der folgende Sketch läuft gerade auf einem Arduino Nano. Der hängt am RS485 Bus und verfügt über einen NFS-Reader. PDF-Doku (https://dangerousthings.com/wp-content/uploads/PN532_Manual_V3-1.pdf).
// Enable debug prints to serial monitor
#define MY_DEBUG
#define MY_NODE_ID 22
// Enable and select radio type attached
//#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
// Enable RS485 transport layer
#define MY_RS485
#define MY_TRANSPORT_WAIT_READY_MS 1000
// Define this to enables DE-pin management on defined pin
#define MY_RS485_DE_PIN 2
// Set RS485 baud rate to use
#define MY_RS485_BAUD_RATE 38400
// Enable this if RS485 is connected to a hardware serial port
// Not possible with Arduino Nano !!
//#define MY_RS485_HWSERIAL Serial
#include <SPI.h>
#include <MySensors.h>
#include <Wire.h>
#include <PN532_I2C.h>
#include <PN532.h>
// Add your valid rfid keys here. To find you your key just run sketch; hold your new RFID tag in fron ot the reader;
// and copy the key from serial output of this sketch.
const uint8_t maxKeyLength = 7;
uint8_t validKeys[][maxKeyLength] = {
{ 0xB3, 0xC6, 0xD9, 0x80, 0x00, 0x00, 0x00 },
{ 0, 0, 0, 0, 0, 0, 0 }, // ADD YOUR KEYS HERE!
{ 0, 0, 0, 0, 0, 0, 0 }};
int keyCount = sizeof validKeys / maxKeyLength;
#define CHILD_ID 99 // Id of the sensor child
// Pin definition
const int lockPin = 4; // (Digital 4) The pin that activates the relay/solenoid lock.
bool lockStatus;
MyMessage lockMsg(CHILD_ID, V_LOCK_STATUS);
PN532_I2C pn532i2c(Wire);
PN532 nfc(pn532i2c);
void setup() {
pinMode(lockPin, OUTPUT);
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.print("Couldn't find PN53x board");
while (1); // halt
Serial.print("Found NFC chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
Serial.print('.'); Serial.println((versiondata>> & 0xFF, DEC);
// Set the max number of retry attempts to read from a card
// This prevents us from waiting forever for a card, which is
// the default behaviour of the PN532.
nfc.setPassiveActivationRetries(0x3);
// configure board to read RFID tags
nfc.SAMConfig();
lockStatus = loadState(0); // Read last lock status from eeprom
setLockState(lockStatus, true); // Now set the last known state and send it to controller
void presentation() {
sendSketchInfo("RFID Lock", "1.0");
present(CHILD_ID, S_LOCK);
void loop() {
bool success;
uint8_t key[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
uint8_t currentKeyLength; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
// Wait for an ISO14443A type cards (Mifare, etc.). When one is found
// 'uid' will be populated with the UID, and uidLength will indicate
// if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], ¤tKeyLength);
if (success) {
Serial.print("Found tag id: ");
for (uint8_t i=0; i < currentKeyLength; i++)
if (i>0) Serial.print(",");
Serial.print("0x");Serial.print(key[i], HEX);
for (uint8_t i=currentKeyLength; i < maxKeyLength; i++)
Serial.print(",0x00");
Serial.println("");
bool valid = false;
// Compare this key to the valid once registered here in sketch
for (int i=0;i<keyCount && !valid;i++) {
for (int j=0;j<currentKeyLength && !valid;j++) {
if (key[j] != validKeys[i][j]) {
break;
if (j==currentKeyLength-1) {
valid = true;
if (valid) {
// Switch lock status
setLockState(!lockStatus, true);
// Wait for card/tag to leave reader
while(nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], ¤tKeyLength));
// Unlocks the door.
void setLockState(bool state, bool doSend){
if (state)
Serial.println("open lock");
else
Serial.println("close lock");
if (doSend)
send(lockMsg.set(state));
digitalWrite(lockPin, state);
saveState(0,state);
lockStatus = state;
void receive(const MyMessage &message) {
// We only expect one type of message from controller. But we better check anyway.
if (message.type==V_LOCK_STATUS) {
// Change relay state
setLockState(message.getBool(), false);
// Write some debug info
Serial.print("Incoming lock status:");
Serial.println(message.getBool());
Auf der Debug-Konsole bekomme ich dann solche Meldungen:
(leicht verfremdet)
ZitatFound tag id: 0x4,0x15,0x99,0x49,0xDD,0xDD,0x81
Found tag id: 0x65,0xDD,0xDD,0x6B,0x00,0x00,0x00
Ziel ist
A) Der Sketch sollte einen Pin ansteuern können. Das zu Nutzen mach aber bestenfalls Sinn wenn der Arduino gut geschützt ist...
