUM0LTVCLUJFLTU0LUEyLTEyfGZoZW0tPmxhbmRldmljZS0+bGFuZGV2aWNlMjIyfFBDLUM0LTVCLUJFLTU0LUEyLTEyfGZoZW0tPmxhbmRldmljZS0+fFBDLUM0LURELTU3LTBCLUFELUMwfGZoZW0tPmxhbmRldmljZS0+bGFuZGV2aWNlMjE1fFBDLUM0LURELTU3LTBCLUFELUMwfGZoZW0tPmxhbmRldmljZS0+fFBDLUM0LURELTU3LTFELTc4LUNCfGZoZW0tPmxhbmRldmljZS0+bGFuZGV2aWNlMjM0fFBDLUM0LURELTU3LTFELTc4LUNCfGZoZW0tPmxhbmRldmljZS0+fFBDLUM0LURFLUUyLUQ2LUIxLTg0fGZoZW0tPmxhbmRldmljZS0+bGFuZGV2aWNlMjIzfFBDLUM0LURFLUUyLUQ2LUIxLTg0fGZoZW0tPmxhbmRldmljZS0+fFBDLUM4LTJCLTk2LUM5LUU2LTFGfGZoZW0tPmxhbmRldmljZS0+bGFuZGV2aWNlMjE0fFBDLUM4LTJCLTk2LUM5LUU2LTFGfGZoZW0tPmxhbmRldmljZS0+MTkyLjE2OC4yLjMyfFBDLUM4LTJCLTk2LUNBLTcyLTU4fGZoZW0tPmxhbmRldmljZS0+bGFuZGV2aWNlMjI3fFBDLUM4LTJCLTk2LUNBLTcyLTU4fGZoZW0tPmxhbmRldmljZS0+QzhfMkJfOTZfQ0FfNzJfNTh8bGFuZGV2aWNlMjI3fG1hY19DOF8yQl85Nl9DQV83Ml81OHxQQy1DOC0yQi05Ni1DQS03Mi01OCBbbGFuZGV2aWNlMjI3XSAoV0xBTjogNzIgLyAxMyBNYml0L3MsIFJTU0k6IC0zOSl8ZmhlbS0+bGFuZGV2aWNlLT4xOTIuMTY4LjIuMjV8UEMtQzgtMkItOTYtQ0EtQUEtMzF8ZmhlbS0+bGFuZGV2aWNlLT5sYW5kZXZpY2UyMzN8UEMtQzgtMkItOTYtQ0EtQUEtMzF8ZmhlbS0+bGFuZGV2aWNlLT5DOF8yQl85Nl9DQV9BQV8zMXxsYW5kZXZpY2UyMzN8bWFjX0M4XzJCXzk2X0NBX0FBXzMxfFBDLUM4LTJCLTk2LUNBLUFBLTMxIFtsYW5kZXZpY2UyMzNdIChXTEFOOiA3MiAvIDE0IE1iaXQvcywgUlNTSTogLTQ2KXxmaGVtLT5sYW5kZXZpY2UtPjE5Mi4xNjguMi4yOXxQQy1FOC1EQi04NC04NC01MC1BQnxmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIzMnxQQy1FOC1EQi04NC04NC01MC1BQnxmaGVtLT5sYW5kZXZpY2UtPkU4X0RCXzg0Xzg0XzUwX0FCfGxhbmRldmljZTIzMnxtYWNfRThfREJfODRfODRfNTBfQUJ8UEMtRTgtREItODQtODQtNTAtQUIgW2xhbmRldmljZTIzMl0gKFdMQU46IDY5IC8gMTAgTWJpdC9zLCBSU1NJOiAtNTQpfGZoZW0tPmxhbmRldmljZS0+fFBDLUU4LURCLTg0LUM2LTUxLUNCfGZoZW0tPmxhbmRldmljZS0+bGFuZGV2aWNlMjQwfFBDLUU4LURCLTg0LUM2LTUxLUNCfGZoZW0tPmxhbmRldmljZS0+MTkyLjE2OC4yLjM2fFBDLUVDLTk0LUNCLTg3LUU4LTM0fGZoZW0tPmxhbmRldmljZS0+bGFuZGV2aWNlMjI4fFBDLUVDLTk0LUNCLTg3LUU4LTM0fGZoZW0tPmxhbmRldmljZS0+RUNfOTRfQ0JfODdfRThfMzR8bGFuZGV2aWNlMjI4fG1hY19FQ185NF9DQl84N19FOF8zNHxQQy1FQy05NC1DQi04Ny1FOC0zNCBbbGFuZGV2aWNlMjI4XSAoV0xBTjogNzIgLyA4IE1iaXQvcywgUlNTSTogLTU0KXxmaGVtLT5sYW5kZXZpY2UtPnxQQy1GNC1DRi1BMi0wOS05QS05N3xmaGVtLT5sYW5kZXZpY2UtPmxhbmRldmljZTIzMHxQQy1GNC1DRi1BMi0wOS05QS05N3xmaGVtLT5sYW5kZXZpY2UtPjE5Mi4xNjguMi40fFJlcGVhdGVyfGZoZW0tPmxhbmRldmljZS0+bGFuZGV2aWNlMjEyfFJlcGVhdGVyfGZoZW0tPmxhbmRldmljZS0+MUNfRURfNkZfRTBfNzdfNkN8bGFuZGV2aWNlMjEyfG1hY18xQ19FRF82Rl9FMF83N182Q3xSZXBlYXRlciBbbGFuZGV2aWNlMjEyXSB8Ym94X3dsYW5fQ291bnR8OHxib3hfZ3Vlc3RXbGFuQ291bnR8MHxib3hfd2xhbl8yLjRHSHp8b258Ym94X3dsYW5fNUdIenxvZmZ8Ym94X2d1ZXN0V2xhbnxvZmZ8Ym94X2d1ZXN0V2xhblJlbWFpbnwwfGJveF9tYWNGaWx0ZXJfYWN0aXZlfG9mZnxib3hfZGVjdHx8Ym94X21vaHx8Ym94X3Bvd2VyUmF0ZXw3NnxmaGVtLT5pc19kb3VibGVfd2xhbnwwfGJveF91cHRpbWV8MTExOTYwIHNlYyA9IDFUIDA3OjA2OjAwfGJveF9md1ZlcnNpb258MjYzLjA3LjU3fGJveF9md1VwZGF0ZXwwfGJveF90cjA2NHxvbnxib3hfdHIwNjl8b2ZmfGJveF91cG5wfG9ufGJveF91cG5wX2NvbnRyb2xfYWN0aXZhdGVkfG9ufC0+VVBOUHwxfGJveF9zdGREaWFsUG9ydHx8Ym94X2NwdVRlbXB8MHxnc21fcnNzaXx8Z3NtX3N0YXRlfHxnc21fdGVjaG5vbG9neXx8Z3NtX2ludGVybmV0fHwuYm94X1RvZGF5Qnl0ZXNSZWNlaXZlZEhpZ2h8fC5ib3hfVG9kYXlCeXRlc1JlY2VpdmVkTG93fHwuYm94X1RvZGF5Qnl0ZXNTZW50SGlnaHx8LmJveF9Ub2RheUJ5dGVzU2VudExvd3w=')}
2024.01.21 01:56:11 1: stacktrace:
2024.01.21 01:56:11 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (4825)
2024.01.21 01:56:11 1:     main::FRITZBOX_Readout_Process      called by ./FHEM/72_FRITZBOX.pm (4810)
2024.01.21 01:56:11 1:     main::FRITZBOX_Readout_Done         called by (eval 654511) (1)
2024.01.21 01:56:11 1:     (eval)                              called by fhem.pl (1177)
2024.01.21 01:56:11 1:     main::AnalyzePerlCommand            called by fhem.pl (1206)
2024.01.21 01:56:11 1:     main::AnalyzeCommand                called by fhem.pl (1133)
2024.01.21 01:56:11 1:     main::AnalyzeCommandChain           called by ./FHEM/98_telnet.pm (263)
2024.01.21 01:56:11 1:     main::telnet_Read                   called by fhem.pl (3985)
2024.01.21 01:56:11 1:     main::CallFn                        called by fhem.pl (786)
2024.01.21 03:01:04 2: [FritzRepeater | 600 | 263.07.57 | Readout_Response.4747] - SIGNIFICANT:Device is offline
2024.01.21 03:11:04 2: [FritzRepeater | 600 | 263.07.57 | open_Web_Connection.8734] - SIGNIFICANT:Web connection could not be established. Please check your credentials (password, user).
