FHEM - Hausautomations-Systeme => Homematic => Thema gestartet von: eisman am 26 November 2019, 09:05:47
Titel: gelöst: update vom 26.11.19 Fehlermeldungen
Beitrag von: eisman am 26 November 2019, 09:05:47
hi,
2019.11.26 08:49:48 3: CUL_HM set LD_0201 getConfig
2019.11.26 08:50:38 3: Device TC_0301 added to ActionDetector with 000:10 time
2019.11.26 08:51:06 3: CUL_HM LD_0201 repeat, level 00 instead of C8
2019.11.26 08:51:06 2: CUL_HM LD_0201 attack:011EA18F21810001040000000001,011EA18F2181000103:11EA18F21810000040000000000
2019.11.26 08:51:06 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 3454.
2019.11.26 08:51:06 1: waiting for: , got:RegisterRead # await msgNo:, rec:1
2019.11.26 08:51:06 1: waiting for: , got:RegisterRead # await msgNo:, rec:2
2019.11.26 08:51:06 1: waiting for: , got:RegisterRead # await msgNo:, rec:3
2019.11.26 08:51:06 1: waiting for: , got:RegisterRead # await msgNo:, rec:4
2019.11.26 08:51:06 1: waiting for: , got:RegisterRead # await msgNo:, rec:5
2019.11.26 08:51:06 3: CUL_HM set TC_0301 statusRequest
2019.11.26 08:51:06 3: Device TC_0301 added to ActionDetector with 000:10 time
2019.11.26 08:51:07 3: CUL_HM set LD_0201 getConfig
2019.11.26 08:51:11 1: waiting for: , got:RegisterRead # await msgNo:, rec:7
2019.11.26 08:51:11 1: waiting for: , got:RegisterRead # await msgNo:, rec:8
2019.11.26 08:51:11 1: waiting for: PeerList, got:RegisterRead # await msgNo:9, rec:9
2019.11.26 08:51:11 1: waiting for: PeerList, got:RegisterRead # await msgNo:9, rec:10
2019.11.26 08:51:37 3: Device TC_0401 added to ActionDetector with 000:10 time
2019.11.26 08:51:54 3: Device TC_0501 added to ActionDetector with 000:10 time
2019.11.26 08:52:12 3: CUL_HM set TC_0301 statusRequest
2019.11.26 08:52:25 2: CUL_HM TC_0301 attack:011EA18F1F90CF020E,011EA18F1F90CF030E:11EA18F1F90CF010E
2019.11.26 08:53:13 3: CUL_HM set TC_0501 statusRequest
leider kommen die Meldungen immer wieder.
nach restore update/2019-11-26
restore ./CHANGED
restore ./FHEM/30_HUEBridge.pm
restore ./FHEM/31_HUEDevice.pm
restore ./FHEM/70_SolarEdgeAPI.pm
restore ./FHEM/73_AutoShuttersControl.pm
restore ./FHEM/73_ElectricityCalculator.pm
restore ./FHEM/73_GasCalculator.pm
restore ./FHEM/73_WaterCalculator.pm
restore ./FHEM/93_DbRep.pm
restore ./FHEM/98_update.pm
restore ./FHEM/WMBus.pm
restore ./FHEM/controls_fhem.txt
restore ./FHEM/lib/AttrTemplate/httpmod.template
restore ./FHEM/lib/AttrTemplate/mqtt2.template
restore ./MAINTAINER.txt
skipping ./fhem.cfg
skipping ./log/fhem.save
restore ./www/images/fhemSVG/hue_filled_lightstrip.svg
restore ./www/pgm2/fhemweb_colorpicker.js
ist alles wieder OKay
mfg edgar
Titel: Antw:update vom 26.11.19 Fehlermeldungen
Beitrag von: frank am 26 November 2019, 10:37:02
den fehler habe ich auch hin und wieder.
ich denke, er tritt nur in speziellen situationen auf. ich konnte ihn leider noch nicht reproduzieren.
das restore wird dir nicht helfen.
Beitrag von: eisman am 26 November 2019, 11:50:19
Hallo Frank,
bisher ist es nicht wieder aufgetreten.
Und vor dem Update gab es sowas auch nicht.
aber es muss was mit HM sein, da ich 4 FHEM Installationen habe und es ist nur die mit HM betroffen.
nach ändern von attr IOgrp VCCU auf attr IOgrp VCCU:HMLAN0,HMLAN1,HMLAN2
sind nach dem update keine Probleme mehr aufgetreten....
Edgar