B) Ich möchte einen Event im FHEM erhalten und die ID des Tags sehen. Daraufhin will ich dann FHEM entscheiden lassen was zu tun ist.
Hintergrund: Die Steuersignale für Garagentore ((Türöffner) usw. will ich keinesfalls außen an Gebäuden erreichbar haben.
Was mir helfen würde wäre eine Idee wie man das am besten coded. Noch besser ein Codeschnipsel, gerne auch ungetestet!
nicht getestet, aber als Gedankenanstoß:
Vielleicht kann man die ID als String, per V_TEXT S_INFO an FHEM schicken, siehe:
MySensors API
https://www.mysensors.org/download/serial_api_20
und
https://forum.fhem.de/index.php/topic,75374.0.html
Danke, ich fürchte das ist die falsche Richtung. V_Text denke ist um ein Display anzusteuern. (Oder geht das dann in beide Richtungen?)
Ich wäre eher gewesen bei:
ZitatV_IR_RECEIVE 33 This message contains a received IR-command S_IR
Im Moment brauche ich erst noch einen String mit der ID des RFID Tags. Denke das bekomme ich hier vor Ort hin. Würde mich dann nochmals melden wegen einem Tipp um das zu übertragen und einen Event im FHEM zu erzeugen...
Der Sketch zeigt schon mal die ID in der Debug-Konsole:
* The MySensors Arduino library handles the wireless radio link and protocol
* between your home built sensors/actuators and HA controller of choice.
* The sensors forms a self healing radio network with optional repeaters. Each
* repeater and gateway builds a routing tables in EEPROM which keeps track of the
* network topology allowing messages to be routed to nodes.
* Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
* Copyright (C) 2013-2015 Sensnology AB
* Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
* Documentation: http://www.mysensors.org
* Support Forum: http://forum.mysensors.org
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* version 2 as published by the Free Software Foundation.
* REVISION HISTORY
* Version 1.0 - Henrik Ekblad
* DESCRIPTION
* RFID Lock sensor/actuator
* Use RFID tag to lock/unlock a door or trigger a scene on your controller.
* This example sketch allows you to add an optional relay or solenoid
* which can be activated/opened by RFID or controller.
* Use the I2C wiring option for your RFID module and connect to the following Arduino pins.
* RFID Arduino
* GND -> GND
* VCC -> +5V
* SCL -> A5
* SDA -> A4
* Use normal wiring for NRF24L01 radio
* Attach a optional relay or solonoid lock to pin 4
* http://www.mysensors.org/build/rfid
#define MY_DEBUG
#define MY_RS485
#define RF_INIT_DELAY 125
#include <SPI.h>
#include <Wire.h>
#include <PN532.h>
String tagid = String();
#define CHILD_ID_LOCK 1 // Id of the sensor child
#define CHILD_ID_WRONG 2 // Id of the sensor child
#define CHILD_ID_ALARM 3 // Id of the sensor child
#define CHILD_ID_TAGID 4 // Id of the sensor child
//#define CHILD_ID 99 // Id of the sensor child
// Pin definition
bool lockStatus;
MyMessage lockMsg(CHILD_ID_LOCK, V_LOCK_STATUS);
MyMessage armMsg(CHILD_ID_WRONG, V_ARMED);
MyMessage wrongMsg(CHILD_ID_ALARM, V_TRIPPED);
MyMessage tagMsg(CHILD_ID_TAGID, V_IR_RECEIVE);
//xxx
void setup() {
nfc.begin();
while (1); // halt
Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
nfc.SAMConfig();
sendSketchInfo("RFID Lock", "0.0.2");
present(CHILD_ID_LOCK, S_LOCK); delay(RF_INIT_DELAY);
present(CHILD_ID_WRONG, S_DOOR); delay(RF_INIT_DELAY);
present(CHILD_ID_ALARM, S_MOTION); delay(RF_INIT_DELAY);
present(CHILD_ID_TAGID, S_IR); delay(RF_INIT_DELAY);
void loop() {
bool success;
// Serial.print(key, BYTE);
// Serial.println(uid);
if (success) {
tagid+=("Found tag id: ");
if (i>0) tagid+=(",");
tagid+=("0x");tagid+=(key[i]);
tagid+=(",0x00");
// Serial.println("Start");
