FHEM - Entwicklung => FHEM Code changes => Thema gestartet von: System am 11 November 2019, 21:15:33
Titel: Revision 20495: 22_HOMEMODE: prevent to execute empty HomeCMDs, fix blocking IP check ...
Beitrag von: System am 11 November 2019, 21:15:33
22_HOMEMODE: prevent to execute empty HomeCMDs, fix blocking IP check if no internet connection is available, add missing name for logging 'executed CMDs'
Source: Revision 20495: 22_HOMEMODE: prevent to execute empty HomeCMDs, fix blocking IP check ... (http://svn.fhem.de/trac/changeset/20495/trunk)
