GDS Fehlermeldung
Begonnen von Steffen, 14 Dezember 2015, 17:05:08
Steffen
habe seit dem 13.12 diese Fehler Meldung im Log:
2015.12.14 17:01:57 1: PERL WARNING: Use of uninitialized value $align in string eq at /opt/fhem/FHEM/55_GDS.pm line 972.
2015.12.14 17:01:57 3: stacktrace:
2015.12.14 17:01:57 3:     main::__ANON__                      called by /opt/fhem/FHEM/55_GDS.pm (972)
2015.12.14 17:01:57 3:     main::_readItem                     called by /opt/fhem/FHEM/55_GDS.pm (922)
2015.12.14 17:01:57 3:     main::getConditions                 called by /opt/fhem/FHEM/55_GDS.pm (1326)
2015.12.14 17:01:57 3:     main::_finishedCONDITIONS           called by (eval 344) (1)
2015.12.14 17:01:57 3:     (eval)                              called by fhem.pl (980)
2015.12.14 17:01:57 3:     main::AnalyzePerlCommand            called by fhem.pl (1000)
2015.12.14 17:01:57 3:     main::AnalyzeCommand                called by fhem.pl (928)
2015.12.14 17:01:57 3:     main::AnalyzeCommandChain           called by /opt/fhem/FHEM/98_telnet.pm (272)
2015.12.14 17:01:57 3:     main::telnet_Read                   called by fhem.pl (3162)
2015.12.14 17:01:57 3:     main::CallFn                        called by fhem.pl (656)
2015.12.14 17:01:57 1: PERL WARNING: Use of uninitialized value $align in string eq at /opt/fhem/FHEM/55_GDS.pm line 976.
2015.12.14 17:01:57 3:     main::__ANON__                      called by /opt/fhem/FHEM/55_GDS.pm (976)
keine Ahnung ob es schlimm ist, scheint aber Trotzdem zu Funktionieren...
Mfg Steffen
Steffen
habe immer noch diese Fehlermeldung im Log:
2015.12.27 16:57:43 1: PERL WARNING: Use of uninitialized value $align in string eq at /opt/fhem/FHEM/55_GDS.pm line 972.
2015.12.27 16:57:43 3: stacktrace:
2015.12.27 16:57:43 3:     main::__ANON__                      called by /opt/fhem/FHEM/55_GDS.pm (972)
2015.12.27 16:57:43 3:     main::_readItem                     called by /opt/fhem/FHEM/55_GDS.pm (922)
2015.12.27 16:57:43 3:     main::getConditions                 called by /opt/fhem/FHEM/55_GDS.pm (1326)
2015.12.27 16:57:43 3:     main::_finishedCONDITIONS           called by (eval 6639) (1)
2015.12.27 16:57:43 3:     (eval)                              called by fhem.pl (988)
2015.12.27 16:57:43 3:     main::AnalyzePerlCommand            called by fhem.pl (1008)
2015.12.27 16:57:43 3:     main::AnalyzeCommand                called by fhem.pl (936)
2015.12.27 16:57:43 3:     main::AnalyzeCommandChain           called by /opt/fhem/FHEM/98_telnet.pm (271)
2015.12.27 16:57:43 3:     main::telnet_Read                   called by fhem.pl (3185)
2015.12.27 16:57:43 3:     main::CallFn                        called by fhem.pl (657)
2015.12.27 16:57:43 1: PERL WARNING: Use of uninitialized value $align in string eq at /opt/fhem/FHEM/55_GDS.pm line 976.
2015.12.27 16:57:43 3:     main::__ANON__                      called by /opt/fhem/FHEM/55_GDS.pm (976)
2015.12.27 16:57:43 3:     main::getConditions                 called by /opt/fhem/FHEM/55_GDS.pm (701)
2015.12.27 16:57:43 3:     main::GDS_GetUpdate                 called by fhem.pl (2800)
2015.12.27 16:57:43 3:     main::HandleTimeout                 called by fhem.pl (589)
2015.12.27 17:05:00 3: CUL_HM set WaschKeller desired-temp 17.0
2015.12.27 17:57:46 1: PERL WARNING: Use of uninitialized value $align in string eq at /opt/fhem/FHEM/55_GDS.pm line 972.
