Ich habe das Problem, dass der MQTT2_CLIENT nicht merkt, also immer opened ist und bleibt obwohl der Server nicht mehr erreichbar ist.
bin noch neu bei Mqtt, vielleicht auch etwas übersehen.
logs und defs anbei
server
defmod mqtt_fhem MQTT2_SERVER 1883 global
attr mqtt_fhem autocreate no
attr mqtt_fhem room MQTT2_DEVICE
setstate mqtt_fhem 2019-08-28 17:52:18 RETAIN {"tele/WZ_C_T_P/LWT":"Online"}
setstate mqtt_fhem 2019-08-28 17:52:18 nrclients 1
setstate mqtt_fhem 2019-08-28 16:41:20 state Initialized
client
defmod mqttclient1 MQTT2_CLIENT 192.168.2.114:1883
attr mqttclient1 clientId mqttclient1
attr mqttclient1 keepaliveTimeout 10
attr mqttclient1 room test
attr mqttclient1 verbose 5
setstate mqttclient1 opened
setstate mqttclient1 2019-08-28 17:35:27 state opened
Verbose 5 am client
2019.08.28 17:39:38.074 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:39:38.074 5: mqttclient1: keepalive 10
2019.08.28 17:39:28.074 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:39:28.074 5: mqttclient1: keepalive 10
2019.08.28 17:39:18.072 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:39:18.072 5: mqttclient1: keepalive 10
2019.08.28 17:39:08.071 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:39:08.071 5: mqttclient1: keepalive 10
2019.08.28 17:38:58.061 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:38:58.060 5: mqttclient1: keepalive 10
2019.08.28 17:38:51.351 5: mqttclient1: dispatch autocreate=no\000mqttclient1\000tele/WZ_C_T_P/SENSOR\000{"Time":"2019-08-28T16:38:50","BMP180":{"Temperature":39.3,"Pressure":995.5},"CCS811":{"eCO2":403,"TVOC":0},"PressureUnit":"hPa","TempUnit":"C"}
2019.08.28 17:38:51.351 5: mqttclient1: received PUBLISH (0)(20)tele/WZ_C_T_P/SENSOR{"Time":"2019-08-28T16:38:50","BMP180":{"Temperature":39.3,"Pressure":995.5},"CCS811":{"eCO2":403,"TVOC":0},"PressureUnit":"hPa","TempUnit":"C"}
2019.08.28 17:38:51.345 5: mqttclient1: dispatch autocreate=no\000mqttclient1\000tele/WZ_C_T_P/STATE\000{"Time":"2019-08-28T16:38:50","Uptime":"0T01:10:24","Vcc":3.466,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":764,"POWER1":"on","Dimmer":4,"Color":"0A0000","HSBColor":"0,100,4","Channel":[3,0,0],"Scheme":0,"Width":1,"Fade":"off","Speed":1,"LedTable":"off","Wifi":{"AP":1,"SSId":"FRITZBox2","BSSId":"24:65:11:87:35:32","Channel":11,"RSSI":100,"LinkCount":1,"Downtime":"0T00:00:04"}}
2019.08.28 17:38:51.344 5: mqttclient1: received PUBLISH (0)(19)tele/WZ_C_T_P/STATE{"Time":"2019-08-28T16:38:50","Uptime":"0T01:10:24","Vcc":3.466,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":764,"POWER1":"on","Dimmer":4,"Color":"0A0000","HSBColor":"0,100,4","Channel":[3,0,0],"Scheme":0,"Width":1,"Fade":"off","Speed":1,"LedTable":"off","Wifi":{"AP":1,"SSId":"FRITZBox2","BSSId":"24:65:11:87:35:32","Channel":11,"RSSI":100,"LinkCount":1,"Downtime":"0T00:00:04"}}
2019.08.28 17:38:48.059 5: mqttclient1: received PINGRESP
2019.08.28 17:38:48.053 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:38:48.053 5: mqttclient1: keepalive 10
2019.08.28 17:38:38.052 5: mqttclient1: received PINGRESP
2019.08.28 17:38:38.046 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:38:38.046 5: mqttclient1: keepalive 10
2019.08.28 17:38:28.041 5: mqttclient1: received PINGRESP
2019.08.28 17:38:28.036 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:38:28.036 5: mqttclient1: keepalive 10
Server wieder online ca.17.51
2019.08.28 17:53:06.874 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:53:06.873 5: mqttclient1: keepalive 10
2019.08.28 17:52:56.874 5: mqttclient1: received PINGRESP
2019.08.28 17:52:56.867 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:52:56.867 5: mqttclient1: keepalive 10
2019.08.28 17:52:53.074 5: mqttclient1: dispatch autocreate=no\000mqttclient1\000tele/WZ_C_T_P/SENSOR\000{"Time":"2019-08-28T16:52:51","BMP180":{"Temperature":38.5,"Pressure":995.5},"CCS811":{"eCO2":425,"TVOC":3},"PressureUnit":"hPa","TempUnit":"C"}
2019.08.28 17:52:53.074 5: mqttclient1: received PUBLISH (0)(20)tele/WZ_C_T_P/SENSOR{"Time":"2019-08-28T16:52:51","BMP180":{"Temperature":38.5,"Pressure":995.5},"CCS811":{"eCO2":425,"TVOC":3},"PressureUnit":"hPa","TempUnit":"C"}
