hiho,
ich hätte wieder mal ein paar meldungen im log anzubieten *g*
folgendes passiert beim updaten - keines der module hab ich in verwendung:2019.11.22 08:22:18 1: Calling /usr/bin/perl ./contrib/commandref_join.pl -noWarnings, this may take a while
2019.11.22 08:22:41 1: *** EN AutoShuttersControl line 7346: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN AutoShuttersControl line 7450: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN AutoShuttersControl line 7463: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 11364: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 11391: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 11393: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 11426: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 11457: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 11517: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 11639: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 11720: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 11974: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 12030: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 12154: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 12196: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 12268: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 12556: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 12586: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN DbRep line 12819: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN SISPM line 543: div with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN SSCam line 11239: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN SSCam line 11245: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN Weather line 991: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN Weather line 1019: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN Weather line 1033: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** EN WifiLight line 3975: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE AutoShuttersControl line 7706: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE AutoShuttersControl line 7738: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE AutoShuttersControl line 7747: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 13817: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 13843: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 13845: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 13878: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 13911: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 13971: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 14007: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 14097: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 14176: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 14426: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 14485: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 14615: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 14662: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 14738: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 15034: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 15065: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE DbRep line 15309: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE SSCam line 13093: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE SSCam line 13103: td with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE Weather line 1165: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE Weather line 1195: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE Weather line 1210: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: *** DE WifiLight line 4620: table with attributes (apart from class) is not allowed
2019.11.22 08:22:41 1: update finished, "shutdown restart" is needed to activate the changes.
2019-11-22 08:22:41 Global global UPDATE
bezüglich DbRep schaue ich mir das an.
Dieser Check scheint neu zu sein, die Meldung habe ich bei mir bis jetzt noch nie gesehen.
LG,
Heiko
bei mir tritt dasselbe im Log seit 21.11. auf. Zudem dauert es im Vergleich zu vorher relativ lange (ca. 1-2 Minuten), bis diese Fehlermeldungen kommen und das update fertig ist.
Vielen Dank vorab!
Achim
Näheres zur Änderung der commandref_join.pl ist hier zu finden: https://forum.fhem.de/index.php/topic,105376.0.html (https://forum.fhem.de/index.php/topic,105376.0.html)
Allgemeiner Hinweis: das update geht schneller durch, wenn man die comandref auf "modular" umstellt.
ZitatNäheres zur Änderung der commandref_join.pl ist hier zu finden ....
Ah ja, danke. Jetzt kann ich es einordnen.
Für DbRep habe ich die comref überarbeitet und eingecheckt. Dabei ist aus gegebenen Anlass auch gleich der Punkt "diffValue" korrigiert und neue Features ausgerollt -> https://forum.fhem.de/index.php/topic,53584.msg993666.html#msg993666
Morgen früh wie gewohnt im Update.
LG,
Heiko
(SSCam nehme ich mir auch noch vor und checke die comref-Korrektur ein)
