FHEM => Automatisierung => DOIF => Thema gestartet von: Masiwo am 30 April 2020, 11:20:32
Titel: [Gelöst] DOIF Modul lädt nach Update nicht mehr
Beitrag von: Masiwo am 30 April 2020, 11:20:32
Guten Morgen zusammen,
leider lädt nach einem update das gesamte DOIF Modul nicht mehr.. von welcher auf welche Version kann ich leider nicht mehr rekonstruieren, ich bekomme nach einem studown restart allerdigns folgenden, langen error:
reload: Error:Modul 98_DOIF deactivated:
Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 83.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_DOIF.pm line 3609, <$fh> line 83.
2020.04.30 11:17:29 0: Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 83.
2020.04.30 11:17:29 1: Including /opt/fhem/FHEM/Playeronoff.cfg
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delTimer redefined at ./FHEM/98_DOIF.pm line 34, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_killBlocking redefined at ./FHEM/98_DOIF.pm line 45, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delAll redefined at ./FHEM/98_DOIF.pm line 53, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Initialize redefined at ./FHEM/98_DOIF.pm line 93, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_reloadFW redefined at ./FHEM/98_DOIF.pm line 114, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_hsv redefined at ./FHEM/98_DOIF.pm line 119, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_rgb redefined at ./FHEM/98_DOIF.pm line 146, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_UpdateCell redefined at ./FHEM/98_DOIF.pm line 177, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget redefined at ./FHEM/98_DOIF.pm line 195, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Update redefined at ./FHEM/98_DOIF.pm line 205, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Register redefined at ./FHEM/98_DOIF.pm line 219, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterCell redefined at ./FHEM/98_DOIF.pm line 242, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine parse_tpl redefined at ./FHEM/98_DOIF.pm line 352, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine import_tpl redefined at ./FHEM/98_DOIF.pm line 438, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_FOR redefined at ./FHEM/98_DOIF.pm line 454, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_def redefined at ./FHEM/98_DOIF.pm line 494, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterEvalAll redefined at ./FHEM/98_DOIF.pm line 566, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_tablePopUp redefined at ./FHEM/98_DOIF.pm line 628, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_summaryFn redefined at ./FHEM/98_DOIF.pm line 638, <$fh> line 2.
2020.04.30 11:17:29 1: reload: Error:Modul 98_DOIF deactivated:
Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 2.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_DOIF.pm line 3609, <$fh> line 2.
2020.04.30 11:17:29 0: Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 2.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delTimer redefined at ./FHEM/98_DOIF.pm line 34, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_killBlocking redefined at ./FHEM/98_DOIF.pm line 45, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delAll redefined at ./FHEM/98_DOIF.pm line 53, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Initialize redefined at ./FHEM/98_DOIF.pm line 93, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_reloadFW redefined at ./FHEM/98_DOIF.pm line 114, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_hsv redefined at ./FHEM/98_DOIF.pm line 119, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_rgb redefined at ./FHEM/98_DOIF.pm line 146, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_UpdateCell redefined at ./FHEM/98_DOIF.pm line 177, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget redefined at ./FHEM/98_DOIF.pm line 195, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Update redefined at ./FHEM/98_DOIF.pm line 205, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Register redefined at ./FHEM/98_DOIF.pm line 219, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterCell redefined at ./FHEM/98_DOIF.pm line 242, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine parse_tpl redefined at ./FHEM/98_DOIF.pm line 352, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine import_tpl redefined at ./FHEM/98_DOIF.pm line 438, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_FOR redefined at ./FHEM/98_DOIF.pm line 454, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_def redefined at ./FHEM/98_DOIF.pm line 494, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterEvalAll redefined at ./FHEM/98_DOIF.pm line 566, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_tablePopUp redefined at ./FHEM/98_DOIF.pm line 628, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_summaryFn redefined at ./FHEM/98_DOIF.pm line 638, <$fh> line 5.
Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 5.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_DOIF.pm line 3609, <$fh> line 5.