Serial.println(tagid);
// Serial.println("Ende");
bool tripped = 1;
Serial.println(tripped);
send(wrongMsg.set(tripped?"1":"0")); // Send tripped value to gw
send(tagMsg.set(tagid)); // Send id of the rfid-tag to gw
//V_IR_RECEIVE 33 This message contains a received IR-command S_IR
//MyMessage lockMsg(CHILD_ID_LOCK, V_LOCK_STATUS);
//MyMessage armMsg(CHILD_ID_WRONG, V_ARMED);
//MyMessage wrongMsg(CHILD_ID_ALARM, V_TRIPPED);
//MyMessage tagMsg(CHILD_TAGID, V_TRIPPED);
Serial.println("");
bool valid = false;
break;
valid = true;
if (valid) {
if (state)
else
if (doSend)
saveState(0,state);
lockStatus = state;
18608 TSF:MSG:SEND,22-22-0-0,s=4,c=1,t=33,pt=1,l=1,sg=0,ft=0,st=OK:1
Found tag id: 0x222,0x2222,0x37,0x59,0x00,0x00,0x00Found tag id: 0x2222,0x22,0x37,0x59,0x00,0x00,0x00
1
20432 TSF:MSG:SEND,22-22-0-0,s=3,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
20444 TSF:MSG:SEND,22-22-0-0,s=4,c=1,t=33,pt=1,l=1,sg=0,ft=0,st=OK:1
Nun muss ich noch die Übertragung zu FHEM hinbekommen...
Ich habe mal bei einem Sensor mit V_var1 Etc. rumexperementiert. Das ist bei jedem Device verfügbar und du kannst das auch in FHEM als Reading registrieren.
Gesendet von meinem Huawei P10 Plus mit Tapatalk
An der Stelle, wo die debug Ausgabe rauskommt, die ID nicht (nur) seriell ausgeben, sondern parallel in ein char[] kopieren.
Das char[] kannst du dann ganz normal als payload senden, egal mit welcher Variable (V_TEXT, V_VAR, V_ID,...). Ich würde wohl V_ID nehmen. Payloadgrenze von max 26(?) Bytes am Stück beachten (mit NRF24).
Wenn du eine andere Variable nutzt als von MYSENSORS vorgeschlagen, geht halt das autocreate nicht und du musst das in FHEM entsprechen per Hand anlegen (mapreading...).
Vermutlich brauchst du vor dem Senden auch noch eine Konvertierung nach HEX, sonst ist die ID dezimal.
Das mit den IR-typischen Variablen sollte schon klappen. V_ID würde ich (im Moment noch nicht) nehmen, das erfordert die Prästentation eines Temp-Sensors, dass das mit autocreate klappt.
Habe mal etwas an dem Sketch rumgebastelt, habe aber keinen solchen Leser (irgendwo liegt noch ein mrf522 rum, der auf seinen Einsatz wartet...) und kann daher nicht selbst testen:
* REVISION HISTORY
* DESCRIPTION
* RFID Arduino
* GND -> GND
* VCC -> +5V
* SCL -> A5
* SDA -> A4
#define MY_DEBUG
#define MY_DEBUG_LOCAL
#define MY_RS485
#include <SPI.h>
#include <Wire.h>
#include <PN532.h>
// Pin definition
bool lockStatus;
//xxx
void setup() {
nfc.begin();
while (1); // halt
Serial.print(F("Found NFC chip PN5")); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.print(F("Firmware ver. ")); Serial.print((versiondata>>16) & 0xFF, DEC);
nfc.SAMConfig();
void loop() {
bool success;
/* Wait for an ISO14443A type cards (Mifare, etc.). When one is found
if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)*/
if (success) {
#ifdef MY_DEBUG_LOCAL
Serial.println(key, BYTE);
#endif
char buffer[24];
sprintf(buffer, "0x%07lX", key);
send(tagMsg.set(buffer));
/*tagid=(""); //Start with an empty string!
tagid+=(",0x00");
// Serial.println("Ende");*/
bool tripped = 1;
#endif
//send(tagMsg.set(tagid)); // Send id of the rfid-tag to gw
Serial.println("");
#endif
bool valid = false;
break;
valid = true;
if (valid) {
if (state)
else
#endif
if (doSend)
saveState(0,state);
lockStatus = state;
Da jedenfalls ich den Leser mittelfristig mit RS485@HW-serial betreiben wollte, habe ich mal angefangen, sämtliche seriellen Ausgaben abschaltbar zu machen ;) . Übrigens schlucken so lange Texte viel Speicher, ergo ist das Motto: solange aussagefähig, ist kürzer besser, und am besten aus dem EEPROM geladen (F("))...
