ich wollte heute zwei Aktoren am System anmelden.
Also VCCU hmPairForSec auf 60 gestellt an den Aktoren auf den Config-Knopf gedrückt,
im Log steht auch:
2017.09.22 08:08:08.217 2: CUL_HM Unknown device HM_5859A5 is now defined
2017.09.22 08:08:08.546 2: CUL_HM Unknown device HM_5859A5 is now defined
2017.09.22 08:10:12.174 3: CUL_HM set vccu hmPairForSec 60
2017.09.22 08:10:17.411 2: CUL_HM Unknown device HM_5859A5 is now defined
2017.09.22 08:10:17.716 2: CUL_HM Unknown device HM_5859A5 is now defined
2017.09.22 08:13:10.795 3: CUL_HM set vccu hmPairForSec 60
2017.09.22 08:13:14.515 2: CUL_HM Unknown device HM_5859DC is now defined
2017.09.22 08:13:14.603 2: CUL_HM Unknown device HM_5859DC is now defined
Leider sind die Devices nicht vorhanden. Auch nicht in der fhem.cfg !
Im WebUI wird auch nicht das "?" hinter Save config angezeigt, was dafür spricht, dass keine Veränderung an der fhem.cfg vorgenommen wurde.
Ich bin ehrlich gesagt etwas ratlos.
Hat die VCCU die vielleicht schon als unknown_5859DC usw. ?
Also in den Readings der vccu kommt es nicht vor
unknown_03343D
received
2017-08-14 19:40:58
unknown_033FBE
received
2017-08-15 14:41:21
unknown_1BC5C6
received for 4C2BFE -107
2017-09-22 00:23:16
unknown_1BE56B
received for 000000 -87
2017-09-19 21:58:13
unknown_1D001B
received
2017-08-18 22:17:26
unknown_1D52C9
received
2017-08-14 18:15:13
unknown_1D6694
received
2017-08-15 14:39:59
unknown_1D7C9C
received
2017-08-15 11:26:44
unknown_1DA4C4
received
2017-08-14 17:30:35
unknown_1DEBE0
received
2017-08-15 14:41:55
unknown_3C06A2
received
2017-08-16 21:13:23
unknown_48865E
received
2017-08-14 18:37:37
unknown_5859A5
received for 000000 -80
2017-09-22 08:30:56
unknown_5859DC
received for 000000 -50
2017-09-22 08:15:13
unknown_5FA203
received
2017-08-17 15:54:12
unknown_673CA2
received
2017-08-17 12:14:03
unknown_6EA203
received
2017-08-17 19:17:31
unknown_70C2A2
received
2017-08-14 19:31:39
unknown_77CDA2
received
2017-08-14 19:39:35
unknown_90A203
received
2017-08-15 12:51:28
unknown_9783A7
received for 9EDED8 -59
2017-09-01 15:34:07
unknown_A01116
received
2017-08-14 21:00:30
unknown_A20334
received
2017-08-14 20:31:55
unknown_A462F5
received
2017-08-16 21:17:28
unknown_A6103F
received
2017-08-15 14:41:19
unknown_AC76A0
received
2017-08-07 13:15:58
unknown_D6A203
received
2017-08-19 07:37:35
unknown_D8A203
received
2017-08-15 13:34:20
unknown_DDA203
received
2017-08-15 14:41:08
unknown_DFA203
received
2017-08-15 14:41:01
unknown_EDA203
received
2017-08-15 19:28:31
unknown_F9A002
received
2017-08-15 14:41:33
unknown_FDDC86
received
2017-07-31 14:44:54
unknown_FF8670
received
2017-08-12 20:36:34
Passt auch nicht anhand der Zeitstempel
die hier?
2017-09-22 08:30:56
unknown_5859DC
2017-09-22 08:15:13
Hatte ich auch schon mal, wenn die VCCU schon in unknown hat dann verweigert sie das anlernen. Mit deletereading löschen und nochmal versuchen?
Ich weiß es nicht besser.
Sorry,
das waren meine Readings. Klar stehen da die Geräte drin. Die sind ja auch unbekannt. Sie sind aber NICHT in der Ignore list in fhem.cfg!
Habe die fhem.cfg komlett durchsucht, beide Geräte sind nicht drin....
Kann also kein Problem sein.
Ich mache mal ein Anlernversuch mit aktiviertem Logging..
Greets
Byte
Reden wir aneinander vorbei?
Die beiden Geräte willst Du doch anlernen?
Und wenn die VCCU die schon als unknown hat, kann es sein, dass sie sie nicht anlernt. :-[
Meines wissens nach kann man nur Geräte die "ignored" sind nicht anlernen.
Unknown werden nicht ignoriert, da sie ja nur unbekannt sind (was normal ist, wenn sie nicht angelernt sind!)
unknown werden auch nicht in der fhem.cfg gespeichert, nur ignored devices...
Wie kann man, falls es doch daran liegen sollte, die unknown entfernen?
Greets
Byte
Das meinte ich ja, sollte eigentlich nicht so sein, aber vielleicht ist es einfach so. Versuch macht kluch ;)
deletereading vccu unknown_5859A5
So,
hab die Readings gelöscht. Trotzdem gehts nicht.
Hier man das HMLAN Log:
2017.09.22 19:56:11.887 3: CUL_HM set vccu hmPairForSec 60
2017.09.22 19:56:28.860 2: CUL_HM Unknown device HM_5859DC is now defined
2017.09.22 19:56:28.900 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4112.
2017.09.22 19:56:28.905 1: PERL WARNING: Use of uninitialized value $mh{"devN"} in regexp compilation at ./FHEM/10_CUL_HM.pm line 2946.
2017.09.22 19:57:05.292 1: Perfmon: possible freeze starting at 19:57:04, delay is 1.292
2017.09.22 19:59:47.509 0: HMLAN_Send: HMLAN1 I:K
2017.09.22 19:59:47.515 0: HMLAN_Parse: HMLAN1 V:03C5 sNo:LEQ0640815 d:2CD8CE O:1DA462 t:38E4D880 IDcnt:001F L:2 %
2017.09.22 20:00:12.753 0: HMLAN_Send: HMLAN1 I:K
2017.09.22 20:00:13.014 0: HMLAN_Parse: HMLAN1 V:03C5 sNo:LEQ0640815 d:2CD8CE O:1DA462 t:38E53B20 IDcnt:001F L:2 %
2017.09.22 20:00:37.012 0: HMLAN_Parse: HMLAN1 R:E20DACE stat:0000 t:38E59945 d:FF r:FF9F m:24 8670 20DACE 000000 00B540
2017.09.22 20:00:37.850 0: HMLAN_Send: HMLAN1 I:K
2017.09.22 20:00:37.854 0: HMLAN_Parse: HMLAN1 V:03C5 sNo:LEQ0640815 d:2CD8CE O:1DA462 t:38E59D2C IDcnt:001F L:2 %
2017.09.22 20:00:39.112 3: CUL_HM set vccu hmPairForSec 60
2017.09.22 20:01:03.104 0: HMLAN_Send: HMLAN1 I:K
2017.09.22 20:01:03.109 0: HMLAN_Parse: HMLAN1 V:03C5 sNo:LEQ0640815 d:2CD8CE O:1DA462 t:38E5FFD7 IDcnt:001F L:2 %
2017.09.22 20:01:04.075 0: HMLAN_Parse: HMLAN1 R:E17E2BB stat:0000 t:38E60391 d:FF r:FFA4 m:47 A002 17E2BB 1C5801 0424B9ADA1958902
2017.09.22 20:01:04.335 0: HMLAN_Parse: HMLAN1 R:E17E2BB stat:0000 t:38E60491 d:FF r:FFA3 m:47 8002 17E2BB 1C5801 00F9EE2F20
2017.09.22 20:01:09.368 0: HMLAN_Parse: HMLAN1 R:E5859DC stat:0000 t:38E617D6 d:FF r:FFC6 m:02 8400 5859DC 000000 2800694F45513033363034313110010100
2017.09.22 20:01:09.370 2: CUL_HM Unknown device HM_5859DC is now defined
2017.09.22 20:01:14.542 0: HMLAN_Parse: HMLAN1 R:E3BD2E7 stat:0000 t:38E62B5D d:FF r:FFAE m:7A 865E 3BD2E7 000000 9002A5005DC0
2017.09.22 20:01:28.253 0: HMLAN_Send: HMLAN1 I:K
2017.09.22 20:01:28.509 0: HMLAN_Parse: HMLAN1 V:03C5 sNo:LEQ0640815 d:2CD8CE O:1DA462 t:38E66217 IDcnt:001F L:2 %
2017.09.22 20:01:36.610 0: HMLAN_Parse: HMLAN1 R:E3FBEE5 stat:0000 t:38E6828E d:FF r:FFC6 m:4D A641 3FBEE5 1DA462 013600
2017.09.22 20:01:36.665 0: HMLAN_Send: HMLAN1 S:SAAC083C6 stat: 00 t:00000000 d:01 r:AAC083C6 m:4D 8002 1DA462 3FBEE5 0101C800
2017.09.22 20:01:36.666 0: HMLAN_Send: HMLAN1 I:K
2017.09.22 20:01:36.982 0: HMLAN_Parse: HMLAN1 V:03C5 sNo:LEQ0640815 d:2CD8CE O:1DA462 t:38E68309 IDcnt:001F L:2 %
2017.09.22 20:01:36.983 0: HMLAN_Parse: HMLAN1 R:RAAC083C6 stat:0002 t:00000000 d:FF r:7FFF m:4D 8002 1DA462 3FBEE5 0101C800
Hab auch mal einen reset des Aktors gemacht....
