FHEM - Entwicklung => FHEM Code changes => Thema gestartet von: System am 14 Februar 2020, 16:45:27
Titel: Revision 21198: mqtt2.template: add OpenMQTTGateway_BT_scanner again - should not have ...
Beitrag von: System am 14 Februar 2020, 16:45:27
mqtt2.template: add OpenMQTTGateway_BT_scanner again - should not have been deleted
Source: Revision 21198: mqtt2.template: add OpenMQTTGateway_BT_scanner again - should not have ... (http://svn.fhem.de/trac/changeset/21198/trunk)
