habe einen Arduino Mega mit ConfugurableFirmata V_2_06 per Ethernet mit dem Fhemserver (auf Raspi) verbunden. Die Verbindung steht auch sauber.
CFGFN FHEM/arduino.cfg
CONNECTS 1
DEF 3030 global
DeviceName 3030
FD 31
NAME Arduino_03
NOTIFYDEV global
NR 116
NTFY_ORDER 50-Arduino_03
PORT 3030
STATE Initialized
TYPE FRM
analog_pins 54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
analog_resolutions 54:10,55:10,56:10,57:10,58:10,59:10,60:10,61:10,62:10,63:10,64:10,65:10,66:10,67:10,68:10,69:10
encoder_pins 2,3,18,19,20,21
encoder_resolutions 2:28,3:28,18:28,19:28,20:28,21:28
firmware ConfigurableFirmataHB02.ino
firmware_version V_2_06
i2c_pins 20,21
input_pins 2,3,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
onewire_pins 2,3,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
output_pins 2,3,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
protocol_version V_2_06
pwm_pins 2,3,5,6,7,8,9,10,11,12,13,44,45,46
pwm_resolutions 2:8,3:8,5:8,6:8,7:8,8:8,9:8,10:8,11:8,12:8,13:8,44:8,45:8,46:8
Helper:
DBLOG:
state:
myDbLog:
TIME 1515783028.63968
VALUE Initialized
2018-01-12 19:50:28 state Initialized
SERIAL:
SocketDevice:
BUF
DeviceName 3030
FD 37
NAME Arduino_03_192.168.0.51_49168
NR 386
PEER 192.168.0.51
PORT 49168
SNAME Arduino_03
SSL
STATE Connected
TEMPORARY 1
TYPE FRM
icon it_server
room Arduino
nun habe ich versuch an Pin 22 einen 1-wire bus zu connecten, leider zieht Fhem jedoch via OWX kein device vom 1wire Bus.
ALARMED 0
ASYNCHRONOUS 0
DEF Arduino_03:22
DeviceName Arduino_03:22
FRM_OWX_CORRELATIONID 0
HWDEVICE Arduino_03
INITDONE 1
INTERFACE firmata
IODev Arduino_03
NAME Ard03_1W_02
NR 159
PARTIAL
PIN 22
PRESENT 1
ROM_ID FF
STATE Initialized
TYPE OWX
interval 300
timeout 2
version 7.05
DEVHASH:
Ard03_1W_02 Busmaster
DEVS:
FRM_OWX_REPLIES:
2018-01-12 19:25:38 state error initializing: pin 22
room Arduino
Logfile:2018.01.12 19:50:59 1: OWX_Init called for bus Ard03_1W_02 with interface state Initialized, now going for detect
2018.01.12 19:51:04 1: OWX_Discover: 1-Wire devices found on bus Ard03_1W_02 ()
wie kann ich die Ursache eingrenzen oder optimaler Weise auch beheben?
Sieht die Verkabelung in etwa so aus?
Gruß Jens
in etwa, die Verkabelung ist zwar am Mega und auf Grund von 5 cm Leitungslänge benötige ich den Pullup nicht, aber sie Stimmt, habs nachgemessen, Spannung und Ground kommen an.
Probier's mal mit. ;)
hab ich,
gleiches Ergebniss 2018.01.12 21:26:13 1: OWX_Discover: 1-Wire devices found on bus Ard03_1W_02 ()
habe heute im Log gefunden:
2018.01.13 13:22:47 1: Error: >Arduino_03:22< has no TYPE, but following keys: ><
kann das mit der Ursache zusammenhängen?
Hallo devien,
also muss der Fehler weiter eingegrenzt werden. Hast du "update" und "shutdown restart" ausgeführt? Sind die Module aktuell? Was sagt "version"? Wie ist das Schaltbild? Welche 1-wire-devices verwendest du?