Zitat2017.09.22 19:56:28.900 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4112.
Da ist doch was faul? Bist Du up to Date mit FHEM?
Bei den Raw Messages kann ich Dir leider nicht helfen. Die L:2% machen mich stutzig. Ist das Überlast?
Ja, bin ich (up to date).
Finde ich auch komisch.
Eventlog:
2017-09-22 20:06:50.798 Global global UNDEFINED HM_5859DC CUL_HM 5859DC
2017-09-22 20:06:55.053 MQTT mqtt connection: active
Mich irritiert die WARNUNG im log
2017.09.22 20:23:51.978 3: CUL_HM set vccu hmPairForSec 60
2017.09.22 20:24:16.335 2: CUL_HM Unknown device HM_5859DC is now defined
2017.09.22 20:24:16.374 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4112.
2017.09.22 20:24:16.379 1: PERL WARNING: Use of uninitialized value $mh{"devN"} in regexp compilation at ./FHEM/10_CUL_HM.pm line 2930.
klingt für mich, als ob beim Erstellen etwas schief gelaufen ist
Schaue ich mir an. Dauert etwas, bin unterwegs.
Danke.
Diese Meldung ist bei mir reproduzierbar.
Taucht bei jedem Anlernversuch auf:
2017.09.22 22:21:07.579 3: CUL_HM set vccu hmPairForSec 60
2017.09.22 22:21:18.516 2: CUL_HM Unknown device HM_5859DC is now defined
2017.09.22 22:21:18.554 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4112.
2017.09.22 22:21:18.559 1: PERL WARNING: Use of uninitialized value $mh{"devN"} in regexp compilation at ./FHEM/10_CUL_HM.pm line 2930.
2017.09.22 22:22:00.359 1: Perfmon: possible freeze starting at 22:21:59, delay is 1.359
was muss ich liefern, damit man mir helfen kann?
Ich benötige die Schalter kurzfristig. Bin ehrlich gesagt etwas genervt, dass ich die nun nicht anlernen kann....
Greets
Byte
mach mal
list autocreate
und
list HM_5859DC
Also ich habe nun folgendes gemacht:
1) Device resettet
2) log geleert
3) global verbose auf 5
4) vccu hmPairForSec 60
5 ) config Knopf gedrückt (blinkt ziemlich lange)
2017.09.23 14:36:36.817 4: Connection closed for WEB_172.30.90.22_52384: EOF
2017.09.23 14:36:37.075 4: WEB_172.30.90.22_52362 POST /fhem&detail=vccu&dev.setvccu=vccu&fwcsrf=csrf_239928979354596&cmd.setvccu=set&arg.setvccu=hmPairForSec&val.setvccu=60; BUFLEN:0
2017.09.23 14:36:37.076 5: Cmd: >set vccu hmPairForSec 60<
2017.09.23 14:36:37.079 3: CUL_HM set vccu hmPairForSec 60
2017.09.23 14:36:37.333 4: WEB_172.30.90.22_52362 GET /fhem?detail=vccu&fw_id=; BUFLEN:0
2017.09.23 14:36:37.403 4: WEB: /fhem?detail=vccu&fw_id= / RL:7333 / text/html; charset=UTF-8 / Content-Encoding: gzip
2017.09.23 14:36:37.912 4: WEB_172.30.90.22_52362 GET /fhem?cmd=%7BReadingsVal(%22vccu%22%2C%22virtual%22%2C%22%22)%7D&XHR=1&fwcsrf=csrf_239928979354596; BUFLEN:0
2017.09.23 14:36:37.913 5: Cmd: >{ReadingsVal("vccu","virtual","")}<
2017.09.23 14:36:37.914 4: WEB: /fhem?cmd=%7BReadingsVal(%22vccu%22%2C%22virtual%22%2C%22%22)%7D&XHR=1&fwcsrf=csrf_239928979354596 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2017.09.23 14:36:38.175 4: WEB_172.30.90.22_52385 GET /fhem?XHR=1&inform=type=status;filter=vccu;since=1506170196;fmt=JSON&fw_id=883×tamp=1506170199128; BUFLEN:0
2017.09.23 14:36:38.187 4: WEB_172.30.90.22_52363 GET /fhem?cmd=%7BAttrVal(%22vccu%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=csrf_239928979354596; BUFLEN:0
2017.09.23 14:36:38.188 5: Cmd: >{AttrVal("vccu","room","")}<
2017.09.23 14:36:38.189 4: WEB: /fhem?cmd=%7BAttrVal(%22vccu%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=csrf_239928979354596 / RL:26 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2017.09.23 14:36:48.268 2: CUL_HM Unknown device HM_5859DC is now defined
2017.09.23 14:36:48.269 5: Starting notify loop for global, 1 event(s), first is UNDEFINED HM_5859DC CUL_HM 5859DC
2017.09.23 14:36:48.269 5: createNotifyHash
2017.09.23 14:36:48.310 5: PRESENCE (AndyPresence) - processing events from global
2017.09.23 14:36:48.311 5: PRESENCE (AnnaPresence) - processing events from global
2017.09.23 14:36:48.319 5: PRESENCE (KerstinPresence) - processing events from global
2017.09.23 14:36:48.321 5: PRESENCE (MajaPresence) - processing events from global
2017.09.23 14:36:48.323 5: PRESENCE (TVPresence) - processing events from global
2017.09.23 14:36:48.324 5: ZE.Batterie: not on any display, ignoring notify
2017.09.23 14:36:48.353 5: End notify loop for global
2017.09.23 14:36:48.357 5: HMLAN/RAW: /E5859DC,0000,3CE3A884,FF,FFC2,0184005859DC0000002800694F45513033363034313110010100
2017.09.23 14:36:48.357 0: HMLAN_Parse: HMLAN1 R:E5859DC stat:0000 t:3CE3A884 d:FF r:FFC2 m:01 8400 5859DC 000000 2800694F45513033363034313110010100
2017.09.23 14:36:48.359 5: HMLAN1: dispatch A1A0184005859DC0000002800694F45513033363034313110010100::-62:HMLAN1
2017.09.23 14:36:48.360 2: CUL_HM Unknown device HM_5859DC is now defined
2017.09.23 14:36:48.360 5: Starting notify loop for global, 1 event(s), first is UNDEFINED HM_5859DC CUL_HM 5859DC
2017.09.23 14:36:48.361 5: PRESENCE (AndyPresence) - processing events from global
2017.09.23 14:36:48.362 5: PRESENCE (AnnaPresence) - processing events from global
2017.09.23 14:36:48.370 5: PRESENCE (KerstinPresence) - processing events from global
2017.09.23 14:36:48.372 5: PRESENCE (MajaPresence) - processing events from global
2017.09.23 14:36:48.374 5: PRESENCE (TVPresence) - processing events from global
2017.09.23 14:36:48.375 5: ZE.Batterie: not on any display, ignoring notify
2017.09.23 14:36:48.402 5: End notify loop for global
2017.09.23 14:36:53.576 4: <hidden>: HTTP response code 200
2017.09.23 14:36:53.577 4: HttpUtils <hidden>: Got data, length: 23
2017.09.23 14:36:53.577 5: HttpUtils response header:
HTTP/1.1 200 OK
Server: nginx/1.10.1
Date: Sat, 23 Sep 2017 12:37:46 GMT
Content-Type: application/json
Content-Length: 23
Connection: close
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET, POST, OPTIONS
Access-Control-Expose-Headers: Content-Length,Content-Type,Date,Server,Connection
Strict-Transport-Security: max-age=31536000; includeSubdomains
