bisher hatte ich eine ältere Version von zigbee2MQTT auf einem anderen Raspberry installiert.
Dafür gab es dann schon dies Gerät:
CID RASPI5
DEF RASPI5
DEVICETOPIC MQTT2_RASPI5
FUUID 5c49df8f-f33f-a3b0-cd49-62a7f04197a6de76
IODev m2s
LASTInputDev m2s
MSGCNT 24
NAME MQTT2_RASPI5
NR 608
STATE online
TYPE MQTT2_DEVICE
m2s_MSGCNT 24
m2s_TIME 2020-04-07 14:56:45
2020-01-13 13:45:25 devices {"type":"devices","message":[{"ieeeAddr":"0x000b57fffe9a1211","type":"Router","model":"LED1649C5","friendly_name":"IKEA01"}]}
2020-01-13 13:45:21 graphviz digraph G {
node[shape=record];
"0x00124b001b7b29dd" [label="{0x00124b001b7b29dd|Coordinator|No model information available|online}"];
"0x00124b001b7b29dd" -> "0x000b57fffe9a1211" [label="141"]
"0x000b57fffe9a1211" [label="{IKEA01|Router|IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (LED1649C5)|online}"];
"0x000b57fffe9a1211" -> "0x00124b001b7b29dd" [label="82"]
2020-04-07 14:56:45 log {"type":"pairing","message":"interview_successful","meta":{"friendly_name":"AQARA2","model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","supported":true}}
2019-01-18 16:58:12 rename_new 'IKEA_01'
2019-01-18 16:58:12 rename_old IKEA_01
2020-04-07 14:51:17 state online
2020-04-07 14:50:11 subscriptions zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/get zigbee2mqtt/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/set zigbee2mqtt/+/+/+/+/set/+ zigbee2mqtt/+/+/+/get zigbee2mqtt/+/+/+/get/+ zigbee2mqtt/+/+/+/set zigbee2mqtt/+/+/+/set/+ zigbee2mqtt/+/+/get zigbee2mqtt/+/+/get/+ zigbee2mqtt/+/+/set zigbee2mqtt/+/+/set/+ zigbee2mqtt/+/get zigbee2mqtt/+/get/+ zigbee2mqtt/+/set zigbee2mqtt/+/set/+ zigbee2mqtt/bridge/bind/# zigbee2mqtt/bridge/config/+ zigbee2mqtt/bridge/config/+/+ zigbee2mqtt/bridge/configure zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/get_group_membership zigbee2mqtt/bridge/device/+/get_group_membership zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/add zigbee2mqtt/bridge/group/+/+/remove zigbee2mqtt/bridge/group/+/+/remove_all zigbee2mqtt/bridge/group/+/add zigbee2mqtt/bridge/group/+/remove zigbee2mqtt/bridge/group/+/remove_all zigbee2mqtt/bridge/group/remove_all zigbee2mqtt/bridge/networkmap zigbee2mqtt/bridge/networkmap/routes zigbee2mqtt/bridge/ota_update/check zigbee2mqtt/bridge/ota_update/update zigbee2mqtt/bridge/unbind/#
IODev m2s
bridgeRegexp zigbee2mqtt/([A-Za-z0-9]*)[/]?.*:.* "zigbee_$1"
getList devicelist:noArg log zigbee2mqtt/bridge/config/devices
networkmap_raw:noArg raw zigbee2mqtt/bridge/networkmap raw
networkmap_graphviz:noArg graphviz zigbee2mqtt/bridge/networkmap graphviz
model L_01_zigbee2mqtt_bridge
readingList zigbee2mqtt/bridge/state:.* state
zigbee2mqtt/bridge/config/devices:.* {}
zigbee2mqtt/bridge/config/log_level:.* log_level
zigbee2mqtt/bridge/config/permit_join:.* permit_join
zigbee2mqtt/bridge/config/rename:.* { json2nameValue($EVENT, 'rename_') }