Gruß Jens
Zitat von: dirigent am 13 Januar 2018, 14:48:50
Hallo devien,
Gruß Jens
update ist aktuell, natürlich schutdown restart bereits gemacht - > keine Auswirkung
version:
Latest Revision: 15863
File Rev Last Change
fhem.pl 15842 2018-01-10 21:07:52Z rudolfkoenig
96_allowed.pm 15709 2017-12-27 15:03:48Z rudolfkoenig
90_at.pm 15795 2018-01-05 20:46:21Z rudolfkoenig
98_autocreate.pm 15620 2017-12-16 18:10:36Z rudolfkoenig
93_DbLog.pm 15851 2018-01-11 22:22:44Z DS_Starter
98_DOIF.pm 15751 2018-01-02 11:03:10Z Damian
98_dummy.pm 12700 2016-12-02 16:49:42Z rudolfkoenig
91_eventTypes.pm 14888 2017-08-13 12:07:12Z rudolfkoenig
01_FHEMWEB.pm 15850 2018-01-11 22:04:01Z rudolfkoenig
92_FileLog.pm 15628 2017-12-17 12:01:30Z rudolfkoenig
95_FLOORPLAN.pm 13735 2017-03-19 12:43:53Z UliM
10_FRM.pm 15794 2018-01-05 19:14:58Z jensb
20_FRM_AD.pm 15770 2018-01-03 19:06:32Z jensb
20_FRM_OUT.pm 15771 2018-01-03 19:12:25Z jensb
20_FRM_PWM.pm 15772 2018-01-03 19:27:23Z jensb
52_I2C_MCP23008.pm 13602 2017-03-05 01:39:01Z klausw
52_I2C_MCP342x.pm 13424 2017-02-16 22:06:16Z klausw
No Id found for 99_myFloorplanList.pm
91_notify.pm 15795 2018-01-05 20:46:21Z rudolfkoenig
11_OWDevice.pm 14523 2017-06-16 05:15:56Z neubert
10_OWServer.pm 15589 2017-12-11 11:58:29Z neubert
00_OWX.pm 15392 2017-11-05 06:46:46Z phenning
11_OWX_FRM.pm 15392 2017-11-05 06:46:46Z phenning
98_ping.pm 10939 2016-02-25 22:30:46Z mattwire
33_readingsGroup.pm 15100 2017-09-19 21:21:27Z justme1968
00_RPII2C.pm 15021 2017-09-06 19:48:55Z klausw
51_RPI_GPIO.pm 15821 2018-01-07 21:36:43Z klausw
99_SUNRISE_EL.pm 15572 2017-12-08 22:18:13Z rudolfkoenig
98_SVG.pm 15863 2018-01-12 21:32:18Z rudolfkoenig
42_SYSMON.pm 15378 2017-11-01 20:36:57Z hexenmeister
32_SYSSTAT.pm 10567 2016-01-18 21:34:09Z justme1968
50_TelegramBot.pm 15652 2017-12-20 11:29:39Z viegener
98_telnet.pm 15676 2017-12-23 19:33:43Z rudolfkoenig
99_Utils.pm 15713 2017-12-28 11:01:02Z rudolfkoenig
98_version.pm 15140 2017-09-26 09:20:09Z markusbloch
59_Weather.pm 12559 2016-11-13 08:54:54Z borisneubert
98_weblink.pm 14888 2017-08-13 12:07:12Z rudolfkoenig
No Id found for Base.pm
Blocking.pm 15412 2017-11-09 14:34:29Z rudolfkoenig
Color.pm 11159 2016-03-30 16:08:06Z justme1968
No Id found for Constants.pm
DevIo.pm 14933 2017-08-20 14:21:58Z rudolfkoenig
GPUtils.pm 6653 2014-10-02 11:59:37Z ntruchsess
HttpUtils.pm 15631 2017-12-17 12:33:03Z rudolfkoenig
myUtilsTemplate.pm 7570 2015-01-14 18:31:44Z rudolfkoenig
# $Id: OWNet.pm,v 1.24 2013/02/02 11:41:28 alfille Exp $
No Id found for Platform.pm
No Id found for Protocol.pm
RTypes.pm 10476 2016-01-12 21:03:33Z borisneubert
SetExtensions.pm 12935 2017-01-02 19:51:46Z rudolfkoenig
TcpServerUtils.pm 15707 2017-12-27 14:41:21Z rudolfkoenig
TimeSeries.pm 10907 2016-02-21 17:38:02Z borisneubert
YahooWeatherAPI.pm 15742 2018-01-01 07:55:55Z neubert
doif.js 15546 2017-12-03 09:57:42Z Ellert
fhemweb.js 15850 2018-01-11 22:04:01Z rudolfkoenig
fhemweb_readingsGroup.js 15189 2017-10-03 17:53:27Z justme1968
das Schaltbild ist klassisch (am arduino, siehe vorige Antworten)
Angeschlossen ist ein U1WTVS von SEDtronic https://www.unipi.technology/sedtronic-1-wire-sensor-p67?categoryId=3 (https://www.unipi.technology/sedtronic-1-wire-sensor-p67?categoryId=3)
getestet und funktional ist er auch, hatte ihn (und weitere welche ich bereits alternativ am arduino ausprobiert hab) zuvor bereits am Unipi funktional getestet gehabt.
nachdem mir offenbar unbekannt verursacht der fhem Prozess abgestürzt ist habe ich ihn neu gestartet und im Log tauchte folgende Meldung auf:
pin '22' is not configured for mode 'ONEWIRE' at FHEM/lib/Device/Firmata/Platform.pm line 779.
Gegen den Absturz gibt es ein Patch: https://forum.fhem.de/index.php/topic,82020.msg740801.html#msg740801 (https://forum.fhem.de/index.php/topic,82020.msg740801.html#msg740801)
wie setze ich das patch ein?, ich würde eben die original 11_OQX_FRM.pm umbenennen und gegen den Patch ersetzen, aber bin mir nicht sicher das das der korrekte weg ist.
der Dateigröße nach muss ich das patch wohl eher der original Datei anhängen oder?
EDIT: habs gefunden / herrausgefunden, zwichen den @ stehen die Zeilennummern wo der jwl. code gegen den im Patch jeweils ausgetausch werden muss. Das wird wohl etwas dauern, ich frickel das mal rein.
davon ab, ich glaub nicht das der Patch auch mein 1-w erkennungsproblem löst :(
hab den Absturzpatch erfolgreich eingefügt.
Wie erwartet hat die jedoch die Problematik das die 1 Wire Interfaces nicht erkannt werden nicht gebessert.
Habe eben deinen Link angesehen. Keine Ahnung, ob der Kombisensor überhaupt unterstützt wird. pah kann dir da sicher Auskunft geben. Vorerst empfehle ich eine DS18b20 o.a. zu versuchen.
Gruß Jens
Gruß Jens
der Sensor basiert auf einem 1w Batteriesensor, funktioniert wie gesagt am Fehm server selbst (unipi+raspberry).
habe auch einen 18b20 getestet, gleiches Ergebniss leider.
habe zum Test ob ich evtl. den Pin trotz Pinout falsch identifiziert hab, als FRM_OUT steuert der Arduino problemlos eine Relaiscard an. Der Pin und Ansteuerung über TCP/P funktioieren, es muss bei mir also wohl doch irgendwo am OWX hängen...
Hab auch getestet das device mal umzubennenen (ziffern raus) leider auch kein Positiver Effekt.
Hast du es mal an einem Port unter 20 versucht?
nein hab ich noch nicht, da ich mir die Kommunikations Ports in Reserver halten möchte (eigentlich) theoretisch nurtzt das ethernet schield nur die Pins 10-13, 14 bis 21 sollten also frei sein, aber es ist nicht mein Wunsch die unteren Ports zu nutzen, testen kann ichs aber mal.
so, nun habe ich es an PINs 19 - 21 versucht, unterhalb von 21 scheint es zu funktionieren.
ALARMED 0
ASYNCHRONOUS 0
DEF Arduino_03:20
DeviceName Arduino_03:20
HWDEVICE Arduino_03
INITDONE 1
INTERFACE firmata
IODev Arduino_03
NAME Ard03_1W_bb
NR 169
PARTIAL
PIN 20
PRESENT 1
ROM_ID FF
STATE Initialized
TYPE OWX
interval 300
timeout 2
version 7.05
DEVHASH:
Ard03_1W_bb Busmaster
OWX_26_728E06020000 26.728E06020000.B8
DEVS:
26.728E06020000.B8
FRM_OWX_REPLIES:
room Arduino
und
ALARMED 0
ASYNCHRONOUS 0
DEF Arduino_03:21
DeviceName Arduino_03:21
FRM_OWX_CORRELATIONID 6
FRM_OWX_CURRDEV 26.7A8F06020000.D4
HWDEVICE Arduino_03
INITDONE 1
INTERFACE firmata
IODev Arduino_03
NAME Ard03_1W_cc
NR 171
PARTIAL
PIN 21
PRESENT 1
ROM_ID FF
STATE Initialized
TYPE OWX
interval 300
timeout 2
version 7.05
DEVHASH:
Ard03_1W_cc Busmaster
OWX_26_7A8F06020000 26.7A8F06020000.D4
DEVS:
26.7A8F06020000.D4
FRM_OWX_REPLIES:
26.7A8F06020000.D4 ���������
FRM_OWX_REQUESTS:
0:
device 26.7A8F06020000.D4
command:
id 0
read 0.01
select:
crc 212
family 38
identity:
122
143
6
2
0
0
write:
180
1:
command:
id 1
read 0.02
select:
crc 212
family 38
identity:
122
143
6
2
0
0
write:
184
0
3:
command:
id 3
read 0.01
select:
crc 212
family 38
identity:
122
143
6
2
0
0
write:
180
4:
command:
id 4
read 0.02
select:
crc 212
family 38
identity:
122
143
6
2
0
0
write:
184
0
room Arduino
man sieht aber auch hier einen Unterschied zwischen den beiden PINS welcher offenbar im LOG angezeigt wird:
2018.01.14 10:39:05 1: OWXMULTI_BinValues: OWX_26_7A8F06020000: conversion not complete or data invalid in context ds2438.getvdd 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff
Nun bleiben mir also 2 Fragen,
1. warum funktioniert es nur unterhalb von PIN21?