2024.01.21 03:11:04 2: [FritzRepeater | 600 | 263.07.57 | Readout_Response.4747] - SIGNIFICANT:Web connection could not be established
2024.01.21 03:20:59 2: [FritzRepeater | 600 | 263.07.57 | Readout_Start.2598] - SIGNIFICANT:stopped while to many authentication errors
matze1999
matze1999
#20
hängt wahrscheinlich mit der Zwangstrennung zusammen, auch die als Repeater eingesetze 7490:
2024.01.21 03:31:05 2: [FritzRepeater2 | 7490 | 113.07.57 | Readout_Response.4747] - SIGNIFICANT:Device is offline
2024.01.22 04:05:52 2: [FritzRepeater2 | 7490 | 113.07.57 | Readout_Start.2598] - SIGNIFICANT:stopped while to many authentication errors
Auf den boxen sind im Log keine Fehlermeldungen bzgl. Anmeldung zu finden.
Das sind drei Standorte per VPN, da ist die offline Zeit manchmal ziemlich lang.
matze1999
JoWiemann
matze1999
Hallo Matze,
folgende Attribute sollten Dir eigentlich weiter helfen können:
reConnectInterval <seconds>
Nach Netzwerkausfall oder FritzBox Nichtverfügbarkeit. Standard ist 180 (Sekunden). Der kleinste mögliche Wert ist 55 (Sekunden)
maxSIDrenewErrCnt <5..20>
Anzahl der in Folge zulässigen Fehler beim abholen der SID von der FritzBox. Minimum ist fünf, maximum ist zwanzig. Standardwert ist 5. Wird die Anzahl überschritten, dann wird der interne Timer deaktiviert.
nonblockingTimeOut <50|75|100|125>
Timeout für das regelmäßige Holen der Daten von der Fritz!Box. Standard ist 55 (Sekunden).
Grüße Jörg
Jörg Wiemann
matze1999
hab das mal eingetragen, mal sehen wie es morgen früh aussieht.
matze1999
ch.eick
Moin zusammen,
ist die korrigierte Version jetzt wieder im normalen Update enthalten?
Ich habe ebenfalls den Fehler bei einer FRITZ!Box 7362 SL (UI) als Repeater.
2024.01.22 19:30:31.581 2: [ZentrumRepeater02 | 7362 | 131.07.14 | Readout_Response.4762] - SIGNIFICANT:undefined situation
2024.01.22 19:33:31.650 2: [ZentrumRepeater02 | 7362 | 131.07.14 | Readout_Response.4762] - SIGNIFICANT:undefined situation
VG  Christian
JoWiemann
VG  Christian
Hallo Christian,
zeigt Dir Update Check die neue Version nicht an? Ist seid heute 08:00 über Update verfügbar.
Grüße Jörg
Jörg Wiemann
JoWiemann
Hallo in die Runde,
es ist schön, dass ich hier viel Unterstützung bekomme. Ich würde mich aber auch freuen, wenn sich mehr von Euch schon bei den Betas beteiligen könnten.