2017.09.23 14:36:53.577 5: TelegramBot_Callback Telegram: called from Polling
2017.09.23 14:36:53.578 5: TelegramBot_Callback Telegram: data returned :{"ok":true,"result":[]}:
2017.09.23 14:36:53.578 5: TelegramBot_Deepencode Telegram: encoded a String from :true: to :true:
2017.09.23 14:36:53.578 5: TelegramBot_Deepencode Telegram: found an ARRAY
2017.09.23 14:36:53.579 5: TelegramBot_Deepencode Telegram: found a HASH
2017.09.23 14:36:53.579 5: TelegramBot_Callback Telegram: after encoding
2017.09.23 14:36:53.579 5: TelegramBot_Callback Telegram: polling returned result? 0
2017.09.23 14:36:53.579 5: UpdatePoll Telegram: number of results 0
2017.09.23 14:36:53.580 5: TelegramBot_UpdatePoll Telegram: called
2017.09.23 14:36:53.580 5: TelegramBot_UpdatePoll Telegram: - Initiate non blocking polling - With callback set
2017.09.23 14:36:53.581 5: TelegramBot_readToken: Read Telegram API token from file
2017.09.23 14:36:53.584 4: TelegramBot_UpdatePoll Telegram: initiate polling with nonblockingGet with 120s
2017.09.23 14:36:53.584 4: HttpUtils url=<hidden>
2017.09.23 14:36:53.586 5: IP: api.telegram.org -> 149.154.167.199
2017.09.23 14:36:53.588 5: TelegramBot_UpdatePoll Telegram: - Ende > next polling started
2017.09.23 14:36:53.589 4: TelegramBot_Callback Telegram: resulted in SUCCESS from Polling
2017.09.23 14:36:53.589 5: TelegramBot_Callback Telegram: - Ende > Control back to FHEM
2017.09.23 14:36:53.936 5: HttpUtils request header:
GET /bot201446298:AAFxWvpqw27z0W_70RTfV3kP-DC674OPEFs/getUpdates?offset=0&limit=5&timeout=120 HTTP/1.0
Host: api.telegram.org
agent: TelegramBot/1.0
User-Agent: TelegramBot/1.0
Accept: application/json
Accept-Charset: utf-8
2017.09.23 14:36:56.916 0: HMLAN_Send: HMLAN1 I:K
2017.09.23 14:36:56.920 5: HMLAN/RAW: /HHM-LAN-IF,03C5,LEQ0640815,2CD8CE,1DA462,3CE3CB2F,001F,02
2017.09.23 14:36:56.921 0: HMLAN_Parse: HMLAN1 V:03C5 sNo:LEQ0640815 d:2CD8CE O:1DA462 t:3CE3CB2F IDcnt:001F L:2 %
2017.09.23 14:37:14.037 4: BlockingCall (FRITZBOX_Readout_Run_Web): created child (955), uses telnetForBlockingFn_1506167519 to connect back
2017.09.23 14:37:14.040 4: FRITZBOX FritzBox: Readout_Start.673 Fork process FRITZBOX_Readout_Run_Web
2017.09.23 14:37:14.060 4: FRITZBOX FritzBox: Readout_Run_Web.1255 Prepare query string for luaQuery.
2017.09.23 14:37:14.061 5: FRITZBOX FritzBox: Web_Query.4573 Request data via API luaQuery.
2017.09.23 14:37:14.783 5: FRITZBOX FritzBox: Web_Query.4581 Response: 200 OK
{"tam":[{"_node":"TAM0","Name":"Anrufbeantworter","Active":"0","Display":"1","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM1","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM2","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM3","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM4","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM5","Name":"Anrufbeantworter","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM6","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM7","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM8","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM9","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"}],"wlanListNew":[{"mac":"DC:66:72:81:1D:0D","rssi":"0","speed":"0","_node":"wlanlist0"},{"mac":"E8:AB:FA:8C:DE:11","rssi":"0","speed":"0","_node":"wlanlist1"},{"mac":"74:DA:38:0E:45:DB","rssi":"0","speed":"0","_node":"wlanlist2"},{"mac":"08:EE:8B:A1:CB:3B","rssi":"0","speed":"0","_node":"wlanlist3"},{"mac":"30:19:66:CF:D5:55","rssi":"0","speed":"0","_node":"wlanlist4"},{"mac":"B4:74:43:AA:A1:D5","rssi":"0","speed":"0","_node":"wlanlist5"},{"mac":"56:31:C4:C5:68:54","rssi":"0","speed":"0","_node":"wlanlist6"},{"mac":"C4:50:06:78:8A:E1","rssi":"0","speed":"0","_node":"wlanlist7"},{"mac":"56:31:C4:C5:68:55","rssi":"0","speed":"0","_node":"wlanlist8"},{"mac":"78:F7:BE:C7:91:49","rssi":"0","speed":"0","_node":"wlanlist9"},{"mac":"78:D6:F0:20:3F:D2","rssi":"0","speed":"0","_node":"wlanlist10"},{"mac":"F0:4F:7C:7D:42:FF","rssi":"0","speed":"0","_node":"wlanlist11"},{"mac":"40:A6:D9:2A:EE:AC","rssi":"0","speed":"0","_node":"wlanlist12"},{"mac":"0C:15:39:EA:6D:A1","rssi":"0","speed":"0","_node":"wlanlist13"},{"mac":"08:EE:8B:6F:DB:19","rssi":"0","speed":"0","_node":"wlanlist14"},{"mac":"18:46:17:FB:A4:E3","rssi":"0","speed":"0","_node":"wlanlist15"}],"box_fwUpdate":"0","box_guestWlanRemain":"0","box_cpuTemp":"0","userProfil":"user0","box_wlan_5GHz":"0","TodayBytesReceivedLow":"0","box_moh":"0","box_tr064":"1","lanDeviceNew":[{"mac":"","active":"0","ip":"172.30.90.223","_node":"landevice0","online":"0","name":"AndreasVPN","ethernet":"0","speed":"0","UID":"landevice1884","guest":"0","wlan":"0"},{"mac":"DC:66:72:81:1D:0D","active":"0","ip":"","_node":"landevice1","online":"0","name":"Galaxy-Tab-S2-Andy-localdomain","ethernet":"0","speed":"0","UID":"landevice1889","guest":"0","wlan":"1"},{"mac":"08:EE:8B:6F:DB:19","active":"0","ip":"","_node":"landevice2","online":"0","name":"PC-08-EE-8B-6F-DB-19","ethernet":"0","speed":"0","UID":"landevice1899","guest":"0","wlan":"1"},{"mac":"08:EE:8B:A1:CB:3B","active":"0","ip":"","_node":"landevice3","online":"0","name":"PC-08-EE-8B-A1-CB-3B","ethernet":"0","speed":"0","UID":"landevice1888","guest":"0","wlan":"1"},{"mac":"0C:15:39:EA:6D:A1","active":"0","ip":"","_node":"landevice4","online":"0","name":"PC-0C-15-39-EA-6D-A1","ethernet":"0","speed":"0","UID":"landevice1898","guest":"0","wlan":"1"},{"mac":"F0:9F:C2:11:65:C0","active":"1","ip":"172.30.90.191","_node":"landevice5","online":"0","name":"PC-172-30-90-191","ethernet":"1","speed":"1000","UID":"landevice1874","guest":"0","wlan":"0"},{"mac":"18:46:17:FB:A4:E3","active":"0","ip":"","_node":"landevice6","online":"0","name":"PC-18-46-17-FB-A4-E3","ethernet":"0","speed":"0","UID":"landevice1900","guest":"0","wlan":"1"},{"mac":"30:19:66:CF:D5:55","active":"0","ip":"","_node":"landevice7","online":"0","name":"PC-30-19-66-CF-D5-55","ethernet":"0","speed":"