hat jemand schon OWServer auf einem Raspi4 unter Buster installiert? Bei mir funktioniert es nicht. Die Installation läuft durch aber die Weboberfläche ist nicht erreichbar.
Bei sudo /etc/init.d/owserver restart kommt
pi@fhempinew:~ $ sudo /etc/init.d/owserver restart
[....] Restarting owserver (via systemctl): owserver.serviceJob for owserver.service failed because the service did not take the steps required by its unit configuration.
See "systemctl status owserver.service" and "journalctl -xe" for details.
pi@fhempinew:~ $ sudo systemctl status owserver.service
● owserver.service - Backend server for 1-wire control
Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor preset: enabled)
Active: failed (Result: protocol) since Tue 2019-08-13 20:20:32 CEST; 5min ago
Docs: man:owserver(1)
Process: 3873 ExecStart=/usr/bin/owserver -c /etc/owfs.conf (code=exited, status=0/SUCCES
Main PID: 3873 (code=exited, status=0/SUCCESS)
Aug 13 20:20:32 fhempinew systemd[1]: owserver.service: Service RestartSec=100ms expired, s
Aug 13 20:20:32 fhempinew systemd[1]: owserver.service: Scheduled restart job, restart coun
Aug 13 20:20:32 fhempinew systemd[1]: Stopped Backend server for 1-wire control.
Aug 13 20:20:32 fhempinew systemd[1]: owserver.service: Start request repeated too quickly.
Aug 13 20:20:32 fhempinew systemd[1]: owserver.service: Failed with result 'protocol'.
Aug 13 20:20:32 fhempinew systemd[1]: Failed to start Backend server for 1-wire control.
pi@fhempinew:~ $ sudo journalctl -xe
-- Support: https://www.debian.org/support
-- A stop job for unit owserver.service has finished.
-- The job identifier is 4987 and the job result is done.
Aug 13 20:29:16 fhempinew systemd[1]: owserver.service: Start request repeated too quickly.
Aug 13 20:29:16 fhempinew systemd[1]: owserver.service: Failed with result 'protocol'.
-- Subject: Unit failed
-- Defined-By: systemd
-- The unit owserver.service has entered the 'failed' state with result 'protocol'.
Aug 13 20:29:16 fhempinew systemd[1]: Failed to start Backend server for 1-wire control.
-- Subject: A start job for unit owserver.service has failed
-- A start job for unit owserver.service has finished with a failure.
-- The job identifier is 4987 and the job result is failed.
Aug 13 20:29:18 fhempinew sudo[4240]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COM
Aug 13 20:29:18 fhempinew sudo[4240]: pam_unix(sudo:session): session opened for user root
lines 4434-4455/4455 (END)
Bist jetzt bin ich bei der Suche im Web nur auf weiter User getroffen die das Problem haben aber eine Lösung war nicht zu finden.
Cetri
Guten Abend
wie im anderen Thread bereits geschrieben läuft FHEM nun bei mir.
1wire funktioniert auch. Hier mein Weg:
OW Server installieren
https://wiki.fhem.de/wiki/OWServer_%26_OWDevice
sudo apt-get install owserver ow-shell owhttpd owftpd
Bei einer Fehlermeldung: sudo apt-get purge
sudo apt-get update
sudo apt-get dist-upgrade
Version überprüfen
/usr/bin/owhttpd -V
3.2p3
libow version:
3.2p3
Schreibrechte auf die owfs.conf
pi@RPiGarageneu:~ $ cd /etc
pi@RPiGarageneu:/etc $ sudo chmod 777 owfs.conf
Dadurch kann die alte Datei hochgeladen werden
Schreibrechte um 11-onwire.rules nach cd /etc/udev/rulres.d zu kopieren
cd /etc/udev sudo chmod 777 rules.d
Über die Berechtigungen kann sicher wieder diskutiert werden - aber so läuft es bei mir jetzt
Hoffe du kommst damit weiter
Helmut
Helmut
Hi Helmut,
ja danke. Jetzt geht es. ;)
Jörg
Freut mich dass auch ich einmal helfen konnte
