hallo zusammen,
mein signalesp ( wemos d1 / cc1101 ) läuft leider immer nur wenige minuten , dann ist er nicht mehr erreichbar.
2017.08.23 18:21:08 4: signalesp/HandleWriteQueue: nothing to send, stopping timer
2017.08.23 18:21:19 4: signalesp: Calling Getting Attr sub with args: set cc1101_frequency = 433
2017.08.23 18:21:19 3: signalesp: delete cc1101_frequeny
2017.08.23 18:21:28 5: signalesp: command for gets: C0DnF
2017.08.23 18:21:28 5: AddSendQueue: signalesp: C0DnF (1)
2017.08.23 18:21:28 5: signalesp SW: C0DnF
2017.08.23 18:21:29 4: signalesp/HandleWriteQueue: nothing to send, stopping timer
2017.08.23 18:21:40 3: signalesp reset
2017.08.23 18:21:40 3: Opening signalesp device 192.168.178.67:23
2017.08.23 18:21:40 4: HttpUtils url=http://192.168.178.67:23/
2017.08.23 18:21:44 3: Can't connect to 192.168.178.67:23: connect to http://192.168.178.67:23 timed out
2017.08.23 18:21:44 3: SIGNALduino signalesp: connect to http://192.168.178.67:23 timed out
2017.08.23 18:22:13 4: signalesp: Calling Getting Attr sub with args: set cc1101_frequency = 868
2017.08.23 18:22:13 3: signalesp: setting cc1101_frequency to 868
2017.08.23 18:22:21 3: signalesp reset
2017.08.23 18:22:21 3: Opening signalesp device 192.168.178.67:23
2017.08.23 18:22:28 3: signalesp reset
2017.08.23 18:22:28 3: Opening signalesp device 192.168.178.67:23
2017.08.23 18:22:55 5: Triggering sandrafhemon
2017.08.23 18:22:55 4: sandrafhemon exec IF ([Voicemode] eq "on")(set pushmsg msg 'fhemmessage' 'anwesenheit sandra ist angemeldet')
2017.08.23 18:23:41 3: signalesp reset
2017.08.23 18:23:41 3: Opening signalesp device 192.168.178.67:23
2017.08.23 18:23:41 4: HttpUtils url=http://192.168.178.67:23/
2017.08.23 18:23:44 3: Can't connect to 192.168.178.67:23: connect to http://192.168.178.67:23 timed out
2017.08.23 18:24:45 4: HttpUtils url=http://192.168.178.67:23/
2017.08.23 18:24:58 3: signalesp reset
2017.08.23 18:24:58 3: Opening signalesp device 192.168.178.67:23
ggf. falsche firmware ?
kann mir bitte jemand sagen, welche firmware jetzt wirklich tauglich ist, für diese kombination. ich steige im anderen thread leider nicht mehr wirklich durch.
gruss byte09
welche Firmware benutzt du?
was steht in der seriellen Konsole?
tja, jetzt hast du mich echt erwischt . :o
sorry, die teile sind echt neuland für mich und ich habe keine ahnung wo ich es auslesen kann
geflashed habe ich über die arduino IDE .
dort diese version Signalesp :
#include <WiFiManager.h>
* RF_RECEIVER v3.3 for Arduino
* Sketch to use an arduino as a receiver/sending device for digital signals
* The Sketch can also encode and send data via a transmitter,
* while only PT2262 type-signals for Intertechno devices are implemented in the sketch,
* there is an option to send almost any data over a send raw interface
* 2014-2015 N.Butzek, S.Butzek
* 2016 S.Butzek
* This software focuses on remote sensors like weather sensors (temperature,
* humidity Logilink, TCM, Oregon Scientific, ...), remote controlled power switches
* (Intertechno, TCM, ARCtech, ...) which use encoder chips like PT2262 and
* EV1527-type and manchester encoder to send information in the 433MHz Band.
* But the sketch will also work for infrared or other medias. Even other frequencys
* can be used
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
//#define CMP_MEMDBG 1
#define CMP_cc1101
#define PROGNAME "SIGNALEsp"
#define PROGVERS "3.3.1-dev"
weiss jetzt echt nicht ob das weiterhilft !?
Gruss Byte
sieht nach dem Quellcode von trebron106 aus.
kannst gerne meinen letzten Entwicklungsstand (https://forum.fhem.de/index.php/topic,58396.msg675579.html#msg675579) testen (Sourcen (https://github.com/habeIchVergessen/SIGNALESP/tree/dev-cc1101)).