0","UID":"landevice1890","guest":"0","wlan":"1"},{"mac":"40:A6:D9:2A:EE:AC","active":"0","ip":"","_node":"landevice8","online":"0","name":"PC-40-A6-D9-2A-EE-AC","ethernet":"0","speed":"0","UID":"landevice1897","guest":"0","wlan":"1"},{"mac":"56:31:C4:C5:68:54","active":"0","ip":"","_node":"landevice9","online":"0","name":"PC-56-31-C4-C5-68-54","ethernet":"0","speed":"0","UID":"landevice1891","guest":"0","wlan":"1"},{"mac":"56:31:C4:C5:68:55","active":"0","ip":"","_node":"landevice10","online":"0","name":"PC-56-31-C4-C5-68-55","ethernet":"0","speed":"0","UID":"landevice1893","guest":"0","wlan":"1"},{"mac":"74:DA:38:0E:45:DB","active":"0","ip":"","_node":"landevice11","online":"0","name":"PC-74-DA-38-0E-45-DB","ethernet":"0","speed":"0","UID":"landevice1886","guest":"0","wlan":"1"},{"mac":"78:D6:F0:20:3F:D2","active":"0","ip":"","_node":"landevice12","online":"0","name":"PC-78-D6-F0-20-3F-D2","ethernet":"0","speed":"0","UID":"landevice1895","guest":"0","wlan":"1"},{"mac":"78:F7:BE:C7:91:49","active":"0","ip":"","_node":"landevice13","online":"0","name":"PC-78-F7-BE-C7-91-49","ethernet":"0","speed":"0","UID":"landevice1894","guest":"0","wlan":"1"},{"mac":"B4:74:43:AA:A1:D5","active":"0","ip":"","_node":"landevice14","online":"0","name":"PC-B4-74-43-AA-A1-D5","ethernet":"0","speed":"0","UID":"landevice1919","guest":"0","wlan":"1"},{"mac":"C4:50:06:78:8A:E1","active":"0","ip":"","_node":"landevice15","online":"0","name":"PC-C4-50-06-78-8A-E1","ethernet":"0","speed":"0","UID":"landevice1892","guest":"0","wlan":"1"},{"mac":"E8:AB:FA:8C:DE:11","active":"0","ip":"","_node":"landevice16","online":"0","name":"PC-E8-AB-FA-8C-DE-11","ethernet":"0","speed":"0","UID":"landevice1887","guest":"0","wlan":"1"},{"mac":"F0:4F:7C:7D:42:FF","active":"0","ip":"","_node":"landevice17","online":"0","name":"PC-F0-4F-7C-7D-42-FF","ethernet":"0","speed":"0","UID":"landevice1896","guest":"0","wlan":"1"},{"mac":"","active":"0","ip":"172.30.90.224","_node":"landevice18","online":"0","name":"Test","ethernet":"0","speed":"0","UID":"landevice1883","guest":"0","wlan":"0"},{"mac":"9C:C7:A6:0E:56:FF","active":"1","ip":"172.30.90.221","_node":"landevice19","online":"0","name":"fritz.box","ethernet":"0","speed":"0","UID":"landevice1885","guest":"0","wlan":"0"}],"dectUser":[{"Intern":"","Id":"0","IntRingTone":"0","RadioRingID":"0","Name":"","AlarmRingTone0":"","G722RingToneName":"","ImagePath":"","_node":"User0","G722RingTone":""},{"Intern":"610","Id":"1","IntRingTone":"0","RadioRingID":"0","Name":"Haupt","AlarmRingTone0":"","G722RingToneName":"","ImagePath":"","_node":"User1","G722RingTone":""}],"TodayBytesReceivedHigh":"0","init":"","UMTS_enabled":"0","box_ipExtern":"172.30.90.221","userTicket":[{"_node":"ticket0","id":"743238"},{"_node":"ticket1","id":"072019"},{"_node":"ticket2","id":"251257"},{"_node":"ticket3","id":"121769"},{"_node":"ticket4","id":"462880"},{"_node":"ticket5","id":"791204"},{"_node":"ticket6","id":"596034"},{"_node":"ticket7","id":"552389"},{"_node":"ticket8","id":"954291"},{"_node":"ticket9","id":"263778"}],"userProfilNew":[{"_node":"user0","type":"4","name":"(guest)"},{"_node":"user1","type":"3","name":"(default)"}],"GSM_AcT":"","GSM_NetworkState":"0","box_connect":"5","box_fwVersion":"84.06.83","box_dect":"1","alarmClock":[{"_node":"AlarmClock0","Name":"Wecker 1","Active":"0","Weekdays":"255","Number":"1","Time":"0000"},{"_node":"AlarmClock1","Name":"Wecker 2","Active":"0","Weekdays":"255","Number":"1","Time":"0000"},{"_node":"AlarmClock2","Name":"Wecker 3","Active":"0","Weekdays":"255","Number":"1","Time":"0000"}],"box_stdDialPort":"60","radio":[{"_node":"WEBRADIO0","Name":""},{"_node":"WEBRADIO1","Name":""},{"_node":"WEBRADIO2","Name":""},{"_node":"WEBRADIO3","Name":""},{"_node":"WEBRADIO4","Name":""},{"_node":"WEBRADIO5","Name":""},{"_node":"WEBRADIO6","Name":""},{"_node":"WEBRADIO7","Name":""},{"_node":"WEBRADIO8","Name":""},{"_node":"WEBRADIO9","Name":""},{"_node":"WEBRADIO10","Name":""},{"_node":"WEBRADIO11","Name":""},{"_node":"WEBRADIO12","Name":""},{"_node":"WEBRADIO13","Name":""},{"_node":"WEBRADIO14","Name":""},{"_node":"WEBRADIO15","Name":""},{"_node":"WEBRADIO16","Name":""},{"_node":"WEBRADIO17","Name":""},{"_node":"WEBRADIO18","Name":""},{"_node":"WEBRADIO19","Name":""},{"_node":"WEBRADIO20","Name":""},{"_node":"WEBRADIO21","Name":""},{"_node":"WEBRADIO22","Name":""},{"_node":"WEBRADIO23","Name":""},{"_node":"WEBRADIO24","Name":""},{"_node":"WEBRADIO25","Name":""},{"_node":"WEBRADIO26","Name":""},{"_node":"WEBRADIO27","Name":""},{"_node":"WEBRADIO28","Name":""},{"_node":"WEBRADIO29","Name":""},{"_node":"WEBRADIO30","Name":""},{"_node":"WEBRADIO31","Name":""},{"_node":"WEBRADIO32","Name":""},{"_node":"WEBRADIO33","Name":""},{"_node":"WEBRADIO34","Name":""},{"_node":"WEBRADIO35","Name":""},{"_node":"WEBRADIO36","Name":""},{"_node":"WEBRADIO37","Name":""},{"_node":"WEBRADIO38","Name":""},{"_node":"WEBRADIO39","Name":""}],"box_wlan_24GHz":"0","TodayBytesSentHigh":"0","box_guestWlan":"0","box_tr069":"0","fonPort":[{"_node":"Port0","Name":"Ersatz","MSN":"SIP3"},{"_node":"Port1","Name":"Faxgerät HP Officejet","MSN":"SIP1#"},{"_node":"Port2","Name":"","MSN":""},{"_node":"Port3","Name":"","MSN":""}],"box_powerRate":"37","diversity":[],"GSM_RSSI":"0","wlanList":"wlanlist0","handset":[{"_node":"Handset0","FWVersion":"3.92","User":"1","Manufacturer":"AVM","Model":"0x08"},{"_node":"Handset1","FWVersion":"","User":"0","Manufacturer":"","Model":""},{"_node":"Handset2","FWVersion":"","User":"0","Manufacturer":"","Model":""},{"_node":"Handset3","FWVersion":"","User":"0","Manufacturer":"","Model":""},{"_node":"Handset4","FWVersion":"","User":"0","Manufacturer":"","Model":""},{"_node":"Handset5","FWVersion":"","User":"0","Manufacturer":"","Model":""}],"TodayBytesSentLow":"0","is_double_wlan":"1","lanDevice":"landevice0"}
2017.09.23 14:37:14.784 5: FRITZBOX FritzBox: Web_Query.4603 Decode JSON string.