2020.04.30 11:17:29 0: Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 5.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delTimer redefined at ./FHEM/98_DOIF.pm line 34, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_killBlocking redefined at ./FHEM/98_DOIF.pm line 45, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delAll redefined at ./FHEM/98_DOIF.pm line 53, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Initialize redefined at ./FHEM/98_DOIF.pm line 93, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_reloadFW redefined at ./FHEM/98_DOIF.pm line 114, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_hsv redefined at ./FHEM/98_DOIF.pm line 119, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_rgb redefined at ./FHEM/98_DOIF.pm line 146, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_UpdateCell redefined at ./FHEM/98_DOIF.pm line 177, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget redefined at ./FHEM/98_DOIF.pm line 195, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Update redefined at ./FHEM/98_DOIF.pm line 205, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Register redefined at ./FHEM/98_DOIF.pm line 219, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterCell redefined at ./FHEM/98_DOIF.pm line 242, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine parse_tpl redefined at ./FHEM/98_DOIF.pm line 352, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine import_tpl redefined at ./FHEM/98_DOIF.pm line 438, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_FOR redefined at ./FHEM/98_DOIF.pm line 454, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_def redefined at ./FHEM/98_DOIF.pm line 494, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterEvalAll redefined at ./FHEM/98_DOIF.pm line 566, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_tablePopUp redefined at ./FHEM/98_DOIF.pm line 628, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_summaryFn redefined at ./FHEM/98_DOIF.pm line 638, <$fh> line 23.
Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 23.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_DOIF.pm line 3609, <$fh> line 23.
2020.04.30 11:17:29 0: Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 23.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delTimer redefined at ./FHEM/98_DOIF.pm line 34, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_killBlocking redefined at ./FHEM/98_DOIF.pm line 45, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delAll redefined at ./FHEM/98_DOIF.pm line 53, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Initialize redefined at ./FHEM/98_DOIF.pm line 93, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_reloadFW redefined at ./FHEM/98_DOIF.pm line 114, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_hsv redefined at ./FHEM/98_DOIF.pm line 119, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_rgb redefined at ./FHEM/98_DOIF.pm line 146, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_UpdateCell redefined at ./FHEM/98_DOIF.pm line 177, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget redefined at ./FHEM/98_DOIF.pm line 195, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Update redefined at ./FHEM/98_DOIF.pm line 205, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Register redefined at ./FHEM/98_DOIF.pm line 219, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterCell redefined at ./FHEM/98_DOIF.pm line 242, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine parse_tpl redefined at ./FHEM/98_DOIF.pm line 352, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine import_tpl redefined at ./FHEM/98_DOIF.pm line 438, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_FOR redefined at ./FHEM/98_DOIF.pm line 454, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_def redefined at ./FHEM/98_DOIF.pm line 494, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterEvalAll redefined at ./FHEM/98_DOIF.pm line 566, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_tablePopUp redefined at ./FHEM/98_DOIF.pm line 628, <$fh> line 26.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_summaryFn redefined at ./FHEM/98_DOIF.pm line 638, <$fh> line 26.
Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 26.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_DOIF.pm line 3609, <$fh> line 26.
2020.04.30 11:17:29 0: Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 26.
2020.04.30 11:17:29 1: Including /opt/fhem/FHEM/DigitalClockBrightness.cfg
2020.04.30 11:17:29 1: Including /opt/fhem/FHEM/AbfallSystem.cfg
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delTimer redefined at ./FHEM/98_DOIF.pm line 34, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_killBlocking redefined at ./FHEM/98_DOIF.pm line 45, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delAll redefined at ./FHEM/98_DOIF.pm line 53, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Initialize redefined at ./FHEM/98_DOIF.pm line 93, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_reloadFW redefined at ./FHEM/98_DOIF.pm line 114, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_hsv redefined at ./FHEM/98_DOIF.pm line 119, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_rgb redefined at ./FHEM/98_DOIF.pm line 146, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_UpdateCell redefined at ./FHEM/98_DOIF.pm line 177, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget redefined at ./FHEM/98_DOIF.pm line 195, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Update redefined at ./FHEM/98_DOIF.pm line 205, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Register redefined at ./FHEM/98_DOIF.pm line 219, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterCell redefined at ./FHEM/98_DOIF.pm line 242, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine parse_tpl redefined at ./FHEM/98_DOIF.pm line 352, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine import_tpl redefined at ./FHEM/98_DOIF.pm line 438, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_FOR redefined at ./FHEM/98_DOIF.pm line 454, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_def redefined at ./FHEM/98_DOIF.pm line 494, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterEvalAll redefined at ./FHEM/98_DOIF.pm line 566, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_tablePopUp redefined at ./FHEM/98_DOIF.pm line 628, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_summaryFn redefined at ./FHEM/98_DOIF.pm line 638, <$fh> line 25.
Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 25.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_DOIF.pm line 3609, <$fh> line 25.
2020.04.30 11:17:29 0: Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 25.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delTimer redefined at ./FHEM/98_DOIF.pm line 34, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_killBlocking redefined at ./FHEM/98_DOIF.pm line 45, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delAll redefined at ./FHEM/98_DOIF.pm line 53, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Initialize redefined at ./FHEM/98_DOIF.pm line 93, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_reloadFW redefined at ./FHEM/98_DOIF.pm line 114, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_hsv redefined at ./FHEM/98_DOIF.pm line 119, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_rgb redefined at ./FHEM/98_DOIF.pm line 146, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_UpdateCell redefined at ./FHEM/98_DOIF.pm line 177, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget redefined at ./FHEM/98_DOIF.pm line 195, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Update redefined at ./FHEM/98_DOIF.pm line 205, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Register redefined at ./FHEM/98_DOIF.pm line 219, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterCell redefined at ./FHEM/98_DOIF.pm line 242, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine parse_tpl redefined at ./FHEM/98_DOIF.pm line 352, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine import_tpl redefined at ./FHEM/98_DOIF.pm line 438, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_FOR redefined at ./FHEM/98_DOIF.pm line 454, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_def redefined at ./FHEM/98_DOIF.pm line 494, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterEvalAll redefined at ./FHEM/98_DOIF.pm line 566, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_tablePopUp redefined at ./FHEM/98_DOIF.pm line 628, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_summaryFn redefined at ./FHEM/98_DOIF.pm line 638, <$fh> line 28.
Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 28.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_DOIF.pm line 3609, <$fh> line 28.
2020.04.30 11:17:29 0: Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 28.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delTimer redefined at ./FHEM/98_DOIF.pm line 34, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_killBlocking redefined at ./FHEM/98_DOIF.pm line 45, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delAll redefined at ./FHEM/98_DOIF.pm line 53, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Initialize redefined at ./FHEM/98_DOIF.pm line 93, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_reloadFW redefined at ./FHEM/98_DOIF.pm line 114, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_hsv redefined at ./FHEM/98_DOIF.pm line 119, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_rgb redefined at ./FHEM/98_DOIF.pm line 146, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_UpdateCell redefined at ./FHEM/98_DOIF.pm line 177, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget redefined at ./FHEM/98_DOIF.pm line 195, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Update redefined at ./FHEM/98_DOIF.pm line 205, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Register redefined at ./FHEM/98_DOIF.pm line 219, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterCell redefined at ./FHEM/98_DOIF.pm line 242, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine parse_tpl redefined at ./FHEM/98_DOIF.pm line 352, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine import_tpl redefined at ./FHEM/98_DOIF.pm line 438, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_FOR redefined at ./FHEM/98_DOIF.pm line 454, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_def redefined at ./FHEM/98_DOIF.pm line 494, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterEvalAll redefined at ./FHEM/98_DOIF.pm line 566, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_tablePopUp redefined at ./FHEM/98_DOIF.pm line 628, <$fh> line 32.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_summaryFn redefined at ./FHEM/98_DOIF.pm line 638, <$fh> line 32.
Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 32.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_DOIF.pm line 3609, <$fh> line 32.
2020.04.30 11:17:29 0: Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 32.
