I setup mqtt2 with mosquitto
define mqtt2 MQTT2_CLIENT 192.168.180.5:8883
attr mqtt2 SSL 1
attr mqtt2 devStateIcon .*:mqtt
attr mqtt2 room System
attr mqtt2 username fhem
define bridge_mqtt MQTT_GENERIC_BRIDGE
attr bridge_mqtt IODev mqtt2
attr bridge_mqtt room System
And works with a dummy device with mqttsubscriibe for temperature sensors.
Now I want it to work with tasmota switches. I only found examples with mqtt2_server. Does someone have an example for tamsota with mqtt2_client with mosquitto broker ?
Not a direct answer: I'd recommend to use two "helper MQTT2_DEVICE"s:
One that collects all messages that do not have any "recipient" in FHEM yet (if you let autocreate work (make a test with "simple"), basically all MQTT info will go to one singe MQTT2_DEVICE...).
Note: autocreate and MQTT_GENERIC_BRIDGE may not work too good together, so see other option below...
The second you can create by do an attrTemplate-assignment to the first: attr <your collecting device> attrTemplate MQTT2_CLIENT_general_bridge
This second device will have a "bridgeRegexp" to sort out the original devices that will work if you use "standard" MQTT topic structure in your tasmota devices. You may change this setting to your needs.
Perhaps the best way to get a first impression how this may work is to add a MQTT2_SERVER device using a different Port ("define myMQTT2test server 1884 global") and point one tasmota after oneother to that IP/Port combination for initial setup. Later you may just change the IO from M2_Server to M2_Client.
Hope this helps as a starting point.
Kind regards, Beta-User
Here is my Tasmota coffee machine switch:
stat/Wuudi/RESULT = {"Topic":"Wuudi"}
and in FHEM:
defmod KU_Kaffee MQTT2_DEVICE DVES_2A360A
attr KU_Kaffee IODev MQTT2_FHEM_Server
attr KU_Kaffee autocreate 0
attr KU_Kaffee comment NOTE: For on-for-timer SetExtensions are used. You may add on-for-timer option running on the device. The following is limited to 1h max duration, but will not affect future simple "on" commands:<br>on-for-timer {my $duration = $EVTPART1*10;; 'cmnd/Wuudi/Backlog POWER1 1;; delay '.$duration.';; POWER1 0'}<br>See the "Praxisbeispiele" in the wiki for "pulseTime1" alternative option and it's restrictions.
attr KU_Kaffee genericDeviceType switch
attr KU_Kaffee icon virtualbox
attr KU_Kaffee jsonMap POWER1:0 POWER2:0 POWER3:0 POWER4:0 Dimmer:0 Channel_0:0 Channel_1:0 Channel_2:0 Channel_3:0 Channel_4:0 HSBColor:0 Color:0
attr KU_Kaffee model tasmota_basic_state_power1
attr KU_Kaffee readingList tele/Wuudi/LWT:.* LWT\
tele/Wuudi/STATE:.* { json2nameValue($EVENT,'',$JSONMAP) }\
tele/Wuudi/SENSOR:.* { json2nameValue($EVENT,'',$JSONMAP) }\
tele/Wuudi/INFO.:.* { json2nameValue($EVENT,'',$JSONMAP) }\
tele/Wuudi/UPTIME:.* { json2nameValue($EVENT,'',$JSONMAP) }\
subscriptions
cmnd/DVES_2A360A_fb/# cmnd/Wuudi/# cmnd/tasmotas/#
FallbackTopic
GroupTopic
cmnd/tasmotas/
And here the mqtt2 Device in FHEM:
defmod MQTT2_FHEM_Server MQTT2_SERVER 1883 global
setstate MQTT2_FHEM_Server 2020-04-26 17:57:34 RETAIN {"tele/DVES_93AADA/LWT":"Offline","tele/Wuudi/LWT":"Online","tele/tasmota/LWT":"Online","tele/tasmota_809852/LWT":"Offline","tele/tasmota_93AADA/LWT":"Offline"}
setstate MQTT2_FHEM_Server 2020-04-17 09:10:34 lastPublish cmnd/InSmart/Backlog:StateText1 off;; StateText2 on;; StateText3 toggle;; StateText4 hold;; SetOption26 1;; SaveData 1
setstate MQTT2_FHEM_Server 2020-04-26 17:58:37 nrclients 6
setstate MQTT2_FHEM_Server 2020-04-17 15:46:32 state Initialized
Greetings, Arnd
Signalduino (Nano, ESP, ...), CUL (Busware, Nano, Maple, ...), Homematic (HM-MOD-UART-RPI, ESP, Maple, ...), LaCrosseGateway (LGW, ESP, ...), 1-wire, ESPEasy, Bravia, Yamaha, ...
