habe leider nichts gefunden eventuell habt ihr eine Lösung. Fehler bzw. ich bekomme ständig ein Warning
2018.03.26 08:19:49 1: PERL WARNING: could not find ParserDetails.ini in /usr/local/share/perl/5.24.1/XML/SAX
2018.03.26 08:19:49 1: stacktrace:
2018.03.26 08:19:49 1: main::__ANON__ called by /usr/local/share/perl/5.24.1/XML/SAX.pm (212)
2018.03.26 08:19:49 1: XML::SAX::do_warn called by /usr/local/share/perl/5.24.1/XML/SAX.pm (62)
2018.03.26 08:19:49 1: XML::SAX::load_parsers called by /usr/local/share/perl/5.24.1/XML/SAX.pm (114)
2018.03.26 08:19:49 1: XML::SAX::parsers called by /usr/local/share/perl/5.24.1/XML/SAX/ParserFactory.pm (18)
2018.03.26 08:19:49 1: XML::SAX::ParserFactory::new called by /usr/local/share/perl/5.24.1/XML/SAX/ParserFactory.pm (26)
2018.03.26 08:19:49 1: XML::SAX::ParserFactory::parser called by /usr/share/perl5/XML/Simple.pm (385)
2018.03.26 08:19:49 1: XML::Simple::build_tree called by /usr/share/perl5/XML/Simple.pm (333)
2018.03.26 08:19:49 1: (eval) called by /usr/share/perl5/XML/Simple.pm (332)
2018.03.26 08:19:49 1: XML::Simple::build_simple_tree called by /usr/share/perl5/XML/Simple.pm (294)
2018.03.26 08:19:49 1: XML::Simple::parse_string called by /usr/share/perl5/XML/Simple.pm (215)
2018.03.26 08:19:49 1: XML::Simple::XMLin called by (eval 156) (1)
2018.03.26 08:19:49 1: (eval) called by ./FHEM/70_ENIGMA2.pm (998)
2018.03.26 08:19:49 1: main::ENIGMA2_ReceiveCommand called by FHEM/HttpUtils.pm (583)
2018.03.26 08:19:49 1: main::__ANON__ called by fhem.pl (705)
Simple ist installiert.
Danke für eure Hilf
keiner ne idee?