2017.09.23 14:37:14.786 4: FRITZBOX FritzBox: Readout_Run_Web.1336 Recognized query answer of firmware >= 6.69
2017.09.23 14:37:14.787 5: FRITZBOX FritzBox: Web_Query.4573 Request data via API luaQuery.
2017.09.23 14:37:15.086 5: FRITZBOX FritzBox: Web_Query.4581 Response: 200 OK
{"landevice11":"0","landevice13":"2","landevice15":"2","user1_today":"0","landevice4":"0","landevice5":"2","wlanlist12":"0","wlanlist10":"0","wlanlist7":"0","wlanlist14":"0","landevice16":"0","landevice17":"2","user1_month":"0","user1_filter":"filtprof1","wlanlist0":"0","landevice10":"0","wlanlist4":"0","wlanlist6":"0","wlanlist1":"0","landevice7":"2","wlanlist3":"0","wlanlist15":"0","wlanlist8":"0","user0_today":"0","landevice0":"0","landevice8":"0","user0_month":"0","user0_filter":"filtprof2","landevice19":"0","landevice18":"0","wlanlist9":"0","wlanlist2":"0","landevice9":"0","wlanlist5":"0","landevice12":"0","landevice14":"2","landevice6":"2","landevice3":"0","wlanlist11":"0","landevice1":"2","landevice2":"0","wlanlist13":"0"}
2017.09.23 14:37:15.087 5: FRITZBOX FritzBox: Web_Query.4603 Decode JSON string.
2017.09.23 14:37:15.089 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->sid: 7f4053d305531030
2017.09.23 14:37:15.089 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->sidTime: 1506170235.08974
2017.09.23 14:37:15.090 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1: Haupt
2017.09.23 14:37:15.090 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_intern: 610
2017.09.23 14:37:15.090 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_alarmRingTone:
2017.09.23 14:37:15.091 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_intRingTone: HandsetDefault
2017.09.23 14:37:15.091 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_radio:
2017.09.23 14:37:15.092 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_custRingTone:
2017.09.23 14:37:15.092 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_custRingToneName:
2017.09.23 14:37:15.092 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_imagePath:
2017.09.23 14:37:15.093 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->610->id: 1
2017.09.23 14:37:15.093 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->610->userId: 1
2017.09.23 14:37:15.093 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_manufacturer: AVM
2017.09.23 14:37:15.094 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_model: C4
2017.09.23 14:37:15.094 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_fwVersion: 3.92
2017.09.23 14:37:15.094 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->610->brand: AVM
2017.09.23 14:37:15.095 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->610->model: C4
2017.09.23 14:37:15.095 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon1: Ersatz
2017.09.23 14:37:15.095 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon1_out: SIP3
2017.09.23 14:37:15.096 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon1_intern: 1
2017.09.23 14:37:15.096 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon2: Faxgerät HP Officejet
2017.09.23 14:37:15.096 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon2_out: SIP1#
2017.09.23 14:37:15.097 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon2_intern: 2
2017.09.23 14:37:15.097 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio00:
2017.09.23 14:37:15.097 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->0:
2017.09.23 14:37:15.098 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio01:
2017.09.23 14:37:15.098 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->1:
2017.09.23 14:37:15.098 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio02:
2017.09.23 14:37:15.099 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->2:
2017.09.23 14:37:15.099 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio03:
2017.09.23 14:37:15.099 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->3:
2017.09.23 14:37:15.100 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio04:
2017.09.23 14:37:15.100 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->4:
2017.09.23 14:37:15.100 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio05:
2017.09.23 14:37:15.101 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->5:
2017.09.23 14:37:15.101 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio06:
2017.09.23 14:37:15.101 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->6:
2017.09.23 14:37:15.102 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio07:
2017.09.23 14:37:15.102 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->7:
2017.09.23 14:37:15.102 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio08:
2017.09.23 14:37:15.103 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->8:
2017.09.23 14:37:15.103 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio09:
2017.09.23 14:37:15.103 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->9:
2017.09.23 14:37:15.104 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio10:
2017.09.23 14:37:15.104 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->10:
2017.09.23 14:37:15.104 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio11:
2017.09.23 14:37:15.105 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->11:
2017.09.23 14:37:15.105 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio12:
2017.09.23 14:37:15.105 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->12:
2017.09.23 14:37:15.106 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio13:
2017.09.23 14:37:15.106 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->13:
2017.09.23 14:37:15.106 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio14:
2017.09.23 14:37:15.107 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->14:
2017.09.23 14:37:15.107 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio15:
2017.09.23 14:37:15.107 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->15:
2017.09.23 14:37:15.108 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio16:
2017.09.23 14:37:15.108 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->16:
2017.09.23 14:37:15.108 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio17:
2017.09.23 14:37:15.109 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->17:
2017.09.23 14:37:15.109 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio18:
2017.09.23 14:37:15.109 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->18:
2017.09.23 14:37:15.109 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio19:
2017.09.23 14:37:15.110 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->19:
2017.09.23 14:37:15.110 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio20:
2017.09.23 14:37:15.110 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->20:
2017.09.23 14:37:15.111 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio21:
2017.09.23 14:37:15.111 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->21:
2017.09.23 14:37:15.111 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio22:
2017.09.23 14:37:15.112 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->22:
2017.09.23 14:37:15.112 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio23:
2017.09.23 14:37:15.112 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->23:
2017.09.23 14:37:15.113 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio24:
2017.09.23 14:37:15.113 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->24:
2017.09.23 14:37:15.113 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio25:
2017.09.23 14:37:15.114 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->25:
2017.09.23 14:37:15.114 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio26:
2017.09.23 14:37:15.114 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->26:
2017.09.23 14:37:15.115 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio27:
2017.09.23 14:37:15.115 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->27:
2017.09.23 14:37:15.115 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio28:
2017.09.23 14:37:15.116 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->28:
2017.09.23 14:37:15.116 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio29:
2017.09.23 14:37:15.116 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->29:
2017.09.23 14:37:15.117 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio30:
2017.09.23 14:37:15.117 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->30:
2017.09.23 14:37:15.117 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio31:
2017.09.23 14:37:15.118 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->31:
2017.09.23 14:37:15.118 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio32:
2017.09.23 14:37:15.118 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->32:
2017.09.23 14:37:15.119 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio33:
2017.09.23 14:37:15.119 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->33:
2017.09.23 14:37:15.119 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio34:
2017.09.23 14:37:15.120 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->34:
2017.09.23 14:37:15.120 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio35:
2017.09.23 14:37:15.120 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->35:
2017.09.23 14:37:15.121 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio36:
2017.09.23 14:37:15.121 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->36:
2017.09.23 14:37:15.121 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio37:
2017.09.23 14:37:15.121 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->37:
2017.09.23 14:37:15.122 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio38:
2017.09.23 14:37:15.122 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->38:
2017.09.23 14:37:15.123 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio39:
2017.09.23 14:37:15.123 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->39:
2017.09.23 14:37:15.123 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radioCount: 40
2017.09.23 14:37:15.124 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->DC_66_72_81_1D_0D->speed: 0
2017.09.23 14:37:15.124 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->DC_66_72_81_1D_0D->speed_rx: 0
2017.09.23 14:37:15.124 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->DC_66_72_81_1D_0D->rssi: 0
2017.09.23 14:37:15.125 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->E8_AB_FA_8C_DE_11->speed: 0
2017.09.23 14:37:15.125 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->E8_AB_FA_8C_DE_11->speed_rx: 0
2017.09.23 14:37:15.125 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->E8_AB_FA_8C_DE_11->rssi: 0
2017.09.23 14:37:15.126 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->74_DA_38_0E_45_DB->speed: 0
2017.09.23 14:37:15.126 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->74_DA_38_0E_45_DB->speed_rx: 0
2017.09.23 14:37:15.126 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->74_DA_38_0E_45_DB->rssi: 0
2017.09.23 14:37:15.127 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_A1_CB_3B->speed: 0
2017.09.23 14:37:15.127 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_A1_CB_3B->speed_rx: 0
2017.09.23 14:37:15.127 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_A1_CB_3B->rssi: 0
2017.09.23 14:37:15.128 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->30_19_66_CF_D5_55->speed: 0
2017.09.23 14:37:15.128 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->30_19_66_CF_D5_55->speed_rx: 0
2017.09.23 14:37:15.128 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->30_19_66_CF_D5_55->rssi: 0
2017.09.23 14:37:15.129 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->B4_74_43_AA_A1_D5->speed: 0
2017.09.23 14:37:15.129 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->B4_74_43_AA_A1_D5->speed_rx: 0
2017.09.23 14:37:15.130 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->B4_74_43_AA_A1_D5->rssi: 0
2017.09.23 14:37:15.130 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_54->speed: 0
2017.09.23 14:37:15.130 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_54->speed_rx: 0
2017.09.23 14:37:15.131 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_54->rssi: 0
2017.09.23 14:37:15.131 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->C4_50_06_78_8A_E1->speed: 0
2017.09.23 14:37:15.131 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->C4_50_06_78_8A_E1->speed_rx: 0
2017.09.23 14:37:15.132 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->C4_50_06_78_8A_E1->rssi: 0
2017.09.23 14:37:15.132 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_55->speed: 0
2017.09.23 14:37:15.132 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_55->speed_rx: 0
2017.09.23 14:37:15.133 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_55->rssi: 0
2017.09.23 14:37:15.133 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_F7_BE_C7_91_49->speed: 0
2017.09.23 14:37:15.133 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_F7_BE_C7_91_49->speed_rx: 0
2017.09.23 14:37:15.134 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_F7_BE_C7_91_49->rssi: 0
2017.09.23 14:37:15.134 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_D6_F0_20_3F_D2->speed: 0
2017.09.23 14:37:15.134 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_D6_F0_20_3F_D2->speed_rx: 0
2017.09.23 14:37:15.135 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_D6_F0_20_3F_D2->rssi: 0
2017.09.23 14:37:15.135 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->F0_4F_7C_7D_42_FF->speed: 0
2017.09.23 14:37:15.135 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->F0_4F_7C_7D_42_FF->speed_rx: 0
2017.09.23 14:37:15.136 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->F0_4F_7C_7D_42_FF->rssi: 0
2017.09.23 14:37:15.136 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->40_A6_D9_2A_EE_AC->speed: 0
2017.09.23 14:37:15.136 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->40_A6_D9_2A_EE_AC->speed_rx: 0
2017.09.23 14:37:15.137 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->40_A6_D9_2A_EE_AC->rssi: 0
2017.09.23 14:37:15.137 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->0C_15_39_EA_6D_A1->speed: 0
2017.09.23 14:37:15.137 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->0C_15_39_EA_6D_A1->speed_rx: 0
2017.09.23 14:37:15.138 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->0C_15_39_EA_6D_A1->rssi: 0
2017.09.23 14:37:15.138 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_6F_DB_19->speed: 0
2017.09.23 14:37:15.138 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_6F_DB_19->speed_rx: 0
2017.09.23 14:37:15.139 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_6F_DB_19->rssi: 0
2017.09.23 14:37:15.139 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->18_46_17_FB_A4_E3->speed: 0
2017.09.23 14:37:15.139 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->18_46_17_FB_A4_E3->speed_rx: 0
2017.09.23 14:37:15.140 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->18_46_17_FB_A4_E3->rssi: 0
2017.09.23 14:37:15.140 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->172.30.90.223: AndreasVPN
2017.09.23 14:37:15.141 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1884: AndreasVPN
2017.09.23 14:37:15.141 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: Galaxy-Tab-S2-Andy-localdomain
2017.09.23 14:37:15.141 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1889: Galaxy-Tab-S2-Andy-localdomain
2017.09.23 14:37:15.142 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-08-EE-8B-6F-DB-19
2017.09.23 14:37:15.142 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1899: PC-08-EE-8B-6F-DB-19
2017.09.23 14:37:15.142 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-08-EE-8B-A1-CB-3B
2017.09.23 14:37:15.143 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1888: PC-08-EE-8B-A1-CB-3B
2017.09.23 14:37:15.143 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-0C-15-39-EA-6D-A1
2017.09.23 14:37:15.143 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1898: PC-0C-15-39-EA-6D-A1
2017.09.23 14:37:15.144 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->172.30.90.191: PC-172-30-90-191
2017.09.23 14:37:15.144 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1874: PC-172-30-90-191
2017.09.23 14:37:15.145 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 mac_F0_9F_C2_11_65_C0: PC-172-30-90-191 (LAN2, 1 Gbit/s)
2017.09.23 14:37:15.145 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-18-46-17-FB-A4-E3
2017.09.23 14:37:15.145 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1900: PC-18-46-17-FB-A4-E3
2017.09.23 14:37:15.146 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-30-19-66-CF-D5-55
2017.09.23 14:37:15.146 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1890: PC-30-19-66-CF-D5-55
2017.09.23 14:37:15.146 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-40-A6-D9-2A-EE-AC
2017.09.23 14:37:15.147 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1897: PC-40-A6-D9-2A-EE-AC
2017.09.23 14:37:15.147 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-56-31-C4-C5-68-54
2017.09.23 14:37:15.147 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1891: PC-56-31-C4-C5-68-54
2017.09.23 14:37:15.148 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-56-31-C4-C5-68-55
2017.09.23 14:37:15.148 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1893: PC-56-31-C4-C5-68-55
2017.09.23 14:37:15.148 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-74-DA-38-0E-45-DB
2017.09.23 14:37:15.149 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1886: PC-74-DA-38-0E-45-DB
2017.09.23 14:37:15.149 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-78-D6-F0-20-3F-D2
2017.09.23 14:37:15.149 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1895: PC-78-D6-F0-20-3F-D2
2017.09.23 14:37:15.150 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-78-F7-BE-C7-91-49
2017.09.23 14:37:15.150 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1894: PC-78-F7-BE-C7-91-49
2017.09.23 14:37:15.150 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-B4-74-43-AA-A1-D5
2017.09.23 14:37:15.151 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1919: PC-B4-74-43-AA-A1-D5
2017.09.23 14:37:15.151 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-C4-50-06-78-8A-E1
2017.09.23 14:37:15.151 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1892: PC-C4-50-06-78-8A-E1
2017.09.23 14:37:15.152 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-E8-AB-FA-8C-DE-11
2017.09.23 14:37:15.152 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1887: PC-E8-AB-FA-8C-DE-11
2017.09.23 14:37:15.152 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-F0-4F-7C-7D-42-FF
2017.09.23 14:37:15.152 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1896: PC-F0-4F-7C-7D-42-FF
2017.09.23 14:37:15.153 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->172.30.90.224: Test
2017.09.23 14:37:15.153 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1883: Test
2017.09.23 14:37:15.153 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->172.30.90.221: fritz.box
2017.09.23 14:37:15.154 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1885: fritz.box
2017.09.23 14:37:15.154 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 mac_9C_C7_A6_0E_56_FF: fritz.box
2017.09.23 14:37:15.155 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_wlanCount: 0
2017.09.23 14:37:15.155 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_guestWlanCount: 0
2017.09.23 14:37:15.155 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_wlan_2.4GHz: off
2017.09.23 14:37:15.156 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_wlan_5GHz: off
2017.09.23 14:37:15.156 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_guestWlan: off
2017.09.23 14:37:15.156 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_guestWlanRemain: 0
2017.09.23 14:37:15.157 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_dect: on
2017.09.23 14:37:15.157 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_moh: default
2017.09.23 14:37:15.157 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_powerRate: 37
2017.09.23 14:37:15.158 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->is_double_wlan: 1
2017.09.23 14:37:15.158 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_fwVersion: 84.06.83
2017.09.23 14:37:15.158 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_fwUpdate: 0
2017.09.23 14:37:15.159 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_tr064: on
2017.09.23 14:37:15.159 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_tr069: off
2017.09.23 14:37:15.159 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_stdDialPort: dect1
2017.09.23 14:37:15.160 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_ipExtern: 172.30.90.221
2017.09.23 14:37:15.160 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_connect: 5
2017.09.23 14:37:15.160 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_cpuTemp: 0
2017.09.23 14:37:15.161 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 gsm_rssi:
2017.09.23 14:37:15.161 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 gsm_state:
2017.09.23 14:37:15.161 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 gsm_technology:
2017.09.23 14:37:15.162 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 gsm_internet:
2017.09.23 14:37:15.162 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm1: Wecker 1
2017.09.23 14:37:15.162 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm1_state: off
2017.09.23 14:37:15.163 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm1_time: 00:00
2017.09.23 14:37:15.163 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm1_target: FON 1
2017.09.23 14:37:15.163 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm1_wdays: daily
2017.09.23 14:37:15.164 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm2: Wecker 2
2017.09.23 14:37:15.164 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm2_state: off
2017.09.23 14:37:15.164 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm2_time: 00:00
2017.09.23 14:37:15.165 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm2_target: FON 1
2017.09.23 14:37:15.165 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm2_wdays: daily
2017.09.23 14:37:15.165 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm3: Wecker 3
2017.09.23 14:37:15.166 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm3_state: off
2017.09.23 14:37:15.166 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm3_time: 00:00
2017.09.23 14:37:15.166 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm3_target: FON 1
2017.09.23 14:37:15.167 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm3_wdays: daily
2017.09.23 14:37:15.167 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 tam1: Anrufbeantworter
2017.09.23 14:37:15.167 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 tam1_state: off
2017.09.23 14:37:15.167 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 tam1_newMsg: 0
2017.09.23 14:37:15.167 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 tam1_oldMsg: 0
2017.09.23 14:37:15.168 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 user01: (guest)
2017.09.23 14:37:15.168 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 user01_thisMonthTime: 0:00
2017.09.23 14:37:15.168 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 user01_todayTime: 0:00
2017.09.23 14:37:15.168 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 user01_todaySeconds: 0
2017.09.23 14:37:15.168 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 user01_type: Guest
2017.09.23 14:37:15.169 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 userTicket01: 743238