@beta-user,
Looks like a nice option, can you give me some more , as an example, so I can test it. I have a clean fhem installation on a different server, I only want to use the mosquitto broker, I also ude homeassistant, and want to use both smarthome systems together
regards RIchard
So just use your clean test installation and point MQTT2_CLIENT to your mosquitto and activate "autocreate simple", then apply the already mentionned "sorting" attrTemplate. Then we should see to which extend everything works?
I got some results and looks like its working (created a lot of devices). Now I modifying an devices
I have one question. The icon appears when I press it in the fhem web interface light on , it changes shot orange and that green (icon is correct nut green). When I press it from the tasmota webinterface it goes only to te right icon. My wish that it also change the orange color.
When I do the jsonmap POWER:State (with capitel S) than fhem works with color, but the state form tasmota doesn't work anymore. Any idea how to fix that the icon color en type is right?
l MQTT2_lampslaap
CID lampslaap
DEF lampslaap
DEVICETOPIC MQTT2_lampslaap
FUUID 5ea92a45-f33f-d772-afa7-c64962a965eb31ff
IODev mqtt2
LASTInputDev mqtt2
MSGCNT 81
NAME MQTT2_lampslaap
NR 67
STATE OFF
TYPE MQTT2_DEVICE
mqtt2_MSGCNT 81
mqtt2_TIME 2020-04-29 10:20:37
JSONMAP:
POWER state
2020-04-29 10:19:17 Heap 24
2020-04-29 10:02:43 LWT Online
2020-04-29 10:19:17 LoadAvg 19
2020-04-29 10:19:17 MqttCount 3
2020-04-29 10:06:01 POWER OFF
2020-04-29 10:19:17 Sleep 50
2020-04-29 10:19:17 SleepMode Dynamic
2020-04-29 10:19:17 State OFF
2020-04-29 10:19:17 Switch1 OFF
2020-04-29 10:19:17 Time 2020-04-29T09:19:17
2020-04-29 10:19:17 Uptime 2T11:45:31
2020-04-29 10:19:17 UptimeSec 215131
2020-04-29 10:19:17 Wifi_AP 1
2020-04-29 10:19:17 Wifi_BSSId B0:B8:67:08:14:84
2020-04-29 10:19:17 Wifi_Channel 1
2020-04-29 10:19:17 Wifi_Downtime 0T00:00:18
2020-04-29 10:19:17 Wifi_LinkCount 1
2020-04-29 10:19:17 Wifi_RSSI 56
2020-04-29 10:19:17 Wifi_SSId sensors
2020-04-29 10:19:17 Wifi_Signal -72
2020-04-28 22:09:16 associatedWith MQTT2_GeneralBridge
2020-04-29 10:20:37 state OFF
IODev mqtt2
Webcmd on:off:reboot
autocreate 0
icon light_ceiling_light
jsonMap POWER:state
readingList tele/lampslaap/LWT:.* LWT
tele/lampslaap/STATE:.* { json2nameValue($EVENT,'',$JSONMAP) }
tele/lampslaap/SENSOR:.* { json2nameValue($EVENT,'',$JSONMAP) }
tele/lampslaap/INFO.:.* { json2nameValue($EVENT,'',$JSONMAP) }
tele/lampslaap/UPTIME:.* { json2nameValue($EVENT,'',$JSONMAP) }
stat/lampslaap/RESULT:.* { json2nameValue($EVENT,'',$JSONMAP) }
room Slaapkamer
setList on cmnd/lampslaap/POWER on
off cmnd/lampslaap/POWER off
stateFormat state
Hm, hard to follow your description, and even harder to suggest a solution...
So short story: there are a lot more attrTemplates available to configure Tasmota-MQTT-Devices, but they have one big disadvantages when beeing applied while using a second controller software: They will change some basic settings on the ESP itself (e.g. sending states in lowercase and use POWER1 instead of POWER for first relay). Not sure, if homeassistant will "like" these changes.
Perhaps you best do also a test on that with a single device? (There should be also a template available to revert these changes; if not: it's just a couple of backlog commands). Otherwise we would have to do a much deeper digg into the interdependencies of different attributes...