Als Merkposten noch:
- https://forum.mysensors.org/topic/2439/rfid-garage-door-opener (Schön strukturiert, leider noch V1.5, mit der Option, zulässige IDs zu programmieren)
- https://forum.mysensors.org/topic/2223/rfid-2-person-readout (auch V1.5, interessant: die dump_byte_array-Funktion)
Gruß, Beta-User
Danke an alle für den Input.
Ich hab nochmals ganz von vorne angefangen beim Original Muster von MySensors.
Und schrittweise die Sachen übernommen.
Der Stand Ausgabe auf der Debug-Konsole:
ZitatFound tag id: 0x65,0x61,0xA9,0x6B,0x00,0x00,0x00
Start
0x101,0x97,0x169,0x107,0x00,0x00,0x00
Ende
19716 TSF:MSG:SEND,22-22-0-0,s=4,c=1,t=33,pt=0,l=10,sg=0,ft=0,st=OK:0x783008EA
1
19728 TSF:MSG:SEND,22-22-0-0,s=3,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
Der EventMonitor:
Zitat2018-03-03 10:00:31 MYSENSORS_DEVICE MYSENSOR_22 ir_receive4: 0x783008EA
2018-03-03 10:00:31 MYSENSORS_DEVICE MYSENSOR_22 tripped3: on
Der Code: https://github.com/ranseyer/home-automatics/blob/master/MySens-RS485-Lock-201802/MySens-RS485-Lock-201802.ino
Was mir unklar ist:
Was genau tut das (ja das ist bestimmte eine dumme Frage!)
char buffer[24];
Problem dabei: "key enthält nicht den ganzen Key.
Dieser wäre dezimal in tagid enthalten (wobei mir dezimal auch nicht gefällt):
tagid+=(",0x00");
char buffer[24];
Zu was tut das:
Es wird erst eine Variable des Typs char definiert mit max. 24 Zeichen Länge. In diese werden dann aus der Variable "key" die ersten 7 Bytes als großgeschriebener HEX-Wert geschoben, wobei der String mit "0x" anfängt.
Eigentlich sollte in key aber wirklich der ganze Key enthalten sein, auch die Ausgangsfunktion aus dem MySensors-Sketch bedient sich ja daraus.
Wirf da mal das 0x raus und verlängere das, einfach die 7 ersetzen durch irgendwas, was weniger wie 24 ist...
Cool, viel besser (Test mit zwei Tags...):
char buffer[24];
sprintf(buffer, "%23lX", key);
246=F6 das verstehe ich.
Events:
2018-03-03 13:28:54 MYSENSORS_DEVICE MYSENSOR_22 ir_receive4: 303108EA
2018-03-03 13:28:54 MYSENSORS_DEVICE MYSENSOR_22 tripped3: on
2018-03-03 13:28:57 MYSENSORS_DEVICE MYSENSOR_22 ir_receive4: 393508EA
2018-03-03 13:28:57 MYSENSORS_DEVICE MYSENSOR_22 tripped3: on
Debug:
Start
Ende
24931 TSF:MSG:SEND,22-22-0-0,s=4,c=1,t=33,pt=0,l=23,sg=0,ft=0,st=OK: 303108EA
1
24944 TSF:MSG:SEND,22-22-0-0,s=3,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
Found tag id: 0xF6,0xEA,0x25,0x3B,0x00,0x00,0x00
Start
0x246,0x234,0x37,0x59,0x00,0x00,0x00
Ende
27575 TSF:MSG:SEND,22-22-0-0,s=4,c=1,t=33,pt=0,l=23,sg=0,ft=0,st=OK: 393508EA
1
(Ich werde die Zahlen später mal etwas editieren...)
Cool!
Irritierend ist nur, dass die beiden Ausgaben nicht im wesentlichen identisch ist, aber vermutlich habe ich da eine falsche Vorstellung von der HEX-Umrechnerei.
Jetzt müßte man also entscheiden, ob man lieber bei der "alten" Methode bleibt (in Hex-Schreibweise, damit es immer 2 Stellen sind), oder ob wir das buffer-char-array verwenden wollen. Ich würde doch eher zu letzterem tendieren, zumal ich nicht weiß, ob das Ergebnis der "neuen" Methode ebenso eindeutig ist wie das alte, sonst könnte man das komplett umstellen.
