Ich habe in meinen readings zu den Thermometern sog. statTemperatureDay (komischerweise aktualisiert dieser sich nicht) Werte.
statTemperatureDay Min: 19.3 Avg: 20.6 Max: 20.8
Dort würde ich gerne in meiner readinggroup auch diese min / max / Avg Werte anzeigen lassen.
defmod LaCrosse.Components readingsGroup <%temperature_humidity>,<Temperatur>,<Luftfeuchigkeit>,<Taupunkt>,<Batterie>,<MIN> TYPE=LaCrosse:temperature,humidity,dewpoint,battery,statTemperatureDay.min
attr LaCrosse.Components mapping %ALIAS
attr LaCrosse.Components room Gerätestatus,System->Hardware
attr LaCrosse.Components valueFormat {temperature => "%.1f°;C", humidity => "%.1f %%", dewpoint => "%.1f°;C"}
attr LaCrosse.Components valueIcon {'battery.critical' => 'measure_battery_0@red',\
'battery.low' => 'measure_battery_0@orange',\
'battery.ok' => 'measure_battery_100@green',\
'batteryLevel.0' => 'measure_battery_0@red',\
'batteryLevel.25' => 'measure_battery_25@red',\
'batteryLevel.50' => 'measure_battery_50@orange',\
'batteryLevel.75' => 'measure_battery_75@green',\
'batteryLevel.100' => 'measure_battery_100@green'}
attr LaCrosse.Components valueStyle { if($READING eq "temperature" && $VALUE > 20){ 'style="color:green;;;;font-weight:bold"' }elsif( $READING eq "temperature" && $VALUE <= 20 ){ 'style="color:blue"' }elsif( $READING eq "temperature" && $VALUE > 23 ){ 'style="color:red"' }else{ 'style="color:gray"' } }
CFGFN ./FHEM/fhem_activesensor.cfg
DEF 23
FUUID 5ccbe869-f33f-e9d9-7285-edd4ed9531101ed8
IODev myJeeLink
LASTInputDev myJeeLink
LaCrosse_lastRcv 2020-10-28 07:34:29
MSGCNT 4054
NAME AZ.LaCrosse
NR 493
STATE T: 19 H: 54 D: 9.5
TYPE LaCrosse
addr 23
battery_new 0
corr1 0
corr2 0
myJeeLink_MSGCNT 4064
myJeeLink_RAWMSG OK 9 35 1 4 167 54
myJeeLink_TIME 2020-10-28 07:34:29
previousH 54
previousT 19.1
sensorType 0=T(H)
2020-10-28 07:34:29 battery ok
2020-10-28 07:34:29 dewpoint 9.5
2019-03-15 15:51:33 error 0
2020-10-28 07:34:29 humidity 54
2020-08-11 13:37:24 humidity0 41
2020-09-26 04:31:27 rain 969.5
2020-10-28 07:34:29 statDewpointDay Min: 9.3 Avg: 9.6 Max: 10.0
2020-10-27 07:59:55 statDewpointDayLast Min: 9.5 Avg: 10.2 Max: 10.9
2020-10-28 07:34:29 statDewpointHour Min: 9.5 Avg: 9.6 Max: 9.6
2020-10-28 06:59:55 statDewpointHourLast Min: 9.4 Avg: 9.5 Max: 9.7
2020-10-28 07:34:29 statDewpointMonth Min: 7.1 Avg: 10.1 Max: 13.1
2020-10-01 07:59:55 statDewpointMonthLast Min: 6.0 Avg: 10.9 Max: 16.5
2020-10-28 07:34:29 statDewpointYear Min: -4.0 Avg: 9.3 Max: 21.5
2020-01-01 07:59:55 statDewpointYearLast Min: -0.5 Avg: 9.4 Max: 20.0 (since: 2019-01-03_16:39:49 )
2020-10-28 07:34:29 statHumidity Hour: 0.0 Day: 0.0 Month: 10.0 Year: 7.0
2020-10-26 14:29:03 statHumidityDay Min: 55 Avg: 58 Max: 62