2. kann ich die Fehlermeldung im Log beheben?
Geht doch. :)
Die Begrenzung der möglichen PINs muss sich mal ein Entwickler ausgedacht haben...
Zitat2018.01.13 13:22:47 1: Error: >Arduino_03:22< has no TYPE, but following keys: ><
kannst du ignorieren.
Zitat2018.01.14 10:39:05 1: OWXMULTI_BinValues: OWX_26_7A8F06020000: conversion not complete or data invalid in context ds2438.getvdd 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff
ist vermutlich ein Kontaktfehler.
Gruß Jens
Zitat von: dirigent am 14 Januar 2018, 11:48:06
Geht doch. :)
eine begrenzung und trotzdem werden die höheren PINs im Arduino device als 1 wire Ports angezeigt?
das scheint mir etwas inkonsequent
...kannst du ignorieren.ist vermutlich ein Kontaktfehler.
ein Kontaktfehler beim Physikalischen Anschluss?
Ja und Ja. 8)
hm, nun krieg ich meine Sensoren zwar angezeigt, aber die Einstufung als OWMulti ist unproduktiv.
Leider raucht mir FHEM jedes mal ab wenn ich die Sensoren als OWDevice definiere und
ALARMED 0
ASYNCHRONOUS 0
DEF Arduino_03:20
HWDEVICE Arduino_03
INITDONE 1
INTERFACE firmata
IODev Arduino_03
NAME Ard03_1W_bb
NR 167
PARTIAL
PIN 20
PRESENT 1
ROM_ID FF
STATE Initialized
TYPE OWX
interval 300
timeout 2
version 7.05
DEVHASH:
DEVS:
FRM_OWX_REPLIES:
room Arduino
[/code]
als IODevice setze...
die letzte Meldung im Log vorm Absturz lautet dann immer:2018.01.14 15:35:42 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/10_OWServer.pm line 387.
2018.01.14 15:35:42 1: PERL WARNING: Use of uninitialized value in pattern match (m//) at ./FHEM/10_OWServer.pm line 400.
2018.01.14 15:35:51 1: PERL WARNING: Use of uninitialized value in subroutine entry at ./FHEM/11_OWDevice.pm line 448.
Undefined subroutine &main:: called at ./FHEM/11_OWDevice.pm line 448.
Das liegt wohl daran, dass OWDevice zu OWServer gehört, du aber OWX nutzt.
ZitatDefiniert ein 1-Wire- Gerät. 1-Wire- Geräte werden anhand ihrer Adresse <address> definiert. Diese wird durch den zuvor eingerichteten OWServer bereitgestellt.
Gruß Jens
Gruß Jens
klingt plausibel, aber da ich den Arduino über FRM angebunden hab kann ich nur OWX nehmen, welche alternative bleibt mir wenn OWMulti mir nicht mal die Temperatur vom Device ausgibt?
bzw wie komme ich zumindest an owg_val herran?
ASYNC 0
DEF DS2438 7A8F06020000
ERRCOUNT 26
ERRSTATE 1
INTERVAL 300
IODev Ard_drei_bb
NAME OWX_26_7A8F06020000
NOTIFYDEV global
NR 169
NTFY_ORDER 50-OWX_26_7A8F06020000
OW_FAMILY 26
OW_ID 7A8F06020000
PRESENT 0
ROM_ID 26.7A8F06020000.D4
STATE initialized
TYPE OWMULTI
Helper:
DBLOG:
state:
myDbLog:
TIME 1515944689.27011
VALUE initialized
2018-01-14 16:44:49 state initialized
owg_val:
-0.00390625
10.23
10.23
0.249755859375
IODev Ard_drei_bb
model DS2438
room OWX
Es gibt eine neue modifizierte 11_OWX_FRM.pmhttps://forum.fhem.de/index.php/topic,81104.msg748728.html#msg748728 (https://forum.fhem.de/index.php/topic,81104.msg748728.html#msg748728).