Aber wenn wir in der alten Vorgehensweise die Kommas und 0x-e drin lassen, wird das zu lang zum Versenden, dafür kann man den Vergleichscode lassen, wie er ist. Ich würde also jetzt das rausnehmen (aus den "=+"-Anweisungen).
Andere Meinungen?
Denke die HEX Schreibweise macht am meisten Sinn. (Aber im Prinzip geht es ja nur darum einen eindeutigen Wert zu haben. Egal welchen.)
Schon, die Frage ist nur, welche:
oder
303108EA
Tendiere eingentlich dazu, dass 6561A96B000000 die beste Variante wäre... Sind 14 Zeichen, was im Rahmen des übertagbaren liegt und man kann den Vergleich lassen, wie er ist ;) .
Denke das ist auch die TagID: 0x65,0x61,0xA9,0x6B,0x00,0x00,0x00.
Denke ich würde es so machen:
if (success) {
if (i>0) Serial.print(key[i], HEX);
Serial.print("00");
Serial.println("");
das ergibt dann
ZitatFound tag id: EA253B000000
Start
Ende
4940 TSF:MSG:SEND,22-22-0-0,s=4,c=1,t=33,pt=0,l=23,sg=0,ft=0,st=OK: 393508EA
Bei Serial.print darf gerne eine "korrekte" Darstellung rauskommen, das sollte dann ja auch in die Liste der gültigen ID's so aufgenommen werden.
Aber der Sende-String/char* muß kürzer sein.
Hmmm. Kannst du mal etwas mit dem spritf rumspielen und das Ergebnis auch an Serial ausgeben? Insbesondere: Was ergibt:
sprintf(buffer, "%X", key);
Das ergibt:
Start
Ende
Das sind 4 Hexzahlen + das Auffüllen mit dreimal Hex "00" ...
Aber was mir gerade so auffällt: Eine Hex-Zahl wird verschluckt.
Hmmm, vielleicht so? Aber dann ist die Länge nicht mehr dynamisch...
sprintf(buffer, "%X%X%X%X%X%X%X", key[0],key[1],key[2],key[3],key[4],key[5],key[6]);
Evtl. wäre das eine Variante:
char buffer[currentKeyLength*2];
sprintf(buffer, "%hhX", key);
Serial.print(buffer);
Bei mir kann es leider erst morgen weitergehen. Im Moment bin ich bei:
Start
Ende
Buffer
8E21
5041 TSF:MSG:SEND,22-22-0-0,s=3,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
Hmm, warum fehlt da immer der erste Wert?
Mag er key[0] nur, wenn man es ausdrücklich sagt?
Dann wäre
sprintf(buffer, "%X%X", key[0], key);
vielleicht eine Option?
Vorsichtshalber auch mit etwas längerem Array?
char buffer[currentKeyLength*2+3];
Interessante Sache jedenfalls. Vielleicht sollte ich doch mal einen Minimal-Aufbau machen...
Schönen Sonntag jedenfalls
Ist der Grund, warum das erste Element des key-Arrays nicht ausgegeben wird vielleicht der, dass dieser länger ist als die anderen?
Dann könnte vielleicht das funktionieren:
sprintf(buffer, "%llX%X", key[0], key);
Insgesamt wäre es aber wohl besser, wieder zu der zusammensetzenden Form zurückzukehren. Sonst ist irgendwie zu unklar, wie lange das geht bzw. wo das Grenzen hat. Eigentlich sollte folgendes klappen, allerdings wohl in Kleinschreibung, aber was soll's:
tagid+=(String(key[i], HEX));
tagid+=("00");
Das mit der String-Funktion ist aus dem https://forum.mysensors.org/topic/2223/rfid-2-person-readout geklaut, da ist auch eine Vergleichsfunktion drin. Wenn du sowas brauchst, solltest du die allerdings noch in eine Array-Form umbauen.
Müßte eigentlich so gehen:
Im Header:
String ok_rfid[]={ "abcdefg",
"hijklmn"};
In der Prüfung eine for (i bis int n = sizeof(ok_rfid) / sizeof(ok_rfid[0]), in der dann geprüft wird, ob tagid==ok_rfid;
Wenn wir das fertig und funktional haben, sollten wir den Sketch dann (mit nRF24) bei MySensors einchecken...
Gruß, Beta-User
Die Funktion ist fast perfekt. Nutzen würde ich das ganze "Betamäßig".
