Hi
Since a while a try to add some motion sensor to FHEM but it is not possible
i did that :
inform on
set EnOcean teach 120
i press the "LRN" button on the motion sensor
but nothing happened ?
i have alreay one motion sensor of the same technology working, why the news sensor is not working ?
please advise
Unfortunately, you do not write the exact name of the sensor.
There was a breaking change in teach-in/autocreate behavior by FHEM in february 19 (https://forum.fhem.de/index.php/topic,97027.msg902168.html#msg902168).
Please add
attr <IODev> learningDev all
and try again.
If that does not help, please provide more infos (exact name, log,..)
Regards, Christian
hi
thanks
now i can add the 2 new occupancy sensor devices but i catch this : EnOcean EnO_01A575DD 4BS teach-in is missing
2019.05.04 21:28:06 1: EnOcean Unknown device with SenderID 01A90EA1 and 4BS telegram, please define it.
2019.05.04 21:28:06 2: autocreate: define EnO_01A90EA1 EnOcean 01A90EA1 EnOcean:1:A5:BA00FF09:01A90EA1:00:03FFFFFFFF4C00
2019.05.04 21:28:06 2: EnOcean define EnO_01A90EA1 EnOcean 01A90EA1 EnOcean:1:A5:BA00FF09:01A90EA1:00:03FFFFFFFF4C00
2019.05.04 21:28:06 2: EnOcean define FileLog_EnO_01A90EA1 FileLog ./log/EnO_01A90EA1-%Y.log EnO_01A90EA1
2019.05.04 21:28:06 2: EnOcean EnO_01A90EA1 4BS teach-in is missing
2019.05.04 21:30:09 3: TCM TCM_ESP3_1 set teach 120
2019.05.04 21:30:48 1: EnOcean Unknown device with SenderID 01A575DD and 4BS telegram, please define it.
2019.05.04 21:30:48 2: autocreate: define EnO_01A575DD EnOcean 01A575DD EnOcean:1:A5:C900FF09:01A575DD:00:03FFFFFFFF4400
2019.05.04 21:30:48 2: EnOcean define EnO_01A575DD EnOcean 01A575DD EnOcean:1:A5:C900FF09:01A575DD:00:03FFFFFFFF4400
2019.05.04 21:30:48 2: EnOcean define FileLog_EnO_01A575DD FileLog ./log/EnO_01A575DD-%Y.log EnO_01A575DD
2019.05.04 21:30:48 2: EnOcean EnO_01A575DD 4BS teach-in is missing
2019.05.04 21:30:49 2: EnOcean EnO_01A575DD 4BS teach-in accepted EEP A5-07-01 Manufacturer: EnOcean GmbH
2019.05.04 21:30:49 2: EnOcean define SVG_EnO_01A575DD SVG FileLog_EnO_01A575DD:EnO_motion:CURRENT
2019.05.04 21:30:49 2: EnOcean define SVG_EnO_01A575DD_2 SVG FileLog_EnO_01A575DD:EnO_voltage4current4:CURRENT
please help
Does something not work? Is something wrong? If so, what?
I guess "EnOcean EnO_01A575DD 4BS teach-in is missing" is just information and you can ignore it.
Regards, Christian
