folgendes warning kommt seit dem heutigen update2020.05.23 09:29:19 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 4188.
2020.05.23 09:29:19 1: stacktrace:
2020.05.23 09:29:19 1: main::__ANON__ called by ./FHEM/10_CUL_HM.pm (4188)
2020.05.23 09:29:19 1: main::CUL_HM_SetList called by ./FHEM/10_CUL_HM.pm (4254)
2020.05.23 09:29:19 1: main::CUL_HM_Set called by fhem.pl (3789)
2020.05.23 09:29:19 1: main::CallFn called by fhem.pl (1897)
2020.05.23 09:29:19 1: main::DoSet called by fhem.pl (1939)
2020.05.23 09:29:19 1: main::CommandSet called by fhem.pl (2751)
2020.05.23 09:29:19 1: main::getAllSets called by ./FHEM/01_FHEMWEB.pm (3203)
2020.05.23 09:29:19 1: main::FW_devState called by ./FHEM/01_FHEMWEB.pm (1826)
2020.05.23 09:29:19 1: main::FW_makeDeviceLine called by ./FHEM/01_FHEMWEB.pm (1999)
2020.05.23 09:29:19 1: main::FW_showRoom called by ./FHEM/01_FHEMWEB.pm (1165)
2020.05.23 09:29:19 1: main::FW_answerCall called by ./FHEM/01_FHEMWEB.pm (590)
2020.05.23 09:29:19 1: main::FW_Read called by fhem.pl (3789)
2020.05.23 09:29:19 1: main::CallFn called by fhem.pl (760)
ein rückspielen der alten cul_hm löst das problem erst mal ...
bei mir auch:
2020.05.23 10:48:48.152 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/10_CUL_HM.pm line 4161.
2020.05.23 10:48:48.152 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 4188.
2020.05.23 10:48:48.152 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/10_CUL_HM.pm line 4188.
2020.05.23 10:48:48.160 1: PERL WARNING: Use of uninitialized value $peer in pattern match (m//) at ./FHEM/10_CUL_HM.pm line 8360.
2020.05.23 10:48:48.160 1: PERL WARNING: Use of uninitialized value $peer in string eq at ./FHEM/10_CUL_HM.pm line 8361.
2020.05.23 10:48:48.160 1: PERL WARNING: Use of uninitialized value $peer in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 8361.
2020.05.23 10:48:48.161 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 4195.
Fix ist eingecheckt.
Sorry, für den Bug...
Ich habe keine errors/warnings mehr gesehen.
thx für die flotte reaktion.
moin,
die heutige version 22013 erzeugt mit hminfo configCheck noch folgende warning:
Zitat2020.05.23 13:08:04.505 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/10_CUL_HM.pm line 8790.
2020.05.23 13:08:04.505 1: stacktrace:
2020.05.23 13:08:04.506 1: main::__ANON__ called by ./FHEM/10_CUL_HM.pm (8790)
2020.05.23 13:08:04.506 1: main::CUL_HM_getRegInfo called by ./FHEM/10_CUL_HM.pm (3964)
2020.05.23 13:08:04.506 1: main::CUL_HM_Get called by ./FHEM/98_HMinfo.pm (624)
2020.05.23 13:08:04.507 1: main::HMinfo_burstCheck called by ./FHEM/98_HMinfo.pm (2411)
2020.05.23 13:08:04.507 1: main::HMinfo_configCheck called by FHEM/Blocking.pm (194)
2020.05.23 13:08:04.507 1: main::BlockingStart called by FHEM/Blocking.pm (107)
2020.05.23 13:08:04.507 1: main::BlockingCall called by ./FHEM/98_HMinfo.pm (1324)
2020.05.23 13:08:04.508 1: main::HMinfo_GetFn called by fhem.pl (3761)
2020.05.23 13:08:04.508 1: main::CallFn called by fhem.pl (1964)
2020.05.23 13:08:04.508 1: main::CommandGet called by fhem.pl (1245)
2020.05.23 13:08:04.509 1: main::AnalyzeCommand called by fhem.pl (1098)
2020.05.23 13:08:04.509 1: main::AnalyzeCommandChain called by ./FHEM/01_FHEMWEB.pm (2688)
2020.05.23 13:08:04.509 1: main::FW_fC called by ./FHEM/01_FHEMWEB.pm (914)
2020.05.23 13:08:04.510 1: main::FW_answerCall called by ./FHEM/01_FHEMWEB.pm (583)
2020.05.23 13:08:04.510 1: main::FW_Read called by fhem.pl (3761)
2020.05.23 13:08:04.510 1: main::CallFn called by fhem.pl (756)
Dankeschön, das ging ja schnell.
die sache scheint noch ned ganz ausgestanden ... ne stunde nach dem update heute kommt einmalig:2020.05.24 08:18:23 1: logfile wurde gelöscht
2020.05.24 09:19:39 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 3461.
2020.05.24 09:19:39 1: stacktrace:
2020.05.24 09:19:39 1: main::__ANON__ called by ./FHEM/10_CUL_HM.pm (3461)
2020.05.24 09:19:39 1: main::CUL_HM_parseCommon called by ./FHEM/10_CUL_HM.pm (1542)
2020.05.24 09:19:39 1: main::CUL_HM_Parse called by fhem.pl (3985)
2020.05.24 09:19:39 1: main::Dispatch called by ./FHEM/00_HMUARTLGW.pm (1463)
2020.05.24 09:19:39 1: main::HMUARTLGW_Parse called by ./FHEM/00_HMUARTLGW.pm (1566)
2020.05.24 09:19:39 1: main::HMUARTLGW_Read called by fhem.pl (3789)
2020.05.24 09:19:39 1: main::CallFn called by fhem.pl (760)
2020.05.24 09:19:39 1: waiting for: , got:RegisterRead # await msgNo:, rec:3
good catch.
Hatte nichts mit der Änderung zu tun, ist auch nur kosmetisch und schon sehr lange im Code.
Ist korrigiert und eingecheckt ( nicht einfsch zu testen...)
na wunderbar - thx fürs schnelle reagieren.
ich mach das mal auf erledigt wieder und lass dann morgen auch so, sollt er wider erwarten noch einmal aufmucken ...
Hatte den Fehler auch, danke für's schnelle fixen! 8)