Veröffentlichen sollten wir das so noch nicht:
-Die ID wird ja doppelt ermittelt. Ohne "key" bekomme ich das derzeit nicht hin
-Denke die originale ermittlung des Keys war falsch, unsere ist richtig (die billigen Mifare-Karten haben 4 Bytes und nicht drei)
-Denke meinen Code kann man niemandem zeigen...
PS: Ich würde für mich selbst noch erweitern (Ob sowas in ein Muster gehört ist dann die zweite Frage)
-Wenn beliebiger Tag erkannt, oder ein IO angesteuert wird einen Output-Pin defaultmäßig 3 Minuten aktivieren (für Licht, Camera, ...)
-Klingeltaste (Wenn ein IO angesteuert wird "tripped ausspucken)
Denke das bekomm ich hin...
PPS: Meine HW ist instabil. (Denke der Spannungsregler vom Arduino Nano ist zu schwach, Teilweise wird der FTDI-Chip nicht am Rechner erkannt, oder der Reader vom Arduino)
Serial.print("Original tag id: ");
Serial.print("00");
Serial.println("");
tagid+=("00");
bool tripped = 1;
#endif
char buffer[24];
send(tagMsg.set(buffer)); // Send id of the rfid-tag to gw
Serial.print("New tag id: "); Serial.print(tagid); Serial.println("");
Debug:
ZitatOriginal tag id: 61A96B000000
1
66662 TSF:MSG:SEND,22-22-0-0,s=3,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
66678 TSF:MSG:SEND,22-22-0-0,s=4,c=1,t=33,pt=0,l=23,sg=0,ft=0,st=OK: 623608E3
New tag id: 6561a96b000000
Zitat2018-03-04 10:22:08 MYSENSORS_DEVICE MYSENSOR_22 tripped3: on
2018-03-04 10:22:08 MYSENSORS_DEVICE MYSENSOR_22 ir_receive4: 623608E3
Du kannst m.E. einfach die ersten 10 Zeilen weglassen (das ist der Teil, der die erste Ausgabe veranlasst). Einfach mit /* beginnen und dann */ ans Ende...
Ist der Sketch auf github?
Nee, das was in FHEM ankommt, ist der inhalt von "key". Der wird von der originalen Routine angezeigt. Ich habe jetzt spontan auch nicht geschafft die "tagid" genauso umzuwandeln...
ZitatDenke die originale ermittlung des Keys war falsch
Das ist Quatsch. Nur die Anzeige war verkürzt...
Versende einfach die tagid ;) . Nicht mehr das mit sprintf...
So, jetzt habe ich den RC522 auch mal testweise in Betrieb genommen. Mit dem folgenden Code bekomme ich die ID's verschickt, Rest ist nicht getestet:
EDIT: Ist eine MCP2551-AltSoftSerial-Version; bitte bei Bedarf den DE-Pin zuschalten ;)
Example sketch/program showing An Arduino Door Access Control featuring RFID, EEPROM, Relay
This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
This example showing a complete Door Access Control System
Simple Work Flow (not limited to) :
+----------------------------------->READ TAGS+^------------------------------------------+
| +----v-----+ +-----v----+ |
| |MASTER TAG| |OTHER TAGS| |
| +-----v---+ +----v----+ +----v------+ |
| +------------+READ TAGS+---+ |KNOWN TAG| |UNKNOWN TAG| |
| +----v-----+ +----v----+ +--v--------+ +-v----------+ +------v----+ |
| |MASTER TAG| |KNOWN TAG| |UNKNOWN TAG| |GRANT ACCESS| |DENY ACCESS| |
| +----+ +----v------+ +--v---+ | +--------------->
+-------+EXIT| |DELETE FROM| |ADD TO| | |
+----+ | EEPROM | |EEPROM| | |
Use a Master Card which is act as Programmer then you can able to choose card holders who will granted access or not
* **Easy User Interface**
Just one RFID tag needed whether Delete or Add Tags. You can choose to use Leds for output or Serial LCD module to inform users.
* **Stores Information on EEPROM**
Information stored on non volatile Arduino's EEPROM memory to preserve Users' tag and Master Card. No Information lost
if power lost. EEPROM has unlimited Read cycle but roughly 100,000 limited Write cycle.
* **Security**
To keep it simple we are going to use Tag's Unique IDs. It's simple and not hacker proof.
@license Released into the public domain.
Typical pin layout used:
MFRC522 Arduino Arduino Arduino Arduino Arduino
Reader/PCD Uno/101 Mega Nano v3 Leonardo/Micro Pro Micro
Signal Pin Pin Pin Pin Pin Pin
RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
SPI SS SDA(SS) 10 53 D10 10 10
SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
#define SN "RFID Reader"
#define SV "0.1"
#include <EEPROM.h> // We are going to read and write PICC's UIDs from/to EEPROM
#include <SPI.h> // RC522 Module uses SPI protocol
#include <MFRC522.h> // Library for Mifare RC522 Devices
#include <Bounce2.h>
#define MY_DEBUG
//#define MY_DEBUG_LOCAL
#define MY_RS485
//#define MY_SPLASH_SCREEN_DISABLED
//#define MY_RS485_DE_PIN 2
#define MY_RS485_BAUD_RATE 19200 //57600 //38400 //9600
//#define MY_RS485_SOH_COUNT 3
#define MY_NODE_ID 94
#define MY_TRANSPORT_WAIT_READY_MS 20000
#include <Arduino.h>
//für die millis()-Berechnung, wann wieder gesendet werden soll
unsigned long SEND_FREQUENCY = 180000; // Sleep time between reads (in milliseconds)
unsigned long lastSend = 0;
#define ONE_SEC 1000
#define MAX_CARDS 18
#define PROG_WAIT 10
#define HEARTBEAT 10
/*Pin definitions*/
#define LED_PIN A3
#define GARAGEPIN 4
#define SWITCH_PIN 5
#define RST_PIN 7 // MFRC
#define SS_PIN 10 // MFRC
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
MFRC522::Uid olduid;
MFRC522::Uid masterkey = { 10, {0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, 0 };
byte countValidCards = 0;
MFRC522::Uid validCards[MAX_CARDS];
void ShowCardData(MFRC522::Uid* uid);
bool sameUid(MFRC522::Uid* old, MFRC522::Uid* check);
void copyUid(MFRC522::Uid* src, MFRC522::Uid* dest);
bool isValidCard(MFRC522::Uid* uid);
int releasecnt = 0;
#define CHILD_ID_ALARM 1
#define CHILD_ID_LOCK 2
//volatile String tagid = String();
Bounce debouncer = Bounce();
int oldSwitchValue = -1;
int switchValue = 0;
long timer = -1;
bool programmode = false;
bool ledon;
int programTimer = 0;
bool armed = true;
unsigned long lastTime = 0;
MyMessage lockArmMsg(CHILD_ID_ALARM, V_ARMED);
void before()
pinMode(GARAGEPIN, OUTPUT); // Initialise in/output ports
// Make sure MFRC will be disabled on the SPI bus
pinMode(RST_PIN, OUTPUT);
digitalWrite(RST_PIN, LOW);
pinMode(SS_PIN, OUTPUT);
digitalWrite(SS_PIN, LOW);
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, LOW);
// Setup the button
pinMode(SWITCH_PIN, INPUT);
// Activate internal pull-up
digitalWrite(SWITCH_PIN, HIGH);
// After setting up the button, setup debouncer
debouncer.attach(SWITCH_PIN);
debouncer.interval(5);
sendSketchInfo(SN, SV);
recallEeprom();
// Init MFRC RFID sensor
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522
ShowReaderDetails(); // Show details of PCD - MFRC522 Card Reader details
send(lockArmMsg.set(armed));
Serial.println(F("Init done..."));
void setup() {
void loop()
timer++;
debouncer.update();
// Get the update value
int switchValue = debouncer.read();
if (switchValue != oldSwitchValue) {
// Send in the new value
Serial.print (F("Switch "));
Serial.println (switchValue);
if (switchValue && programmode) {
lastTime = millis() / 1000;
if (!switchValue && programmode && lastTime > 0) {
if ( (millis() / 1000) - lastTime > 3) {
Serial.println(F("Reset all cards"));
blinkFast(50);
} else {
Serial.println(F("Program off"));
storeEeprom();
if (!switchValue) {
programTimer = 0;
oldSwitchValue = switchValue;
if (programmode && ((timer % (ONE_SEC / HEARTBEAT)) == 0 )) {
ledon = !ledon;
digitalWrite(LED_PIN, ledon);
programTimer++;
// Stop program mode after 20 sec inactivity
if (programTimer > PROG_WAIT) {
digitalWrite(LED_PIN, false);
Serial.println(F("Program expired"));
if ((timer % (200 / HEARTBEAT)) == 0 ) {
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent()) {
if (releasecnt > 0) {
releasecnt--;
if (!releasecnt) {
olduid.size = 0;
Serial.println(F("release"));
return;
releasecnt = 5;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
// Dump debug info about the card; PICC_HaltA() is automatically called
//mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
getTagId(&(mfrc522.uid));
if (!olduid.size || !sameUid(&(mfrc522.uid), &olduid)) {
ShowCardData(&(mfrc522.uid));
copyUid(&(mfrc522.uid), &olduid);
if ( isValidCard(&olduid) ) {
OpenDoor(programmode);
} else {
if (sameUid(&(mfrc522.uid), &masterkey)) {
// Only switch in program mode when mastercard is found AND the program button is pressed
if (switchValue) {
Serial.println(F("Program mode"));
programmode = true;
programTimer = 0;
lastTime = 0;
} else {
if (programmode) {
Serial.println(F("new card"));
programTimer = 0;
if (countValidCards < MAX_CARDS)
// Add card to list...
