mit der Version5 über MQTT tue ich mir etwas schwer. Ich vermute dass es an einer falschen Einstellung liegt?
In der /etc/default/ebusd habe ich die Adresse meines eBus Adapters hinterlegt:
EBUSD_OPTS="-d 192.168.0.209:9999 -l /var/log/ebusd.log --scanconfig --latency=20000"
Im log bekomme ich jetzt folgende Ausgabe:
2023-12-26 21:39:14.254 [bus notice] device status: transport opened
2023-12-26 21:39:14.255 [main notice] ebusd 23.3.23.3 started with broadcast scan on device: 192>
2023-12-26 21:39:14.732 [bus notice] bus started with own address 31/36
2023-12-26 21:39:14.732 [bus notice] signal acquired
2023-12-26 21:39:23.006 [bus notice] max. symbols per second: 134
2023-12-26 21:39:24.732 [main notice] starting initial broadcast scan
2023-12-26 21:39:25.756 [bus error] send to fe: ERR: wrong symbol received, retry
2023-12-26 21:39:26.996 [bus error] send to fe: ERR: wrong symbol received, retry
2023-12-26 21:39:28.166 [bus error] send to fe: ERR: wrong symbol received
2023-12-26 21:39:28.166 [main error] initial scan failed: ERR: wrong symbol received
2023-12-26 21:39:38.167 [main notice] starting initial broadcast scan
2023-12-26 21:39:38.309 [bus error] send to fe: ERR: wrong symbol received, retry
2023-12-26 21:39:41.906 [bus error] send to fe: ERR: wrong symbol received, retry
2023-12-26 21:39:42.446 [bus error] send to fe: ERR: wrong symbol received
2023-12-26 21:39:42.446 [main error] initial scan failed: ERR: wrong symbol received
Im Log des Adapters erhalte ich die Mitteilung dass die Anmeldung erfolgreich war
21:39:14 Info host_task_tcp: accepted: 192.168.0.193
Kann mir jemand sagen wo das Problem liegt?
Update: Fehler gefunden!
In der /etc/default/ebusd muss folgende Zeile hinterlegt werden:
EBUSD_OPTS="--scanconfig=full -d enh:192.168.0.209:9999"
