ich habe ein Problem mit einer Readingsgroup, die mein FHEM für 30-40 Sekunden lahmlegt.
Hier das Ergebnis von apptime :
name function max count total average maxDly
nmapListe readingsGroup_Notify 36589 657 36787 55.99 0 HASH(nmapListe); HASH(Netzwerk)
Mosquitto MQTT::Read 9033 26 15755 605.96 0 HASH(Mosquitto)
WEB_192.168.178.54_62048 FW_Read 7860 10 11316 1131.60 0 HASH(WEB_192.168.178.54_62048)
FileLog_sysmon FileLog_Get 6479 7 23468 3352.57 0 HASH(FileLog_sysmon); FileLog_sysmon; CURRENT; INT; 2020-03-01_00:00:00; 2020-03-02_00:00:01; 4:cpu_temp_avg\x3a:0:; 4:cpu_temp\x3a:0:; 4:cpu_freq\x3a:0:
tmr-OWX_Discover HASH(0x3ccbd98) 5208 1 5208 5208.00 901 HASH(OneWireAdapter)
WEB_192.168.178.54_62089 FW_Read 4940 23 6890 299.57 0 HASH(WEB_192.168.178.54_62089)
tmr-CUL_HM_updateConfig updateConfig 3066 1 3066 3066.00 9105 updateConfig
FileLog_Mess_Steckdose_2 FileLog_Get 2433 1 2433 2433.00 0 HASH(FileLog_Mess_Steckdose_2); FileLog_Mess_Steckdose_2; CURRENT; INT; 2020-03-01_00:00:00; 2020-03-02_00:00:01; 4:Mess_Steckdose_2.ENERGY_Power\x3a::; 4:Mess_Steckdose_2.ENERGY_Total\x3a::
tmr-CUL_HM_procQs CUL_HM_procQs 1869 7 2630 375.71 22602 CUL_HM_procQs
FileLog_Mess_Steckdose_3 FileLog_Get 1856 1 1856 1856.00 0 HASH(FileLog_Mess_Steckdose_3); FileLog_Mess_Steckdose_3; CURRENT; INT; 2020-03-01_00:00:00; 2020-03-02_00:00:01; 4:Mess_Steckdose_3.ENERGY_Power\x3a::; 4:Mess_Steckdose_3.ENERGY_Total\x3a::
FileLog_Cryptoz FileLog_Get 1648 1 1648 1648.00 0 HASH(FileLog_Cryptoz); FileLog_Cryptoz; CURRENT; INT; 2020-03-01_00:00:00; 2020-03-02_00:00:01; 4:Wallet.amount\x3a::; 4:IOTA.iota\x3a::($fld[3]*100); 4:VERGE.verge\x3a::($fld[3]*1000); 4:RIPPLE.ripple\x3a::($fld[3]*100)
tmr-OWTHERM_GetValues HASH(0x3f0ff28) 1403 2 2591 1295.50 10314 HASH(Temperatur_Puffer_unten)
tmr-OWTHERM_GetValues HASH(0x3bd6d58) 1401 2 2588 1294.00 7516 HASH(Temperatur_Puffer_Mitte)
tmr-OWTHERM_GetValues HASH(0x3f52cd0) 1401 2 2611 1305.50 6117 HASH(Temperatur_Keller)
tmr-OWTHERM_GetValues HASH(0x3cebdc8) 1400 2 2586 1293.00 8916 HASH(Temperatur_Puffer_oben)
tmr-OWTHERM_GetValues HASH(0x3dcf1a0) 1400 2 2587 1293.50 13113 HASH(Temperatur_Solar_Kollektor_Vorlauf)
tmr-OWTHERM_GetValues HASH(0x3f92228) 1400 2 2589 1294.50 11715 HASH(Temperatur_Solar_Kollektor_Ruecklauf)
tmr-rssFeed_GetUpdate HASH(0x2e27218) 1315 1 1315 1315.00 13317 HASH(ecuadorNews)
WLAN_CUL CUL_Read 1245 4 1577 394.25 0 HASH(WLAN_CUL)
tmr-ONKYO_AVR_GetStatus HASH(0x30f2c78) 1202 8 2355 294.38 16899 HASH(Amplifier)
FileLog_Mess_Steckdose_1 FileLog_Get 1140 1 1140 1140.00 0 HASH(FileLog_Mess_Steckdose_1); FileLog_Mess_Steckdose_1; CURRENT; INT; 2020-03-01_00:00:00; 2020-03-02_00:00:01; 4:Mess_Steckdose_1.ENERGY_Total\x3a::; 4:Mess_Steckdose_1.ENERGY_Power\x3a::
Wenn man die Readingsgroup nmapListe aus fhem.cfg rausnimmt (und nur das nmap-Modul ohne readingsgroup läuft ),
läuft fhem normal. ist also nicht das nmap-Modul, sondern wirklich die Readingsgroup.
Hier die Config:
define nmapListe readingsGroup <>,<Nr>,<IP-Adresse>,<online>,<RechnerName>,<Uptime>,<Last Seen>,<MAC> Netzwerk:@4,#1_ip,<#1>,#1_state,(.*)_alias,#1_uptimeText,#1_lastSeen,#1_macAddress
attr nmapListe alias Home-Netzwerk
attr nmapListe cellStyle { "c:1" => 'style="text-align:right"',"c:3" => 'style="text-align:center"',"c:4" => 'style="text-align:left"' }
attr nmapListe icon it_network
attr nmapListe room 1__Netzwerk
attr nmapListe sortColumn 2
attr nmapListe valueFormat { \
if ($VALUE eq 'absent') { "<img src='./fhem/images/default/WLAN_Status.0.png' alt='absent'>" }\
elsif ($VALUE eq 'present') {"<img src='./fhem/images/default/WLAN_Status.1.png' alt='present'>" }\
elsif (substr($READING,rindex($READING,"_")) eq "_ip") { substr($VALUE,rindex($VALUE,".")+1) } \
else { "" }\
attr nmapListe valueStyle {$READING =~ m/(.+)_/;;\
my $state = ReadingsVal($DEVICE, $1."_state", "NA");;\
my $style = "";;\
return('style="text-align: right;; '.$style.'"') if($state eq "present" && $READING =~ m/_uptime/);;\
return('style="color: #FF0000;; text-align: right;; '.$style.'"') if($state eq "absent" && $READING =~ m/_uptime/);;\
return('style="'.$style.'"') if($state eq "present");;\
return('style="color: #FF0000;; '.$style.'"') if($state eq "absent");;\
Woran liegt das lange Timeout, ist mein Rechner (raspi 1) dazu einfach zu lahm ?
Es sind 30-35 Devices
Ralf