2020-10-24 07:59:55 statHumidityDayLast Min: 56 Avg: 58 Max: 65
2020-10-26 14:29:03 statHumidityHour Min: 55 Avg: 58 Max: 58
2020-10-24 23:59:59 statHumidityHourLast Min: 58 Avg: 58 Max: 58
2020-10-28 06:59:55 statHumidityLast Hour: 1.0 Day: -4 Month: -1 Year: 6 (since: 2019-01-03_16:39:49 )
2020-10-26 14:29:03 statHumidityMonth Min: 45 Avg: 54 Max: 65
2020-10-01 07:59:55 statHumidityMonthLast Min: 33 Avg: 52 Max: 72
2020-10-28 06:59:55 statHumidityTendency 1h: +1 2h: +1 3h: +1 6h: +2
2020-10-26 14:29:03 statHumidityYear Min: 22 Avg: 46 Max: 72 (since: 2019-01-09_21:06:20 )
2020-10-28 07:34:29 statRain Hour: 0.0 Day: 0.0 Month: 0.0 Year: -61.0
2020-10-28 06:59:55 statRainLast Hour: 0.0 Day: 0.0 Month: -61.0 Year: 0.0 (since: 2019-03-15_15:51:33 )
2020-10-28 07:34:29 statTemperature Hour: -0.1 Day: -0.2 Month: -0.9 Year: 1.3
2020-10-26 14:29:03 statTemperatureDay Min: 19.3 Avg: 20.6 Max: 20.8
2020-10-24 07:59:55 statTemperatureDayLast Min: 19.3 Avg: 20.2 Max: 20.4
2020-10-26 14:29:03 statTemperatureHour Min: 19.7 Avg: 20.7 Max: 20.7
2020-10-24 23:59:59 statTemperatureHourLast Min: 20.7 Avg: 20.7 Max: 20.8
2020-10-28 06:59:55 statTemperatureLast Hour: -0.1 Day: 0.1 Month: 0.5 Year: -2.0 (since: 2019-01-03_16:39:49 )
2020-10-26 14:29:03 statTemperatureMonth Min: 18.7 Avg: 19.8 Max: 21.2
2020-10-01 07:59:55 statTemperatureMonthLast Min: 17.7 Avg: 21.3 Max: 30.9
2020-10-28 06:59:55 statTemperatureTendency 1h: -0.1 2h: -0.3 3h: -0.4 6h: -0.7
2020-10-26 14:29:03 statTemperatureYear Min: 17.2 Avg: 21.9 Max: 35.9 (since: 2019-01-09_21:06:20 )
2020-10-28 07:34:29 statWindSpeedDay Min: 60.1 Avg: 60.1 Max: 60.1
2020-10-27 07:59:55 statWindSpeedDayLast Min: 60.1 Avg: 60.1 Max: 60.1
2020-10-28 07:34:29 statWindSpeedHour Min: 60.1 Avg: 60.1 Max: 60.1
2020-10-28 06:59:55 statWindSpeedHourLast Min: 60.1 Avg: 60.1 Max: 60.1
2020-10-28 07:34:29 statWindSpeedMonth Min: 60.1 Avg: 60.1 Max: 60.1
2020-10-01 07:59:55 statWindSpeedMonthLast Min: 60.1 Avg: 60.7 Max: 60.8
2020-10-28 07:34:29 statWindSpeedYear Min: 60.1 Avg: 60.7 Max: 60.8
2020-01-01 07:59:55 statWindSpeedYearLast Min: 60.8 Avg: 60.8 Max: 60.8 (since: 2019-03-15_15:51:33 )
2020-10-28 07:34:29 state T: 19 H: 54
2020-10-28 07:34:29 temperature 19
2020-08-11 13:37:24 temperature0 33.6
2020-09-26 04:31:27 windDirectionDegree 180
2020-09-26 04:31:27 windDirectionText S
2020-09-26 04:31:27 windGust 25.8
2020-09-26 04:31:27 windSpeed 60.1
helper:
_98_statistics LaCrosse.Statistiken
IODev myJeeLink
comment Arbeitszimmer
doAverage 1
event-min-interval dewpoint:60,state:60,temperature:60,humidity:60,battery:360
event-on-change-reading dewpoint,state,temperature,humidity,battery
group Temperaturen
icon temperature_humidity
room Haus->Arbeitszimmer