Lösche mal alle relevanten Einträge zu FRM, OWX und OWMulti aus der fhem.save und starte fhem neu. So konnte man OWTherm zum plaudern überreden.
Gruß Jens
hm,
OW Therm bietet mir aber höhstens die Chance die Temperaturwerte der Sensoren zu bekommen, VAD und VIS hingegen kriege ich darüber nicht. Ich nehme an das ich via OW Multi die Sensoren paralel abgefragt bekomme, eine doppelte Definition der Sensoren verursacht mir jedoch ein gewisses unbehagen.
Ich hege den Gedanken mir evt einen DS2482-100 an den Arduino zu hängen, aber kann ich damit dann per OW Server auf diesen zugreifen?
Äh - wieso das denn ? Der DS2438 hat ein ganz anderes Kommunikationsprotokoll als ein DS18B20 (und Ähnliche).
Entweder OWTHERM, ODER OWMULTI.
pah
pah
Weil OW Multi mir bei diesem Sensor nicht die Werte ausgibt die ich benötige (was OW Device zuvor jedoch am Raspberri selbst problemlos gemacht hat).
ganz zu schweigen das OWMulti mir ständig
2018.01.14 21:10:19 1: OWXMULTI_BinValues: OWX_26_7A8F06020000: conversion not complete or data invalid in context ds2438.getvdd 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff
beschert, obgleich ich die Verkabelung mehrfach auf sauberkeit geprüft und auch die Sensoren ausgetauscht habe.
Kann nicht sein - wenn Mist empfangen wird, wird eben kein Wert berechnet.
Und die Vorstellung, dass man dann eben einfach OWTHERM an Stelle von OWMULTI verwendet, ist absurd.
Bei mir werkeln übrigens 8 verschiedene DS2438 mit OWMULTI ganz problemlos vor sich hin.
pah
pah
ja, wie schon beschrieben würde mir OWTherm nicht zusagen wenn ich die beiden anderen Messwerte meiner Sensoren dadurch verliere.
habe bei mir https://www.unipi.technology/sedtronic-1-wire-sensor-p67?categoryId=3 (https://www.unipi.technology/sedtronic-1-wire-sensor-p67?categoryId=3) im Einsatz, auf OWMulti geben die
ASYNC 0
ERRCOUNT 26
ERRSTATE 1
INTERVAL 300
IODev Ard_drei_bb
NOTIFYDEV global
NR 169
OW_FAMILY 26
OW_ID 7A8F06020000
PRESENT 0
STATE initialized
TYPE OWMULTI
Helper:
DBLOG:
state:
myDbLog:
VALUE initialized
owg_val:
-0.00390625
10.23
10.23
0.249755859375
IODev Ard_drei_bb
model DS2438
room OWX
aus. ich nehme einfach mal an das " owg_val" 2 der Werte ausgibt die ich benötige, nur eben nicht die Temperatur.....
Rede ich chinesisch, oder wie ? Mit OWTHERM kann man keine DS2438 abfragen.
pah
Sorry, wenn ich mit meinem missverständlichen Beitrag für Stress gesorgt habe. Es sollte kein OWTherm definiert werden, sondern es handelte sich um ein Beispiel.
Lösche alle Devices, welche die OWID 7A8F06020000 haben und führe folgende Kommandos aus:
setreading Ard_drei_bb state Initialized
get Ard_drei_bb devices
get OWX_26_7A8F06020000 reading
get OWX_26_7A8F06020000 temperature
Gruß Jens
Zitatsetreading Ard_drei_bb state Initialized
Warum das denn ? Das sollte man niemals von Hand machen, sondern dem Modul überlassen. Sonst sind unerwünschte Effekte nicht auszuschließen.
pah
pah
das habe ich nicht per Hand gemacht, das kam selbsständig, da hatte ich kein doing drann.
Ich entnehme jedoch deiner Entrüstung das das nicht so sein sollte?
