hiho,
steh wieder mal bei "neustart-warnings" an. als einzige gemeinsamkeit scheint hier irgendwas mit json nicht zu stimmen.
in homematic trag ichs jetzt nur mal ein, weils hm an erster stelle steht. also sorry, falls ich total falsch hier bin, ich weiß es aber nicht besser in dem fall!
kann mir also jemand eventuell sagen, wo und wie ich hier ansetzen muß?2019.07.24 08:12:33 1: update finished, "shutdown restart" is needed to activate the changes.
2019.07.24 08:12:36 1: Server shutdown delayed due to logdb for max 10 sec
2019.07.24 08:12:46 0: Server shutdown
2019.07.24 08:12:47 1: Including fhem.cfg
2019.07.24 08:12:47 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4524, <$fh> line 200.
2019.07.24 08:12:47 1: stacktrace:
2019.07.24 08:12:47 1: main::__ANON__ called by fhem.pl (4524)
2019.07.24 08:12:47 1: main::AttrVal called by ./FHEM/10_CUL_HM.pm (9328)
2019.07.24 08:12:47 1: main::CUL_HM_ActCheck called by ./FHEM/10_CUL_HM.pm (9211)
2019.07.24 08:12:47 1: main::CUL_HM_ActAdd called by ./FHEM/10_CUL_HM.pm (716)
2019.07.24 08:12:47 1: main::CUL_HM_Attr called by fhem.pl (3753)
2019.07.24 08:12:47 1: main::CallFn called by fhem.pl (2995)
2019.07.24 08:12:47 1: main::CommandAttr called by fhem.pl (1236)
2019.07.24 08:12:47 1: main::AnalyzeCommand called by fhem.pl (1089)
2019.07.24 08:12:47 1: main::AnalyzeCommandChain called by fhem.pl (1377)
2019.07.24 08:12:47 1: main::CommandInclude called by fhem.pl (601)
2019.07.24 08:12:48 1: PERL WARNING: Prototype mismatch: sub main::decode_json ($) vs ($;$) at /usr/share/perl/5.24/Exporter.pm line 66, <$fh> line 542.
2019.07.24 08:12:48 1: stacktrace:
2019.07.24 08:12:48 1: main::__ANON__ called by /usr/share/perl/5.24/Exporter.pm (66)
2019.07.24 08:12:48 1: Exporter::import called by ./FHEM/82_LGTV_WebOS.pm (70)
2019.07.24 08:12:48 1: (eval) called by ./FHEM/82_LGTV_WebOS.pm (68)
2019.07.24 08:12:48 1: (eval) called by fhem.pl (2605)
2019.07.24 08:12:48 1: (eval) called by fhem.pl (2604)
2019.07.24 08:12:48 1: main::CommandReload called by fhem.pl (1992)
2019.07.24 08:12:48 1: main::LoadModule called by fhem.pl (2049)
2019.07.24 08:12:48 1: main::CommandDefine called by fhem.pl (1236)
2019.07.24 08:12:48 1: main::AnalyzeCommand called by fhem.pl (1089)
2019.07.24 08:12:48 1: main::AnalyzeCommandChain called by fhem.pl (1377)
2019.07.24 08:12:48 1: main::CommandInclude called by fhem.pl (601)
2019.07.24 08:12:48 1: PERL WARNING: Prototype mismatch: sub FHEM::UWZ::decode_json ($) vs ($;$) at /usr/share/perl/5.24/Exporter.pm line 66, <$fh> line 3267.
2019.07.24 08:12:48 1: Exporter::import called by ./FHEM/77_UWZ.pm (75)
2019.07.24 08:12:48 1: (eval) called by ./FHEM/77_UWZ.pm (73)
2019.07.24 08:12:49 1: PERL WARNING: Prototype mismatch: sub main::decode_json ($;$) vs ($) at (eval 172) line 1.
2019.07.24 08:12:49 1: stacktrace:
2019.07.24 08:12:49 1: main::__ANON__ called by /usr/share/perl/5.24/Carp.pm (169)
2019.07.24 08:12:49 1: Carp::carp called by /usr/share/perl/5.24/Exporter/Heavy.pm (38)
2019.07.24 08:12:49 1: Exporter::Heavy::__ANON__ called by /usr/share/perl/5.24/Exporter/Heavy.pm (185)
2019.07.24 08:12:49 1: Exporter::Heavy::heavy_export called by /usr/share/perl/5.24/Exporter/Heavy.pm (205)
2019.07.24 08:12:49 1: Exporter::Heavy::heavy_export_to_level called by /usr/share/perl5/JSON.pm (111)
2019.07.24 08:12:49 1: JSON::import called by (eval 172) (1)
2019.07.24 08:12:49 1: main::BEGIN called by (eval 172) (1)
2019.07.24 08:12:49 1: (eval) called by (eval 172) (1)
2019.07.24 08:12:49 1: (eval) called by ./FHEM/72_FRITZBOX.pm (56)
2019.07.24 08:12:49 1: (eval) called by fhem.pl (2605)
2019.07.24 08:12:49 1: (eval) called by fhem.pl (2604)
2019.07.24 08:12:49 1: main::CommandReload called by fhem.pl (1992)
2019.07.24 08:12:49 1: main::LoadModule called by fhem.pl (2049)
2019.07.24 08:12:49 1: main::CommandDefine called by fhem.pl (1236)
2019.07.24 08:12:49 1: main::AnalyzeCommand called by fhem.pl (1089)
2019.07.24 08:12:49 1: main::AnalyzeCommandChain called by fhem.pl (1377)
2019.07.24 08:12:49 1: main::CommandInclude called by fhem.pl (601)
2019.07.24 08:13:01 1: Including ./log/fhem.save
2019.07.24 08:13:10 0: Featurelevel: 5.9
das ganze rennt in einer vm mit nem 08/15 debian, dass auch brav up2date ist.
Die Meldungen bezüglich des protoype mismatch kommen aus fhem.pl, dazu solltest Du in der richtigen Forumrubrik für fhem.pl nachfragen.
Die erste Meldung kommt aus Homematic, ist nicht weiter schlimm, sondern nur unschön - und sie wurde schon von anderen Usern gemeldet.
Sorry, mein erster Satz war natürlich Quatsch. Die Meldung kommt aus perl selbst.
no problem *g*
mir gings eh nur darum, mal rauszufinden, obs gröbere probleme gibt. wenn das einzelne modulprobleme sind, is es mir derzeit egal - ihr richtets dass sicher mal bei zeiten.
wäre nur blöd gewesen, hätte mit z.b. json selber was nicht gestimmt.