Ich habe mittlerweile über Kleinanzeigen einen ziemlich großen AVM Zoo zu Hause. Aber alles Mögliche kann ich mir nicht leisten und ich kann auch nicht alle möglichen Netzwerk Topologien aufbauen und testen.
Von daher meine Bitte nicht erst mit dem Update zu testen. Würde mir zeitlichen Stress ersparen. Familie und Beruf haben halt immer noch Priorität.
Vielen lieben Dank
Jörg
Jörg Wiemann
erwin
Auf Basis des heutigen updates:
Log einer neu-definiton eine repeaters 1200:
2024.01.22 21:10:23.324 3: [CL_FritzboxR | 0000 | none | Set_check_APIs.5448] - BASIC: boxUser (bei Repeatern nicht unbedingt notwendig) nicht definiert. Bitte auch das Passwort mit <set CL_FritzboxR password> setzen.
2024.01.22 21:10:25.026 2: [CL_FritzboxR | 1200 | none | Helper_read_Password.9438] - SIGNIFICANT:No password in file
2024.01.22 21:10:25.122 2: [CL_FritzboxR | 1200 | none | Helper_read_Password.9438] - SIGNIFICANT:No password in file
2024.01.22 21:10:25.123 2: [CL_FritzboxR | 1200 | none | open_Web_Connection.8709] - SIGNIFICANT:No password set. Please define it (once) with 'set CL_FritzboxR password YourPassword'
2024.01.22 21:10:25.123 3: [CL_FritzboxR | 1200 | none | Set_check_APIs.5669] - BASIC:SID Response -> 1
2024.01.22 21:10:25.124 3: [CL_FritzboxR | 1200 | none | Set_check_APIs.5680] - BASIC:Response -> luaQuery:200 luaData:200 TR064:200 boxModelJason:200
### hier wurde set password xxx ....
2024.01.22 21:11:28.398 1: PERL WARNING: Use of uninitialized value $avmModel in pattern match (m//) at ./FHEM/72_FRITZBOX.pm line 8717.
2024.01.22 21:11:28.400 1: stacktrace:
2024.01.22 21:11:28.400 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8717)
2024.01.22 21:11:28.400 1:     main::FRITZBOX_open_Web_Connection  called by ./FHEM/72_FRITZBOX.pm (8752)
2024.01.22 21:11:28.401 1:     main::FRITZBOX_call_Lua_Query       called by ./FHEM/72_FRITZBOX.pm (2825)
2024.01.22 21:11:28.401 1:     main::FRITZBOX_Readout_Run_Web      called by FHEM/Blocking.pm (194)
2024.01.22 21:11:28.401 1:     main::BlockingStart                 called by FHEM/Blocking.pm (107)
2024.01.22 21:11:28.402 1:     main::BlockingCall                  called by ./FHEM/72_FRITZBOX.pm (2655)
2024.01.22 21:11:28.402 1:     main::FRITZBOX_Readout_Start        called by fhem.pl (3508)
2024.01.22 21:11:28.402 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.01.22 21:16:55.065 3: [CL_FritzboxR | 0000 | 172.07.57 | Set_check_APIs.5448] - BASIC: boxUser (bei Repeatern nicht unbedingt notwendig) nicht definiert. Bitte auch das Passwort mit <set CL_FritzboxR password> setzen.
2024.01.22 21:16:56.883 3: [CL_FritzboxR | 1200 | 172.07.57 | Set_check_APIs.5680] - BASIC:Response -> luaQuery:200 luaData:200 TR064:200 boxModelJason:200
2024.01.22 21:39:34.294 3: [CL_FritzboxR | 1200 | 172.07.57 | Set.2064] - BASIC:set CL_FritzboxR update
ab dann problemlos, beim nächsten update war dann auch INTERNAL MODEL und reading box_model korrekt gesetzt.
