FHEM - Hausautomations-Systeme => ZWave => Thema gestartet von: TomekWaw am 29 Oktober 2019, 06:00:25
Titel: New door lock: ABUS HomeTec Pro CFA3010 Z-Wave S2
Beitrag von: TomekWaw am 29 Oktober 2019, 06:00:25
Turns out that ABUS has released a new version if its HomeTec Pro Lock, now with Z-Wave module.
Here's the press release:
https://www.abus.com/content/download/55801/4818206/file/Press%20release_ABUS_HomeTecPro_Z-Wave.pdf
Seems it's available already for ~190 EUR
https://www.ebay.de/itm/ABUS-HomeTec-Pro-CFA3010-Z-Wave-plus-Turschlossantrieb-Turantrieb-Turschloss/143397550345
I'm not an expert on Z-wave, but it says Z-Wave S2 security.
Would this technically work on Aeotec Z-stick / ZWDongle ?
If yes, would it need a new FHEM module or rather new device definition, that doesn't exist yet?
Titel: Antw:New door lock: ABUS HomeTec Pro CFA3010 Z-Wave S2
Beitrag von: rudolfkoenig am 29 Oktober 2019, 08:41:32
ZitatWould this technically work on Aeotec Z-stick / ZWDongle ?
As far as I know, yes.
ZitatIf yes, would it need a new FHEM module or rather new device definition, that doesn't exist yet?
S2 does not necessary mean a new FHEM module, but definitely an implementation, and to my knowledge nobody is working on it right now.
If I interpret the document from the Z-Wave alliance correctly, S2 devices have to be backwards compatible with the older version of the security class.
Beitrag von: subseven am 04 Dezember 2019, 22:50:28
I bought this Lock,
you have to switch vom S2-Security to S0 as it is described in the manual.
After that it work with Z-Wave. I use the Dongle UZB1
Beitrag von: baschtlwaschtl am 09 Januar 2020, 13:37:34
@rudolfkoenig: is there any plans to implement s2 security into FHEM?
thanks for infos :)
basti
Beitrag von: rudolfkoenig am 09 Januar 2020, 13:55:43
I dont know of any.