Oder du wartest, bis Sidey den merge fertig hat und kannst dann hier (https://github.com/RFD-FHEM/SIGNALESP/tree/dev-cc1101) die Sourcen finden.
Super , werde ich morgen mal angehen . Ich Danke dir erstmal und geb Bescheid ob es läuft.
Gruss byte09
Gesendet von meinem SM-G900F mit Tapatalk
hi habeIchVegessen,
leider lässt sich die datei nicht kompilieren . Abbruch mit diesem Fehler :
Arduino: 1.8.3 (Windows Store 1.8.6.0) (Windows 10), Board: "WeMos D1 R2 & mini, 80 MHz, 921600, 4M (3M SPIFFS)"
C:\Users\Thomas\Desktop\esp\SIGNALESP-dev-cc1101\SIGNALESP\SIGNALESP.ino:34:20: fatal error: output.h: No such file or directory
#Arduino: 1.8.3 (Windows Store 1.8.6.0) (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.6.0_x64__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.6.0_x64__mdqgnx93n4wtt\hardware -hardware C:\Users\Thomas\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.6.0_x64__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.6.0_x64__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Thomas\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.6.0_x64__mdqgnx93n4wtt\libraries -libraries C:\Users\Thomas\Documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=512K64,ResetMethod=ck,Debug=Disabled,DebugLevel=None____ -ide-version=10803 -build-path C:\Users\Thomas\AppData\Local\Temp\arduino_build_806151 -warnings=none -build-cache C:\Users\Thomas\AppData\Local\Temp\arduino_cache_797319 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\Thomas\Desktop\esp\SIGNALESP-dev-cc1101\SIGNALESP\SIGNALESP.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.6.0_x64__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.6.0_x64__mdqgnx93n4wtt\hardware -hardware C:\Users\Thomas\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.6.0_x64__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.6.0_x64__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Thomas\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.6.0_x64__mdqgnx93n4wtt\libraries -libraries C:\Users\Thomas\Documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=512K64,ResetMethod=ck,Debug=Disabled,DebugLevel=None____ -ide-version=10803 -build-path C:\Users\Thomas\AppData\Local\Temp\arduino_build_806151 -warnings=none -build-cache C:\Users\Thomas\AppData\Local\Temp\arduino_cache_797319 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\Thomas\Desktop\esp\SIGNALESP-dev-cc1101\SIGNALESP\SIGNALESP.ino
Using board 'generic' from platform in folder: C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0
Detecting libraries used...
"C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Thomas\AppData\Local\Temp\arduino_build_806151/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "C:\Users\Thomas\AppData\Local\Temp\arduino_build_806151\sketch\SIGNALESP.ino.cpp" -o "nul"
"C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Thomas\AppData\Local\Temp\arduino_build_806151/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "C:\Users\Thomas\AppData\Local\Temp\arduino_build_806151\sketch\SIGNALESP.ino.cpp" -o "nul"
"C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Thomas\AppData\Local\Temp\arduino_build_806151/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "C:\Users\Thomas\AppData\Local\Temp\arduino_build_806151\sketch\SIGNALESP.ino.cpp" -o "nul"
"C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Thomas\AppData\Local\Temp\arduino_build_806151/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\DNSServer\src" "C:\Users\Thomas\AppData\Local\Temp\arduino_build_806151\sketch\SIGNALESP.ino.cpp" -o "nul"
"C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Thomas\AppData\Local\Temp\arduino_build_806151/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\DNSServer\src" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "C:\Users\Thomas\AppData\Local\Temp\arduino_build_806151\sketch\SIGNALESP.ino.cpp" -o "nul"
"C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Thomas\AppData\Local\Temp\arduino_build_806151/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\DNSServer\src" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "-IC:\Users\Thomas\Documents\Arduino\libraries\WiFiManager" "C:\Users\Thomas\AppData\Local\Temp\arduino_build_806151\sketch\SIGNALESP.ino.cpp" -o "nul"
"C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Thomas\AppData\Local\Temp\arduino_build_806151/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\DNSServer\src" "-IC:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "-IC:\Users\Thomas\Documents\Arduino\libraries\WiFiManager" "C:\Users\Thomas\AppData\Local\Temp\arduino_build_806151\sketch\SIGNALESP.ino.cpp" -o "C:\Users\Thomas\AppData\Local\Temp\arduino_build_806151\preproc\ctags_target_for_gcc_minus_e.cpp"
#include <output.h>
compilation terminated.
