Revision 20036: 76_SMAInverter: V2.13.0, attr target-serial/target-susyid are set ...
76_SMAInverter: V2.13.0, attr target-serial/target-susyid are set automatically if not defined, new inverter types added, support of Meta/Installer, ETOTAL is calculated if inverter doesn't provide it
Source: Revision 20036: 76_SMAInverter: V2.13.0, attr target-serial/target-susyid are set ... (http://svn.fhem.de/trac/changeset/20036/trunk)
