Hier ist das Listing dieses Devices :
DEF cfba8db6 80
FUUID 5cb87507-f33f-775d-e984-68852c7c3aaf98ce
IODev ZWAVE2
LASTInputDev ZWAVE2
MSGCNT 3507
NAME HeizungWC
NR 155
STATE meterReset
TYPE ZWave
ZWAVE2_MSGCNT 3507
ZWAVE2_RAWMSG 0004005006700602020000
ZWAVE2_TIME 2021-12-07 16:18:26
ZWaveSubDevice no
cmdsPending 0
homeId cfba8db6
isWakeUp
lastMsgSent 1638890305.98405
nodeIdHex 50
webCmd desired-temp
Helper:
DBLOG:
temperature:
logdb:
TIME 1638889367.72656
VALUE 20.0
OLDREADINGS:
2021-12-07 16:17:10 basicReport 255
2021-12-07 16:14:47 basicSet 255
2021-12-07 16:18:25 configAHiAirMaxLimit 400
2021-12-07 16:18:25 configALoAirMinLimit 50
2021-12-07 16:18:25 configCOModeSetpoint 220
2021-12-07 16:18:25 configCOOLSetpoint 210
2021-12-07 16:18:25 configDIFFL4 10
2021-12-07 16:18:25 configECOModeSetpoint 200
2021-12-07 16:18:25 configFHiFloorMaxLimit 270
2021-12-07 16:18:25 configFLoFloorMinLimit 50
2021-12-07 16:18:25 configFloorSensorType 10kNtc
2021-12-07 16:18:25 configOperationMode Heat
2021-12-07 16:18:25 configPLoMinTemperatureInPowerRegMode 0
2021-12-07 16:18:25 configPSetting 2
2021-12-07 16:18:26 configTemperatureSensor FFloorMode
2021-12-07 16:18:15 desired-temp 22.0
2021-12-07 16:10:14 meterSupported type:energy, import only (consumed), resetable:yes, scales: 0:kWh
2021-12-07 16:18:18 model ThermoFloor AS Heatit Thermostat TF 021
2021-12-07 16:18:18 modelConfig thermofloor/heatit021.xml
2021-12-07 16:18:18 modelId 019b-0001-0001
2021-12-07 16:18:15 setpointTemp 22.0 C heating
2021-12-07 16:16:38 state meterReset
2021-12-07 16:16:05 temperature 20.0 C
2021-12-07 16:14:59 thermostatMode heating
2021-12-07 16:18:26 timeToAck 0.026
2021-12-07 16:18:26 transmit OK
2021-12-07 16:17:05 undef 26 undef previous: 0 delta_time: 26 s
DbLogInclude temperature
IODev ZWAVE2
classes ZWAVEPLUS_INFO THERMOSTAT_SETPOINT SENSOR_MULTILEVEL VERSION THERMOSTAT_MODE ASSOCIATION_GRP_INFO ASSOCIATION POWERLEVEL MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY METER CONFIGURATION
devStateIcon .*Off:sani_floor_heating_off .*On:sani_floor_heating .*Save:sani_floor_heating_neutral .*:sani_floor_heating
event-on-change-reading temperature,state
eventMap /tmOff:Off/tmHeating:On/tmEnergySaveHeating:Save
icon sani_heating
room Erdgeschoss,Heizung,ZWave
vclasses ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 CONFIGURATION:2 DEVICE_RESET_LOCALLY:1 MANUFACTURER_SPECIFIC:2 METER:4 POWERLEVEL:1 SENSOR_MULTILEVEL:6 THERMOSTAT_MODE:3 THERMOSTAT_SETPOINT:3 VERSION:2 ZWAVEPLUS_INFO:2
webCmd Off:On:Save
Das letzte Reading ist das Ergebnis von :
get HeizungWC meter
aber das Egebnis ist wenig sinnvoll.
Das Geraet liefert Daten, mit dem das Modul nichts anfangen kann.
Ich habe nochmal die Doku (SDS13781) konsultiert, finde da aber auch keine neuen "Bits" fuer die METER Klasse.
Ich habe jetzt immerhin das FHEM ZWave Modul geaendert, so dass es statt undef ab sofort UNKNOWN_XX zurueckliefert, in der Hoffnung, dass XX weiterhilft.
Danke, habe ich mir fast gedacht.
Das sollte ja offiziell etwas ueber den Stromverbrauch stehen.
Ich habe das mit dem Hersteller klaeren koennen.
Die Information ueber dem zugehoerigen xml-File ist nicht ganz korrekt : Dieser Thermostat kann keine Energie messen.