Bibliothek EEPROM in Version 1.0 im Ordner: C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM wird verwendet
Bibliothek ESP8266WiFi in Version 1.0 im Ordner: C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi wird verwendet
Bibliothek DNSServer in Version 1.1.0 im Ordner: C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\DNSServer wird verwendet
Bibliothek ESP8266WebServer in Version 1.0 im Ordner: C:\Users\Thomas\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer wird verwendet
Bibliothek WiFiManager in Version 0.12 im Ordner: C:\Users\Thomas\Documents\Arduino\libraries\WiFiManager wird verwendet
exit status 1
Fehler beim Kompilieren für das Board Generic ESP8266 Module.
die datei output.h liegt mit im sketchordner ... verstehe ich nicht wirklich.
gruss Byte09
erstelle mal das Verzeichnis signalduino-esp unter %USERPROFILE%\Documents\Arduino\libraries
mkdir -p %USERPROFILE%\Documents\Arduino\libraries\signalduino-esp
dahin kopierst du die cpp- und h-Dateien aus den src-Verzeichnissen unter libraries\*.
unter SimpleFIFO auch keywords mit kopieren.
ich danke dir für deine hilfe. habe den sketch jetzt zumindest kompiliert bekommen und geflashed . werde mich nachher nochmal melden, ob er denn nun auch tut was er soll.
gruss byte09
haz sich zar flashen lassen, und ist über fhem auch ansprechbar, aber schalten tut er nicht .
folgende meldung im log :
2017.08.24 17:03:36 0: Strange call for nonexistent <undefined>: GetFn
2017.08.24 17:03:38 0: Strange call for nonexistent <undefined>: GetFn
device :
00 f0
DEF 00000FFF0F 0F F0
NAME IT_00000FFF0F
NR 888
STATE on
TYPE IT
XMIT 00000fff0f
XMITdimdown 00
XMITdimup 00
XMITon 0f
CODE:
1 00000fff0f
2017-08-05 13:46:08 protocol V1
2017-08-24 17:03:38 state on
IODev signalesp
alias Dose_Devon
room IT
kannst du damit was anfangen ?
gruss byte
Hast du das Update für SIGNALDuino ausgeführt?
setze mal verbose auf 4. erstmal für signalesp.
das ist alles waskommt auf verbose 4
2017.08.24 17:24:56 4: signalesp/HandleWriteQueue: nothing to send, stopping timer
2017.08.24 17:25:38 4: signalesp: Calling Getting Attr sub with args: set verbose = 5
2017.08.24 17:25:38 3: signalesp: setting Verbose to: 5
2017.08.24 17:26:12 0: Strange call for nonexistent <undefined>: GetFn
2017.08.24 17:26:14 0: Strange call for nonexistent <undefined>: GetFn
SIGNALduino ist auf dem neuesten stand, glaube ich wenigstens, lasse aber gerade nochmal ein update laufen.
was wird bei folgendem Kommando ausgegeben?
version 00_SIGNALDuino
setze mal verbose 4 für global.
welches Kommando verursacht die Fehlermeldung?
set IT_00000FFF0F toggle?
