FHEM - Hausautomations-Systeme => Sonstige Systeme => Thema gestartet von: presskopf am 11 Juli 2019, 00:43:16
Titel: Firmata auf Mega2560 & PWM an 44,45,46
Beitrag von: presskopf am 11 Juli 2019, 00:43:16
ich möchte an einem Mega 2560 unter (USB-)Firmata die Pins 44, 45 und 46 für das Modul FRM_PWM nutzen.
Leider klappt das nicht so recht. Es kommt nix, egal wie hoch ich den Output stelle.
Nutze ich FRM_OUT, dann leuchtet das angeschlossene LED.
Habe ich hier einen Konflikt mit den anderen Modulen der Firmata? Timer?
Am Pin 7 löppt alles.
Matthias
   CFGFN
   DEF        /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0@57600
   DRIVER_VERSION 0.64
   DeviceName /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0@57600
   FD         4
   FUUID      5d21101e-f33f-860a-bd3b-eeb4eb635f32a254
   NAME       FRM_HBO
   NOTIFYDEV  global
   NR         21
   NTFY_ORDER 50-FRM_HBO
   PARTIAL
   STATE      Initialized
   TYPE       FRM
   analog_pins 54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
   analog_resolutions 54:10,55:10,56:10,57:10,58:10,59:10,60:10,61:10,62:10,63:10,64:10,65:10,66:10,67:10,68:10,69:10
   encoder_pins 2,3,18,19,20,21
   encoder_resolutions 2:28,3:28,18:28,19:28,20:28,21:28
   firmware   ConfigurableFirmata_ms-mega_1.ino
   firmware_version V_2_10
   i2c_pins   20,21
   input_pins 2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
   onewire_pins 2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
   output_pins 2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
   protocol_version V_2_06
   pullup_pins 2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
   pwm_pins   2,3,4,5,6,7,8,9,10,11,12,13,44,45,46
   pwm_resolutions 2:8,3:8,4:8,5:8,6:8,7:8,8:8,9:8,10:8,11:8,12:8,13:8,44:8,45:8,46:8
     2019-07-09 23:01:38   error           Unhandled sysex command
     2019-07-11 00:34:24   state           Initialized
   SERIAL:
