habe ich Log von Fhem die folgenden Fehlermeldungen. Im Moment etwas ratlos, wo ich suchen soll?
2019.11.06 16:09:20 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 21759) line 8.
2019.11.06 16:09:20 1: PERL WARNING: substr outside of string at (eval 21759) line 5.
2019.11.06 16:04:55 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 21611) line 8.
2019.11.06 16:04:55 1: PERL WARNING: substr outside of string at (eval 21611) line 5.
2019.11.06 16:04:04 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 21593) line 8.
2019.11.06 16:04:04 1: PERL WARNING: substr outside of string at (eval 21593) line 5.
2019.11.06 15:03:12 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 19300) line 8.
2019.11.06 15:03:12 1: PERL WARNING: substr outside of string at (eval 19300) line 5.
2019.11.06 15:00:19 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 19201) line 8.
2019.11.06 15:00:19 1: PERL WARNING: substr outside of string at (eval 19201) line 5.
2019.11.06 15:00:01 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 19190) line 8.
2019.11.06 15:00:01 1: PERL WARNING: substr outside of string at (eval 19190) line 5.
2019.11.06 13:59:26 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 16490) line 8.
2019.11.06 13:59:26 1: PERL WARNING: substr outside of string at (eval 16490) line 5.
2019.11.06 13:59:07 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 16471) line 8.
2019.11.06 13:59:07 1: PERL WARNING: substr outside of string at (eval 16471) line 5.
2019.11.06 13:58:20 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 16356) line 8.
2019.11.06 13:58:20 1: PERL WARNING: substr outside of string at (eval 16356) line 5.
2019.11.06 12:58:34 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 13658) line 8.
2019.11.06 12:58:34 1: PERL WARNING: substr outside of string at (eval 13658) line 5.
2019.11.06 12:58:13 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 13601) line 8.
2019.11.06 12:58:13 1: PERL WARNING: substr outside of string at (eval 13601) line 5.
2019.11.06 12:57:29 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 13578) line 8.
2019.11.06 12:57:29 1: PERL WARNING: substr outside of string at (eval 13578) line 5.
2019.11.06 11:57:42 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 9279) line 8.
2019.11.06 11:57:42 1: PERL WARNING: substr outside of string at (eval 9279) line 5.
2019.11.06 11:57:19 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 9270) line 8.
2019.11.06 11:57:19 1: PERL WARNING: substr outside of string at (eval 9270) line 5.
2019.11.06 11:56:36 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 9247) line 8.
2019.11.06 11:56:36 1: PERL WARNING: substr outside of string at (eval 9247) line 5.
2019.11.06 10:56:49 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 5762) line 8.
2019.11.06 10:56:49 1: PERL WARNING: substr outside of string at (eval 5762) line 5.
2019.11.06 10:56:26 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 5748) line 8.
2019.11.06 10:56:26 1: PERL WARNING: substr outside of string at (eval 5748) line 5.
2019.11.06 10:55:45 1: PERL WARNING: Use of uninitialized value $raw in subtraction (-) at (eval 5727) line 8.
2019.11.06 10:55:45 1: PERL WARNING: substr outside of string at (eval 5727) line 5.
Da ich im Moment nicht weiß, wo der Fehler herkommt, habe ich auch keine weiteren Infos hier bereitgestellt.
Gruß Dorian
Siehe https://forum.fhem.de/index.php/topic,71806.msg633579.html#msg633579, Stichwort "stacktrace". Macht den Heuhaufen evtl. etwas kleiner...
Klingt nach einer Berechnung, die du selbst (anlaßbezogen) durchführen läßt.
Ok. Danke sowas habe ich gesucht.
Dann mach ich mal auf die Suche.
Dorian