copyUid(&(mfrc522.uid), &validCards[countValidCards]);
countValidCards++;
blinkFast(15);
} else {
Serial.println(F("Invalid card"));
if (armed) {
send(wrongMsg.set(1));
delay(2000);
send(wrongMsg.set(0));
void ShowCardData(MFRC522::Uid* uid) {
Serial.print(F("Card UID:"));
for (byte i = 0; i < uid->size; i++) {
if (uid->uidByte[i] < 0x10) {
Serial.print(F(" 0"));
} else {
Serial.print(F(" "));
Serial.print(uid->uidByte[i], HEX);
Serial.println();
void getTagId(MFRC522::Uid* uid) {
String tagid=("");
} else {
tagid+=(" ");
tagid+=("0x");
tagid+=(String(uid->uidByte[i], HEX));
Serial.print("tagid: ");
char TAGID[tagid.length() + 1];
tagid.toCharArray(TAGID, tagid.length() + 1);
send(tagMsg.set(TAGID)); // Send id of the rfid-tag to gw
dest->size = src->size;
dest->sak = src->sak;
for (byte i = 0; i < src->size; i++) {
dest->uidByte[i] = src->uidByte[i];
if (old->size != check->size) {
return false;
for (byte i = 0; i < old->size; i++) {
if (old->uidByte[i] != check->uidByte[i]) {
return false;
return true;
for (byte i = 0; i < countValidCards; i++) {
if (validCards[i].size != uid->size) {
break;
for (int j = 0; j < uid->size; j++) {
if (validCards[i].uidByte[j] != uid->uidByte[j]) {
break;
if (j == (uid->size - 1)) {
return true;
return false;
void storeEeprom()
byte address = 0;
saveState(address++, countValidCards);
saveState(address++, validCards[i].size);
for (byte j = 0; j < 10; j++) {
saveState(address++, validCards[i].uidByte[j]);
void recallEeprom()
byte address = 0;
countValidCards = loadState(address++);
if (countValidCards > MAX_CARDS) {
Serial.println(F("Not a valid EEPROM reading set to default"));
storeEeprom();
return;
validCards[i].size = loadState(address++);
validCards[i].uidByte[j] = loadState(address++);
void blinkFast(int times)
for (int i = 0; i < times; i++) {
ledon = !ledon;
delay(100);
void OpenDoor(bool fakeOpen)
Serial.println(F("Open door!"));
send(lockMsg.set(false));
if (!fakeOpen) {
digitalWrite(LED_PIN, HIGH);
digitalWrite(GARAGEPIN, HIGH);
delay(1000);
if (!fakeOpen) {
digitalWrite(GARAGEPIN, LOW);
send(lockMsg.set(true));
void ShowReaderDetails() {
// Get the MFRC522 software version
byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
Serial.print(F("MFRC522 Software Version: 0x"));
Serial.print(v, HEX);
if (v == 0x91) {
Serial.print(F(" = v1.0"));
} else if (v == 0x92) {
Serial.print(F(" = v2.0"));
} else {
Serial.print(F(" (unknown)"));
Serial.println("");
// When 0x00 or 0xFF is returned, communication probably failed
if ((v == 0x00) || (v == 0xFF)) {
Serial.println(F("WARNING: Communication failure, is the MFRC522 properly connected?"));
void incomingMessage(const MyMessage &message)
if (message.type == V_LOCK_STATUS) {
if (!message.getBool()) {
OpenDoor(false);
Serial.print(F("Lock status: "));
else
if (message.type == V_ARMED) {
armed = message.getBool();
Serial.print(F("Arm status: "));
else
Serial.print(F("Incoming msg type: "));
Serial.print(message.type);
Serial.print(F(" id: "));
Serial.print(message.sensor);
Serial.print(F(" content: "));
Serial.println(message.getInt());
