Revision 20058: 93_DbLog: configCheck changed: check if new DbLog version is available ...
93_DbLog: configCheck changed: check if new DbLog version is available or the local one is modified
Source: Revision 20058: 93_DbLog: configCheck changed: check if new DbLog version is available ... (http://svn.fhem.de/trac/changeset/20058/trunk)