2020.04.30 11:17:29 1: Including /opt/fhem/FHEM/GarageNotify.cfg
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delTimer redefined at ./FHEM/98_DOIF.pm line 34, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_killBlocking redefined at ./FHEM/98_DOIF.pm line 45, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delAll redefined at ./FHEM/98_DOIF.pm line 53, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Initialize redefined at ./FHEM/98_DOIF.pm line 93, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_reloadFW redefined at ./FHEM/98_DOIF.pm line 114, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_hsv redefined at ./FHEM/98_DOIF.pm line 119, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_rgb redefined at ./FHEM/98_DOIF.pm line 146, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_UpdateCell redefined at ./FHEM/98_DOIF.pm line 177, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget redefined at ./FHEM/98_DOIF.pm line 195, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Update redefined at ./FHEM/98_DOIF.pm line 205, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_Widget_Register redefined at ./FHEM/98_DOIF.pm line 219, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterCell redefined at ./FHEM/98_DOIF.pm line 242, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine parse_tpl redefined at ./FHEM/98_DOIF.pm line 352, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine import_tpl redefined at ./FHEM/98_DOIF.pm line 438, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_FOR redefined at ./FHEM/98_DOIF.pm line 454, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_uiTable_def redefined at ./FHEM/98_DOIF.pm line 494, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_RegisterEvalAll redefined at ./FHEM/98_DOIF.pm line 566, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_tablePopUp redefined at ./FHEM/98_DOIF.pm line 628, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_summaryFn redefined at ./FHEM/98_DOIF.pm line 638, <$fh> line 22.
Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 22.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_DOIF.pm line 3609, <$fh> line 22.
2020.04.30 11:17:29 0: Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 22.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_delTimer redefined at ./FHEM/98_DOIF.pm line 34, <$fh> line 51.
2020.04.30 11:17:29 1: PERL WARNING: Subroutine DOIF_killBlocking redefined at ./FHEM/98_DOIF.pm line 45, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_delAll redefined at ./FHEM/98_DOIF.pm line 53, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Initialize redefined at ./FHEM/98_DOIF.pm line 93, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_reloadFW redefined at ./FHEM/98_DOIF.pm line 114, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_hsv redefined at ./FHEM/98_DOIF.pm line 119, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_rgb redefined at ./FHEM/98_DOIF.pm line 146, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_UpdateCell redefined at ./FHEM/98_DOIF.pm line 177, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Widget redefined at ./FHEM/98_DOIF.pm line 195, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Widget_Update redefined at ./FHEM/98_DOIF.pm line 205, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Widget_Register redefined at ./FHEM/98_DOIF.pm line 219, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_RegisterCell redefined at ./FHEM/98_DOIF.pm line 242, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine parse_tpl redefined at ./FHEM/98_DOIF.pm line 352, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine import_tpl redefined at ./FHEM/98_DOIF.pm line 438, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_uiTable_FOR redefined at ./FHEM/98_DOIF.pm line 454, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_uiTable_def redefined at ./FHEM/98_DOIF.pm line 494, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_RegisterEvalAll redefined at ./FHEM/98_DOIF.pm line 566, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_tablePopUp redefined at ./FHEM/98_DOIF.pm line 628, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_summaryFn redefined at ./FHEM/98_DOIF.pm line 638, <$fh> line 51.
2020.04.30 11:17:30 1: reload: Error:Modul 98_DOIF deactivated:
Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 51.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_DOIF.pm line 3609, <$fh> line 51.