zigbee2mqtt/bridge/log:.*\"type\".\"devices\".\"message\".* devices
zigbee2mqtt/bridge/log:.* log
zigbee2mqtt/bridge/networkmap:.* {}
zigbee2mqtt/bridge/networkmap/graphviz:.* graphviz
zigbee2mqtt/bridge/networkmap/raw:.* raw
room MQTT2_DEVICE
setList log_level:debug,info,warn,error zigbee2mqtt/bridge/config/log_level $EVTPART1
permit_join:true,false zigbee2mqtt/bridge/config/permit_join $EVTPART1
remove:textField zigbee2mqtt/bridge/config/remove $EVTPART1
rename:textField zigbee2mqtt/bridge/config/rename {"old":"$EVTPART1","new":"$EVTPART2"}
setStateList on off
Die Configuration dort war:
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://192.168.0.20:11883'
client_id: RASPI5
advanced:
rtscts: false
include_device_information: true
serial:
port: >-
/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
Nun habe ich das zigbee2MQTT aktualisiert. Es kam dabei dies Gerät dazu:
CFGFN
CID zigbee_bridge
DEF zigbee_bridge
DEVICETOPIC MQTT2_zigbee_bridge
FUUID 5e8b528e-f33f-a3b0-729d-bdf74fa4768d051d
IODev m2s
LASTInputDev m2s
MSGCNT 1
NAME MQTT2_zigbee_bridge
NR 15096
STATE ???
TYPE MQTT2_DEVICE
m2s_MSGCNT 1
m2s_TIME 2020-04-07 14:51:18
2020-04-06 18:02:22 associatedWith MQTT2_RASPI5
2020-04-07 14:51:18 commit 840b9d9
2020-04-07 14:51:18 coordinator_meta_maintrel 0
2020-04-07 14:51:18 coordinator_meta_majorrel 2
2020-04-07 14:51:18 coordinator_meta_minorrel 0
2020-04-07 14:51:18 coordinator_meta_product 0
2020-04-07 14:51:18 coordinator_meta_revision
2020-04-07 14:51:18 coordinator_meta_transportrev 2
2020-04-07 14:51:18 coordinator_type zStack12
2020-04-07 14:51:18 log_level info
2020-04-07 14:51:18 permit_join true
2020-04-07 14:51:18 version 1.12.0
IODev m2s
readingList zigbee2mqtt/bridge/config:.* { json2nameValue($EVENT) }
room MQTT2_DEVICE
Nun habe ich sogar 2 Geräte, bei denen ich nicht weiß, ob das so richtig ist, was ich damit anfange und welche templates ich denen zuweise.
Könnte mir jemand einen Tip geben?
Die reinen Nutzgeräte von IKEA und XIAOMI funktionieren perfekt.
Der Update deines zigbee2MQTT liefert zusätzliche und verbesserte Informationen an den MQTT2 Server und daher
hat der MQTT2 Server die neuen Informationen einem neuem Gerät MQTT2_zigbee_bridge zugewiesen.
Eigentlich hast du schon ein zigbee Brücken Gerät, das bei dir MQTT2_RASPI5 heißt. Die zusätzlichen Informationen
die jetzt MQTT2_zigbee_bridge zugewiesen sind gehören bei dir eigentlich zu MQTT2_RASPI5.
Mein Vorschlag ist dein MQTT2_RASPI5 Gerät auf das aktuelle Template zigbee2mqtt_bridge zu migrieren.
Eventuell vorher mit update check, update und shutdown restart dein FHEM auf den neuesten Stand bringen.
Im Bereich zigbee2mqtt Templates hat es einiges getan.
Anschließend wäre das neue Gerät MQTT2_zigbee_bridge überflüssig und daher dann auch gelöscht werden.
Mit freundlichem Gruß
joelinux
Danke dir.
Habe ich umgesetzt und nun schaue ich nach (negativen) Effekten