version :
no loaded modules found that match: 00_SIGNALDuino.pm
fhemweb.js 14906 2017-08-15 20:06:05Z rudolfkoenig
fhemweb_colorpicker.js 13580 2017-03-02 13:03:29Z justme1968
fhemweb_fbcalllist.js 13629 2017-03-06 20:50:43Z markusbloch
fhemweb_readingsGroup.js 13580 2017-03-02 13:03:29Z justme1968
fhemweb_readingsHistory.js 13580 2017-03-02 13:03:29Z justme1968
fhemweb_sortable.js 13629 2017-03-06 20:50:43Z markusbloch
fhemweb_uzsu.js 13580 2017-03-02 13:03:29Z justme1968
svg.js 13579 2017-03-02 12:39:59Z rudolfkoenig
bin jetzt aber ein schritt weiter, nach dem update . logbeim schalten des devices :
2017.08.24 17:43:39 5: signalesp/write: adding to queue sendMsg P3#is00F000FFFF0F#R6
2017.08.24 17:43:39 5: signalesp: sendmsg msg=P3#is00F000FFFF0F#R6
2017.08.24 17:43:39 5: signalesp: sendmsg IT V1 convertet tristate to bits=000001000000010101010001
2017.08.24 17:43:39 5: signalesp: sendmsg Preparing rawsend command for protocol=3, repeats=6, clock=250 bits=000001000000010101010001
2017.08.24 17:43:39 5: AddSendQueue: signalesp: SR;R=6;P0=250;P1=-7750;P2=750;P3=-250;P4=-750;D=01040404040423040404040404042304230423042304040423; (1)
2017.08.24 17:43:39 4: signalesp/set: sending via SendMsg: SR;R=6;P0=250;P1=-7750;P2=750;P3=-250;P4=-750;D=01040404040423040404040404042304230423042304040423;
2017.08.24 17:43:39 5: signalesp SW: SR;R=6;P0=250;P1=-7750;P2=750;P3=-250;P4=-750;D=01040404040423040404040404042304230423042304040423;
2017.08.24 17:43:39 4: signalesp SendrawFromQueue: msg=SR;R=6;P0=250;P1=-7750;P2=750;P3=-250;P4=-750;D=01040404040423040404040404042304230423042304040423;
2017.08.24 17:43:39 4: signalesp/msg READ: SR;R=6;P0=250;P1=-7750;P2=750;P3=-250;P4=-750;D=01040404040423040404040404042304230423042304040423;
2017.08.24 17:43:39 5: signalesp/msg READ: regexp=^S(R|C|M); cmd=sendraw msg=SR;R=6;P0=250;P1=-7750;P2=750;P3=-250;P4=-750;D=01040404040423040404040404042304230423042304040423;
2017.08.24 17:43:39 4: signalesp/read sendraw answer: SR;R=6;P0=250;P1=-7750;P2=750;P3=-250;P4=-750;D=01040404040423040404040404042304230423042304040423;
2017.08.24 17:43:39 4: signalesp/HandleWriteQueue: nothing to send, stopping timer
....... schaltet aber nicht. Wenn ich den normale signalduino als iodevice nutze geht es.
get ccconf geht auch nicht:
2017.08.24 17:45:28 5: signalesp: command for gets: C0DnF
2017.08.24 17:45:28 5: AddSendQueue: signalesp: C0DnF (1)
2017.08.24 17:45:28 5: signalesp SW: C0DnF
2017.08.24 17:45:28 4: signalesp/msg READ: Unsupported command
2017.08.24 17:45:28 4: signalesp/msg READ: Received answer (Unsupported command) for ccconf does not match C0Dn11.*
2017.08.24 17:45:28 4: signalesp/HandleWriteQueue: nothing to send, stopping timer
ich werde daraus nicht schlau
nachtrag : hardwaredefffekt was das senden betrifft kann ich wohl ausschliessen, da ich ja eine version drauf hatte, die sich aber aufgehangen hat. aber schalten tat sie !
bugfix für ccconf auf github verfügbar
ITv1 senden funktioniert bei mir.
ok, dann werde ich das teil wohl erstmal auf eis legen :( .
dank dir. gruss Byte
Hat jemand mal eine genau PIN Belegung bzw wie der cc1101 an des WEMOS D1/ESp8266 dran muss ?
danke
Sascha
https://wiki.fhem.de/wiki/SIGNALduino#Controller (https://wiki.fhem.de/wiki/SIGNALduino#Controller)
Thomas
Hallo Sacha,,
Ungeprüft: dürfte das http://www.bastelbudenbuben.de/wp-content/uploads/asgarosforum/128/Schaltplan.pdf (http://www.bastelbudenbuben.de/wp-content/uploads/asgarosforum/128/Schaltplan.pdf) die Standard Wemos-CC1101-Beschaltung sein ....
Möchte mir auch einen zum experimentieren (http://www.bastelbudenbuben.de/2017/03/21/espressif-esp8266-12f-mit-cc1101-transceiver-im-asynchronous-mode-betreiben/) aufbauen... dann würde ich das Pinout kontrolieren ...
Platine.pdf (http://www.bastelbudenbuben.de/wp-content/uploads/asgarosforum/128/Platine.pdf)
Grüße,
Jürgen
Die Platinen sind angekommen. Und funktioniert, jedenfalls in der gezeigten Kombi. Firmware geflasht, eingerichtet, läuft...
(https://uploads.tapatalk-cdn.com/20191107/18afa56e603ba4315d6c1adcb7c97ae1.jpg)
Gesendet von meinem MI 9 mit Tapatalk
