FHEM => Frontends => TabletUI => Thema gestartet von: Wolfgang Hochweller am 03 April 2020, 14:11:54
Titel: [FUIP] Fehlermeldungen, ausgeloest durch FUIP
Beitrag von: Wolfgang Hochweller am 03 April 2020, 14:11:54
Das sehe ich im Log :
2020.04.03 14:04:07 1: PERL WARNING: "my" variable $fields masks earlier declaration in same scope at ./FHEM/42_FUIP.pm line 3679, <$fh> line 1302.
2020.04.03 14:04:07 1: stacktrace:
2020.04.03 14:04:07 1:     main::__ANON__                      called by ./FHEM/42_FUIP.pm (3679)
2020.04.03 14:04:07 1:     (eval)                              called by fhem.pl (2609)
2020.04.03 14:04:07 1:     (eval)                              called by fhem.pl (2608)
2020.04.03 14:04:07 1:     main::CommandReload                 called by fhem.pl (2000)
2020.04.03 14:04:07 1:     main::LoadModule                    called by fhem.pl (2057)
2020.04.03 14:04:07 1:     main::CommandDefine                 called by fhem.pl (1247)
2020.04.03 14:04:07 1:     main::AnalyzeCommand                called by fhem.pl (1100)
2020.04.03 14:04:07 1:     main::AnalyzeCommandChain           called by fhem.pl (1385)
2020.04.03 14:04:07 1:     main::CommandInclude                called by fhem.pl (610)
2020.04.03 14:04:07 3: FUIP: Registering ui for URL /ui
2020.04.03 14:04:07 1: PERL WARNING: Use of uninitialized value in lc at fhem.pl line 5400, <$fh> line 1302.
2020.04.03 14:04:07 1:     main::__ANON__                      called by fhem.pl (5400)
2020.04.03 14:04:07 1:     main::FileRead                      called by ./FHEM/42_FUIP.pm (2632)
2020.04.03 14:04:07 1:     FUIP::load                          called by ./FHEM/42_FUIP.pm (223)
2020.04.03 14:04:07 1:     FUIP::Define                        called by fhem.pl (3772)
2020.04.03 14:04:07 1:     main::CallFn                        called by fhem.pl (2082)
2020.04.03 14:04:07 1:     main::FileRead                      called by ./FHEM/42_FUIP.pm (2637)
Titel: Antw:Fehlermeldungen, ausgeloest durch FUIP
Beitrag von: Rewe2000 am 05 April 2020, 19:28:26
Hallo Wolfgang,
da häng ich mich mal an, auch bei mir kommen ähnliche Fehler in Zusammenhang mit FUIP.
Ich hoffe Thorsten liest hier mit und prüft mal ob der Fehler eventuell bei uns liegt.
2020.04.05 19:20:47 1: PERL WARNING: "my" variable $fields masks earlier declaration in same scope at ./FHEM/42_FUIP.pm line 3679, <$fh> line 4859.
2020.04.05 19:20:48 3: FUIP: Registering ui for URL /ui
2020.04.05 19:20:48 1: PERL WARNING: Use of uninitialized value in lc at fhem.pl line 5403, <$fh> line 4859.
Hinweis:
Wolfgang, du solltest noch im Betreff [FUIP] als erstes mit anhängen, damit Thorsten auf den Beitrag aufmerksam wird.
Gruß Reinhard
Titel: Antw:[FUIP] Fehlermeldungen, ausgeloest durch FUIP
Beitrag von: mbr89 am 26 April 2020, 11:36:28
push
https://github.com/ThorstenPferdekaemper/FHEM-FUIP ... geht hier überhaupt noch was ?
PERL WARNING: "my" variable $fields masks earlier declaration in same scope at ./FHEM/42_FUIP.pm line 3679. -> https://github.com/ThorstenPferdekaemper/FHEM-FUIP/blob/master/FHEM/42_FUIP.pm#L3679
SVN ... https://svn.fhem.de/ ... echt jetzt !?! ... das nutzt doch keiner mehr ... https://youtu.be/sagbQLHxJ0U?t=74 ... wo er halt recht hat !!!
https://svn.fhem.de/trac/browser/tags/FHEM_6_0/fhem/fhem.pl#L1302
https://svn.fhem.de/trac/browser/tags/FHEM_6_0/fhem/fhem.pl#L1353
https://svn.fhem.de/trac/browser/tags/FHEM_6_0/fhem/fhem.pl#L4859
https://svn.fhem.de/trac/browser/tags/FHEM_6_0/fhem/fhem.pl#L5400
https://svn.fhem.de/trac/browser/tags/FHEM_6_0/fhem/fhem.pl#L5403
https://svn.fhem.de/trac/browser/tags/FHEM_6_0/fhem/fhem.pl#L5405
Hach ich bin beruhigt ... PERL Fehlermeldungen sind genauso be*****sen wie bei anderen Sprachen ... ASM, C, C++, Java ...
Beitrag von: smuckl am 07 Januar 2021, 02:32:43
Dank der Antwort von mbr89, habe ich mich noch mal an das Ganze Thema mit dem Fehler gesetzt und einfach mal das "my" vor dem "fields" in Zeile 3769 entfernt und seit drei Tagen ist der Fehler im log verschwunden und FPUI funktioniert weiterhin einwandfrei  ;)