2015.12.27 17:57:46 3: stacktrace:
2015.12.27 17:57:46 3:     main::__ANON__                      called by /opt/fhem/FHEM/55_GDS.pm (972)
2015.12.27 17:57:46 3:     main::_readItem                     called by /opt/fhem/FHEM/55_GDS.pm (922)
2015.12.27 17:57:46 3:     main::getConditions                 called by /opt/fhem/FHEM/55_GDS.pm (1326)
2015.12.27 17:57:46 3:     main::_finishedCONDITIONS           called by (eval 7126) (1)
2015.12.27 17:57:46 3:     (eval)                              called by fhem.pl (988)
2015.12.27 17:57:46 3:     main::AnalyzePerlCommand            called by fhem.pl (1008)
2015.12.27 17:57:46 3:     main::AnalyzeCommand                called by fhem.pl (936)
2015.12.27 17:57:46 3:     main::AnalyzeCommandChain           called by /opt/fhem/FHEM/98_telnet.pm (271)
2015.12.27 17:57:46 3:     main::telnet_Read                   called by fhem.pl (3185)
2015.12.27 17:57:46 3:     main::CallFn                        called by fhem.pl (657)
2015.12.27 17:57:46 1: PERL WARNING: Use of uninitialized value $align in string eq at /opt/fhem/FHEM/55_GDS.pm line 976.
2015.12.27 17:57:46 3:     main::__ANON__                      called by /opt/fhem/FHEM/55_GDS.pm (976)
2015.12.27 17:57:47 1: PERL WARNING: Use of uninitialized value $align in string eq at /opt/fhem/FHEM/55_GDS.pm line 972.
2015.12.27 17:57:47 3: stacktrace:
2015.12.27 17:57:47 3:     main::__ANON__                      called by /opt/fhem/FHEM/55_GDS.pm (972)
2015.12.27 17:57:47 3:     main::_readItem                     called by /opt/fhem/FHEM/55_GDS.pm (922)
2015.12.27 17:57:47 3:     main::getConditions                 called by /opt/fhem/FHEM/55_GDS.pm (701)
2015.12.27 17:57:47 3:     main::GDS_GetUpdate                 called by fhem.pl (2800)
2015.12.27 17:57:47 3:     main::HandleTimeout                 called by fhem.pl (589)
2015.12.27 17:57:47 1: PERL WARNING: Use of uninitialized value $align in string eq at /opt/fhem/FHEM/55_GDS.pm line 976.
2015.12.27 17:57:47 3:     main::__ANON__                      called by /opt/fhem/FHEM/55_GDS.pm (976)
2015.12.27 17:57:48 1: PERL WARNING: Use of uninitialized value $align in string eq at /opt/fhem/FHEM/55_GDS.pm line 972.
2015.12.27 17:57:48 3: stacktrace:
2015.12.27 17:57:48 3:     main::__ANON__                      called by /opt/fhem/FHEM/55_GDS.pm (972)
2015.12.27 17:57:48 3:     main::_readItem                     called by /opt/fhem/FHEM/55_GDS.pm (922)
2015.12.27 17:57:48 3:     main::getConditions                 called by /opt/fhem/FHEM/55_GDS.pm (1326)
2015.12.27 17:57:48 3:     main::_finishedCONDITIONS           called by (eval 7127) (1)
2015.12.27 17:57:48 3:     (eval)                              called by fhem.pl (988)
2015.12.27 17:57:48 3:     main::AnalyzePerlCommand            called by fhem.pl (1008)
2015.12.27 17:57:48 3:     main::AnalyzeCommand                called by fhem.pl (936)
2015.12.27 17:57:48 3:     main::AnalyzeCommandChain           called by /opt/fhem/FHEM/98_telnet.pm (271)
2015.12.27 17:57:48 3:     main::telnet_Read                   called by fhem.pl (3185)
2015.12.27 17:57:48 3:     main::CallFn                        called by fhem.pl (657)
2015.12.27 17:57:48 1: PERL WARNING: Use of uninitialized value $align in string eq at /opt/fhem/FHEM/55_GDS.pm line 976.
2015.12.27 17:57:48 3:     main::__ANON__                      called by /opt/fhem/FHEM/55_GDS.pm (976)
bekomme es leider nicht von alleine Weg, könnte jemand das bitte ansehen?!
Mfg Steffen
Und auch wenn Du es noch fünf Mal behauptest, das ist kein Fehler, sondern nur eine Warnung. Aber ein Grund, mir deshalb meine Urlaubsruhe stören zu lassen, ist das keinesfalls :)
Wenn ich mal viel Zeit und Lust habe, schaue ich mal nach, was dafür verantwortlich ist. Bei mir taucht die Warnung auch auf, aber sie interessiert/stört mich nicht besonders.