   APICHECKED 1
   APICHECK_RET_CODES Ok
   CFGFN
   DEBUGLOG   OFF
   DEF        192.168.10.29
   FUUID      65aecbae-f33f-f1ab-9d4e-83d6c6546c4016c5
   HOST       192.168.10.29
   INTERVAL   300
   LUADATA    1
   LUAQUERY   1
   MODEL      FRITZ!Repeater 1200
   NAME       CL_FritzboxR
   NR         129
   NTFY_ORDER 50-CL_FritzboxR
   SECPORT    49443
   SID_RENEW_CNT 1
   SID_RENEW_ERR_CNT 0
   STATE      WLAN: on gWLAN: off
   TIMEOUT    55
   TR064      1
   TYPE       FRITZBOX
   UPNP       1
   VERSION    07.57.10
   _BETA      0
   eventCount 23
   .attraggr:
   .attreocr:
   .attrminint:
     2024-01-22 22:39:41   box_cpuTemp     56
     2024-01-22 22:39:41   box_fwVersion   172.07.57
     2024-01-22 22:39:41   box_guestWlan   off
     2024-01-22 22:39:41   box_guestWlanCount 0
     2024-01-22 22:39:41   box_guestWlanRemain 0
     2024-01-22 22:39:41   box_macFilter_active off
     2024-01-22 21:16:56   box_model       FRITZ!Repeater 1200 [avm]
     2024-01-22 22:39:41   box_powerRate   79
     2024-01-22 22:39:41   box_sys_LogNewest 500 22.01.24 21:11:28
     2024-01-22 22:39:41   box_tr064       on
     2024-01-22 22:39:41   box_tr069       off
     2024-01-22 22:39:41   box_upnp        on
     2024-01-22 22:39:41   box_upnp_control_activated on
     2024-01-22 22:39:41   box_uptime      11655720 sec = 134T 21:42:00
     2024-01-22 22:39:41   box_wlan_2.4GHz on
     2024-01-22 22:39:41   box_wlan_5GHz   on
     2024-01-22 22:39:41   box_wlan_Count  5
     2024-01-22 22:39:41   box_wlan_LogExtended on
     2024-01-22 22:39:41   box_wlan_LogNewest 756 22.01.24 22:33:54
     2024-01-22 22:39:41   mac_......
     2024-01-22 22:39:41   retStat_lastReadout 299 values captured in 6.73 s
     2024-01-22 22:39:41   state           WLAN: on gWLAN: off
   fhem:
     LOCAL      0
     definedHost 192.168.xx.yy
     is_double_wlan 1
     radioCount 0
     sid        df9e516ee4d4577c
     sidErrCount 0
     sidNewCount 0
     sidTime    1705959581.07832
     landevice:  .....
     wlanDevice: ....
   helper:
     FhemLog3Std 0
     TimerCmd   CL_FritzboxR.Cmd
     TimerReadout CL_FritzboxR.Readout
     debugLog   CL_FritzboxR_debugLog
     logDebug
   INTERVAL   300
   deviceInfo name,connection,ipv4
weitere boxen dzt: 7590AX, 6490 Cable, beide unauffällig!
Danke für die Weiterentwicklung!!!
l.g. erwin
FHEM aktuell auf RaspberryPI Mdl 1-4
Maintainer: 00_KNXIO.pm 10_KNX.pm
User: CUNO2 (868 SLOWRF) - HMS100xx, FS20, FHT, 1-Wire  - 2401(iButton), 18x20, 2406, 2413 (AVR), 2450,..,MQTT2, KNX, SONOFF, mySENSORS,....
Hardware:  Busware ROT, Weinzierl IP731, 1-Wire GW,...
Nobbynews
Zitat von: JoWiemann am 22 Januar 2024, 20:45:10Von daher meine Bitte nicht erst mit dem Update zu testen. Würde mir zeitlichen Stress ersparen. Familie und Beruf haben halt immer noch Priorität.
Kann ich sehr gut nachvollziehen.
Ich gelobe Besserung.
Norbert
