ich habe heute mein FHEM aktualisiert. Seit dem habe ich für gassistant und alexa folgende Fehler im Log. Bis zum Update liefen beide Assistenten fehlerfrei. Ich habe die Logs so engestellt, das die neueste Zeile oben steht, also bitte nicht wundern.
at Function.Module._load (module.js:497:3
at tryModuleLoad (module.js:505:12)
at Module.load (module.js:565:32)
at Object.Module._extensions..js (module.js:663:10)
at Module._compile (module.js:652:30)
at Object.<anonymous> (/usr/local/lib/node_modules/gassistant-fhem/lib/cli.js:16:18)
at getModule (/usr/local/lib/node_modules/gassistant-fhem/lib/cli.js:10:13)
at request (/usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-request/lib/index.js:28:15)
at /usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-rpc/lib/index.js:159:12
at extractValue (/usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-rpc/lib/index.js:149:19)
Error: getaddrinfo EAI_AGAIN fhem-ga-connector.firebaseapp.com:443
[9.6.2019, 20:34:47] [FHEM] got: 8 results
*** FHEM: connected
[9.6.2019, 20:34:47] *** SSH: proxy configuration failed: Reverse Proxy replied with neither registered nor unregistered status: out:  err:ssh: Could not resolve hostname fhem-va.fhem.de: Temporary failure in name resolution
[9.6.2019, 20:34:47] sshautoconf: aborted with Reverse Proxy replied with neither registered nor unregistered status: out:  err:ssh: Could not resolve hostname fhem-va.fhem.de: Temporary failure in name resolution
[9.6.2019, 20:34:47] sshautoconf: SSH key seems to exist
[9.6.2019, 20:34:47] Passed config: {"connections":[{"filter":"alexaName=..*","name":"FHEM","uid":999,"port":"8083","server":"127.0.0.1","webname":"fhem"}],"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":44573}}
[9.6.2019, 20:34:47] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[9.6.2019, 20:34:47] *** SSH: checking proxy configuration
[9.6.2019, 20:34:47] Server listening on: http://127.0.0.1:44573 for proxy connections
Habt ihr eine Idee, wo ich suchen kann?
FHEM stürzt zwar auch ab, das sieht aber laut CPU Auslastung nach einem mysql Problem aus. Erst als ich FHEM gekillt habe (auf einen normalen Stop des Dienstes reagierte FHEM nicht), ging die Auslastung der CPU runter.
				Problem #1 wird laut Meldung von einem Netzwer/Google-Firebase Problem verursacht (hatte Google nicht neutlich Serverprobleme?)
Problem #2 kann man mit "perl fhem.pl -d fhem.cfg" in der Konsole eingrenzen.
Eventuell ein generelles Problem bei Dir mit der Namensauflösung?
Kannst Du das bitte einmal testen?
				Danke Jungs.
Der Tipp von CoolTux war es. Ich hatte an den DNS Einstellungen des Servers etwas geändert. Nach dem Neustart des Servers haben die komplett gegriffen. Damit hatte der Server keinen Zugriff mehr auf das Internet. Läuft jetzt nach Anpassungen an den DNS Einstellungen wieder.
Das der Fehler aber dazu führt, das FHEM 100% CPU Last braucht, hätte ich nicht gedacht.
Danke noch mal für die Tipps.