2017.09.23 14:37:15.169 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 .box_TodayBytesReceivedHigh: 0
2017.09.23 14:37:15.169 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 .box_TodayBytesReceivedLow: 0
2017.09.23 14:37:15.169 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 .box_TodayBytesSentHigh: 0
2017.09.23 14:37:15.169 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 .box_TodayBytesSentLow: 0
2017.09.23 14:37:15.170 4: FRITZBOX FritzBox: Readout_Run_Web.1681 Captured 247 values
2017.09.23 14:37:15.170 5: FRITZBOX FritzBox: Readout_Run_Web.1682 Handover to main process (6548): fhem->sid|7f4053d305531030|fhem->sidTime|1506170235.08974|dect1|Haupt|dect1_intern|610|dect1_alarmRingTone||dect1_intRingTone|HandsetDefault|dect1_radio||dect1_custRingTone||dect1_custRingToneName||dect1_imagePath||fhem->610->id|1|fhem->610->userId|1|dect1_manufacturer|AVM|dect1_model|C4|dect1_fwVersion|3.92|fhem->610->brand|AVM|fhem->610->model|C4|fon1|Ersatz|fon1_out|SIP3|fon1_intern|1|fon2|Faxgerät HP Officejet|fon2_out|SIP1#|fon2_intern|2|radio00||fhem->radio->0||radio01||fhem->radio->1||radio02||fhem->radio->2||radio03||fhem->radio->3||radio04||fhem->radio->4||radio05||fhem->radio->5||radio06||fhem->radio->6||radio07||fhem->radio->7||radio08||fhem->radio->8||radio09||fhem->radio->9||radio10||fhem->radio->10||radio11||fhem->radio->11||radio12||fhem->radio->12||radio13||fhem->radio->13||radio14||fhem->radio->14||radio15||fhem->radio->15||radio16||fhem->radio->16||radio17||fhem->radio->17||radio18||fhem->radio->18||radio19||fhem->radio->19||radio20||fhem->radio->20||radio21||fhem->radio->21||radio22||fhem->radio->22||radio23||fhem->radio->23||radio24||fhem->radio->24||radio25||fhem->radio->25||radio26||fhem->radio->26||radio27||fhem->radio->27||radio28||fhem->radio->28||radio29||fhem->radio->29||radio30||fhem->radio->30||radio31||fhem->radio->31||radio32||fhem->radio->32||radio33||fhem->radio->33||radio34||fhem->radio->34||radio35||fhem->radio->35||radio36||fhem->radio->36||radio37||fhem->radio->37||radio38||fhem->radio->38||radio39||fhem->radio->39||fhem->radioCount|40|fhem->wlanDevice->DC_66_72_81_1D_0D->speed|0|fhem->wlanDevice->DC_66_72_81_1D_0D->speed_rx|0|fhem->wlanDevice->DC_66_72_81_1D_0D->rssi|0|fhem->wlanDevice->E8_AB_FA_8C_DE_11->speed|0|fhem->wlanDevice->E8_AB_FA_8C_DE_11->speed_rx|0|fhem->wlanDevice->E8_AB_FA_8C_DE_11->rssi|0|fhem->wlanDevice->74_DA_38_0E_45_DB->speed|0|fhem->wlanDevice->74_DA_38_0E_45_DB->speed_rx|0|fhem->wlanDevice->74_DA_38_0E_45_DB->rssi|0|fhem->wlanDevice->08_EE_8B_A1_CB_3B->speed|0|fhem->wlanDevice->08_EE_8B_A1_CB_3B->speed_rx|0|fhem->wlanDevice->08_EE_8B_A1_CB_3B->rssi|0|fhem->wlanDevice->30_19_66_CF_D5_55->speed|0|fhem->wlanDevice->30_19_66_CF_D5_55->speed_rx|0|fhem->wlanDevice->30_19_66_CF_D5_55->rssi|0|fhem->wlanDevice->B4_74_43_AA_A1_D5->speed|0|fhem->wlanDevice->B4_74_43_AA_A1_D5->speed_rx|0|fhem->wlanDevice->B4_74_43_AA_A1_D5->rssi|0|fhem->wlanDevice->56_31_C4_C5_68_54->speed|0|fhem->wlanDevice->56_31_C4_C5_68_54->speed_rx|0|fhem->wlanDevice->56_31_C4_C5_68_54->rssi|0|fhem->wlanDevice->C4_50_06_78_8A_E1->speed|0|fhem->wlanDevice->C4_50_06_78_8A_E1->speed_rx|0|fhem->wlanDevice->C4_50_06_78_8A_E1->rssi|0|fhem->wlanDevice->56_31_C4_C5_68_55->speed|0|fhem->wlanDevice->56_31_C4_C5_68_55->speed_rx|0|fhem->wlanDevice->56_31_C4_C5_68_55->rssi|0|fhem->wlanDevice->78_F7_BE_C7_91_49->speed|0|fhem->wlanDevice->78_F7_BE_C7_91_49->speed_rx|0|fhem->wlanDevice->78_F7_BE_C7_91_49->rssi|0|fhem->wlanDevice->78_D6_F0_20_3F_D2->speed|0|fhem->wlanDevice->78_D6_F0_20_3F_D2->speed_rx|0|fhem->wlanDevice->78_D6_F0_20_3F_D2->rssi|0|fhem->wlanDevice->F0_4F_7C_7D_42_FF->speed|0|fhem->wlanDevice->F0_4F_7C_7D_42_FF->speed_rx|0|fhem->wlanDevice->F0_4F_7C_7D_42_FF->rssi|0|fhem->wlanDevice->40_A6_D9_2A_EE_AC->speed|0|fhem->wlanDevice->40_A6_D9_2A_EE_AC->speed_rx|0|fhem->wlanDevice->40_A6_D9_2A_EE_AC->rssi|0|fhem->wlanDevice->0C_15_39_EA_6D_A1->speed|0|fhem->wlanDevice->0C_15_39_EA_6D_A1->speed_rx|0|fhem->wlanDevice->0C_15_39_EA_6D_A1->rssi|0|fhem->wlanDevice->08_EE_8B_6F_DB_19->speed|0|fhem->wlanDevice->08_EE_8B_6F_DB_19->speed_rx|0|fhem->wlanDevice->08_EE_8B_6F_DB_19->rssi|0|fhem->wlanDevice->18_46_17_FB_A4_E3->speed|0|fhem->wlanDevice->18_46_17_FB_A4_E3->speed_rx|0|fhem->wlanDevice->18_46_17_FB_A4_E3->rssi|0|fhem->landevice->172.30.90.223|AndreasVPN|fhem->landevice->landevice1884|AndreasVPN|fhem->landevice->|Galaxy-Tab-S2-Andy-localdomain|fhem->landevice->landevice1889|Galaxy-Tab-S2-Andy-localdomain|fhem->landevice->|PC-08-EE-8B-6F-DB-19|fhem->landevice->landevice1899|PC-08-EE-8B-6F-DB-19|fhem->landevice->|PC-08-EE-8B-A1-CB-3B|fhem->landevice->landevice1888|PC-08-EE-8B-A1-CB-3B|fhem->landevice->|PC-0C-15-39-EA-6D-A1|fhem->landevice->landevice1898|PC-0C-15-39-EA-6D-A1|fhem->landevice->172.30.90.191|PC-172-30-90-191|fhem->landevice->landevice1874|PC-172-30-90-191|mac_F0_9F_C2_11_65_C0|PC-172-30-90-191 (LAN2, 1 Gbit/s)|fhem->landevice->|PC-18-46-17-FB-A4-E3|fhem->landevice->landevice1900|PC-18-46-17-FB-A4-E3|fhem->landevice->|PC-30-19-66-CF-D5-55|fhem->landevice->landevice1890|PC-30-19-66-CF-D5-55|fhem->landevice->|PC-40-A6-D9-2A-EE-AC|fhem->landevice->landevice1897|PC-40-A6-D9-2A-EE-AC|fhem->landevice->|PC-56-31-C4-C5-68-54|fhem->landevice->landevice1891|PC-56-31-C4-C5-68-54|fhem->landevice->|PC-56-31-C4-C5-68-55|fhem->landevice->landevice1893|PC-56-31-C4-C5-68-55|fhem->landevice->|PC-74-DA-38-0E-45-DB|fhem->landevice->landevice1886|PC-74-DA-38-0E-45-DB|fhem->landevice->|PC-78-D6-F0-20-3F-D2|fhem->landevice->landevice1895|PC-78-D6-F0-20-3F-D2|fhem->landevice->|PC-78-F7-BE-C7-91-49|fhem->landevice->landevice1894|PC-78-F7-BE-C7-91-49|fhem->landevice->|PC-B4-74-43-AA-A1-D5|fhem->landevice->landevice1919|PC-B4-74-43-AA-A1-D5|fhem->landevice->|PC-C4-50-06-78-8A-E1|fhem->landevice->landevice1892|PC-C4-50-06-78-8A-E1|fhem->landevice->|PC-E8-AB-FA-8C-DE-11|fhem->landevice->landevice1887|PC-E8-AB-FA-8C-DE-11|fhem->landevice->|PC-F0-4F-7C-7D-42-FF|fhem->landevice->landevice1896|PC-F0-4F-7C-7D-42-FF|fhem->landevice->172.30.90.224|Test|fhem->landevice->landevice1883|Test|fhem->landevice->172.30.90.221|fritz.box|fhem->landevice->landevice1885|fritz.box|mac_9C_C7_A6_0E_56_FF|fritz.box|box_wlanCount|0|box_guestWlanCount|0|box_wlan_2.4GHz|off|box_wlan_5GHz|off|box_guestWlan|off|box_guestWlanRemain|0|box_dect|on|box_moh|default|box_powerRate|37|fhem->is_double_wlan|1|box_fwVersion|84.06.83|box_fwUpdate|0|box_tr064|on|box_tr069|off|box_stdDialPort|dect1|box_ipExtern|172.30.90.221|box_connect|5|box_cpuTemp|0|gsm_rssi||gsm_state||gsm_technology||gsm_internet||alarm1|Wecker 1|alarm1_state|off|alarm1_time|00:00|alarm1_target|FON 1|alarm1_wdays|daily|alarm2|Wecker 2|alarm2_state|off|alarm2_time|00:00|alarm2_target|FON 1|alarm2_wdays|daily|alarm3|Wecker 3|alarm3_state|off|alarm3_time|00:00|alarm3_target|FON 1|alarm3_wdays|daily|tam1|Anrufbeantworter|tam1_state|off|tam1_newMsg|0|tam1_oldMsg|0|user01|(guest)|user01_thisMonthTime|0:00|user01_todayTime|0:00|user01_todaySeconds|0|user01_type|Guest|userTicket01|743238|.box_TodayBytesReceivedHigh|0|.box_TodayBytesReceivedLow|0|.box_TodayBytesSentHigh|0|.box_TodayBytesSentLow|0|readoutTime|1.11
2017.09.23 14:37:15.256 4: Connection accepted from telnetForBlockingFn_1506167519_127.0.0.1_50338
2017.09.23 14:37:15.509 5: Cmd: >{BlockingStart('48')}<
2017.09.23 14:37:19.929 4: WEB_172.30.90.22_52362 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2017-09.log; BUFLEN:0
list autocreate
No device named autocreate found
list HM_5859DC
No device named HM_5859DC found
Das Device sollte also erstellt werden, aber irgendwas geht da schief...
Greets
Byte
naja ohne autocreate kein pairing möglich. warum fehlt das bei dir???
define autocreate autocreate
attr autocreate filelog ./log/%NAME-%Y.log
so stehts orginal in der fhem.cfg drin !
genau dass war es!
DANKE!
Ich kann mir ehrlich gesagt nicht erklären, warum der Eintrag aus der Config fehlte!
Greets
Byte