2020.04.30 11:17:30 0: Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 51.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_delTimer redefined at ./FHEM/98_DOIF.pm line 34, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_killBlocking redefined at ./FHEM/98_DOIF.pm line 45, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_delAll redefined at ./FHEM/98_DOIF.pm line 53, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Initialize redefined at ./FHEM/98_DOIF.pm line 93, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_reloadFW redefined at ./FHEM/98_DOIF.pm line 114, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_hsv redefined at ./FHEM/98_DOIF.pm line 119, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_rgb redefined at ./FHEM/98_DOIF.pm line 146, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_UpdateCell redefined at ./FHEM/98_DOIF.pm line 177, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Widget redefined at ./FHEM/98_DOIF.pm line 195, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Widget_Update redefined at ./FHEM/98_DOIF.pm line 205, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Widget_Register redefined at ./FHEM/98_DOIF.pm line 219, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_RegisterCell redefined at ./FHEM/98_DOIF.pm line 242, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine parse_tpl redefined at ./FHEM/98_DOIF.pm line 352, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine import_tpl redefined at ./FHEM/98_DOIF.pm line 438, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_uiTable_FOR redefined at ./FHEM/98_DOIF.pm line 454, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_uiTable_def redefined at ./FHEM/98_DOIF.pm line 494, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_RegisterEvalAll redefined at ./FHEM/98_DOIF.pm line 566, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_tablePopUp redefined at ./FHEM/98_DOIF.pm line 628, <$fh> line 80.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_summaryFn redefined at ./FHEM/98_DOIF.pm line 638, <$fh> line 80.
Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 80.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_DOIF.pm line 3609, <$fh> line 80.
2020.04.30 11:17:30 0: Global symbol "$FW_room" requires explicit package name (did you forget to declare "my $FW_room"?) at ./FHEM/98_DOIF.pm line 655, <$fh> line 80.
2020.04.30 11:17:30 1: Including /opt/fhem/FHEM/TemperaturSensor.cfg
2020.04.30 11:17:30 1: Including /opt/fhem/FHEM/NotifyUtils.cfg
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_delTimer redefined at ./FHEM/98_DOIF.pm line 34, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_killBlocking redefined at ./FHEM/98_DOIF.pm line 45, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_delAll redefined at ./FHEM/98_DOIF.pm line 53, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Initialize redefined at ./FHEM/98_DOIF.pm line 93, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_reloadFW redefined at ./FHEM/98_DOIF.pm line 114, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_hsv redefined at ./FHEM/98_DOIF.pm line 119, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_rgb redefined at ./FHEM/98_DOIF.pm line 146, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_UpdateCell redefined at ./FHEM/98_DOIF.pm line 177, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Widget redefined at ./FHEM/98_DOIF.pm line 195, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Widget_Update redefined at ./FHEM/98_DOIF.pm line 205, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_Widget_Register redefined at ./FHEM/98_DOIF.pm line 219, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_RegisterCell redefined at ./FHEM/98_DOIF.pm line 242, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine parse_tpl redefined at ./FHEM/98_DOIF.pm line 352, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine import_tpl redefined at ./FHEM/98_DOIF.pm line 438, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_uiTable_FOR redefined at ./FHEM/98_DOIF.pm line 454, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_uiTable_def redefined at ./FHEM/98_DOIF.pm line 494, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_RegisterEvalAll redefined at ./FHEM/98_DOIF.pm line 566, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_tablePopUp redefined at ./FHEM/98_DOIF.pm line 628, <$fh> line 3.
2020.04.30 11:17:30 1: PERL WARNING: Subroutine DOIF_summaryFn redefined at ./FHEM/98_DOIF.pm line 638, <$fh> line 3.
Ich hoffe wirklich, dass mir da jemand helfen kann, da dadurch einiges bei meinem FHEM Setup nicht mehr funktioniert..
Daniel
Titel: Antw:DOIF Modul lädt nach Update nicht mehr
Beitrag von: Damian am 30 April 2020, 11:30:47
Teste mal eben die angehängte Version bei dir.
Edit: Version eingecheckt
Beitrag von: Masiwo am 30 April 2020, 11:38:30
Jap, funktioniert wieder alles bestens, vielen lieben Dank für die schnelle Hilfe! ;)
Wird die Datei dann noch ins FHEM update gebraccht, oder war das jetzt ein lokaler Fehler nur bei mir ?
Beitrag von: Damian am 30 April 2020, 12:07:32
Bei mir ist der Fehler nicht aufgetreten. Die korrigierte Version habe ich gerade eingecheckt. Morgen per Update verfügbar.
Beitrag von: Masiwo am 30 April 2020, 12:08:39
Okay, alles klar, dann nochmal danke für den schnellen Support!