2019.08.28 17:52:53.068 5: mqttclient1: dispatch autocreate=no\000mqttclient1\000tele/WZ_C_T_P/STATE\000{"Time":"2019-08-28T16:52:51","Uptime":"0T01:24:25","Vcc":3.466,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"POWER1":"on","Dimmer":4,"Color":"0A0000","HSBColor":"0,100,4","Channel":[3,0,0],"Scheme":0,"Width":1,"Fade":"off","Speed":1,"LedTable":"off","Wifi":{"AP":1,"SSId":"FRITZBox2","BSSId":"24:65:11:87:35:32","Channel":11,"RSSI":100,"LinkCount":1,"Downtime":"0T00:00:04"}}
2019.08.28 17:52:53.068 5: mqttclient1: received PUBLISH (0)(19)tele/WZ_C_T_P/STATE{"Time":"2019-08-28T16:52:51","Uptime":"0T01:24:25","Vcc":3.466,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"POWER1":"on","Dimmer":4,"Color":"0A0000","HSBColor":"0,100,4","Channel":[3,0,0],"Scheme":0,"Width":1,"Fade":"off","Speed":1,"LedTable":"off","Wifi":{"AP":1,"SSId":"FRITZBox2","BSSId":"24:65:11:87:35:32","Channel":11,"RSSI":100,"LinkCount":1,"Downtime":"0T00:00:04"}}
2019.08.28 17:52:47.901 5: mqttclient1: dispatch autocreate=no\000mqttclient1\000tele/WZ_C_T_P/LWT\000Online
2019.08.28 17:52:47.901 5: mqttclient1: received PUBLISH (0)(17)tele/WZ_C_T_P/LWTOnline
2019.08.28 17:52:46.897 5: mqttclient1: received SUBACK (0)(4)(0)
2019.08.28 17:52:46.889 5: mqttclient1: sending SUBSCRIBE (130)(6)(0)(4)(0)(1)#(0)
2019.08.28 17:52:46.888 5: mqttclient1: received CONNACK (0)(0)
2019.08.28 17:52:46.863 1: 192.168.2.114:1883 reappeared (mqttclient1)
2019.08.28 17:52:46.862 5: SW: 101900064d51497364700302000a000b6d717474636c69656e7431
2019.08.28 17:52:46.862 5: mqttclient1: sending CONNECT (16)(25)(0)(6)MQIsdp(3)(2)(0)(10)(0)(11)mqttclient1
2019.08.28 17:52:46.860 4: IP: 192.168.2.114 -> 192.168.2.114
2019.08.28 17:52:46.860 5: HttpUtils url=http://192.168.2.114:1883/
2019.08.28 17:52:46.858 1: 192.168.2.114:1883 disconnected, waiting to reappear (mqttclient1)
2019.08.28 17:52:38.453 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:52:38.452 5: mqttclient1: keepalive 10
2019.08.28 17:52:28.443 5: mqttclient1: sending PINGREQ (192)(0)
2019.08.28 17:52:28.443 5: mqttclient1: keepalive 10
2019.08.28 17:52:18.442 5: mqttclient1: sending PINGREQ (192)(0)
Kann nicht nachvollziehen, gerade getestet.
Im beigefuegten Log sieht man die disconnected...reappeared Meldungen, und dabei wird bei mir state auf disconnected/opened gesetzt.
Heisst nicht, dass das Problem nicht besteht, nur dass ich zum Reproduzieren eine deutlich detailliertere Beschreibung brauche.
Z.Bsp. weiss ich nicht wann der Server offline gegangen ist, und gerade fuer den fraglichen Zeitraum (17:51) gibt es keine Logs.
Ich habe den verboselog gedreht(lesen von oben nach unten) und die Server online/offline eingetragen
man sieht das kein received PINGRESP vom Server mehr kommt
und MQTT2_CLIENT immer opened im state bleibt.
erst als der Server wieder vorhanden ist merkt es der Client siehe disconnect und reappeared,
weiß gerade nicht wie ich es anders beschreiben soll
Server online-->
Server offline-->
Server online--->
2019.08.28 17:53:06.880 5: mqttclient1: received PINGRESP
Was genau verstehst du unter "Server nicht erreichbar"?
Sowas wie Server-Absturz, Kabel abziehen oder Server ausschalten kriegt FHEM normalerweise mit.
ZitatWas genau verstehst du unter "Server nicht erreichbar"?
So wie im richtigen Leben,
in dem simulierten Fall oben habe ich das Netzwerkkabel vom Mqtt2server abgezogen, könnte natürlich auch Stromausfall, Netzgerät ,oder Switch sein.
Ich hatte eigentlich vermutet, dass der Client , da ich
attr mqttclient1 keepaliveTimeout 10gesetzt hatte, bei ausbleibenden Antworten vom Server irgendwie versucht einen reconnect zu machen,
macht er aber nicht. auch gibt es kein reading von der letzten Antwort.
vermissenen tu ich auch ein manuelles reopen am client.
Ich konnte das bei mir auch nachstellen, was mein Verstaendnis von TCP/IP erschuettert.
Ab sofort prueft das Modul, ob beim Senden einer PINGREQ Nachricht die Letzte bestaetigt wurde, und falls nicht, wird die Verbindung neu aufgebaut.
Vielen Dank Rudi,
funktioniert sehr gut!