Hallo pah,
der Grund ist hier beschrieben.
https://forum.fhem.de/index.php/topic,81815.msg749243.html#msg749243 (https://forum.fhem.de/index.php/topic,81815.msg749243.html#msg749243)
Gruß Jens
Wäre ja nett gewesen, wenn man mir das mitgeteilt hätte - ich kann nicht jeden Thread lesen.
pah
Daneben.
Das eine war, wenn ich mich recht erinnere, eine gewünschte Option - und hier geht es um die Behebung eines allgemeinen Problems.
pah
Wenn nach einem Update das System abstürzt und der Wunsch nach Wiederherstellung der Lauffähigkeit von fhem eine Option ist, magst du Recht haben. Die Frage nach dem ehemals unterstützten DS2482 ist weiterhin offen. ;)
wähhhh
ich komme kaum noch mit, Glaube aber ich hab es halbwegs erfasst.
- die Letzten Posts betreffen mein Problem offenbar nicht direkt
- setreading Ard_drei_bb state Initialized <- ist offenbar nicht falsch
bleibt noch die Frage ob es möglich wäre mit einem DS2482-100 am Arduino OWServer zu nutzen anstelle von OWX?
Gruß Jens
hat leider nicht funktioniert, es wird keine Temperatur ausgegeben....
Zitatehemals unterstützten DS2482
Von mir nicht
pah
@pah
Ok, es geht ja auch ohne.
@devien
Ganz schön stur. Poste noch mal alle Infos (Sketch, FRM-und OWX-Device inkl. LOG5, Schaltplan). Irgendwo muss ein Fehler sein. Das Ganze nur mit einem DS18b20.
Gruß Jens
Hey, hatte das nochmal mit nem 18b20 getestet, gab wieder kein Anderes Ergebiss leider.
Bin aus Zeitkritischen Gründen dann dazu übergegangen anstelle des Arduinos einen ungenutzten Raspberry pi 1b fix per fhem2fhem hinzupacken und diesen mit nem 2428-800 zu koppeln, 1 wire übernimmt der nun zuverlässig.
Der Arduino steuert derweil per FRM Out meine 16er Relaiskarte für die Stellmotoren meines Heizkreisverteilers an, das schafft er ohne zu murren, evtl. belege ich demnächst noch die PWM fähigen Ports für die RGB LED Streifen als Beleuchtung. Soll soweit reichen.
Danke für eure Unterstützung.
ich habe aktuell das gleiche Problem.
Das Firmata Device läuft mittels configFirmata auf einem nano 328p.
Ein LCD Display ist eingebunden und empfängt sauber Signale uns stellt die Daten auch korrekt dar.
Jetzt wollte ich ein 1WireBus eröffnen und an diesem mehrere DS18B20 betreiben.
Der DS18B20 ist am Port D9 (9) aktuell angeschlossen:
defmod 1Wtemp OWX FIRMATA:9
es werden aber keine Devices gefunden.
get Version liefert 7.11
Habe ich hier einen Denkfehler oder was ist da los?
niemand eine Idee ??
Hallo.
Lässt sich ggf. nur via Trial & Error herausfinden. Ich hatte bei mir den 4,7KOhm Widerstand vergessen :o (Hinweis hier im Forum erhalten 8)) und aufm Steckbrett waren die Kontakte unsauber (Billigteil). Mit 4,7K und sauberen Kontakten gings super. Deshalb hilft es Dir m.E. eher bei der Hardware zu checken, auch wenns Display (I2C?) bereits läuft.
Ich würds ins Blaue geschossen so versuchen zu prüfen/messen:
- 4,7K zw. 5V und Data, Widerstand OK, Kontakt/ Spannung OK?
- Sensor OK, Kontakte OK (5V, GPIO, GND)?, anderen Sensor probiert?
- andere GPIO probiert?
Bin leider kein Experte und Du hast das wahrscheinlich eh schon alles durch, aber den Versuch isses ggf. wert :)
rob
Zitat von: rob am 26 Juni 2019, 15:40:42
Hallo.
war alles i.O.
ja alles OK
Der Fehler lag beim Anwender....
Ich habe fälschlichscerweise die Bibliothek für den 1Wire nicht unkludiert gehabt ´- x fach schon gebaut und nun das ... :-[
Hi.
Ist doch supi. Problem gefunden und gut. Ich fänds schlimmer, wenn alles dreifach gecheckt und OK wäre und das Problem mal auftaucht und mal nicht - da kann man manchmal verzeifeln ;)
rob
