Revision 20060: WMBus: correction for negative values (DIF_INT*) and removed ...
WMBus: correction for negative values (DIF_INT*) and removed validation check fpr LVAR
Source: Revision 20060: WMBus: correction for negative values (DIF_INT*) and removed ... (http://svn.fhem.de/trac/changeset/20060/trunk)
