FHEM => Anfängerfragen => Thema gestartet von: MisterEltako am 10 Januar 2013, 23:00:10
Titel: webCmd- unknown attribute
Beitrag von: MisterEltako am 10 Januar 2013, 23:00:10
Hi!
Seidem ich heute ein "update"-Befehl aufgerufen habe und restartet habe tritt folgendes Problem auf:
Aussenlicht_Tuer: unknown attribute webCmd, choose one of room group comment alias eventMap IODev do_not_notify:1,0 ignore:1,0 dummy:1,0 showtime:1,0 loglevel:0,1,2,3,4,5,6 event-on-change-reading event-on-update-reading hmClass:receiver,sender serialNr firmware devInfo rawToReadable unit peerList peerIDs actCycle actStatus autoReadReg:1,0 model:ASH550,ASH550I,CMM,DORMA_BRC-H,DORMA_RC-H,DORMA_atent,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-Dis-TD-T,HM-LC-BL1-FM,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-Bl1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-PL,HM-LC-DIM1T-CV,HM-LC-DIM1T-FM,HM-LC-DIM1T-PL,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2T-SM,HM-LC-Dim1PWM-CV,HM-LC-Dim1TPBU-FM,HM-LC-SW1-BA-PCB,HM-LC-SW1-FM,HM-LC-SW1-PB-FM,HM-LC-SW1-PL,HM-LC-SW1-PL-OM54,HM-LC-SW1-SM,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW2-DR,HM-LC-SW2-FM,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW4-DR,HM-LC-SW4-PCB,HM-LC-SW4-SM,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-Sw1PBU-FM,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-LED16,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-4,HM-RC-4-B,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-SCI-3-FM,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-RHS,HM-SEC-SC,HM-SEC-SD,HM-SEC-SFA-SM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WIN,HM-SEN-EP,HM-SEN-MDIR-SM,HM-SWI-3-FM,HM-Sec-Cen,HM-Sen-MDIR-O,HM-WDC7000,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS20-TH-O,HM-WDS30-T-O,HM-WDS40-TH-I,IS-WDS-TH-OD-S-R3,KFM-Display,KFM-Sensor,KS550,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,Roto_ZEL-STG-RM-FFK,Roto_ZEL-STG-RM-FSS-UP3,S550IA,Schueco_263-1350,Schueco_263-144,Schueco_263-145,Schueco_263-146,Schueco_263-155,Schueco_263-157,Schueco_263-158,Schueco_263-160,Schueco_263-162,WS888 subType:AlarmControl,ClimateControl,KFM100,THSensor,blindActuator,dimmer,keyMatic,motionDetector,outputUnit,pushButton,remote,sensor,smokeDetector,swi,switch,thermostat,threeStateSensor,winMatic or use attr global userattr webCmd
definiert ist:
define Aussenlicht_Tuer CUL_HM 1B730F
attr Aussenlicht_Tuer devInfo 010100
attr Aussenlicht_Tuer eventMap on:An off:Aus
attr Aussenlicht_Tuer firmware 2.1
attr Aussenlicht_Tuer hmClass receiver
attr Aussenlicht_Tuer model HM-LC-Sw1PBU-FM
attr Aussenlicht_Tuer room CUL_HM
attr Aussenlicht_Tuer serialNr JEXXXXXXXX
attr Aussenlicht_Tuer subType switch
attr Aussenlicht_Tuer webCmd An:Aus
Bisher hatte ich damit keine Probleme. Alles funktionierte perfekt. Jetzt wird bei jedem Device nach Abspeichern der fhem.cfg das "webCmd" angemeckert.
Anschließend ist auch in FhemWeb in den Dropdwon-Feldern des jeweiligen Device kein "webCmd" mehr aufgeführt.
Mehrfaches Neustarten von Fhem brachte nix.
Hat noch jemandt diese Problem oder weiß jemand Abhilfe????
MfG, MisterEltako
Titel: Aw: webCmd- unknown attribute
Beitrag von: Rohan am 11 Januar 2013, 07:54:15
Schon öfters gewesen...
save drücken und
shutdown restart
machen
Thomas
Beitrag von: MisterEltako am 11 Januar 2013, 13:32:20
Hi!
Ja, das war es wieder. Kleine Dinge - große Auswirkung... ;o)
Problem gelöst!
Danke!
MfG, MisterEltako.
